Treiber
Radeon Software Crimson ReLive Edition 17.11.3 Hotfix für Radeon RX Vega
3
AMD hat mit dem Radeon Software Crimson ReLive Edition 17.11.3 Hotfix einen neuen Treiber veröffentlicht, der sich besonders der Abstürze im Zusammenspiel mit einer Radeon RX Vega 64 oder Radeon RX Vega 56 annehmen soll. AMD beschreibt dies allgemein mit: "An intermittent crash issue may be experienced on some Radeon RX Vega series graphics products."
Weiterhin bekannte Probleme sind:
  • Some desktop productivity apps may experience latency when dragging or moving windows.
  • Tom Clancy's Rainbow Six Siege may experience an application hang when breaching walls with grenades or explosives.
  • Rise of the Tomb Raider may experience an intermittent application hang during gameplay.
  • A random system hang may be experienced after extended periods of use on system configurations using 12 GPU's for compute workloads.
  • The GPU Workload feature may cause a system hang when switching to Compute while AMD CrossFire is enabled. A workaround is to disable AMD CrossFire before switching the toggle to Compute workloads.
  • Resizing the Radeon Settings window may cause the user interface to stutter or exhibit corruption temporarily.
  • Unstable Radeon WattMan profiles may not be restored to default after a system hang.
  • OverWatch may experience a random or intermittent hang on some system configurations. Disabling Radeon ReLive as a temporary workaround may resolve the issue.
Der Radeon Software Crimson ReLive Edition 17.11.3 Hotfix kann wie immer direkt bei AMD in den verschiedenen Windows-Versionen heruntergeladen werden.
