[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Entweder liegt das an Be Quiet dass sie billig einkaufen wollten oder hat der Hersteller selbst, der sie für Be Quiet herstellt, geschlampt. Erfahren werdens wir wohl nie.
Die Kabel sind alle qualitativ unterste Möhre (nicht nur NVIDIA und BeQuiet). Igor hatte da in seinem letzten Video ja drüber gesprochen, und er scheint Recht zu haben: Die Plastikkanten sind allesamt nicht ordentlich entgratet worden (man muss ruckeln/horizontale Kräfte aufwenden, um die Kabel rein- und rauszustecken), die Pins sind nicht ordentlich zentriert (mal abgesehen davon, dass das Herstellungsverfahren für die Pins selbst verbesserungswürdig zu sein scheint, siehe die Theorie mit dem "oben" offen) - da gibt es einfach keine strengen Herstellungskontrollen.
Das wäre nur ein winziger Aufwand pro Kabel, um die am Ende nochmal zu bearbeiten (Kanten)... könnte sogar maschinell gelöst werden... aber die wollen allesamt Geld sparen. 5 Cent pro Kabel gespart, und beim Kunden steht am Ende der Hausbrand als Risikofall. Top.
Das muss doch dann aber auch Be Quiets Qualitätskontrolle aufgefallen sein. Oder geben die die Kabel gerade weiter ohne Überprüfung?
Was sagt ihr Rtx 4090 mit 7900x vs 5950x hat man Vorteile mit dem 7900 X .??? Beim zocken oder soll ich bei meinem 5950 X bleiben?
Lg
BeQuiet lässt, wie fast alle, in China herstellen. Da gibts Samples nach Auftragsstellung, die werden kontrolliert und danach gibt's die Auftragsfertigung.
Stichprobenartig wird da vielleicht ab und ab mal drübergeschaut, aber der Groß an Chargen wandert 1zu1 von China bis ins Paketlager Deutschland und dann zum Kunden, ohne dass die sich jemals jemand anschauen wird. Es könnte also theoretisch sogar sein, dass die chinesische Fabrik die erste Charge/finalen Samples optimal baut, danach schlammt (Kostengründen), frei nach dem Motto: Bis das einer merkt, sind wir schon wieder unter anderem Namen am Markt.
Ich würde da jetzt niemandem etwas unterstellen wollen, am Ende ist im Leben Ignoranz/Inkompetenz vermuten realistischer/wahrscheinlicher als mutwillige Kriminalität.
Das wird eine fehlerhafte erste Charge betreffen nur BQ hat ja bereits begonnen die Kabel aus zu tauschen. Aktuelle werden davon nicht mehr betroffen sein.
Mein BQ Kabel ist in Ordnung und das war eines aus der ersten Charge.
Woher weißt du das es aus der ersten Charge war? Auf dem Kabel steht doch keine nachverfolgbare Seriennr.
Edit: Also nur eine Vermutung deinerseits.
Gibts eigentlich immernoch keinen Hotfix für den aktuellen Nvidia Treiber ? Der aktuelle ist voll für die Tonne.
Im Overclockers Forum diskutieren die grade darüber, dass die Cablemod Kabel früher schonmal weggeschmolzen sind :d
Hier der Originallink zu dem ersten Fall, letztes Jahr
Gibt in dem Thread so einige Erfahrungsberichte von anderen
Nun beim 12VHPWR kann man ohne Tester einfach sehen wohin die Kabel gehen.
Bei meinem Kabel gehen 2x6 Leitungen auf einen 12-Pin. Beim 12-Pin sind oben unter den Sensepins 12V und in der unteren Reihe die Erdung.
Hier sind Diagramme von Pinouts von Corsair, Seasonic und EVGA.
Man sieht oben sind 12V bei 1,3 und 4, unten ist Erdung. 5 wird z.b. der Sensepin sein.
Wenn derjenige im Artikel aber das falsche Kabel gekauft hat, also an anderes Pinout beim Netzteil hat, macht es puff...
Kann aber auch gut sein, das die Pins nicht richtig im Stecker saßen und dadurch wie der Nvidia Adapter schmorten...
Hier ist der Pinout (Seasonic) zum Artikel:
Am Netzteil ist Pin 2 mit 4 gegenüber Corsair vertauscht. Da aber der jeweils andere Pin "leer" ist, kann das Kabel laufen, aber dann wäre statt 50W, 75W auf den einzelnen Kabeln.
beQuiet traue ich nicht über dem weg, seit der Silent Loop V1...3 mal jeweils nach fast genau 3 Monaten war die Pumpe kaputt. Klar RMA gab es...aber das Problem ging nicht weg...und ich habe die ganze Arbeit... Nach dem dritten mal hatte ich faxen dicke.
P.S: bei dem Bild auf Reddit sieht das Kabel ein wenig komisch verknickt aus, als hätte jemande fest daran gezogen :d
Ich vermute mal einfach Leute mit mehr Hirn. Mir ist schleierhaft, warum man genau die karte will (siehe CB review). Wenn's am Platz liegt würde ich lieber ein neues Case kaufen =)
Was genau war der Kritikpunkt von CB an der FE Karte? Hast Du mal einen Link für mich? Finde unter der Abkürzung nichts, und mir fällt grade nicht ein, für welche Tech Seite die stehen soll^^
Weil ich so nett war und hab den Link zum bestellen des Kabels direkt nach der Freischaltung hier gepostet.
War dann auch nach gefühlten 10 Minuten ausverkauft direkt aus dem BeQuiet Shop.
Lg
wie oft willst du das eigentlich noch wissen? :d
Ich glaube meine FE ist gestorben ... oder zumindest angeschlagen ;-)
Stromanschluss ist okay :ROFLMAO:
Sie zeigt plötzlich keinen Bios Splash mehr beim Hochfahren.
Ins Bios kommt man auch mit Bild nur der Splash fehlt.
Statt des Hersteller Logo's kommt jetzt das auch das Windows Logo.
Auch alles andere funktioniert.
O-Ton Nvidia Support: Für was brauchen Sie denn den Bios Splash? Ist der denn wichtig? ... TOP Support :ROFLMAO::ROFLMAO::ROFLMAO:
Damit klar ist was ich meine:
Wenn ich eine andere GraKa ins System stecke:
Motherboard und Windows ist ausgeschlossen nicht dran schuld ;-)
Jemand mit FE ähnliche Probleme? Oder nen Lösungsansatz?
Board CPU und RAM sind getauscht ... vielleicht ist das BQ-Kabel dran schuld? ;-)
Läuft die Stock bei Dir?
Andere Displayausgänge an der Karte probiert?
Übertaktet? Wie viel PL? Wie groß das Netzteil?
Alles Stock aktuell ;-) ... ja auch alle anderen Ausgänge versucht überall identisches verhalten.
Wenn ich den Bios Splash im Bios verlängere/verzögere, bleibt das Bild länger schwarz.
Hatte schon überlegt ob ich das Bios nochmal drüber Flashe ... aber bzgl. Garantie ne dumme Idee, solange das nicht als Anweisung von Nvidia kommt.
Kein OC kein PL alles Stock ... 1200Watt BQ
Windows clean!
Letzten Tests mit der Karte waren ohne OC nur UV ~0,875v ~ 2580MHz ~ PL80%
Windows clean!
Mies. Scheinst alles richtig gemacht zu haben, trotzdem kaputt.
Hast du das Kabel auch mal rausgezogen und die Pins begutachtet? Von außen sieht man den schaden meist nicht.
hab grad meine 3090 strix verkauft.. wehe jetzt geht hier irgendwas in rauch auf.. achso, 950€ bringt sowas..
tobi
Kabel gerade mal gegen das originale Nvidia Adapter Kabel getausch ... leider war es das nicht ...
In einen anderen PC einbauen!
Kann auch der PCI Slot oder sonst etwas sein.
Ist bereits passiert ganz anderes MB CPU und RAM und Windows
Leider identisches verhalten.
Wie gesagt andere GraKa rein "Problem" weg ... sonst aber alles OK mit der Karte.
Warum man dann verschiedene Boards und verschiedenen RAM nimmt check ich nicht...bitte um Aufklärung!
EDIT: "The goal of this review is NOT to test "5800X vs 5800X3D at similar config," but "The current GPU Test System that I have right now, a decent but slightly aged config, vs 5800X3D the way you would build it today" to find out how much of a difference an upgrade can bring."
Naja...
Ja eine Karte zuviel bestellt^^
Ja aber hier könnte man sagen dass das System mit dem 5800X eigentlich höher gespecct ist.
Die Unterschiede wären also minimal höher.
Derselbe hat hier seinen 5800X gegen den 12900k getestet:
Damit könnte man den 5800X3D gegen den 12900k vergleichen. Die sind beinahe gleich schnell, je nach Spiel.
Wobei ich persönlich sagen muss, mehr als 120FPS in 4k brauche ich nicht...wichtiger sind dafür mich dann die 1%low FPS.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
