ATI Catalyst Treiber für Windows XP 64-Bit
Von Andreas Schilling
Nun endlich hat auch [url=http://www.ati.com]ATI[/url] seinen ersten 64Bit Treiber veröffentlicht. Es handelt sich dabei um den Catalyst Beta 1 for Windows XP 64 bit for AMD64. Der Treiber ist kompatibel zu allen RADEON X800 PRO, RADEON X800 XT, RADEON 9800 Series, RADEON 9700 PRO, RADEON 9600 TX, ATI RADEON 9550, RADEON 9500 Series, RADEON 9200 Series, RADEON 7000 Series, MOBILITY RADEON 9500, MOBILITY RADEON 9600 Series, MOBILITY RADEON 9700 Series, MOBILITY FireGL T2, ATI FireGL T2, ATI FireGL X1, ATI FireGL Z1 und ATI FireGL X2 Karten. Der Treiber setzt sich aus dem [url=http://www2.ati.com/drivers/wxp64-amd64-display-driver-beta-015296.exe]Display Driver[/url] und dem [url=http://www2.ati.com/drivers/wxp64-amd64-control-panel-beta-015296.exe]Control Panel[/url] zusammen.The BETA display drivers provided are offered AS IS, without warranty of any kind, and have NOT been completely qualified by ATI. ATI does NOT recommend installing these drivers in systems used for mission critical operations or where productivity of any kind is a concern. These BETA drivers are NOT SUPPORTED by ATI Technical Support or any other ATI department. If you decide to install these drivers and encounter issues that you cannot work with, we suggest these drivers be uninstalled and that you install the "Recommended" drivers for your specific product found on the ATI website
Quellen und weitere Links
    KOMMENTARE ()
