Treiber
Radeon Software Adrenalin Edition 18.9.1 für Shadow of the Tomb Raider
0
AMD hat den Radeon Software Adrenalin Edition 18.9.1 veröffentlicht und konzentriert sich damit vor allem auf den morgigen Start von Shadow of the Tomb Raider. Ebenfalls unterstützt bzw. optimiert wird auf Star Control: Origins.
Zudem will AMD einige Fehler behoben haben. Dazu gehören:
  • Radeon FreeSync may fail to enable when playing Monster Hunter: World.
  • Radeon Settings may sometimes not appear in the right-click context menu on Windows desktop after Radeon Software installation.
  • AMD Link may fail to connect on Android Pie devices due to authentication failures.
  • Radeon Settings may sometimes popup an error message due to Driver and Radeon Settings version mismatch.
  • Cursor or system lag may be observed on some system configurations when two or more displays are connected and one display is powered off.
  • Some DirectX 12 gaming applications may experience instability while recording with Radeon ReLive on system configurations using Radeon R9 290 and Radeon R9 390 series graphics products."
Noch bekannt sind die folgenden Fehler:
  • Some AMD Ryzen Desktop Processors with Radeon Vega Graphics system configurations may experience a black screen during installation downgrade to a previous Radeon Software version. A recommended workaround is to perform a clean install during Radeon Software installation.
  • Radeon RX Vega Series graphics products may experience elevated memory clocks during system idle.
  • System configurations with 16+ CPU cores may experience a random system reboot during installation when upgrading Radeon Software from a version older than RSAE 18.8.1. A clean installation is recommended when performing this Radeon Software upgrade.
Der Radeon Software Adrenalin Edition 18.9.1 kann ab sofort direkt bei AMD heruntergeladen werden.
