[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe den Anschluss jetzt genutzt aber scheinbar bringt der nichts bei meiner 4090. Laut GPU-Z werden wie beim alten Board nur ein paar Watt über PCIe gezogen.
Es bringt soweit etwas, dass die Masse der GPU besser abgeleitet werden kann, wenn du alle CPU-Kabel anschliesst.
Denn es läuft zwar kaum +Spannung über die PCIe-Slots, dafür dummerweise viel zu viel -Spannung.
Dies kann man mit einem Zangenamperemeter deutlich sehen, wenn man die Ströme am GPU-Versorgungskabel misst. Da fliesst weniger Strom zurück zum NT als von diesem zur GPU geht. Also muss der fehlende Strom wo anders fliessen, und das ist dann am PCIe-Slot.
Sooo, KCD2 ist durch und es war eine sehr tolle Zeit mit dem Game, meine 4090 wurde hier auch gut genutzt und wurde stets gebraucht.
Aber ein kleines aber:
Ich fand es absolut bekloppt das ich ab 40% des Games die beste Rüstung, die beste Waffe und überhaupt schon das beste von allem hatte, dies hat mir teils doch irgendwo die Motivation geraubt, selten dämliche Entscheidung vom Entwickler….
Hab KCD2 noch nicht…
Aber beim 1er war das auch so. Man hat quasi „alles“ und dann war die Luft raus
btw:
Am Spannendsten fand ich nachts in Häuser einzubrechen und geiles Zeug zu rauben :)
Glaube auch über die Slot-Blende ;)
Ähnliche Themen
