Heute hat id Software den lange erwarteten Patch 1.1 in der finalen Version veröffentlicht. Mit im Gepäck sind 4 neue Maps und das schon im Dezember veröffentlichte "Quakemas Map Pack". Weiterhin sind noch sehr vele Änderungen für den Multiplayer, z.B. Brightskins, POV, ForceModel Option. Der Patch ist 117MB groß und kann [url=http://www.idsoftware.com/downloads/shambler.php?id=13000]My hier[/url] heruntergeladen werden. Das komplette Changelog kann man unter "read more" lesen. UPDATE: Der Patch wurde von id Software zurückgezogen. Liegt an einem Fehler mit dem Widescreenmodus, der evtl. Bildschirme beschädigen kann.Hyper-Threading Technology: This update enables QUAKE 4 to take advantage of the Hyper-Threading Technology of Intel(r) Dual core processors. Players who have computer systems with this processor will notice significant performance gains in QUAKE 4. With the update, systems with a single core processor which uses the Hyper-Threading Technology will have a performance jump of up to 25% compared to non Hyper-Threaded processors. Dual core processors with Hyper-Threading Technology will see a performance increase of up to 87%. In short, systems with this technology will see the game run much faster than ever before. Test for number of processors (HT or Dual core): To find out if you have Hyper-Threading enabled or a dual core system, perform the following steps: 1. Press Ctrl + Alt + Delete. If a window called "Windows Task Manager" does not appear, click on the "Windows Task Manager" button. 2. When the window appears, click on the "Performance" tab. 3. There will be a section at the top of this window called "CPU Usage History." If you have HT or dual core on your machine, there should be two graphs side by side under the "CPU Usage History" label. 4. If those side-by-side graphs are not present and you believe that the system should have HT, it may not be enabled in the BIOS. For more information on how to enable HT in the BIOS, please consult any guides or manuals from your computer manufacturer. How to enable Hyper-Threading Technology in the game: By DEFAULT, the symmetric multiprocessing (SMP)-based acceleration (which is the feature that enables the performance increase) is DISABLED. If you have a system with multiple CPUs or cores, please follow the directions below. From the Quake 4 Main Menu: 1. Click "Settings". 2. Click "System". 3. Click "Advanced Options". 4. Set "Multiple CPU/Core" to "Yes". (You will be prompted that your changes will not take effect until next time the game is launched.) 5. Click "Back". 6. Click "EXIT" and relaunch the game to initialize the change. Quake 4 will detect the number of processors in your system and prevent you from mistakenly activating this option. If you feel that your system has the necessary hardware to run the SMP optimization, please consult your hardware manufacturer's guides or manuals for instructions on how to enable the multi-processor or dual core feature on your system. As with any new technology, SMP is reliant upon several components working in unison. Such components include the motherboard, CPU, GPU, and sound card. For best results, please make sure that your system's BIOS and all drivers are up to date. If you encounter any instability while using this feature, please disable SMP and see if the problem persists. To help us resolve any incompatibilities, please report the issue to http://www.idsoftware.com/bugs, and include information about your system configuration. New Multiplayer Maps: Outpatient (q4dm10) - Cold, blood-stained hallways and flickering fluorescent lights set the mood in this once active Strogg medical complex. The heart-pounding pace of this map will keep players racing through the winding corridors, but only the quickest will survive. In addition to traditional DM, Outpatient can also be played in Team Deathmatch and Tourney modes. Skeleton Crew (q4dm11) - The dark empty void that surrounds this stranded space station offers no pity for those lost in battle. This multi level arena generates fast paced action that commands the attention of players in all skill levels. Expert navigation of the twists and turns that lead from deck to deck will be your only ally. Engage your foes in Deathmatch or Team Deathmatch games. As an added challenge you can also battle it out 1v1 style in Tourney mode. Mind the Gap (q5ctf6) - This massive processing factory uses alien technology to mine from the core of Stroggos itself - be sure to Mind The Gap in each base which only leads to an inescapable abyss and your death. This multi-tiered structure defies description and will leave only the heartiest and most cunning soldiers as the victors! Contest your team’s supremacy in CTF or Arena CTF modes. Double Edged (q4ctf8) - Double Edged revisits the Quake II(tm) classic… with a twist – Capture the Flag! The battle arena has been doubled so brush up on your long range weapon skills, but don’t fret if your Rail isn’t exactly "impressive." You’ll also find some tight corridors for those of you more comfortable with in-your-face combat. Destined to be a classic in its own right, settle those team grudge matches in this remix of a classic in CTF or Arena CTF battle. Campgrounds Redux (q4dm9) - With QUAKE 4's updated technology, Campgrounds Redux now has a fresh look and feel, revitalizing this QUAKE III(tm) classic. Excellent for any number of players, this updated version supports Deathmatch, Team Deathmatch and Tournament modes, where hard-core QUAKE fans can get crazy with this throw-back to one of their old favorites. Railed (q4tourney1) - Set in an abandoned, rusting Strogg facility, the environment in Railed produces fast-paced frenetic tournament style action! This new map is all about close-quarters combat and hair-trigger reflexes as players hustle through the winding, multi-tiered corridors. Designed especially for Tournament play, Railed also supports Deathmatch and Team Deathmatch game modes, and is guaranteed to provide some thrilling fast-action gameplay. Tremors (q4ctf7) - Built within a twisting underground cavern and peppered throughout with pipes, bridges, and catwalks, Tremors demands tactical expertise. Enemies attack from above and below in the enormous, multi-tiered environment, making team-play invaluable. Tremors is perfect for huge Capture-The-Flag games, and also supports the Arena Capture-The-Flag gameplay mode. To use the new maps in the map rotation cycle, a new map cycle script file has been included, called mapcycle-mp2.scriptcfg. To use the new map cycle script: 1. On the Multiplayer- Create Server screen, click "Advanced Options". 2. In the "Map cycle script file" field, enter "mapcycle-mp2.scriptcfg". 3. Click "Close advanced options". 4. Start the server. Fixes & Updates in 1.1: General: * Corrected an issue with skipping the ending cinematic. * Pentium(r) M processors will now be properly detected. * When using right-click to lower the video quality, the user will be prompted to apply the change immediately. * Corrected a stability issue related to old sound drivers. * Added doImpulse and doButton commands to support button actions and impulses via the console. For example: o bind l "doButton +_moveup; wait 5; doButton -_moveup;" o bind l "doImpulse _impulse1; wait 10; doImpulse _impulse5" * Several sound issues have been corrected. * Added mouse acceleration functionality with the m_accel cvar. This is only available through the console. Higher values give more acceleration. * Video option changes can be applied immediately instead of restarting the game. * Widescreen option will no longer affect the menus adversely. * The FOV (g_fov) can now be adjusted higher than 110. We do not recommend values higher than 110. * Application stability improved when setting the Sound Device to General Software with a Creative X-Fi sound card. * Implemented an AddOn PK4 system similar to Doom 3(tm) v1.3. Please see http://zerowing.idsoftware.com/linux/doom/AddonPaks for more info. * Resolved an issue with the level editor not working correctly with SMP enabled. * Corrected a few localized string errors. * Added a new cvar for adjusting the look speed while zoomed: pm_zoomedSlow (defaults to 100). This can be adjusted from 1 to 100: lower numbers are slower. * Finalized network demos: replay client or server recordings of network game or run performance tests. Please see http://www.iddevnet.com/quake4/NetworkDemos for more info. Multiplayer: New Features: * Brightskins added! Pro models for Marine and Strogg have been added. They can be selected from the Multiplayer menu. Their names are "Pro Marine" and "Pro Strogg". * When Ready mode is enabled, player's Ready state now shows on the Scoreboard screen. * Voice chat for Multiplayer is now available! To use voice chat, a microphone must be present and working on the system. After setting up the microphone correctly in your operating system, a Voice Chat key must be set in the Settings/Controls/Other tab, which is accessed from the Main Menu. Configuration of the voice chat options such as Mic Input Volume, Receive Volume, etc can only be accessed in the ESC menu’s "Voice Config" option once you have successfully loaded into a multiplayer match. When in any team game (TeamDM/CTF/ArenaCTF), only teammates can hear the speaker. When in a non-team game, all players can hear the speaker. * Added sorting functionality for the Multiplayer Friends List. * Added a forcemodel option. Typing one of the three commands below and using tab complete will bring up a list of usable models for that command: o g_forceModel forces all players displayed on the client machine to one of the models listed below, in non-team gameplay modes. The available models are: + model_player_failed_transfer + model_player_slimy_transfer + model_player_corpse + model_player_tactical_elite + model_player_tactical_command + model_player_marine + model_player_marine_morris + model_player_marine_voss + model_player_marine_cortez + model_player_marine_helmeted + model_player_marine_helmeted_bright + model_player_marine_medic + model_player_marine_officer + model_player_marine_fatigues + model_player_marine_tech + model_player_tactical_transfer + model_player_tactical_transfer_bright + model_player_kane_strogg o g_forceMarineModel will force all Marine players displayed on the client machine to one of the models listed below, in team gameplay modes. The available models are: + model_player_marine + model_player_marine_morris + model_player_marine_voss + model_player_marine_cortez + model_player_marine_helmeted + model_player_marine_helmeted_bright + model_player_marine_medic + model_player_marine_officer + model_player_marine_fatigues o g_forceStroggModel will force all Strogg players displayed on the client machine to one of the models listed below, in team gameplay modes. The available models are: + model_player_tactical_transfer + model_player_tactical_transfer_bright + model_player_kane_strogg * Variables for private clients have been implemented. All of these options must be set from the console or in config scripts: o si_privatePlayers: This is the number of private player slots reserved on the server. It subtracts from si_maxPlayers, so a server with si_maxPlayers 16 and 4 private player slots will only allow 12 public players to connect. o g_privatePassword: This is the server-side password setting. o privatePassword: This is the client password used to access a server's private player slots. This must be set from the console. * Added a voting option to shuffle teams. PLEASE NOTE: If auto-balance is on, use the shuffle teams function to redistribute players evenly. Only restarting the map will not shuffle players. * Added a one-minute warning for tournament matches. * Added a server-side console variable that will allow enabling or disabling of voting options. si_voteFlags (which defaults to 0, meaning nothing disabled) is the variable, and it uses a bit mask system: o bit 0 (+1) restart map o bit 1 (+2) min players o bit 2 (+4) auto balance teams o bit 3 (+8) shuffle teams o bit 4 (+16) kick player o bit 5 (+32) change map o bit 6 (+64) change gametype o bit 7 (+128) time limit o bit 8 (+256) tourney round limit o bit 9 (+512) capture limit o bit 10 (+1024) frag limit * Sum the total of the parenthetical numbers for each of the vote options you want to disable. For example, to disable voting on "kick player," "change gametype," and "frag limit," add the numbers: 16, 64, and 1024 (total of 1104), and set on the server: si_voteFlags 1104. Please note that any changes will not take effect until after a map restart, and anyone viewing the voting options during that transitory phase will not see the changes unless they back out to the game and then enter the shell again. * When aiming at a teammate in a team game, their health and armor level shows under their name. * When spectating and following, viewing the MP Statistics (default key 'Z') now shows the stats of whoever you are following. * The Game Browser now has scroll bar arrows to scroll through one server at a time. * Players will be notified when teams are rebalanced. * There is a new system by which players may anonymously report their usage statistics to the developers, such as type of video card, amount of system RAM, the presence of a DVD drive, etc. After installing the 1.1 patch, the first time the game starts, a confirmation window will appear. At this point, the player may choose to enable anonymous usage statistic reporting. Alternately, this may be set ahead of time with a cvar, net_reportUsageStatistics. * Added a "simple items" cvar so that item pickups will appear as icon representations instead of the actual model. Use g_simpleitems 1/0 to enable and disable. This is only available in the console. Adjustments: * The variables pm_bobpitch, pm_bobroll, pm_bobup, pm_crouchbob, pm_runbob, pm_runpitch, pm_runroll and pm_walkbob are no longer cheat protected but clients will not be able to override the server settings. * Selecting a screen size or aspect ratio that cannot be supported on a system will revert to safe defaults and display the correct safe settings values in the System menu. * NetDemo playbacks have gotten a little bit easier with "tab completion". The playNetDemo command now uses tab complete to show available demos. * The serverInfo command will now report more accurate data. * After playing a Multiplayer game and disconnecting, the Game Browser will be displayed instead of the Main Menu. * Name coloring in team game death messages is now disabled. * The dedicated server executable no longer requires a sound card or a pixel shader-capable video card. * With Weapon Stay enabled, a notifying sound will play when running over a weapon you already possess. * Player spawn code has been adjusted to mimic the spawn style of Quake III Team Arena. * Strafe-jumping on stairs is smoother. * When under 25 health, the player will hear a different pain grunt to indicate that health is especially low. * Increased the volume of the sound that plays when you hit an opponent in Multiplayer. * Slightly increased the volume of other player's Lightning Gun and Railgun hum noises to make them easier to hear. * Spectators will no longer be counted as "on a team" for auto-balancing purposes. * The CTF "Defense" award has been adjusted to provide the achievement within a larger radius from any team flag and enemy flags carried by a teammate. * Improved Gametype selections to properly display the appropriate map types in the map selection pane of the Create Server menu. * Adjusted the text "You are not ready" when ready mode is enabled so that it is more obvious to players. * Spectator players will only see chat messages from other spectators, and will not see team chat. Fixes: * The Lightning gun idle sound will not drop unexpectedly due to weapon viewmodel cvar binds. * Shotgun animation will play its full cycle before the new weapon selection begins. * Players falling into a void will die properly. * The "Sudden Death" message will not spam all arenas still conducting matches. * Intermittent highlighting and de-highlighting of the Voice Config tab is fixed. * Colored names now appear correctly in the Multiplayer lobby. * Voice Chat functions properly when enabled during a match in progress. * Cycling through player models after death will now properly decay both the head and body models. * Game stability improved when switching maps and gametypes through vote or server admin menus. * Fixed an intermittent issue with ACTF powerup effects not centering on players correctly. * The Multiple CPU/Core selection in the Advanced System Options will now highlight when mousing over it. * The Friends List will now properly accept names containing the characters "{" and "}". * Name capitalization changes will now take effect immediately in game. * Fixed an issue with certain performance awards being improperly given to players based on the accumulation of enemy and team kills. * Armor status when looking at teammates will now display correctly. * The screenshotJPEG command will correctly increment from the last indexed screenshot image residing in the default screenshots folder of the game installation. * Client calling a map vote will receive an appropriate message if the map that is called does not reside on the server. * Spanish clients will see player names properly during a vote to kick a player whose name includes a space. * Spanish clients will see the correct models for teammates and enemies. * When a player disconnects from a Tournament match early, the server will now seed the remaining players correctly for the remainder of the match. * PunkBuster(tm) now properly enables and disables in the server setup screen. * Muted icons now display properly on the scoreboard tab of the End-Game Summary window. * The Ammo Regen powerup now functions correctly when using the Machinegun. * The Invisibility powerup sound no longer carries over to arena 1 from other arenas. * A Dedicated server will no longer crash if warmup is off and all players disconnect from the server. * Tournament mode matches will enter sudden death properly after players reach the frag limit simultaneously. * Corrected an inconsistency with falling damage in Multiplayer. * PunkBuster rcon output will now be displayed properly to connected clients. * Projectiles will no longer appear to travel through map geometry on clients with slower internet connections. * Jump sounds will no longer get stuck occasionally when gibbing someone. * The "One Minute Warning" will no longer be heard during warm up. * Projectiles will no longer fly sideways through teleporters. * Player corpses will not disappear so suddenly if the player force respawns. * Item effects will now always be aligned with the item pickup. * Icons no longer lag behind the player model. * Players will no longer hear old countdown announcements when spawning into a new tournament arena. * Powerups in tournament games no longer drop into the wrong arenas. * Switching between the Summary and Statistics screens of the End-Game Summary window will no longer reset the Statistics to 0. * Items will not bob so quickly after a server has been active for a long while. * Improved server stability. * In Tournament games, gibs from other arenas will no longer be visible. * Corrected an issue dealing with connecting to password-protected servers while running the game in windowed mode. * The video settings should no longer revert to default when connecting to servers while running the game in windowed mode. * Clicking "Get New List" in the Game Browser will no longer create phantom servers in the list. * Fixed call vote stability for clients running a Spanish or French version of the game. * Playing back net demos will no longer cause a crash. * When playing back a net demo with a mapchange in it, the game will no longer attempt to connect to the server on which the game was recorded. * Fixed announcer not understanding zero fraglimit setting when negative numbers are expressed from client suicides. * Gametype can be changed to CTF with the RCON command. * The number of votes will be displayed correctly for the player calling for the vote. * If a spectating player votes at the end of a tourney, the vote announcement will be properly heard. * The map list will properly display when calling a vote to change the map. * Addressed issue with crusher on the Xaero Gravity (q4ctf5) map not crushing players when activated. * Map performance increased in Relativity (q4ctf4). * Corrected a possible geometry exploit in the Xaero Gravity (q4ctf5) map. * Corrected a geometry exploit in the Sandstorm (q4dm2) map. * Corrected two possible geometry exploits in the Tremors (q4ctf7) map. Single Player: * The player will now always pick up ammo if they are not carrying the maximum amount of ammo. * The player will properly die when killed by clamp and barrels in the Putra level. * Corrected a progression break in the Hub 1 map. * The player will properly die when killed by the plate compressor in the Tram 1 level. * The player will no longer be able to exit the Medlabs ride at the beginning of the level. * Fixed Gladiator's AI state when his shield is disabled with the Lightning Gun. Known Issues: Surround Speakers option in Advanced Audio settings cannot be enabled if Windows Sound options are not set correctly on the local machine. Players with 5.1 surround sound must set their Advanced Speaker Settings to Surround 5.1 instead of Desktop Stereo: 1. From the Windows(r) Control Panel, select "Sounds and Audio Devices." 2. In the "Speaker Settings" area, click the "Advanced" button. 3. Make sure that the speakers are set to "5.1 Surround" or "Surround 5.1" instead of "Desktop Stereo." If this is not set correctly, then enabling the Surround Speakers setting will not apply, and will default back to off.
