AMD und NVIDIA aktualisieren ihre Treiber
20
Sowohl AMD als auch NVIDIA haben ihre Grafikkarten-Treiber aktualisiert. Bei AMD hört dieser auf den Namen Radeon Software Crimson ReLive Edition 16.12.2 und bei NVIDIA bleibt es schlicht bei GeForce 376.60.
AMD nennt gleich einige Highlights der neuen Version:
  • AMD FreeSync technology may experience performance issues with Borderless Fullscreen application support when a secondary display is attached and has dynamic content running such as video playback in a web browser or if other applications or game launchers are running on the primary screen in the background. A workaround if this issue is experienced is to minimize all other running applications that are on the primary desktop display or on non-primary extended displays.
  • Radeon ReLive may fail to install during installation on some system configurations.
  • Battlefield 1 may experience flashing or corruption when running in Multi GPU with Radeon RX 400 series.
  • Instant Replay fails to enable itself after it has been turned off due to content protection.
  • Radeon Settings may not load on system boot for some system configurations.
  • Fixed some errors in translations for Radeon Settings and Radeon ReLive.
  • Audio recorded by Radeon ReLive may sometimes exhibit slow motion when played back.
  • Radeon ReLive may experience recording issues or issues toggling the Overlay/Toolbar when Frame Rate Target Control is enabled. Users are suggested to disable Frame Rate Target Control when using Radeon ReLive.
  • Mouse cursor may stutter in recorded video when there is limited on screen activity outside of minor mouse movement.
  • In AMD Multi GPU configurations the secondary graphics product will exit the low power state when Radeon ReLive is enabled.
  • Radeon ReLive may sometimes not be able to take screenshots of secondary displays.
  • Chromium may fail to utilize hybrid decode for VP9 content.
  • DOTA 2 may experience game corruption when performing a task switch while recording with Radeon ReLive in AMD Multi GPU configurations.
  • Radeon ReLive Overlay/Toolbar will not launch or Record when running League of Legends in Administrator Mode and Windowed Borderless Fullscreen.
  • Long ping times may be experienced with some WiFi adapters.
Bekannt sind die folgenden Probleme:
  • A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background.
  • Counter-Strike: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue.
  • AMD Multi GPU configurations may experience a system hang or reboot during install when using tiled MST 4K or 5K displays.
  • Titanfall 2 may experience black square corruption in game menus or during game play on some Graphics Core Next products.
  • FIFA 17 may experience an application hang or black screen on launch for some select Hybrid Graphics or AMD PowerXpress mobile configurations.
  • Radeon Settings may not show display details for connected displays in AMD X-Connect technology mode.
  • Mouse cursor corruption may be intermittently experienced on Radeon RX 480.
Der Download des Radeon Software Crimson ReLive Edition 16.12.2 ist direkt bei bei AMD möglich.
[h2]NVIDIA GeForce 376.60[/h2]
Auch NVIDIA hat einen neuen Treiber veröffentlicht. NVIDIA hält sich mit den Informationen der Änderungen aber etwas zurück bzw. veröffentlicht keine derart ausführliche Beschreibung der Änderungen. Einzig die Behebung eines Fehlers, der dazu geführt hat, dass Battlefield 1 bei Kepler-Grafikkarten abstürzt und es hier zu Darstellungsfehlern bei allen Grafikkarten mit NVIDIA-GPU kommt, wird genannt. Außerdem soll es nicht mehr zu Blackscreens in DOTA 2 kommen.
Der Download ist auch hier direkt bei NVIDIA möglich.
Quellen und weitere Links KOMMENTARE (20)
