[Sammelthread] Gigabyte Z97X-SOC Force
Spezifikationen
Model numberGA-Z97X-SOC FORCE
EAN4719331812232
Form factorATX (305x244mm)
CPULGA1150
ChipsetIntel® Z97
MemoryNumber of slots: 4
Channels: Dual
Corresponding standard: DDR3
3300 (OC) / 3200 (OC) / 3100 (OC) / 3000 (OC) / 2933 (OC) / 2800 (OC) / 2666 (OC) / 2600 (OC)
2500 (OC) / 2400 (OC) / 2200 (OC) / 2133 (OC) / 2000 (OC) / 1866 (OC) / 1800 (OC) / 1600 / 1333
Built-in graphicsD-sub (1920x1200 @ 60Hz)
DVI-D (1920x1200 @ 60Hz)
HDMI 1.4a (4096x2160 @ 24Hz, 2560x1600 @ 60Hz)
DisplayPort 1.2 (4096x2160 @ 24Hz, 3840x2160 @ 60Hz)
Expansion slot4x PCI Express x16 (2x16, 1x8, 2x4 Lanes)
1x PCI Express x1
2x PCI
Multi-GPU4-Way AMD CrossFire, 2-Way NVIDIA SLI
Storage1x SATA Express*
6x SATA 6Gb/s (RAID 0/1/5/10 support)
*SATA Express and SATA3_4/5 Port shared
Audio7.1 Channel Realtek HD Audio (ALC1150)
LAN1x Qualcomm Atheros Killer E2201 (Gigabit Ethernet)
Interface6x USB3.0 (4x Backpanel, 2x Internal)
8x USB2.0 (4x Backpanel, 4x Internal)
Internal connector1x 24-pin ATX main power
1x 8-pin ATX 12V power
1x 4-pin ATX 12V power
1x OC PEG power
1x SATA Express
6x SATA 6Gb/s
1x CPU fan header
1x water cooling fan header (CPU_OPT)
6x system fan headers
1x front panel header
1x front panel audio header
1x S/PDIF Out header
1x USB 3.0 / 2.0 header
1x USB 2.0 / 1.1 header
2x USB 2.0 / 1.1 ports
1x serial port header
1x Clear CMOS jumper
1x power button
1x reset button
1x Clear CMOS button
1x Gear button
1x OC Turbo button
1x OC Tag button
1x OC Trigger switch
1x CPU BCLK Down button
1x CPU BCLK Up button
1x CPU Ratio Down button
1x CPU Ratio Up button
1x Memory Safe button
1x Settings Lock button
1x Direct to BIOS button
1x OC DIMM switch
1x OC PCIe switch
1x OC Ignition button
1 Clear Battery button
2x BIOS switches
1x onboard voltage measurement module
Back panel4 x USB 2.0 / 1.1 ports
4x USB 3.0 / 2.0 ports
1x optical S / PDIF Out connector
1x D-Sub port
1x DVI-D port
1x HDMI port
1x DisplayPort
1x PS/2 keyboard & mouse port
1x RJ-45 port
6x audio jacks (Center / Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In, Line Out, Mic In)
BIOS2x 128 Mbit flash
AMI UEFI BIOS
Support for DualBIOS
PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0
Supported OSWindows 7 / 8 / 8.1
AccessoriesUser manual
Installation guidebook
I/O shield
Driver disk
4x SATA cable
OC brace
V-probes
2x SLI bridge
BIOS
1) Bilder
2) Spannungen
CPU Vcore0.500V bis 1.800V
-0.300V bis +0.400V
in 1 mV Schritten (Override)
in 1mV Schritten (Offset)
CPU VRIN External Override1.000V bis 2.400Vin 10mV Schritten
CPU Graphics Voltage0.500V bis 1.800V
-0.300V bis +0.400V
in 1mV Schritten (Override)
CPU RING Voltage0.800V bis 1.800V
-0.300V bis +0.400V
CPU System Agent Voltage-0.300V bis +0.400Vals Offset in 1mV Schritten
CPU I/O Analog Voltage-0.300V bis +0,400Vals Offset in 1mV Schritten
CPU I/O Digital Voltage-0.300V bis +0,400Vals Offset in 1mV Schritten
DRAM Voltage1.160V bis 2.100Vin 20mV Schritten
DRAM Termination0.325 bis 1.939Vin 3mV Schritten
PCH Core0.650 bis 1.300Vin 5mV Schritten
PCH I/O1.050V bis 1.900Vin 5mV Schritten
3) BIOS Downloads - Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
  • F3 (Initial Release)
  • F4 (Changes: Enhanced OC & Memory Compatibility)
  • F5 (Changes: CPU Microcode Update)
  • F6 (Changes: G3258 Overclocking, Improve SSD Performance)
  • F7e (Changes: Beta, Support future NVMe SSD drive)
  • F7 (Changes: CPU Microcode Update, Achtung: Es ist anschließend kein Downgrade mehr möglich!)
  • F8 (Changes: Enhanced 5th Gen Core Processors/Broadwell Support)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr, Garantieverlust!)
News & Reviews
HARDWARELUXX Review Gigabyte GA-Z97X-SOC Force im Test
Hardwareluxx News: Gigabyte zeigt Intel Z97-Mainboards
Hardwareluxx News: Computex 2014: Gigabyte zeigt das GA-Z97X-SOC Force LN2
International Reviews
00) Gamezoom
01) Hartware.net
02) Tweakpc
03) Awardfabrik
04) ProClockers
05) OMF
06) Pclab.pl (Vergleichstest, 34 Modelle)
07) shahrsakhtafzar
08) Hardware Asylum
09) EasyCOM (ua)
10) Benchmark.rs
11) ocaholic
12) PC Perspective
13) PCaxe
14) pctuning.tyden.cz
15) Hardware.Info United Kingdom (Vergleichstest, 19 Modelle)
16) PC Ekspert
17) Legit Reviews
18) Benchit
19) HotHardware (Vergleichstest, 5 Modelle)
20) AnandTech
21) Z97 Motherboard LN2 Roundup @ Hardware.Info United Kingdom
ASRock Z97 OC Formula
ASUS Maximus VII Gene
MSI Z97 XPower AC
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tips (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
  • Das Verhalten der Stromsparmechanismen beim Übertakten (vom Z87X-OC):
  • Power-Off Dead Syndrom (Rechner lässt sich plötzlich nicht mehr einschalten)
    Wie ich dem Problem entgegne:
    Man kann das Board wieder zum Leben erwecken, indem man mit einer Litze das Netzteil manuell startet, während der Hauptstecker auf dem Mainboard sitzt. Das System läuft an, startet dann nochmal neu und danach geht es auch schon wieder in Windows.
    Alternativ: Das Board stromlos machen, die Batterie entfernen und das Board entladen (lassen, ca ~ 5 Minuten Wartezeit genügen).
emissary42 schrieb:
Falls noch jemand das Bild von der Verpackung als Wallpaper haben möchte:
Ist nur abfotografiert, sieht aber halbwegs original aus.
Mein Windoof hat schon ein halbes Dutzend Boards gesehen. USB Probleme hatte ich beim Umstieg nie. Wenn doch mal was schief geht, die USB Root Hubs einen nach dem anderen im Gerätemanager entfernen und anschließend die Hardwareerkennung laufen lassen (die aktuellen Treiber sollten ja installiert sein).
besitze halt nur noch usb hardware. also keine ps2 maus/ tastatur. ich werds morgen mal angehen, wenn ich hier noch WLP finde. vll köpfe ich den 4670k bei der gelegenheit
Das heißt du hast das SOCF schon herumliegen?^^
Und kann sich dann zurück halten... Halleluja!
sogar 2 davon :fresse:
Auch von Amazon Uk?
Ja... Du auch?
Nein, ich hab meines anständig hier im Forum gekauft :fresse:
Ist das Gigabyte SOC gut ?
Gut wofür? Übertakten: Ja. Wäsche waschen: Nein.
Ja und ich habs bei myDealZ gepostet und bin leer ausgegangen :(
Es hatte sich leider auch in anderen dunkleren Ecken des Internets herumgesprochen. Irgendwer muss solche Gelegenheiten ja immer zur eigenen Bereicherung bis ans Limit ausnutzen :(
Naja als es bestellt werden konnte ich ahnte ja niemand dass es kostenlos kommt. Es hat 70€ gekostet und damals gingen bei ebay einige schon für 100€ weg (-Gebühr). Ich zb wollte eines für mich und eines für Heino88 hier aus dem Forum, da er demnächst auch aufrüsten wollte. Dass die Boards geschenkt werden wussten wir ja nicht, sonst hätte der Fuchs nämlich auch nicht seine erste Bestellung storniert :-)
bin nun ernsthaft am überlegen das soc einzubauen. leider weiss ich, dass windoof dann wieder probleme machen wird (erst vor kurzem von asus z97x hero auf gigabyte z97x ud3(?) umgebaut, zwei rechner, der eine hat sofort alles erkannt, der andere wollte keine usb geräte annehmen [identische firmenrechner mit identischer software])
oder gibt es da was zu beachten?)
Hey, ich glaube das liegt vor allem am ASUS Board.
Ich hatte auch ein VII Hero rausgeschmissen, erst gegen ein SOC Force und dann ein Gaming 7. Wenn vorher das Asus installiert war konnte der PC danach nicht mehr neustarten/sich ausschalten nach dem herunterfahren und USB Geräte wurden nicht erkannt. Wer weiß was Asus da mal wieder macht...
Naja als es bestellt werden konnte ich ahnte ja niemand dass es kostenlos kommt. Ich zb wollte eines für mich und eines für Heino88 hier aus dem Forum, da er demnächst auch aufrüsten wollte.
Dagegen sagt ja auch niemand was. Ich habe aber auch schon Verkäufer gesehen, die im Moment ihr achtes und neuntes Board verkaufen :rolleyes:
Wo denn? Bei eBay? :d
Unter anderem auch dort, ja. Natürlich war jedes Board "ein Geschenk" und kommt daher ohne Rechnung.
so, hab es verbaut. wider erwarten gab es überhaupt keine probleme. system läuft ohne murren. jedoch hatte ich keine gc extreme WLP mehr da und musste mx-2 von AC nehmen mit dem resultat von 8-10°C schlechteren temps :heul:
edit: interessanterweise kann ich jetzt 4.2ghz bei 1.190V laufen lassen (vorher 1.205). temps sind trotzdem höher (76°C der heisseste kern zu vorher 70°C).
was mir jedoch auffällt ist, dass unter CPU z die spannung um +-0.1V unter last variiert. also mal ist 1.190 dann im nächsten moment 1.290 die spannung. im bios werden 1.190 angezeigt (bzw standard vcore + overdrive)
Team Elite 8GB Kit DDR3 PC3-10600 CL9 @ Preisvergleich | User: astra 1.8| kompatibel |
RAM ist eingetragen.
Welche BIOS Version? Welches CPU-Z Version? Zeig mal wie die Seite im UEFI mit den Spannungen genau aussieht :)
Bios ist F6, CPU z 1.71.1.
screen:
Oh man jetzt hab ich die Gigabyte Software installiert und jetzt fährt der Rechner nicht mehr hoch. Bleibt noch vor dem anmelde Bildschirm hängen... Und jetzt zerrt mich die Frau auch noch zum essen :heul:
Jemand eine Idee?
Ich bin generell nicht so der Fan von den Hersteller Tools. Einzig GTL2 und MemoryTweak habe ich installiert, schon jeweils in verschiedenen Versionen und bisher ohne Probleme (Win7x64sp1).
Hast du eventuell noch entsprechende Software von einem anderen Hersteller auf dem System? Da könnte sich natürlich etwas beißen. Dann starte in den abgesicherten Modus und wirf runter was weg kann :shot:
F8 funktioniert nicht um in den abgesicherten Modus zu kommen... Ist echt total seltsam
Aaah, geht jetzt wohl über shift +f8
Mhhhhh :-)
Passt doch die Optik. Laufen die Module denn einwandfrei? Dann trage ich sie in die Liste ein.
Sage ich dir im Verlauf des Wochenendes ;-)
passen optisch sehr geil zum Board :)
Absolut :) bin glücklich um den Tipp. Morgen bzw Montag kann ich was zur performance sagen
So, der Speicher sowie der BeQuiet Dark Rock Pro 3 arbeiten perfekt mit dem SOC Force zusammen! Kannst du so also in deine Liste aufnehmen.
Das Autoupdate-Tool via App-Center... Funktioniert das bei dir?
