[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
steht kein NVIDIA auf dem Adapter drauf, gehe davon aus das es NICHT der Original Adapter ist.
NVIDIA lässt sich das bestimmt nur einfach aufdrucken. Ich mach mich mal schlau :)
Top! Danke
Top! Danke
dasist ne andere frage:) du hattest nach orignal nvidia adapter gefragt, und da steht kein nvidia drauf :)
der sieht zumindest schonmal besser aus :) "NVIDIA" ist druf ^^
Die Bestellung bei LDLC hat ihren Reiz.
Zu nem fairen Preis ordern und einfach Abwarten bis geliefert wird.
Kein Streß mehr mit Bots und nicht durchgegangenen Zahlungen.
Rückgaberecht ist wie bei uns 14Tage sollte wirklich was sein.
Wo ist denn der Unterschied zu Deutschland? Da sind doch auch alle 'Sold Out' ?
Leider sollen ja die bequiet Netzteile als ATX 3.0 erst nächstes Jahr kommen
Habe mir deshalb gestern das be quiet! Straight Power 11 Platinum mit 1.000W bestellt. Gab/gibt es zu einem guten Preis bei MF. Und bei Reichelt habe ich mir am Montag das be quiet! Adapterkabel (12VHPWR)
geholt. Meiner Meinung nach kann man so auch auf ATX 3.0 verzichten. Und die Netzteile mit dem neuen ATX-Standard werden am Anfang sicherlich deutlich mehr kosten als welche mit ATX 2.4 oder ATX 2.51 vergleichbarer Leistung.
Persönlich habe ich bei be quiet! den Vorteil, dass ich meine Verkabelung im Gehäuse nur geringfügig ändern muss, weil ich bereits ein Straight Power 11 besitze. Muss quasi nur "umstöpseln".
Auf Aliexpress nehmen die doch einfach irgendwelche Bilder die ähnlich sind...
Dann hättest du dir auch nur das Adapterkabel holen können ;)
Mein 700W Bequiet Netzteil läuft auch perfekt mit der 4090 ;)
Wollte eigentlich auch erst nur undervolten, aber was soll`s. Hauptsache Spaß... 🙈
@Stagefire also ist das Problem, dass einige Stecker nicht ganz passen und durch die geringere Kontaktfläche die Temperatur steigt?
Ich tendiere auch zu dieser Lösung, Adapter bei reichelt schon bestellt und dann das straight platinum 1000w und gut ist. Das thermaltake atx 3.0 wird dann storniert
Moin,
wie sicher ist es denn dass x% der Adapter/Stecker "schmelzen" und wie sicher ist es dass andere Adapter das nicht tun?
Aktuell scheint mir es mit den original Adapter wie auch mit den Netzteil eigenen Stecker zu passieren. Kurz: also mit allen Steckern.
Gibt es dazu schon einen abgeschlossenen Bericht der das Problem komplett geklärt oder gar gelöst hat oder ist da noch viel Glaube und Hoffnung im Spiel?
Moin,
Liegt zwischen 0,0001% - 99,7856%.
Hat mir der Schwager meiner Tante dritten Grades erzählt, der hat mal einen Nvidia Mitarbeiter gesehen, im Dunkeln.
Zuverlässiger wird’s zur Zeit leider nicht.
@BlueFireXD
Schmelzen: < 1%
Nicht schmelzen: > 99%
Moin,
nach einiger Zeit ist nun meine Inno 3D Frostbite inkl vorinstalliertem Wasserkühler angekommen.
Am WE hab ich umgebaut, eine kurze Zusammenfassung :
- sehr schöne Karte, wertig und hübsch anzusehen
- Einbau problemlos, der 3x8 Pin Adapter ließ sich bei mir leicht und gängig installieren, keine großen Knickradien, EvolveX Gehäuse
- Spulenfiepen / rasseln habe ich keines wahrnehmen können, kein Vergleich zu meinen 3090ern, Netzteil Enermaxtytan 1050 Watt.
- Out of the Box 2790MHz Boost, mit 0,925Volt Curve 2700MHz, max 330 Watt. In vielen Games unter 250 Watt.
- Habe mit 48 Zoll OLED 120Hz Schirm alles mit FPS Limit 116FPS eingestellt.
- Max Temp 45 Grad auf der GPU, Speicher sehr erfreulich ähnlich niedrig.
Dies ist die erste Kartengeneartion die es möglich macht mit UV am Framelimit zu sein, das ist wikrlich ein großer Wurf.
Bin sehr zufrieden.
Keine Standby nach Monitorwechsel
hat jemand auch das Problem.
Wenn ich mal vom Monitor auf TV switche fährt der Rechner nicht mehr in den Standbymodus.
Der Bildschirm geht zwar aus aber der Rechner bleibt an.
Klicke ich dann ein paar mal die Maus ist der Desktop wieder da.
Dann hilft nur ein neustart damit Energies paren (n icht Hibernate) wieder funktioniert.
Fiep,fiep,fiep ... ich habe dich lieb. o_O
Nein, die war in Ordnung, das war meine, habe ich letzte Woche zurückgeschickt, weil ich eine Founders bekommen habe. Ich hatte sogar 2499 bezahlt. Die Karte habe ich allerdings nicht ausführlichst getestet oder gestresst (nur FS2020 in 5k probiert), insofern nehmt es nicht als Garantie, dass in einem anderen Szenario nicht doch irgendwas ist. Achso, die Verpackung ist zumindest meinerseits NICHT beschädigt worden, natürlich habe ich das Klebesiegel der Grafikkarte und des Stromadapters öffnen müssen
So, heute kam ich endlich mal dazu meine Gigabyte Gaming OC einzubauen. Das Torrent half beim vorschriftsmäßigen Biegen des Adapterkabels (brauche ich zumindest übergangsweise).
Kein Taktwunder, macht "nur" 2730 MHz bei der 450W Konfiguration, ABER: kein Spulenfiepen. Nix. Zumindest nicht in dem Bereich den man üblicherweise nutzt. Die Lüfter gehen für mich voll in Ordnung, da hilft bestimmt auch das gut durchlüftete Case die unten zu halten.
Das Ding behalte ich definitiv, kein Vergleich zur TUF die ich ganz am Anfang hatte. SO hab ich mir das vorgestellt! Gleich mal Anti-Schmelz Garantie einreichen (ihr wisst ja, alles was versichert ist tritt nicht ein) und dann noch die Cashback Bewertung. Ich bin rundum zufrieden!
Ähnliche Themen
Antworten
6K
Aufrufe
381K
