[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
1 und 3 sowie 2 und 4 gehen nicht, da 1 und 2 mit PCI-E Kabel für die CPU verwendet wird.
@WolfJ13
Steht irgendwas im Ereignislog von Windows Anwendung/System?
Um nen Softwarefehler auszuschließen mal schnell n Image z.B mit Acronis gemacht und Windows neu installiert?
Bios Defaultsettings geladen?
Sowas geht bei BestBuy vielleicht in der USA aber hier bei Abzocker NBB die verkaufen doch die hälfte der FEs an „Freunde und Verwandte“
ODER verticken die selber dann auf ebay und Kleinanzeige!!! 😤
@WolfJ13
In dxdiag steht unter Anzeige folgender Fehler:
"Problem mit dem Microsoft Basic Display Adapter-Gerät. Suchen Sie nach "Grafikgerätetreiber – Fehlercode 31", um weitere Informationen zu erhalten."
Also BIOS default nützt auch nichts, Speedway crasht instant.
@scars:
Name der fehlerhaften Anwendung: 3DMarkSpeedWay.exe, Version: 1.0.4.2, Zeitstempel: 0x634e431f
Name des fehlerhaften Moduls: 3DMarkSpeedWay.exe, Version: 1.0.4.2, Zeitstempel: 0x634e431f
Ausnahmecode: 0xc0000409
Fehleroffset: 0x00000000003f7cad
ID des fehlerhaften Prozesses: 0x7b8
Startzeit der fehlerhaften Anwendung: 0x01d8f3bc66c5f9b6
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\Steam\steamapps\common\3DMark\dlc\speed-way-test\windows\bin\x64\3DMarkSpeedWay.exe
Pfad des fehlerhaften Moduls: C:\Program Files (x86)\Steam\steamapps\common\3DMark\dlc\speed-way-test\windows\bin\x64\3DMarkSpeedWay.exe
Berichtskennung: 4acad827-2317-4967-b760-e7a2f1a66ed8
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
Name der fehlerhaften Anwendung: AWCC.exe, Version: 5.5.23.0, Zeitstempel: 0x63613905
Name des fehlerhaften Moduls: KERNELBASE.dll, Version: 10.0.19041.2193, Zeitstempel: 0x7f7062e1
Ausnahmecode: 0xc000027b
Fehleroffset: 0x000000000010fdf2
ID des fehlerhaften Prozesses: 0x49d4
Startzeit der fehlerhaften Anwendung: 0x01d8f3bc2dc0fcef
Pfad der fehlerhaften Anwendung: C:\Program Files\WindowsApps\DellInc.AlienwareCommandCenter_5.5.23.0_x64__htrsf667h5kn2\AWCC.exe
Pfad des fehlerhaften Moduls: C:\Windows\System32\KERNELBASE.dll
Berichtskennung: 1148c15a-a0e7-4210-8bfc-0ad7f712bff6
Vollständiger Name des fehlerhaften Pakets: DellInc.AlienwareCommandCenter_5.5.23.0_x64__htrsf667h5kn2
Anwendungs-ID, die relativ zum fehlerhaften Paket ist: App
Beim Nvidia DLSS Feature Test, wenn ich DLSS 3 auswähle, kommt folgende Fehlermeldung:
"DLSS 3 Frame Generation requires a NVIDIA 40 series GPU and hardware-accelerated GPU scheduling to be enabled in Windows settings."
@scars:
Mach mal steam file check.
Bist du dir da sicher? Wird nicht eher der untere Steckplatz für die CPU verwendet und oben sind die PCI noch frei? Du hast doch das 1000W Platinum E11 oder ? Denn bei mir ist das so bei diesem Netzteil. Ich konnte das Kabel problemlos auf PCIe 1 und PCIe 3 anschließen.
Hier mal ein Foto:
File Check hat keinen Fehler gebracht.
Hier mal ein Foto:
Hab das Dark Power Pro 12 1.200 Watt
Irgendeine Alienware-Anwendung Crashed.
Warum installiert man sich das? Ist das wichtig?
Brauch ich nicht, hat sich wohl einfach mitinstalliert.
Treten die Fehler gleichzeitig auf oder sind das die zwei die du gefunden hast?
Sind die einzigen Fehler. Wie gesagt, alle Games RDR2, Cyberpunk etc. laufen einwandfrei.
Ansonsten installiere ich morgen Windows 11 ...
Kommt euch das nicht auch komisch vor? Es gibt Leute mit Adaptern, da schließt alles bündig ab und die berichten, dass sie keine Probleme beim anschließen hatten und auf der anderen Seite Leute wo es nicht ansatzweise so bündig aussieht wie auf Foto 1.
Hast du es schon mit etwas mehr Kraft probiert? Bei mir ging er auch relativ schwer rein.
3d Mark starten oder 3D Mark 64Bit force?
Hab zwar beides probiert, würde mich aber trotzdem mal interessieren.
Ok, aber trotzdem müssten die 5 PCIe noch frei sein. Und nur die P8 und die MB Steckplätze belegt sein. Und natürlich die Drivers. Bei den PCIe dürfte es fast egal sein welche du nimmst für das bequiet kabel. Scheinen alle genug Power zu haben.
Es funktioniert!! :)
Entweder war es die Deinstallation des Alienware Creepy Programms oder der Verify von 3D Mark bzw. File Check.
So, dann kann das Benchen und Ausloten von OC/UV losgehen. Ich freu mich.
Vielen Dank für die Unterstützung!!!
Random Shot
Interessant ist das natürlich Nachts auf dem Wall wenn es Regnet oder im Dorf Nachts wenn es Regnet. Worst Case. Aber ich hoffe es geht auch so.
Mal gucken, ob ich mit SMT „off“ und/oder mit 8 ph. Cores weniger noch was holen kann. Will nur ungerne auf was Kleines umsteigen
Dass die Schatten so hart an der CPU reißen, wusste ich nicht. (die 4090 ist bei mir teilweise nicht mal 60% ausgelastet 😳). Hab mit Kingdom Come auch erst seit paar Tagen Erfahrung. Das Game war für mich bisher uninteressant, da die 3090 nur sehr bescheiden damit klarkommt
Denke mal es hat sich rumgesprochen, dass man diese beiden Modelle sofern möglich meiden sollte, wenn man schon 2K investiert. Der Preis mit 300-400€ über UVP tut sein übriges
Was gibts gegen die Phantom zu sagen hatte die GS hier zum Testen und die war flüsterleise und hat on Stock gemütliche 2820 MHZ geschafft...natürlich zum OVP gekauft...8-)
Ja habe ich. Meine aktuelle Theorie: Wenn man ein Kabel/Adapter hat oder der Anschluss außerhalb der Toleranzgrenze liegt, ist es unmöglich ihn 100% richtig reinzustecken.
Ich bin der lebende Beweis und ihr habt es von mir zu erst gehört!
die lüfter rattern alle, das hält man nicht aus
Achja, wenn jemand den Adapter nutzt und 2 Daisychain Kabel, dann würde ich definitiv empfehlen in den mittleren 2 Steckern das lange Stück und in den beiden äußeren die 2 kurzen Kabel über kreuz einzustecken.
Falls der Adapter die 1-2-2-1 Pads hat, ist man so auf der sicheren Seite. Auch bei 3+3 Pad Version ist die Last besser verteilt, FALLS mal was schief geht...
Veranschaulicht: Kurz2-Lang1-Lang2-Kurz1
Danke @Stagefire .. Der Thread ist von mir lol
Ah nun da du mich drauf hingewiesen hast (y) ... is ja auch der selbe Nick bei dir wie im AVS ... hab da bei Reddit garnich auf den Nick geachtet aber ja dat warst du.
Absolut das passt auch absolut rein bezogen auf die wohl manchmal nicht existente Qualitätskontrolle der Adapter ... Wenn die Maße der Adapter nich genau stimmen und da noch zuviel Material drauf is
dann reibt sich das miteinander und man kommt dann nich komplett rein ... währe das was anderes wo kein Strom durchlaufen würde würde ich sagen versuchen abzuschleifen / ab zu feilen damits dann passt
aber bei diesem Heiklem Thema und wegen dem Bezug zu Strom sowie Garantie abwicklung sind einem da dann natürlich die Hände gebunden.
Für mich aber auch ein Valider Grund der für Probleme sorgen kann sowie vielleicht auch für den ein oder anderen verschmorten Adapter.
Puh, endlich läufts... heute kam meine Inno3D Ichill Frostbite... natürlich gleich eingebaut, mit drei Kabeln den 12VHPWR-Adapter mit dem Corsair HX850i verbunden, Wasser befüllt und endlich angeschaltet. Windows startet, und kurz nach dem Login gehen beide Monitore aus (no signal). Egal wie, Windows ließ sich nicht booten.
Einiges an Internetrecherche und Verzweiflung später: Scheinbar dieser tolle BIOS/VBios/Mainboard Bug... Idle P-States der Karte führen zum Absturz. Windows im abgesicherten Modus gestartet, per NVidiaInspector im Global Profil die Energieeinstellung auf Performance gesetzt, und jetzt läuft es... Dann heißt es jetzt wohl warten auf den Fix, wie auch immer der aussieht.
Ansonsten, geile Karte. Schön kühl, bei High-FPS etwas rasseln, aber kein Coilwhine. Adapter bleibt sehr kühl, ich meine die Kabel dahinter sind etwas wärmer, aber weit von handwarm entfernt. PUBG mit framecap zieht einfach mal 120-150W weniger als mit der RTX 3080 ti. Wenn ich drei Stunden täglich spiele, hab ich die Anschaffungskosten in 30 Jahren drin :fresse:
Neue Theorie: Die Boardpartner haben es mit dem Anschluss an der GPU nicht so genau genommen und bei einigen passen daher die Kabel/Adapter nicht 100%tig. Würde auch erklären, warum bis jetzt keine FE Karten betroffen sind.
Jupp auch das währe möglich und wie du schon sagst würde das die Sache mit der FE erklären warum die nich in der Liste auftaucht.. ergebe 3 Mögliche Scenerien die auch durchaus kombiniert auftretten könnten.
1. Schlampige Qualitätskontrolle der Adapter ( Beispiel : 4 Adapter die jeweils anders verlötet wurden .. wir haben ja bisher 4 Löt Versionen gesehen obwohl es ein in Serie gerfertigtes Produkt is was immer gleich sein sollte , gemischte Kabel sorten ( 150 und 300er ) , eventuell schon vorher lose verlötung weil zu heiss oder zu schlecht verlötet wurde und diese Plastik Lippe dadurch schon purös wurde sodass das die Lötung den Kontakt schnell verliert selbst bei leichter biegung oder schon lose verschickt wurde was man ja auf einem von den Bildern bei Igor sah )
2. Adapter Maße passen nich sodass keine korrekt Bündige Steckverbindung zu stande kommen kann ( Nutzer hört kein Klicken beim zusammennsteckenn )
3. Buchse Maße an der Karte passen nich sodass keine korrekt Bündige Steckverbindung zu stande kommen kann ( Nutzer hört kein Klicken beim zusammennsteckenn )
Aber natürlich sind da sicher auch so ein paar Fälle dabei wo dann auch wirklich der Nutzer nen fehler gemacht hat und zu stark oder zu früh gebogen hat sowie sicherlich 1 - 2 Fälle wo jemand Mutwillig
den Adapter angekokelt hat damit die Liste länger wird
Danke euch für die Rückmeldungen.
Ich bin so hin und hergerissen. Hatte jetzt ne Strix, TUF non OC, die FE und grad die Inno3D iChill Black drin.. Die ersten 2 waren ne Katastrophe, mit der FE wäre ich zufrieden wenn der penetrante Lüfter nicht wäre, die Inno3D ist bisher richtig gut. 450W max wären auch egal da ich eh UV betreibe. Aber selbst damit habe ich fast die gleichen Scores wie die FE in den Benchmarks mit OC, die auf 550W hochgeht. Ist auch die erste die in RDR2 mit 0,9V und 2600MHz stable ist. Bei allen anderen schmiert das Spiel nach max. 5 Min ab. Auch Coilwhine ist hier kein Thema.
Ich hab halt bei der Inno irgendwie das Gefühl ich hab nen Chinaböller im Tower, auf dem ich, falls was ist, sitzen bleib. Machen die wirklich faxen falls was ist? Ich mein, wir sprechen von über 2k €
Konnte leider dein Vid nicht sehen/hören aber dann verkauf doch die FE einfach. Die wird einem doch aus der Hand gerissen.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
