[url=http://www.intel.com]Intel[/url] hat heute zwei neue Itanium 2 Prozessoren vorgestellt, die besonders durch den Preis auf dem Servermarkt für Furore sorgen sollen. Die beiden mit 1.40 und 1.60 GHz getakteten Prozessoren haben einen 3 MB großen L3 Cache. Es handelt sich dabei im Dual-Prozessoren, die laut Intel um 25 Prozent schneller sein sollen, aber um 28 Prozent billiger sind. So lassen sich nun Entry-Level Server für 2.100$ realisieren, was vorher aufgrund der Preise undenkbar gewesen wäre. Entsprechende Server werden bald von Bull, Dell, Fujitsu Siemens, HCL, IBM, Kraftway, Lenovo, Maxdata, Samsung und der Transtec AG angeboten. Einzeln kostet das 1.40 GHz Modell 1.172$ und die mit 1.60 GHz getaktete Variante soll bei einer Abnahme von 1.000 Stück 2.408$ kosten. INTEL DEVELOPER FORUM, TAIPEI, Taiwan, April 13, 2004 - Intel Corporation today announced two Intel® Itanium® 2 processors. Servers based on the new processors are approximately 28 percent lower in price** and up to 25 percent higher performing than previous dual processor Itanium 2-based servers.Werbung
The new processors broaden the Itanium processor family support of lower-cost server solutions for front-end applications and complement existing Itanium 2-based systems in large scale deployments. A wide range of Itanium 2-based dual processor servers are offered by more than 50 system manufacturers worldwide. Entry level systems start at $2,100***, while fully configured systems with the new processors will be available for approximately $8,000.
"As Itanium 2-based servers push further into enterprise infrastructures we are able to reduce the overall system cost while increasing the performance," said Richard Dracott, general manager of Enterprise Marketing and Planning at Intel. "End users will benefit from the flexibility and choice that Intel-based solutions bring to their organizations."
The price/performance improvements of these new processors are the next step toward achieving Intel's goal of delivering Itanium 2-based systems with up to twice the performance as Intel® Xeon™ processor based systems for the same system cost in 2007.
Intel has two server architectures, which makes up approximately 85 percent of the server market segment share.**** The Itanium 2 processor family is targeted at business critical enterprise servers and technical computing clusters while the Intel Xeon processor family is broadly used for general purpose IT infrastructure.
"In the next few years, system manufacturers will be able to design an Itanium 2 processor and Intel Xeon processor-based system using the same low cost components," Dracott.said. "Every product and technology we roll out moves us one step closer to a common system with common infrastructure costs."
Audi AG, the international high-quality car manufacturer, recently switched from RISC-based servers to HP Integrity dual processor servers running Itanium 2 processors.
"Audi is a pioneer in the innovation of exquisite automobiles that are attractive, sophisticated and technically perfect," said Hans-Ulrik von Bülow, senior CAE systems and methods analyst, AUDI AG. "We rely on the technology we use to create designs so that when the car leaves our warehouse, we know that it will deliver on the Audi brand promise to our customers. That is why we switched from RISC-based systems to Itanium 2-based DP systems to help design car ventilation systems. We get better price/performance and increase our ability to perform a wide range of what-if scenarios to discover more innovative designs and possibilities."
The Itanium 2 processor at 1.40 GHz with 3 MB level three (L3) cache is available worldwide today and the Itanium 2 processor at 1.6 GHz with 3 MB L3 cache is expected to be available worldwide in May. Both processors enable systems for technical computing clusters and entry-level, front-end enterprise systems. In addition, Intel offers to manufacturers a rack-optimized, dual processor Intel server platform for both of these new Itanium 2 processors.
The Itanium 2 processor at 1.40 GHz with 3MB of cache improves the performance up to 25 percent over the Itanium 2 processor at 1.40 GHz with 1.5 MB of cache. Furthermore it delivers up to twice the price/performance of comparable RISC-based systems.***** The increased performance will enhance the speed and efficiency of technical computing applications such as computer aided engineering (CAE), which enables faster product design and more accurate simulations.
The Itanium 2 processor at 1.60 GHz with 3MB of cache delivers outstanding floating point performance per compute node, resulting in an industry-leading DP performance based on Linpack measurements (or floating point operations per second).
New dual processor systems are available from a variety of system manufacturers including Bull, Dell, Fujitsu Siemens, HCL, IBM, Kraftway, Lenovo, Maxdata, Samsung, and Transtec AG.
The Intel Itanium 2 processor at 1.40 GHz with 3 MB of cache is available for $1,172 in 1,000-unit quantities. The Intel Itanium 2 processor at 1.60 GHz with 3 MB of cache will be available for $2,408 in 1,000-unit quantities.
