[Sammelthread] Project C.A.R.S. - Ideen und Vorschläge für eine Liga / PSN-IDs & XBL-GTs
Auf jeden Fall sollte man aufnehmen, dass Fahrer von abseits der Strecke vorsichtig zurück kommen.
Und wenn man im Zweikampf ist. Nicht unnötig nach Innen zieht und den Gegner eventuell umdreht.
Habe auf PS4 gewechselt, PSN ID: f34rl355_kr4u7
Update 1.3 is now available for players on Xbox One that addresses some key issues identified by the community...
PROJECT CARS XBOX ONE PATCH 1.3 FIXED ISSUES
GAMEPAD CONTROLLERS
Added ABS brake rumble to Xbox One triggers, so that the impulse triggers will rumble on losing traction when braking. The amount of trigger rumble is controlled together with Force Feedback strength via the Force Feedback slider.
Improved the efficiency of the controller rumble effect, to help make the steering more responsive
Fixed an issue where moving the sticks from one extreme to the other would sometimes result in the steering getting stuck.
Reworked the Xbox One analogue sticks range and axis dead zones, providing much improved steering control.
WHEEL CONTROLLERS
Fanatec wheels – Fixed the issue with steering jolts that some users experience.
ONLINE
Fixed an occasional crash when advancing from Qualifying to Race.
Fixed an occasional crash when returning from a race to the Race Central.
DRIVER NETWORK TIME TRIAL
Set Time Trials starting time to 11am to match the PC platform. This ensures consistent track temperatures across all platforms, as track temperatures affect lap times.
DRIVER NETWORK GHOSTS
Enabled saving of community event ghosts. These ghosts are automatically stored online, and you can then download ghosts of other players’ laps for these events.
DRIVER NETWORK PROFILE
Fixed an issue where at times the miles driven on a particular track or with a particular car would be logged under the wrong car or track. This improves the accuracy of the player’s Affinity ratings.
TRACKS
Sakitto and Summerton variations - Corrected track info regarding number of turns and track length.
Sakitto Sprint - Fixed a crash that would at times occur when using time acceleration.
Cadwell variations - Fixed draw distance issues on various objects.
Oschersleben variations - Fixed odd lights around track and colour issues with the horizon.
Zolder - Fixed an issue where the player car would sometimes start in a closed garage.
AI
Fixed an issue where AI vehicles were sometimes sent to the pits due to low fuel on races where refueling is not allowed.
PIT STOPS
Pitstop strategy will now use the actual bar value for tyre pressures.
Fixed an issue where the Pit engineer would repeatedly inform the player that a pit crew member has lost a wheel nut during pit stops.
Fixed an issue where the Pit Engineer would call the player to stop for fuel when fuel consumption was disabled in options.
REPLAYS
Improved the smoothness of the sun, moon, stars, and shadow motion when rewinding replays of a race that had a high time acceleration.
Xbox One Update 1.3 now available! - Project CARS
Wie schauts aus? Wer Lust auf ein paar Rennen heute Abend (PS4)?
Ja des passt gut, vor 2 geh ich eh kaum schlafen xD
Vielleicht bin ich später auch novh bei einer Runde dabei.
Gerade paar Runden gedreht. Das mit dem Setup stimmt. Kann ich nun auch bestätigen, da nun der sechste Gang beim Benz optimal ausgefahren wird.
Derzeit meine Zeit:
1:38:373
Kann man eigentlich noch mit einsteigen? Bekomme leider erst Montag meine PS4 und hoffentlich auch Project Cars.
Zum üben kann ich dir die Project Cars Challenge in meiner Signatur empfehlen.
Ahso ok. Dachte die Challenge aus der Sig wäre schon das richtige Event.
Dann hoffe ich mal das ich im laufe der Woche einsteigen kann.
Klar kannst du einsteigen, dass ist das erste Event was so in die Gänge gekommen ist :) es wird auch hoffentlich nicht das letzte sein! und es sollten noch ein paar Community Rennen dazu kommen. Schön wäre noch eine passende Liga dazu :)
Im PSN Store gibt es 2 DLCs für Project Cars. Racing Icons und Limited Edition Car Pack. Kann ich das Limited Edition Pack auf für die normale Version nutzen oder wie der Name schon sagt nur für die Limited Edtion?
Das LECP ist dafür da, um dir die Autos zu geben, die nur in der (ausverkauften) Limited Edition enthalten waren.
Moin an Alle Fahrer,
sollte heute Abend mal ein paar Runden Online (PS4) drehen. wer mag, kann mich gerne adden (PS4: minickmcr56)
Vielleicht bekommen wir ja ein paar Leute zusammen und können ein paar Rennen fahren.
Denke mal, es wird so ab 20 Uhr
Hallo an Alle,
die Time Trial Challenge beginnt nun mit dem achten von insgesamt zehn Events und nun wollte ich mal einen kleinen Blick in die Zukunft werfen.
Die Nordschleife ist sehr beliebt und auch sie sollte ein Event oder gar eine ganze Challenge bekommen. Daher war mein Gedanke, den Zeitraum auf jeden Fall zu erweitern (mindestens einen Monat) und eventuell mit mehreren Klassen dort zu fahren. Auf Screenshots aus der Bestenliste möchte ich hier verzichten, da schon einige eine Zeit gesetzt haben und wir ja im Rahmen der Challenge bleiben wollen :)
Eine andere Challenge würde wieder im Rahmen des wöchentlichen Rhythmus liegen. Diesmal aber nur eine oder zwei Klassen parallel beinhalten.
Da ich privat immer noch arg mit anderen Sachen beschäftigt bin, möchte ich mich persönlich nicht für einen festen Termin in der Woche für ein Rennen festlegen. In der Winterzeit wird das etwas entspannter und dann muss ich schauen, was sich machen lässt.
Dennoch bin ich froh, nette Leute während der Challenge kennen gelernt zu haben und Abends ein paar Runden gemeinsam zu drehen, dies ist halt locker und ohne Termin.
Hoffe, wir haben auch in Zukunft ein paar Teilnehmer :)
Das mit der NOS hört sich gut an. Ich wäre auf jeden Fall dabei. Denke mal sollte dann entweder alle Klassen fahren oder die Kassen festlegen. Was die andere Challenge angeht bin ich auch dabei. Wie auch bei dir ist es bei dem Wetter im Moment bzw. allgemein in den Sommermonaten zeitlich ein bisschen schwierig aber ich denke das sollte zu machen sein.
Unsere erste Challenge ist nun zu Ende gegangen.
Eigentlich wollte ich für die zweite Runde etwas selbst programmiertes im Web zur Verfügung stellen, leider wurde bisher aus Zeitmangel nicht viel daraus. Zumindest nichts produktives :(
Nun meine Idee für eine weitere Challenge:
GT 3 Time Trial Challenge
d.h. jeder wählt zu Beginn der Challenge ein GT 3 Fahrzeug aus und fährt alle Events mit diesem Fahrzeug.
Der Rest sollte wie gewohnt bleiben.
Ich bin erst dabei wenn die gröbsten Bugs bei der X1 gelöst sind. Mit Patch 2 ist das Spiel nur noch Mist.
sowas ist natürlich ärgerlich.
eine andere Idee wäre, man nehme ein paar Strecken und verschiedene Autos und würde die Events gleichzeitig und über einen längeren Zeitraum fahren.
z.B. Nordschleife mit GT3 oder BMW E30/Mercedes E190 AMG.. und dann bis September mal laufen lassen. dann könnte man auch mehr über das Setup diskutieren
bei mir geht es mittlerweile in die heise Phase und daher bin ich nur noch selten online :(
denke aber, dass ich für den Herbst/Winter wieder was zusammen bekomme!
Stay tuned
