ATI Catalyst 4.7 veröffentlicht
[url=http://www.ati.com]ATI[/url] hat soeben den ATI Catalyst 4.7 veröffentlicht. Das komplette Treiberpaket beinhaltet die folgende Einzelpakete: Radeon Display Driver 8.03, Multimedia Center 9.1, HydraVision 3.25.0006, HydraVision Basic Edition 3.25.9006, Remote Wonder 2.3 und WDM Version 4.05. Der Treiber eignet sich für alle Microsoft Windows 2000 und XP Systeme sowie alle ATI Grafikkarten beginnend mit der Radeon 7200 Serie bis hin zu den neuen X800 Modellen. Die Release-Notes haben wir unter "Read More" zusammengefasst, dort findet man auch die Download-Links zu diesem neuen offiziellen Treiber.
  • Enabling both the CRT and DVI connectors and setting the CRT to primary no longer results in display corruption being seen on the display connected to the DVI when running 3D Labs applications and disabling the display on the DVI connector
  • The mouse pointer no longer flashes or becomes corrupted when setting the display mode to 1080i and launching Windows MCE
  • DVD playback hesitation at the beginning of a movie is no longer noticed when using the ATI DVD Player under Windows XP with an ATI 8500 ALL-IN-WONDER™ installed
  • The Windows XP operating system no longer fails to respond when a D3D application generates a floating-point exception error
  • The BIOS Version information is now stated correctly in the Details found in the ATI Options tab. Further, the correct DAC and ASIC information is now displayed in the Adapter tab found in the advanced setting of the display properties
  • The Overlay Theater Mode table has now been extended to support 1080i and 720p
  • Launching EVE Online under Windows XP with an ATI RADEON™ 8500, 9100, or 9200 series no longer results in a VPU recover error before the terms and conditions is displayed
    Das [url=http://www2.ati.com/drivers/wxp-w2k-catalyst-8-03-040610a-016126c.exe]komplette Paket[/url] ist 28.8 MB groß. Sowohl der [url=http://www2.ati.com/drivers/wxp-w2k-8-03-040610a-016126c.exe]Display Treiber[/url], als auch das [url=http://www2.ati.com/drivers/control-panel-8-03-040610a-016126c.exe]Control Panel[/url] sind aber auch einzeln verfügbar.
  • Quellen und weitere Links
      KOMMENTARE ()
