varg86
Experte
- Ort
- Meckenheim
- Desktop System
- Nobara-PC
- Laptop
- Thinkpad x1 Gen7 Nobara
- Ryzen 5600x
- MSI B450I GAMING PLUS AC
- Thermalright Macho HR-02
- 16Gb
- Sapphire 7900GRE
- Xiaomi Mi Curved Gaming Monitor 34"144hz
- 1TB Samsung 870
- Soundkarte
- Sound blaster play 3
- Corsaid 2000D
- Mouse
- Razer Deathadder
- Linux - Nobara 40 - Fedora
- Webbrowser
- Brave
- Internet
- ▼250
Hello,
ich baue gerade nen Dan A4 zusammen und benötige das Netzteil Bracket von Thingiverse da die Pumpe und der Pumpenaufsatz recht spack sitzen.
www.thingiverse.com
This is a custom PSU bracket designed to raise the Dan A4 V4 PSU mounting points up about 5mm. This provides additional room for the cabling with use with a 92mm AIO (such as the 545LC or 645LT) and can also just be used to grant additional working room/airflow within the case.
The bracket walls are optimized for use with a 0.4 nozzle. I've had the most success with a layer height of 0.15 but I used 0.2-0.3 for all prototypes (for a quicker print). Infill should probably be at least 30% but I just printed at 100% for the most strength.
I will be uploading another version with larger holes for use with brass threaded inserts as well.
wäre super wenn mir das jemand drucken kann.
Online habe ich schon geschaut, aber meist ist das unter dem MBW und sonst benötige ich auch nichts.
Muss nix fancy sein, farbe egal,Hauptsache stabil genug für das Netzteil.
Hoffe es erbarmt sich jemand , vielen Dank im Vorraus.
Dan A4 PSU Bracket by LoserCard
This model is outdated. The latest upgraded version is posted here: http://www.thingiverse.com/thing:3763705This is a custom PSU bracket designed to raise the Dan A4 V4 PSU mounting points up about 5mm. This provides additional room for the cabling with use with a 92mm AIO (such as the 545LC or...
