AMD gibt den Catalyst 15.10 Beta frei
Von Andreas Schilling
7
AMD hat einen weiteren Catalyst-Treiber in einer Beta-Version veröffentlicht. Der Catalyst 15.10 Beta steht für Windows 7, Windows 8, Windows 8.1 und Windows 10 jeweils in einer 32- und 64-Bit-Version zur Verfügung. Die Display-Driver-Version lautet 15.201.1151.1005 und AMD will sich für allem der Leistung und Qualität bei Ashes of the Singularity unter DirectX 12 angenommen haben. Weiterhin erwähnt werden folgende Änderungen bzw. Anmerkungen:
Resolved Issues:
  • [77786] Video playback of MPEG2 video fails with a playback error/error code message
  • [77754] A TDR error or crash is experienced when running the Unreal Engine 4 DirectX® benchmark
  • [77073] Star Wars™: Battlefront is able to use high performance graphics when launched on mobile devices with switchable graphics
  • [76930] Intermittent playback issues with Cyberlink PowerDVD when connecting to a 3D display with an HDMI™ cable
  • [59403] Ashes of the Singularity™ - A 'Driver has stopped responding' error may be experienced in DirectX® 12 mode
  • [58435] Driver installation may halt on some configurations
  • [76924] A TDR error may be experienced while toggling between minimized and maximized mode while viewing 4K YouTube content
Known Issues:
  • [77970] Ashes of the Singularity may crash on some AMD 300 series GPUs
  • [59528] Core clock fluctuations may be experienced when FreeSync and FRTC are both enabled on some AMD CrossFire systems
  • [58233] Ashes of the Singularity may fail to launch on some GPUs with 2GB Video Memory. AMD continues to work with Stardock to resolve the issue. In the meantime, deleting the game config file helps resolve the issue
  • [77255] The secondary display adapter is missing in the Device Manager and the AMD Catalyst Control Center after installing the driver on a Microsoft Windows 8.1 system
  • [59475] Elite: Dangerous - poor performance may be experienced in SuperCruise mode
  • [59792] A black screen may be encountered on bootup on Windows 10 systems. The system will ultimately continue to the Windows login screen
Der Download des AMD Catalyst 15.10 Beta ist wie immer direkt von der Treiberseite von AMD möglich.
Quellen und weitere Links KOMMENTARE (7)
