"XPC Tools gives you complete control over your XPC," explained Troy Yang, Product Manager. "Safely and instantly increase bus speeds and voltages for extreme performance and stability when gaming, or configure optimal Smart Fan settings to keep your XPC 'Super Quiet, Super Cool’ while you watch movies or work. XPC Tools' versatile profiles system allows you to create, save and load customized settings for any use or activity."
Overclocking on the fly
Change bus speeds and voltages directly from within Windows for improved performance when you really need it. Dynamically overclock your XPC without rebooting the system or entering the BIOS.
Advanced profile system
Create fully customized profiles to suit any use or setting. Turn everything to maximum for extreme performance when gaming, and then switch to a low noise configuration while you enjoy music or a movie. Profiles can be saved and loaded at the click of a button.
Complete Smart Fan control
Manage Smart Fan directly from within XPC Tools. Adjust settings to suit the thermal or acoustic levels you want. With XPC Tools it's now even easier to keep your XPC "Super Quiet, Super Cool."
Real-time system monitoring
XPC Tools gives you real-time access to a comprehensive range of system metrics and information. 2 fully customizable view modes keep the information you need always on hand. Advanced logging functions make determining optimal settings for your system quick and easy.
Versatile Front-panel Display (VFD) management and configuration
With XPC Tools you can turn the Shuttle VFD accessory on supported XPCs into a complete system-monitoring device. Display system temperatures, fan speeds, and more in real-time on the front of your XPC. Customize your XPC with your own personal message.
Full list of XPC Tools features
