Futuremark veröffentlicht Patches für 3DMark03, 3DMark05 und PCMark04
Die Benchmarkschmiede [url=http://www.futuremark.com]Futuremark[/url] hat gleich drei Patches für seine Benchmarkprogramme 3DMark03, 3DMark05 und PCMark04 veröffentlicht. Dabei wurden zahlreiche Bugs behoben und neue Hardware in die Support-Liste aufgenommen. Es soll bei allen Patches keine Veränderungen in den Ergebnisse geben, es wurden lediglich Fehler ausgemerzt.
  • [url=http://www.hardwareluxx.de/download.php?det=166]Futuremark 3DMark05 120 Installer[/url]
  • [url=http://www.hardwareluxx.de/download.php?det=166]Futuremark 3DMark05 120 Patch[/url]
  • [url=http://www.hardwareluxx.de/download.php?det=79]Futuremark 3DMark03 360 Installer[/url]
  • [url=http://www.hardwareluxx.de/download.php?det=79]Futuremark 3DMark03 360 Patch[/url]
  • [url=http://www.hardwareluxx.de/download.php?det=4]Futuremark PCMark04 130 Installer[/url]
  • [url=http://www.hardwareluxx.de/download.php?det=4]Futuremark PCMark04 130 Patch[/url]
  • Technical Details Associated with 3DMark05 Patch (Build 1.2.0):
    • Benchmark scores do not change between build 1.2.0 and build 1.1.0, except when the system is influenced by the changes listed below;
    • Updated System Info module with support for the latest CPU and graphics hardware;
    • GeForce FX-series now use VS2.a as default;
    • Modified anisotropic texture filtering settings to ensure that all hardware performs the desired amount of filtering when anisotropic filtering is selected from the benchmark settings;
    • Updated version of the Entech library, which is used to detect the clock frequency of the graphics chip core and memory;
    • Improved compatibility for graphics cards with 128MB of video memory when using Anti-Aliasing;
    • Various fixes & corrections to Image Quality Tools;
    • Fixed all reported & reproduced bugs;
    • Possible result vulnerability has been blocked
    Technical Details Associated with 3DMark03 Patch (Build 3.6.0):
    • Benchmark scores do not change between the build 3.6.0 and build 3.5.0;
    • Requires Microsoft DirectX 9.0c End-User Runtime;
    Technical Details Associated with PCMark04 Patch (Build 1.3.0):
    • Benchmark scores do not change between the build 1.3.0 and build 1.2.0;
    Quellen und weitere Links
      KOMMENTARE ()
