• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
Um das verlinken kümmere ich mich später, aber danke schon mal für das Erstellen des Threads :wink:
Wird im Laufe der Zeit vervollständigt werden.
Vielen Dank, ist abonniert. :wink:
Ein passender Wasserkühler: Cuplex Kryos XT
Ram kommt von mir auch noch, erstmal muss die Kiste laufen
Kleine Anmerkung: setz doch die Specs am besten in einen Spoiler, ist übersichtlicher imho
Wasserkühler: XPC Raystorm
Ram: Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
und natürlich die Lowprofile Samsung Green
Ich kümmere mich drum das hier alles eingetragen wird.
---------- Post added at 13:06 ---------- Previous post was at 12:40 ----------
kleines Update
Dieser Thread ist nur fürs Formula. Trotzdem danke.
Ich bräuchte mal von euch eine Beratung...!
Ich kann mich nicht entscheiden, zwischen dem Asus Gene V und dem Asus Maximus Extreme V :confused:......
Cpu habe ich eine 3770k.
Ram Corsair Platinum 2400.
Übertaktet soll nur im "moderaten" Bereich werden,
also alles was eine Corsair H80 der H100 "leise" bewältigen kann....
Vielen Dank schon mal, bin für alle Vorschläge offen...:coffee:
Dieser Thread betriftt zwar weder das Gene noch das Maximus V Extreme - aber ok.
Das Gene ist ein mATX Board also recht klein gehalten, wenn Du mit den zur Verfügung stehenden Bauteilen und Anschlüssen auskommst sicher keine schlechte Wahl.
Das MVE ist auf Overclocking ausgerichtet und meiner Meinung nach für "normales" Übertakten oversized und overpriced.
Das Maximus V Formula ist da eher brauchbar, da es zwar zum Overclocken gut gerüstet ist, aber auch Gamer und alle anderen "normalen" User bedient.
Aber das können viele Boards aller Hertseller im günstigeren Preisbereich auch.
Wenn Du das Geld für ein ROG-Board ausgeben willst, dann ist das Maximus V Formula die vernünftigste Wahl (zumindest seh ich das so und hab es mir geholt.)
Seh ich ähnlich, bei mir hat auch noch die Optik und der Full-Size-Formfaktor eine Rolle gespielt. Für mein TJ07 ist ein mATX-Board einfach zu klein.
ich habe noch Deckel von meinen Schraubverschlüssen drüber gemacht, bei mir tropft nix. Vielleicht hast du zuviel Durchfluss?
Ich hatte ja noch nicht mal das System vollständig gefüllt - Ich nehm an das ich die Schlauchschellen nicht fest genug angezogen hab
Die Vorhandenen Wasseranschlüsse für die Spannungswandler sind doch ideal für Dich....
...und es ist eine Faire Zwischenlösung zwischen dem MV Gene und dem Extreme ( welches auch mir einfach ZU Teuer war) :/
Würde Dir auch Empfehlen das MV Formula zu wählen.
Habs mir eben auch bestellt. :d
Voralleim weil schon von Haus aus eine WaKu drauf verbaut ist, und ich mir den Umbau selbst eh nicht mehr zutraue bei einem MB... :)
Also mit Vollbestückung sind maximal 2200mhz drin ( bei mir).
und mit dem jetzt feinen Verbauten 2700K halt 2133...
Aber das Langt ja auch :)
Hmm weiss jemand ob mein 15,9/9,5mm Tygon schlauch an die MB WaKu passt?
Weil wenn nicht werde ich wahrscheinlich wieder abbestellen, das war eigentlich der Grund...finde nur leider nichts nützliches im Netz was genau für welche passen. Weil wenn nur 8/10mm passt das wär nix...
Habe Masterkleer 16/10er heute ausprobiert, nicht dicht. Jetzt muss ich schauen wie ich die Grakas und das Mainboard trocken kriege :(
Bei mir dicht mit dem, hab aber auch Kabelbinder als Sicherung drum..
Ich habs jetzt mit Schlauchschellen laufen, damit gehts auch
So für die Liste:
Cuplex kyros Delrin passt
Beim Arbeitsspeicher:
ADATA Gaming Series 2400 MHz 2x4GB
Beim RAM kommt über die Zeit noch eine Menge mehr, als Speicheronkel wird das Board eine ganze Menge sehen :d
Dieser hier: http://www.aquatuning.de/product_in...aktiv-Black-3-3m--10ft---Retail-Package-.html
:banana: Rechner is fertisch :banana:
Gibt es eigentlich fürs Asus Programme mit denen ich im Windows Multi, VCore usw einstellen kann?
Jo ist es. Einfach mal auf die CD schauen.
Eigentlich verzichte ich immer auf solche Software, daher lass ich mitgelieferte CDs immer gerne links liegen. Mal schauen heute Abend. :)
