Crysis 2
PC-Patch 1.2.0.0 erschienen
17
Wie das Team von mycrysis.com, der offiziellen Community-Homepage zu Crysis 2, bekannt gab, wurde jetzt der zweite Patch für die PC-Version des von Crytek entwickelten Shooters veröffentlicht. Lesen Sie hier die Changelog, der den hierzulande am 24. März erschienenen Titel auf die Version 1.2.0.0 bringt. Leider müssen die PC-Spieler weiterhin auf den DirectX-11-Renderpfad warten. Dieser könnte unter Umständen in zwei bis drei Monaten nachgereicht werden (wir berichteten).
Crysis 2 PC 1.2.0.0:
List of changes
• Further improved anti-cheat measures
• Fix for spurious characters appearing when initiating text chat
• Fix for Chatlog doesn't disappear after kill cam
• Fixed occasional login issues
• Changed VOIP defaults
• Fixed some UI aspect issues on multiple monitors
• Added option for crouch toggle in MP & SP
• Fixed a bug where players lost Nano Catalyst points after restarting the game
• Filter settings in server browser are now retained
• Default player count required to start a game from the lobby lowered to 4
• Fixed issue related to “Deleting Reference Counted Object Twice” error that appeared for some users with strict router/firewall settings
• Fixed issue of not being able to melee after dying
• Fixed issue where some video cards were being stated as unsupported
We’re working hard with our Ranked Server Partners to switch the servers at the same time that the patch goes live – but inevitably this will take time so we ask for your patience. When you launch the game, the patch will auto-download. If you cannot find servers, please exit the game and re-start to ensure the patch has applied.
You can check the version number by selecting Properties on Crysis2.exe and selecting Details. The correct version after patching will be 1.2.0.0, and the executable will be signed by Crytek GmbH.
Update #1
Added the Nano Catalyst bug to the list of fixed issues. There seems to be a little confusion about the patch so please note, this is not the full list, but rather the key highlights.
Update #2
Added several other key points that are included with this patch.
For Steam Users
Steam users will experience some prolonged loading times in this patch for which we apologise. We will update the Steam build in the next few days to resolve this issue.
Weiterführende Links:
Quellen und weitere Links
    KOMMENTARE (17)
