hallo leute ich habe ein komplett pc hiermal die daten...
und nu wollte ich fragen ob sich das sohnt das Abit AN7 zu holen
habe ne Radeon 9800 XT & 1 GB DDR400 PC3200 DualChannel Speicher
Abit AN7
NVIDIA nForce2 Based AMD K7 Mainboard
FSB400, Dual DDR400, SATA RAID, IEEE1394
ABIT μGuru Technologie
SiSoftware Sandra
System
Manufacturer : HPPAV
Model : MS-7027
Mainboard
Manufacturer : MICRO-STAR INTERNATIONAL CO., LTD
MP Support : 1 CPU(s)
MPS Version : 1.40
Model : MS-7027
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 3GB
Bank0/1 - A0 : None None None None DIMM 512MB
Bank2/3 - A1 : None None None None DIMM 512MB
Bank4/5 - A2 : Empty
Chipset 1
Model : VIA Technologies Inc VT8377 Apollo KT400/A/600 CPU to PCI Bridge
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
Front Side Bus Speed : 2x 199MHz (398MHz data rate)
Maximum FSB Speed / Max Memory Speed : 2x 200MHz / 2x 200MHz
Width : 64-bit
IO Queue Depth : 4 request(s)
Chipset 1 Hub Interface
Type : V-Link
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Speed : 8x 66MHz (528MHz data rate)
IO Queue Depth : 9 request(s)
Logical/Chipset 1 Memory Banks
Bank 0 : 256MB DDR-SDRAM 2.5-3-3-7CL 2CMD
Bank 1 : 256MB DDR-SDRAM 2.5-3-3-7CL 2CMD
Bank 2 : 256MB DDR-SDRAM 2.5-3-3-7CL 2CMD
Bank 3 : 256MB DDR-SDRAM 2.5-3-3-7CL 2CMD
Bank Interleave : 4-way
Multiplier : 1/1x
Width : 64-bit
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 0.03
Speed : 16MHz
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module(s)
Memory Module 1 : Y380032JD-32510-93022602 51046732119 512MB 16x(32Mx8) DDR-SDRAM PC3200U-2544-600 (CL2.5 up to 200MHz)
Memory Module 2 : Y380032JD-32510-93022602 51046732119 512MB 16x(32Mx8) DDR-SDRAM PC3200U-2544-600 (CL2.5 up to 200MHz)
Environment Monitor 1
Model : Winbond W83697HF ISA
Version : 6.00
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 24.0°C / 75.2°F
CPU Temperature : 47.5°C / 117.5°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 4116rpm
Voltage Sensor(s)
CPU Voltage : 1.63V
+3.3V Voltage : 3.36V
+5V Voltage : 5.08V
+12V Voltage : 12.34V
-12V Voltage : -12.36V
-5V Voltage : -5.20V
Standby Voltage : 5.02V
Battery Voltage : 3.66V
AGP Bus(es) on Hub 1
Version : 3.05
Multiplier : 1/2x
Fast-Writes Enabled : No
Isochronous Mode Enabled : No
Addressing Enabled : 32-bit
Aperture Size : 256MB
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (33MHz)
Multiplier : 1/6x
LPC Hub Controller 1
Model : VIA Technologies Inc VT8237 PCI to ISA Bridge
ACPI Power Management Enabled : Yes
Multiplier : 1/4x
Speed : 8MHz
DMA Multiplier : 1/2x
DMA Speed : 4MHz
USB Controller 1
Model : VIA Technologies Inc VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : VIA Technologies Inc VT6202 USB 2.0 Enhanced Host Controller
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 8
Companion Controllers : 4
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 32-bit
FireWire/1394 Controller 1
Model : Creative Labs Audigy 2 Firewire Controller
Version : 1.10
Interface : OHCI
Enhanced Support : No
Channels : 64
Speed : 400MHz
FireWire/1394 Controller 2
Model : Micro-Star International Co Ltd (MSI) VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
Version : 1.00
Interface : OHCI
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : VIA VT823x SMBus
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
Speed : 16kHz
Expansion Slot(s)
PCI0 (1h) : PCI 32-bit +5V PME Full-Length Available (VIA Technologies Inc ProSavageDDR P4X600 CPU to AGP Bridge)
PCI1 (2h) : PCI 32-bit +5V PME Full-Length Available
PCI2 (3h) : PCI 32-bit +5V PME Full-Length Used
PCI3 (4h) : PCI 32-bit +5V PME Full-Length Available
AGP (8h) : AGP 32-bit +5V Full-Length Available (ATI Technologies Radeon 9800 XT (R350))
Port Connector
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB-25 pin female / DB-25 pin female
Keyboard : Keyboard - PS/2 / PS/2
PS/2 Mouse : Mouse - PS/2 / PS/2
USB0 : USB - None / None
AUDIO : Audio - None / None
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 2545 : Large memory modules should be Registered/Buffered.
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Abit AN7
SiSoftware Sandra
System
Model : MS-7027
Mainboard
MPS Version : 1.40
Model : MS-7027
Chipset 1
Width : 64-bit
Type : V-Link
Width : 8-bit
Full Duplex : Yes
Multiplier : 1/1x
Multiplier : 1/1x
Width : 64-bit
APIC 1
Version : 0.03
Speed : 16MHz
Multiplier : 1/2x
Memory Module(s)
Version : 6.00
Cooling Device(s)
Voltage Sensor(s)
CPU Voltage : 1.63V
+5V Voltage : 5.08V
Version : 3.05
Multiplier : 1/2x
Version : 2.10
Multiplier : 1/6x
Multiplier : 1/4x
Speed : 8MHz
DMA Speed : 4MHz
USB Controller 1
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Version : 2.00
Interface : EHCI
Channels : 8
Version : 1.10
Interface : OHCI
Channels : 64
Speed : 400MHz
Version : 1.00
Interface : OHCI
Channels : 64
Speed : 400MHz
PEC Support : No
Speed : 16kHz
Expansion Slot(s)
Port Connector
Performance Tips
