ATI Catalyst 5.5 veröffentlicht
Von Dennis Bode
[url=http://www.ati.com]ATI[/url] hat den neuen Catalyst 5.5 zum Download bereitgestellt. Der neue Catalyst 5.5 enthält wieder etliche Bugfixes. Darunter z. B. beim 3DMark 2005, Star Wars: Knights of the Old Republic 1 und 2 u.v.m. Die vollständige Liste der vorgenommenen Änderungen findet sich unter Read more. Zum Download bei ATI geht es [url=https://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&folderID=27]hier[/url].
  • 3DMark05: Running the application under Windows XP for extended periods of time no longer results in the operating system failing to respond when using an ATI Radeon™ X700 PRO
  • Ashli Viewer sample Wood: Display corruption is no longer noticed when Anisotropic Filtering set to 4x or above
  • Ashli Viewer v1.6.0: Running the application under Windows 2000 and launching a sample item found in the Programs & Shaders no longer results in corruption being displayed in the sample item
  • City of Heros: Playing the game under Windows XP with an ATI Radeon™ Xpress 200 series installed no longer results in the characters in the game appearing corrupted
  • Freedom force VS The 3rd Reich: Playing the game under Windows XP with an ATI Radeon™ 8500 installed no longer results in the super hero character attributes appearing blank
  • Imperial Glory Demo: Playing the game under Windows XP with an ATI Radeon™ X800 installed no longer results in the game failing to respond
  • Star Wars Knights of the Old Republic 2: Setting the graphic option in the Catalyst™ Control Center to Optimal Quality, followed by launching the game and setting the resolution option to 1600x1200, no longer results in a performance drop being noticed
  • Star Wars Knights of the old republic: Loading the Dantooine level of the game under Windows XP no longer results in slow game performance
  • Setting the desktop display to 800x600 or 1600x1200 16/32bpp no longer results in the incorrect display resolution information being provided when checking the video control panel in the Catalyst™ Control Center
  • Setting the display device to 1080i no longer results in the text on the custom format being illegible
  • Setting a customized resolution for 720p now works properly when maintaining the aspect ratio
  • Moving the TV to desktop2 and selecting swap device or double up no longer results in the CRT being in panning mode and display corruption being seen on the TV
  • Having a TV connected as the only display device and clicking the OK button in the ATI displays tab found in the Advanced section of the Display Properties results in a flash of the TV image being noticed
  • Connecting and enabling an HDTV and entering the properties page for the HDTV no longer results in the D3/D4 options being available in the D-Connector Control Panel
  • The occasional Windows error messages no longer occurs when booting into extended desktop under Windows XP when using an ATI Radeon™ X300 or X600
  • Corruption is no longer seen when connecting a secondary display device and moving the primary display device to the left of the secondary device, followed by disconnecting the primary display device and then reconnecting it
  • Previewing or launching the aquarium screen saver under Windows XP Media Center Edition no longer results in the operating system failing to respond
  • RF online game compatibility issue with all ATI Radeon™ series
  • Launching the Catalyst™ Control Center help files from the Start->All Programs->Catalyst™ Control Center now results in the localized version of the help file being displayed
  • Catalyst™ Control Center: Running the French custom install no longer results in a NewFeature1 component being listed
  • The link found in the second and third help page for the Change Desktop Settings found in the Japanese version of the Catalyst™ Control Center no longer cross-references to an incorrect help page
  • A black screen is no longer displayed when launching AMCap and attempting to view video from the tuner when using either the svideo or composite inputs
  • Display corruption is no longer noticed on the TV when setting the TV format to PAL-B and attempting to adjust the flicker removal in the TV Advanced option
  • Having a TV and CRT connected and clicking on Preview Automatic adjustment in the Optimize Media Center no longer results in both display devices displaying a black screen
Quellen und weitere Links
    KOMMENTARE ()
