Creative mit drei neuen professionellen Soundkarten
[url=http://de.europe.creative.com]Creative[/url] hat drei neue Soundkarten der professionellen E-MU Serie veröffentlicht. Die Modelle [url=http://www.emu.com/products/product.asp?category=505&subcategory=491&product=9872]1212M PCI[/url], [url=http://www.emu.com/products/product.asp?category=505&subcategory=491&product=15163]1616 PCI[/url] und [url=http://www.emu.com/products/product.asp?category=505&subcategory=491&product=15189]1616M PCI[/url] richten sich an Anwender, denen neben einer guten Soundqualität auch möglichst viele Ein- und Ausgänge sowie ASIO und hochqualitative DACs und ADCs wichtig sind. Die Preise liegen bei 150 US-Dollar, 350 US-Dollar und 450 US-Dollar für die Modelle 1212M PCI, 1616 PCI und 1616M PCI.
E-MU 1212M: Mastering grade 24-bit/192kHz converters - the same A/D converters used in Digidesign's flagship ProTools HD 192 I/O Interface delivering an amazing 120dB signal-to-noise ratio
Hardware-accelerated effects - over 600 standalone and E-MU Power FX VST plug-in effects with no CPU overhead
PatchMix™ DSP zero-latency hardware mixing and monitoring - with super-flexible patchbay - no external mixer needed
Comprehensive analog and digital I/O plus MIDI - 12 inputs and 12 outputs, plus MIDI I/O and FireWire port
Compatibility with most popular audio/sequencer applications - ultra-low latency 24-bit/192kHz ASIO 2.0 and Stereo WDM drivers
E-MU Production Tools Software Bundle - includes Cakewalk SONAR LE, Steinberg Cubase LE and Wavelab Lite, Ableton Live Lite 4 for E-MU, IK Multimedia AmpliTube LE and T-RackS EQ, Minnetonka diskWelder BRONZE, SFX Machine LT, plus E-MU's Proteus X LE Desktop Sound Module - everything you need to create, record, edit, master and burn is in the box
I/O Konfiguration:
Two 1/4" Balanced Inputs
24-bit/192kHz ADAT In/Out (switchable to S/PDIF)
24-bit/96kHz S/PDIF In/Out (switchable to AES/EBU)
MIDI In/Out
Firewire® Interface
E-MU 1616 PCI:
Premium 24-bit/192kHz converters - 112dB signal-to-noise ratio for pristine recording and playback of your tracks
Two E-MU XTC™ Class-A, ultra-low noise preamps (-127dBu) - Mic/Line and true Hi-Z inputs via Neutrik connectors, with analog soft limiter, 48V phantom power and 60dB of gain
Compatibility with most popular audio/sequencer applications - ultra-low latency 24-bit/192kHz ASIO2, WDM and 64-bit drivers
I/O Konfiguration:
Two E-MU XTC™ Ultra-low Noise Mic/Line/Hi-Z Preamps with Soft Limiter and 48V Phantom Power (-129dBu EIN)
Four 1/4" Balanced Inputs
Six 1/4" Balanced Outputs
Turntable Input (w/ground lug and hardware RIAA preamp)
24-bit/192kHz coaxial S/PDIF Out (switchable to AES/EBU)
Two sets of MIDI In/Out
stereo 1/8" Speaker Outputs (configurable from stereo to 5.1)
Stereo Headphone Output
E-MU 1616M:
Comprehensive analog and digital I/O plus MIDI - MicroDock M offers 16 inputs/16 outputs plus MIDO I/O - everything from balanced analog and turntable inputs to ADAT and S/PDIF (switchable to AES/EBU)
Two E-MU XTC™ Class-A, ultra-low noise preamps (-129.5dBu) - Mic/Line and true Hi-Z inputs via Neutrik connectors, with analog soft limiter, 48V phantom power and 60dB of gain
E-MU Production Tools Software Bundle - includes Cakewalk SONAR LE, Steinberg Cubase LE and Wavelab Lite, Ableton Live Lite 4 for E-MU, IK Multimedia AmpliTube LE and T-RackS EQ, Minnetonka diskWelder BRONZE, SFX Machine LT, plus E-MU's Proteus® X LE Desktop Sound Module - everything you need to create, record, edit, master and burn is in the box
I/O Konfiguration:
Two E-MU XTC™ Ultra-low Noise Mic/Line/Hi-Z Preamps with Soft Limiter and 48V Phantom Power (-129.5dBu EIN)
Stereo 1/8" Speaker Outputs (configurable from stereo to 5.1)
