[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Cool, aber könnte mir vorstellen, dass der sogar schlechter performt als die ganzen dicken 4090er Kühler :) Ist auch offiziell "nur" für 360W ausgelegt.
Früher war das mal DIE Alternative in Sachen Luftkühlung, aber mit popeligen 515 Gramm... ich weiß ja nicht :) Vermutlich für 4090 wirklich uninteressant...
Ich denke Anfang kommender Woche werden sich die Preise Richtung UVP -langsam- einpendeln bzw. Stück für Stück runter korrigieren.
Man muss kein Genie sein um zu erkennen, dass viele 4090 in den Lagern der gängigen Händler stehen und künstlich der Preis oben gehalten wird.
Das kann sicher nur jemand sagen, der Zugriff auf die Großhandelsbestände hat.. ^^
Aber selbst Newegg ist auch aktuell nichts auf Lager. Und die verkaufen nur zur UVP, kein Scalperpreise. Schade das wir sowas nicht haben.
Lol in meiner low-end CPU Klasse bin ich immerhin im PR der mit der höchsten Score haha
Kannst du vielleicht kurz erklären, weshalb er unrecht hat? Ich möchte mir dafür jetzt kein 25 Minuten Video anschauen.
Selbst Der8auer empfiehlt eher das PT runterzuschrauben, anstatt zu UV'en.
PT runterschrauben ist einfacher und die 4090 verhält sich etwas 'intelligenter' als die letzte Generation was den Stromverbrauch angeht, wenn sie < 100% belastet wird. Deswegen führt UV im Vergleich praktisch nicht zu besseren Ergebnissen als mit PT limit, was bei den 30ern noch anders war. Trotzdem kann man zumindest im oberen Voltbereich (>=0.9v) ohne Probleme UV betreiben. Das Ergebnis ist dort praktisch identisch mit PT limit.
Nur sieht es so aus, wenn man einen recht niedrigen UV (800mv oder niedriger) ansetzt, kann es zu diskrepanzen zwischen der angezeigten Frequenz und damit erwarteten Leistung und der praktischen Frequenz/Leistung kommen. Das gibt es noch genauer zu untersuchen.
Ausserdem sieht es so aus, wenn man einen recht niedrigen UV (800mv oder niedriger) ansetzt, kann es zu diskrepanzen zwischen der angezeigten Frequenz und damit erwarteten Leistung und der praktischen Frequenz/Leistung kommen. Das gibt es noch genauer zu untersuchen.
Stimmt nicht ganz. Der Vorteil von UV zu PL ist dass die GPU kühler bleibt.
Deine Zahlen sind doch rein aus der Luft gegriffen... Ganz ehrlich wenn Mehrleistung, dann muss sich das schon lohnen. Da gab es in der Vergangenheit schon deutlich bessere Ti Varianten!
was für aus der luft gegriffen?
die 3090 ti hatte satte 12% mehr leistung an den tag gelegt als die 3090... wir sprechen hier 16-20fps.
wieso muss den Leuten immer das Wort im Mund umdrehen?
Wer schnappt sich gleiche eine strix?😅
Ja das ist nix aber das meinte ich nicht, eher das Thema, dass 60-70% der 4090 Besitzer eine 3090 Ti hatten :rolleyes:
Mal ein Nachtrag zu meinem Video von gestern.
Stock vs UV vs PL vs OC
Das sind bisher meine finalen Ergebnisse
Interessant wäre noch wenn du PL + OC testest. Beispielsweise PL 80% + 200mhz Core Clock.
Ist die bessere UV Methode im Vergleich zum Curve Undervolting.
Sehe ich nicht so.
Es wird noch ca vier Wochen dauern, bis man sich dem UPV nähert.
Mr. Glaskugel!
Warum ist das besser?
da rennst Du ja permanent ins PL und der Takt springt hoch und runter. Zudem ist die GPU auch wärmer.
Der Webmaster von Proshop ist schon ins Wochenende gegangen :-)
Der Takt springt schon mal etwas ist bei mir aber konstant höher als UV per Curve Editor bei gleichem Wattverbrauch.
Außerdem sinkt der Video Takt und der effektive Takt mit UV per Curve, siehe Video von Optimum Tech.
Das mit dem Videotakt stimmt. Hat aber nur was mit encoding zu tun. da kann man ja ein anderes profil wählen.
Kann dir gleich das Szenario screenshoten was du möchtest.
Hier mal der Vergleich:
Was Du sagst ist wiedersprüchlich. Du setzt dir ein Powerlimit aber übertaktest.
Übertakten ist das gleiche wie undervolting. Du setzt die GPU Clock zu einer Spannung höher als Stock.
Du machst jetzt bei 1,05V 195MHz
Und ich mache bei 0,965V 195MHZ
Du rennst ins Powerlimit was deine höhere Taktrate ausbremst
Ich bleibe konstant bei einer Taktrate und habe kein Powerlimit
Die Videoclock wird doch auch beim PL ausgebremst wenn es die 87% übersteigt.
Die strix bei ck war schneller weg als man gucken konnte😅
Verstehe auch die gier nicht das man mehrere hundert euro draufzahlt. So unnötig wenn man ehrlich ist xD. Sobalf die 4080 draußen ist, wird es sich beruhigen die Lage.
Habe ich bei mir auch so als Alltagssetting. 1.1v, +250 GPU, +1000 mem, 75% PT. Gleich Performance wie Stock, aber max 340 Watt und natürlich deutlich kühler und leiser. Bei meiner TUF scheinbar der Sweetspot.
Ich glaube dass es einen gap geben wird.
Die Die dickste Karte auch für überdurchschnittlich viel Geld unf Aufpreis kaufen werden. Also wir deppen.
Und die, die sich sowas nicht leisten können oder wollen. Die werden keine 1600 Euro für eine 4080 zahlen. Alle die das können, kaufen eine 4090.
Mag mich aber auch täuschen
Ähnliche Themen
Antworten
6K
Aufrufe
389K
