[Sammelthread] Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac
  • Ersteller Gelöschtes Mitglied 189576
  • Erstellt am
Sammelthread Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac​
die beiden Mini-ITX AM4 von Asrock
Inhaltsverzeichnis:
  • Technische Daten
  • Preisvergleich
  • Fragen / Antworten
  • RAM Kompatibilität
  • Berichte & Reviews
  • aktuelle BIOS Versionen
Technische Daten
AB350 Gaming-ITX:
Code:
[table="width: 500"]
[tr]
	[td]Gaming Armor[/td]
	[td]Power
- Hi-Density Power Connector (8 pin)
Memory
- 15μ Gold Contact in DIMM Slots
VGA Card
- 15μ Gold Contact in VGA PCIe Slot (PCIE1)
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
- Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]Unique Feature[/td]
	[td]ASRock Super Alloy
- Premium Power Choke
- Dual-N MOSFET
- Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
- Matte Black PCB
- High Density Glass Fabric PCB
- 2oz Copper PCB
Intel® 802.11ac WiFi
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop[/td]
[/tr]
[tr]
	[td]CPU[/td]
	[td]- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
- Digi Power design
- 8 Power Phase design
- Supports 95W Water Cooling[/td]
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory B350[/td]
[/tr]
[tr]
	[td]Memory[/td]
	[td]- Dual Channel DDR4 Memory Technology
- 2 x DDR4 DIMM Slots
- AMD Ryzen series CPUs support DDR4 3466+(OC) / 3200(OC) / 2933(OC) / 2667 / 2400 / 2133 ECC & non-ECC, un-buffered memory*
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
- Max. capacity of system memory: 32GB**
- 15μ Gold Contact in DIMM Slots[/td]
[/tr]
[tr]
	[td]BIOS[/td]
	[td]- 128Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 5.1 compliance wake up events
- Supports jumperfree
- SMBIOS 2.3 support
- CPU, DRAM, PCH 1.05V, PROM 2.5V, Voltage Multi-adjustment[/td]
[/tr]
[tr]
	[td]Graphics[/td]
	[td]- Integrated AMD Radeon™ R-Series Graphics in A-series APU*
- DirectX 12, Pixel Shader 5.0
- Max. shared memory 2GB
- Supports 2 x HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Ports (Compliant HDMI monitor is required)
- Supports HDCP with HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with HDMI Ports[/td]
[/tr]
[tr]
	[td]Audio[/td]
	[td]- 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
- Premium Blu-ray Audio support
- Supports Surge Protection
- Nichicon Fine Gold Series Audio Caps
- 120dB SNR DAC with Differential Amplifier
- Pure Power-In
- Direct Drive Technology
- PCB Isolate Shielding
- Impedance Sensing on Line Out port
- Individual PCB Layers for R/L Audio Channel
- Gold Audio Jacks
- Supports Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]LAN[/td]
	[td]- Gigabit LAN 10/100/1000 Mb/s
- GigaLAN Intel® I211AT
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE[/td]
[/tr]
[tr]
	[td]Wireless LAN[/td]
	[td]- Intel® 802.11ac WiFi Module (Free Bundle)
- Supports IEEE 802.11a/b/g/n/ac
- Supports Dual-Band (2.4/5 GHz)
- Supports high speed wireless connections up to 433Mbps
- Supports Bluetooth 4.2 / 3.0 + High speed class II[/td]
[/tr]
[tr]
	[td]Slots[/td]
	[td]AMD Ryzen series CPUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x16 mode)*
AMD 7th A-Series APUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x8 mode)*
- 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
*Supports NVMe SSD as boot disks[/td]
[/tr]
[tr]
	[td]Storage[/td]
	[td]- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket, supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
[/tr]
[tr]
	[td]Connector[/td]
	[td]- 1 x LPC Header
- 1 x AMD Fan LED Header
- 1 x CPU Fan Connector (4-pin)*
- 1 x Chassis Fan Connector (4-pin)
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*
- 1 x 24 pin ATX Power Connector
- 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
- 1 x Front Panel Audio Connector
- 1 x AMD LED Fan USB Header
- 1 x USB 2.0 Header (Supports 2 USB 2.0 ports) (Supports ESD Protection)
- 1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection)
*The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
**The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
CHA_FAN1/W_PUMP can auto detect if 3-pin or 4-pin fan is in use.[/td]
[/tr]
[tr]
	[td]Rear Panel I/O[/td]
	[td]- 2 x Antenna Ports
- 1 x PS/2 Mouse/Keyboard Port
- 2 x HDMI Ports
- 1 x Optical SPDIF Out Port
- 2 x USB 2.0 Ports (Supports ESD Protection)*
- 1 x USB 3.0 Type-A Port (Supports ESD Protection)
- 1 x USB 3.0 Type-C Port (Supports ESD Protection)
- 2 x USB 3.0 Ports (Supports ESD Protection)
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)[/td]
[/tr]
[tr]
	[td]Software and UEFI[/td]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN*
UEFI
- ASRock Full HD UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock Easy RAID Installer[/td]
[/tr]
[tr]
	[td]Support CD[/td]
	[td]- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar[/td]
[/tr]
[tr]
	[td]Accessories[/td]
	[td]- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
- 2 x ASRock WiFi 2.4/5 GHz Antennas
- 1 x Screw for M.2 Socket[/td]
[/tr]
[tr]
	[td]Hardware Monitor[/td]
	[td]- Temperature Sensing: CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Tachometer: CPU, Chassis, Chassis Optional/Water Pump Fans
- Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Multi-Speed Control: CPU, Chassis, Chassis Optional/Water Pump Fans
- Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore[/td]
[/tr]
[tr]
	[td]Form Factor[/td]
	[td]- Mini-ITX Form Factor: 6.7-in x 6.7-in, 17.0 cm x 17.0 cm
- 2oz Copper PCB[/td]
[/tr]
[tr]
	[td]OS[/td]
	[td]- Microsoft® Windows® 10 64-bit
* For the updated Windows® 10 driver, please visit ASRock's website for details: http://www.asrock.com
[/td]
[/tr]
[tr]
	[td]Certifications[/td]
	[td]- FCC, CE
- ErP/EuP ready (ErP/EuP ready power supply is required)[/td]
[/tr]
[/table]
X370 Gaming-ITX
Code:
[tr]
	[td]Power
Memory
VGA Card
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
[/tr]
[tr]
- Dual-N MOSFET
- Matte Black PCB
- 2oz Copper PCB
ASRock Steel Slots
[/tr]
[tr]
	[td]CPU[/td]
- Digi Power design
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory X370[/td]
[/tr]
[tr]
	[td]Memory[/td]
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory**
[/tr]
[tr]
	[td]BIOS[/td]
[/tr]
[tr]
	[td]Graphics[/td]
[/tr]
[tr]
	[td]Audio[/td]
- Pure Power-In
- Gold Audio Jacks
[/tr]
[tr]
	[td]LAN[/td]
- Supports PXE[/td]
[/tr]
[tr]
- Supports high speed wireless connections up to 867Mbps
- 2 antennas to support 2 (Transmit) x 2 (Receive) diversity technology
[/tr]
[tr]
	[td]Slots[/td]
[/tr]
[tr]
	[td]Storage[/td]
[/tr]
[tr]
	[td]Connector[/td]
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)**
[/tr]
[tr]
- 2 x HDMI Ports
[/tr]
[tr]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock XFast LAN*
UEFI
[/tr]
[tr]
	[td]Support CD[/td]
[/tr]
[tr]
- 1 x ASRock WiFi 2.4/5 GHz Antenna
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
	[td]OS[/td]
[/td]
[/tr]
[tr]
	[td]- FCC, CE
[/tr]
[/table]
Preisvergleich
AB350 Gaming-ITX/ac: ASRock Fatal1ty AB350 Gaming-ITX/ac Preisvergleich geizhals.eu EU
X370 Gaming-ITX/ac: ASRock Fatal1ty X370 Gaming-ITX/ac Preisvergleich geizhals.eu EU
Fragen und Antworten:
  • Was ist der Unterschied zwischen dem AB350 und X370?
    Da ein ITX Board nicht die kompletten Vorteile von X370 nützen kann, unterscheiden sich die beiden nur gering. Das X370 hat schnelleres WLAN und erlaubt PCIe Bifurcation
    edit 17.8.2017: Die beiden haben nun doch andere VRM Komponenten, wie br0da herausgefunden hat:
    FDPC5030 = AB350; SM7341EH = X370
    ASRocks X370 und B350 mini-ITX unterscheidet doch mehr, als der Kühlkörper (anfangs): VRM on the new AM4 motherboards - Page 251
    Die FETs im Vergleich:
    RDS(on) max​
    Rise + Fall Time
    FDPC5030Q1:
    5.0 mOhm @ VGS = 10 V @ ID = 17A
    6.5 mOhm @ VGS = 4.5V @ ID = 14 A
    Q2:
    2.4 mOhm @ VGS = 10V @ ID = 25 A
    3.0 mOhm @ VGS = 4.5V @ ID = 22 A
    Q1: 20ns
    Q2: 20ns
    SM7341EHQ1:
    3.9mOhm @ VGS = 10V @ ID = 24A
    6.5mOhm @ VGS = 4.5V @ ID = 24A
    Q2:
    1.2mOhm @ VGS =10V @ ID = 24A
    2mOhm @ VGS =4.5V @ ID = 24A
    Q1: 18.6ns
    Q2: 39ns
  • Wie unterschieden sich die VRM Kühler?
    alt: https://abload.de/img/img_15572ssdc.jpg
    neu: https://abload.de/img/fullsizerenderfaujg.jpg
  • Ich habe noch den alten VRM-Kühler, was kann ich tun?
    Schreibt den Asrock Support an! Der Support will danach noch eine Rechnung und die Seriennummer vom Board.
    ASRock > Support Request Form
  • Welchen RAM habt ihr getestet?
    Dazu habe ich ein 16GB Trident Z 3200MHz CL14 Kit. F4-3200C14D-16GTZ
    Mit den XMP Profil konnte ich den Ram nicht starten. Wenn ich jedoch die Spannung auf 1.4V erhöhe, die command rate auf 1T setze, Geardown Mode und BankGroupSwap deaktiviere, dann läuft er und es gab nach 2 Stunden Memtest64 keine Fehler.
    Als RAM habe ich Kingston KVR21E15D8K2/16I
    Corsair CMK16GX4M2A2400C14 funktioniert ebenfalls einwandfrei, ist direkt mit 2400Mhz gestartet.
    Aber ne kleine Info, ich habe diesen RAM hier beim Kollegen auf einen AB350 am Laufen:
    GWW416GB3000C15DC
    Dieser hat Samsung D-Die und ist Dualranked. Er läuft auf 3000Mhz mit 15-17-17-35 bei 1,35v, das läuft tadellos. Haben gestern was probiert und sind am Ende bei 1,35v auf 3200mhz bei 17-19-19-38 gekommen. Dualranked sollte er so schnell sein wie 3400-3500er Singlerank.
RAM Kompatibilität
Asrock gibt folgenden Arbeitsspeicher auf der Homepage an (Update 7.10.2017; 27 neue Einträge):
Code:
DDR4	3000	4GB	ADATA	KM4B4GX2A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	2800	16GB	ADATA	AX4U2800316G16			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-SRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400316G16-BBF			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BBZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRD			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRZ			DS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SRZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRZ	ADATA		DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SBF			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BWZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRD			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRZ			DS		2pcs
DDR4	2133	8GB	ADATA	AD4E2133W8G15-BHYA (ECC)			SS		2pcs
DDR4	2400	8GB	Apacer	AU08GGB24CEYBGC			SS		2pcs
DDR4	2133	8GB	Apacer	78.C1GM3.AF10B	Hynix		DS		2pcs
DDR4	3000	8GB	Avexir	AVD4UZ130001608G-4BZ1RR			SS		2pcs	v
DDR4	2400	8GB	Avexir	AVD4UZ124001608G-1COR			SS		2pcs
DDR4	2400	4GB	Avexir	AVD4UZ124001604G-1COB			SS		2pcs
DDR4	3000	8GB	Corsair	CMD32GX4M4B3000C15 (Hynix-M)			SS		2pcs	v
DDR4	2800	8GB	Corsair	CMK32GX4M4A2800C16			DS		2pcs
DDR4	2800	8GB	Corsair	CMD32GX4M4A2800C16			DS		2pcs
DDR4	2800	4GB	Corsair	CMD16GX4M4A2800C16			SS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C15 ver4.23			DS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16 ver 5.30			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C15			SS		2pcs
DDR4	2666	4GB	Corsair	CMK16GX4M4A2666C16			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C16			SS		2pcs
DDR4	2400	8GB	Corsair	CMK32GX4M2A2400C14			SS		2pcs
DDR4	2133	4GB	Corsair	CMV4GX4M1A2133C15			SS		2pcs
DDR4	2666	8GB	Crucial	BLT8G4D26AFTA.16FAD			SS		2pcs
DDR4	2666	4GB	Crucial	BLE4G4D26AFEA.8FAD			SS		2pcs
DDR4	2400	8GB	Crucial	CT8G4WFD824A.18FB1 (ECC)			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFS8213.8FB1			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.16FA2			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.C16FAD11			SS		2pcs
DDR4	2133	4GB	Crucial	CT4G4DFS8213.8FA1			SS		2pcs
DDR4	2133	16GB	Crucial	CT16G4DFD8213.16FB1			SS		2pcs
DDR4	3066	8GB	G.Skill	F4-4133C19D-16GTZKWC			SS		2pcs	v
DDR4	3066	8GB	G.Skill	F4-4000C18D-16GTZR			SS		2pcs	v
DDR4	3000	4GB	G.Skill	F4-3000C15Q-16GRR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3200C16D-16GTZB			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-4266C19D-16GTZR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3466C16D-16GTZSK			SS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3333C16D-32GTZSK			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C14D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3866C18D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C15D-32GTZR			DS		2pcs	v
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFT			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GBTZR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFX			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFX			SS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFT			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFT			DS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFT			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFXR			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFXR			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFT			SS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFX			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFT			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFXR			DS		2pcs
DDR4	2400	4GB	Geil	GWB48GB2400C14DC			SS		2pcs
DDR4	2133	8GB	Geil	GP48GB2133C15SC			SS		2pcs
DDR4	2666	8GB	HyperX	HX426C15FB/8			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13SB2K4/32			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3/8	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3/16	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K4/64	Hynix M-die		DS		2pcs
DDR4	2400	8GB	HyperX	HX424C15FB2K4/32			SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3/8	Hynix M-die		SS		2pcs
DDR4	2400	4GB	HyperX	HX424C15FBK4/16			SS		2pcs
DDR4	2400	16GB	HyperX	HX424C15FBK4/64			DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3/16	Hynix M-die		DS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB2K4/32			SS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB/8			DS		2pcs
DDR4	2400	8GB	J&A	JAD4U24001608-8M			SS		2pcs
DDR4	2400	4GB	J&A	JAD4U24001608-4M			SS		2pcs
DDR4	2133	4GB	J&A	JAD4U21331508-4M			SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron D-die		SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron H-die		SS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron D-die		DS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron H-die		DS		2pcs
DDR4	2400	8GB	Kingston	KVR24N17S8/8			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FBK4/32			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FB2/8			SS		2pcs
DDR4	2400	4GB	Kingston	KVR24N17S8/4	Micron		SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15S8/8			SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15D8/8			DS		2pcs
DDR4	2133	4GB	Kingston	KVR21N15S8/4			SS		2pcs
DDR4	2133	16GB	Kingston	KVR21N15D8/16			DS		2pcs
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMZ			SS		2pcs	v
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMB			SS		2pcs	v
DDR4	3000	4GB	KLEVV	IM44GU48A30-GIIHMC			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX1A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4B4GX1A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX2A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	2666	8GB	KLEVV	KM4Z8GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	8GB	KLEVV	KM4Z8GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X1N-2666-15-15-15-35-0			DS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X2N-2666-15-15-15-35-0			DS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X2N-2400-15-15-15-35-0			DS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X1N-2400-15-15-15-35-0			DS		2pcs
DDR4	2133	8GB	KLEVV	IMA41GU6MFR8N-TF1			SS		2pcs
DDR4	3000	8GB	Neo Forza	NFMUD480E8-3000DH2A			SS		2pcs
DDR4	2800	4GB	Panram	PUD42800C164G4NJW			SS		2pcs
DDR4	2666	8GB	Panram	W4U2666PS-8G			SS		2pcs
DDR4	2666	16GB	Panram	W4U2666PS-16G			DS		2pcs
DDR4	2400	8GB	Panram	PUD42400C158G4NJW			DS		2pcs
DDR4	2400	8GB	Panram	W4U2400PS-8G			SS		2pcs
DDR4	2133	8GB	Panram	W4U2133PS-8G			SS		2pcs
DDR4	3333	8GB	Patriot	PV416G340C6K (11BF2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G340C6K (11E2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G360C7K (11E1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G360C7K (11BF1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G320C6K (11BF2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11EC2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11D1)	Samsung 11D1		SS		2pcs	v
DDR4	3000	4GB	Patriot	PV48G300C6K (14M1)			SS		2pcs	v
DDR4	2933	8GB	Patriot	PV416G300C6K (11BF2)			SS		2pcs	v
DDR4	2933	4GB	Patriot	PV48G300C6K (11EC2)			SS		2pcs	v
DDR4	2400	8GB	Patriot	PSD48G240081			SS		2pcs
DDR4	2400	8GB	Patriot	PVE416G240C5KRD (11BF2)			SS		2pcs
DDR4	2400	4GB	Patriot	PSD44G240081			SS		2pcs
DDR4	2400	4GB	Patriot	PVE48G240C5KRD (11EC2)			SS		2pcs
DDR4	2400	16GB	Patriot	PSD416G24002			DS		2pcs
DDR4	2133	8GB	Patriot	PSD48G21332			SS		2pcs
DDR4	2133	4GB	Patriot	PSD44G213381			SS		2pcs
DDR4	2400	4GB	Samsung	M378A5244CB0-CRC			SS		2pcs
DDR4	2133	8GB	Samsung	M378A5143DB0-CPB			SS		2pcs
DDR4	2133	8GB	Samsung	M391A1G43EB1-CPBQ (ECC)			SS		2pcs
DDR4	2133	4GB	Samsung	M378A5143EB1-CPB			SS		2pcs
DDR4	2133	4GB	Samsung	M378A1G43DB0-CPB			SS		2pcs
DDR4	2133	8GB	Silicon Power	SP008GBLFU213N01			SS		2pcs
DDR4	2666	8GB	Team	TFWD48G2666C15BBK			SS		2pcs
DDR4	2400	8GB	Team	TED48G2400C16BK			SS		2pcs
DDR4	2400	4GB	Team	TED44G2400C16BK			SS		2pcs
DDR4	2133	8GB	Transcend	TS1GLH64V1H			DS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3SP-24MSPGNGFY7B			SS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3CP-241MCALGFY7J1			SS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7B			DS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7J1			DS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42131024			SS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42133512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD421333512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD42133512			SS		2pcs
DDR4	2400	8GB	V-Color	TD8G16C17-UH			DS		2pcs
DDR4	2400	8GB	V-Color	TC48G24S817			SS		2pcs
DDR4	2133	8GB	V-Color	TC48G21S815-iMS			SS		2pcs
DDR4	2133	8GB	V-Color	TD8G8C15-093E			SS		2pcs
Berichte & Reviews
https://smallformfactor.net/reviews/motherboards/fatal1ty-asrocks-x370-ab350-gaming-itxac-motherboards-reviewed
deutsches Video-Review: ASRock Fatal1ty AB350 Gaming-ITX/ac - Quick Review - YouTube
16.03.2018 - Aktuell gibt es einen Bug mit den Raven Ridge CPUs die bei WLAN Nutzung zur Instabilität führen. Dazu solltet ihr mal einen Blick in die Beta BIOS werfen. (4.51A)
Links zu den neusten BIOS Versionen findet ihr hier:
AB350: ASRock > Fatal1ty AB350 Gaming-ITX/ac
X370: ASRock > Fatal1ty X370 Gaming-ITX/ac
Wer noch eine ältere Version nutzt und auf 4.0 oder höher möchte, bitte das Bridge BIOS nicht vergessen.
Der Gigabyte ist ebenfalls schlecht, hatte deswegen alle Hoffnung in Asrock gesetzt...
OC3D hat im Review sich die VRMs vom Gigabyte genauer angesehen. Mit Top Kühler soll es noch gehen, aber mit Tower werden sie schnell warm
Wenn mal jemand messen könnte wie viel Platz zwischen den Spulen und den Kondensatoren ist, lässt sich vlt. ein Ersatz-VRM Kühler finden.
Alternativ halt den Schaum durch nen Kupferblock in der Größe ersetzen.
Oder mal Probieren wie die Kühlung ohne Heatsink funktioniert. Bei den X299 Mainboards die so kritisiert wurden war sie sogar besser als mit! (und die hatten kein WL-Schaumblock drunter).
Man könnte natürlich auch mal bei Asrock Bereich im Forum hier mal dampf machen was der Mist soll...
Asrock sollte jeden einen kostenlosen Kupferkühler bereitstellen.
Ich frag mich echt, wieso noch niemand anders sich deswegen beschwert hat ? In den USA ist das Board schon seit mehr als 7 Tagen am Markr. Auf Reddit etc. hab ich noch nichts gelesen
So ich habe auch mal gemessen. Ist leider beim Kühler etwas schwierig, da hier die Heatpipes des C14 etwas im Weg sind. So schräg von oben drauf gehalten zeigt er mir während Prime 78°C an. Auf der Rückseite des Boards unter dem Kühler sind es allerdings 85°C.
Ich bin jetzt erst mal gespannt, was Sologu berichtet, der hat den Kühler ja schon entfernt.
Außerdem wende ich mich gleich mal an den Support von Asrock.
Wenn die Rückseite 85°C heiß wird, kann man davon ausgehen, dass die ~105°C die matrickz in HWInfo hatte hin hauen...
Habt ihr nen Messschieber um von der Seite zu messen wie breit die Flanke ist:
Bild: 20170718_160839pfsh7g4sr9.jpg - abload.de
Dann noch wie hoch das Wärmeleitpad ist.
Und dann noch wie lang die Reihe der Spulen ist. Damit kann man dann raus finden was für ein Kupfervierkant man braucht, mit Flex oder Dremel entsprechend zurechtschneiden, Kaptonband an die äußeren Seiten welche keinen VRM oder Heatsinkkontakt haben, WLP auf die Kontaktfläche zum Heatsink, ein dünnes Wärmeleitpad Richtung VRMs - Fertig.
Zwischen Rückseite und Front sollten das doch keine 20c Unterschied sein. Kann ich mir nicht vorstellen. Die sind immerhin direkt auf der Platine gelötet da sollte keine 20c verloren gehen.
Gesendet von meinem ONEPLUS A3003 mit Tapatalk
Schalte ich prime wieder aus, ist es aber auch interessant. Die drei hohen Temperaturen bleiben hoch. Die als Motherboard gelabelte steigt sogar leicht an auf 115°C.
Das seltsame ist jedoch, dass das Mainboard unter den VRMs und auch der Kühler wieder kalt werden. Wie kann das denn jetzt sein? Wenn die Temperatur unter Prime hoch ist und ohne Prime auch, dann sollte doch Board und Kühler auch heiß bleiben.
Eine kleine Frage am Rande. Wenn ich den SmallFFT Prime test mache, wird dann auch die SSD benutzt? Denn die Temp von meiner 960 EVO M2 ging gerade extrem hoch. Der eine Sensor blieb bei 50 der andere ging auf 84. Jetzt ist er auch nach etwas Hilfe mit Metall dran halten wieder runter auf 57. Wenn das auch unter anderen Anwendungen passiert, muss ich vlt. ne Hitze Brücke von der SSD zur Motherboard Backplate oder zur Gehäusewand machen.
- - - Updated - - -
Bei mir sind es 111°C unter Last und seltsam 115°C jetzt im IDLE, wobei ich auch gerade den Lüfter runtergeregelt habe.
Wie gesagt finde ich es sehr komisch, dass die Temp oben bleibt auch wenn das Board und der Kühler wieder kalt sind.
- - - Updated - - -
Habe übrigens den Support mal angeschrieben. Hoffe ihr tut es alle gleich, damit sich vlt. schnell was bewegt.
Sehr geehrte Mitarbeiter des Supports,
Ich habe das Motherboard seit ein paar Tagen im Einsatz und mir ist aufgefallen, dass die Spannungswandler sehr heiß werden. Laut HWiNFO64 beträgt die Temperatur über 120°C.
Schaut man sich den Kühler an, stellt man fest, dass dieser gar nicht direkt auf dem Spannungswandlern sitzt, sondern ein mehrere Milimeter dickes geschäumtes Wärmeleitpad sitzt. Dieses führt definitiv zu einem sehr schlechten Wärmetransport und damit zu einem Aufheizen der Spannungswandler.
Ich habe mit einem Thermometer die Temperatur des Kühlers gemessen. Diese beträgt gerade einmal 75°C. Auf der Rückseite des Mainboards unter dem Kühler beträgt die Temperatur 85°C. Es scheint so, als würde der Kühler die Spannungswandler eher zu isolieren, als zu kühlen.
Ich bitte um eine schnelle Antwort und eine Aussicht auf eine Ausbesserung. Ich könnte mir dies in Form eines Ersatz Kühlers vorstellen, der einen geringeren Abstand aufweist und mit besseren dünnen Wärmeleitpads funktioniert. Ansonsten muss ich überlegen, dass Mainboard wieder zurück zu senden. So ist das System viel zu instabil. Ich muss nach Betrieb auf das abkühlen warten, damit der Rechner wieder anspringt.
Mit bitte um schnelle Antwort und freundlichen Grüßen
xxx
Ist vlt. etwas geblufft, denn ich habe ja eigentlich keine Alternative als Board.
Gerade eben mich dort angemeldet! AB350 Gaming-ITX/ac extremly hot VRM - ASRock Forums
vielleicht schreiben ein paar von euch auch noch was rein, damit Asrock weiß, dass es ernst ist!
zu deinem SSD Hitze Problem: Welches Gehäuse nutzt du? Ich hab das Fractal Design Nano S. Hinten ist eine Aussparung und die m2 SSD kann ganz gut atmen.
@Simaryp Der Kühler Isoliert nicht, sondern eher dieses dicke Wärmeleitpad.
Und mit solchen übertriebenen Texten (PC springt nicht an) glaubt dir dort aber auch keiner...
@HardwareFreaky ist halt die Frage wo die Sensoren liegen und wie genau diese sind. Fakt ist aber dass Schutzschaltungen der Manboards eben diesen verwenden werden, also man diese Temperatur senken will.
Dass die Sensoren allerdings auch im Idle so hoch anzeigen haut nicht hin. Es besteht natürlich die Möglichkeit das die aktuellen HWInfo Versionen absoluten Quark anzeigen.
Dennoch ist dieser große Wärmeleitpadschaum einfach nur bekloppt und dürfte OC stark einschränken.
Das Beste wäre halt wenn mal jemand den Kühlkörper abnimmt und die VRMs ohne diesen sowohl in Software als auch mit Thermometer misst.
Dann evtl mal nen Lüfter drüber halten und auch messen um zu sehen ob die Werte zusammenhängen und um ne Ahnung zu bekommen was für Temperaturen raus kommen.
@matrickz verlinke mal dort lieber diesen Post von Sologu:
[Übersicht] PGA AM4 Mainboard VRM Liste - Seite 26
Und schrieb dass du das Ding meinst.
Oder mach selbst nochmal ein Foto von deinem Heatsink mit und lad es dort hoch.
Nutze das Ncase M1, das ist auch hinten nackig. Da kommt dann nach nem halben cm. die Gehäusewand. Jetzt ist die Temperatur auch wieder runter gekommen auf etwas über fünfzig. Ich vermute einfach mal, dass Prime auch die Festplatte mitgenutzt hat.
Was heißt hier übertriebener Text. Wenn ich den Rechner auf Volllast laufen lasse und dann einen Neustart mache, dann fährt er nicht mehr hoch. Das ist ein Fakt. Erst wenn ich warte bis er wieder abgekühlt ist und den Neustart mache geht es. Und ja klar, dass es das WLP ist, aber ich meine halt die Konstruktion als ganzes.
@NasaGTR: Danke für den Tipp. Ist verlinkt!
Hoffen wir mal dass Asrock da irgendwas macht und nicht so wie bei dem K4 Board einfach EOL setzt.
Es gibt einfach sonst nicht wirkliche Alternativen. Asus hat auch kein ITX in der Pipeline.
@Simaryp ok wusste nicht dass der dann nicht neu startet.
ASUS ROGs schienen ja nicht geplant zu sein, aber bei Strix könnte was kommen. - Hoffentlich dann auch mit HDMI2.0b bzw. die Vorbereitung und BIOS Update was HDMI 2.0 dann bei RavenRidge freischaltet.
Ist ja kein Problem, aber man sollte wirklich vorher mal fragen, bevor man jemandem Lügen unterstellt. Ich habe das eine Seite weiter vorne genau erklärt, was geht und was nicht.
Asrock kann natürlich sagen, dass sie kein OC spezifizieren und damit hat sichs.
Ich bin wirklich sehr gespannt was bei Sologu heraus kommt.
das ist ein Fatal1ty Board, also Gamer/Overclock orientiert... Zwar jetzt kein High End aber es geht in die Richtung.
Außerdem war mein 1700 komplett Stock @ 3 GHz und trotzdem über 110 Grad vrm :-[
Irgendwas ist da aber mit dem Temp Sensor auch im Argen. Ka, ob der verpolt angeschlossen ist. Habe jetzt mal das Gehäuse wieder zu, um zu sehen, ob meine "Shrouts" was gebracht haben. Jetzt liegt die Temperatur der VRMs niedriger bei 106° fallend. Den Sensoren ist vlt nicht zu trauen.
Jap, hab auch vermutet dass es vielleicht an falschen Temperaturwerten liegt.
Das könnte Asrock easy mit einem BIOS Update fixen und die Sache wäre gegessen. warten wir mal auf was offizielles.
Schon echt schade, wollt die Woche den Rechner aufsetzen...
So mit meinem Shrout sieht die Sache jetzt wie folgt aus:
Hier noch mal die Temos mit geöffnetem Gehäuse laut HWiNFO64:
Motherboard: 112°C
CPU (Tctl/Tdie): 68°C
CPU:55°C
Auxiliary: 51°C
AUXTIN1: 105°C
AUXTIN2: 103°C
CPU (PECI): 40°C
Mit geschlossenem Case:
Motherboard: 106°C
CPU (Tctl/Tdie): 79°C
CPU: 65°C
Auxiliary: 60°C
AUXTIN1: 100°C
AUXTIN2: 97°C
CPU (PECI): 40°C
Das sind noch keine wirklichen Traum Temperaturen. Wenn ich meinen CMOS Schalter einbaue setze ich den CPU Kühler noch mal neu drauf, vlt. bringt das noch was. Und ich setze auch noch mal Schaumstoff zwischen CPU Kühler und Lüfter, so dass auch da Luft nicht zur Seite raus geht. Man muss auch sagen, dass hier gerade fast 30°C im Zimmer sind. Das hilft natürlich auch nicht gerade.
Was hast du denn geändert?
Ich hab jetzt auch mal den Noctua NH-U12S montiert. Resultat: noch höhere Temps.
Der Standardlüfter hat scheinbar noch etwas die VRM mitgekühlt, das ist jetzt komplett weg.
Katastrophe - 120-122 Grad.
Im Gehäuse siehts auch nicht besser aus...
Ich habe das hier kopiert:
Das perfekte Gehäuse für ITX? NCASE M1 Projekt - Seite 78
Im Ncase ist ein Abstand zwischen den seitlichen Lüftern und der Gehäusewand. Wenn man den stopft, kann der Lüfter nicht Luft aus dem Case ansaugen.
Das hat erst mal ein paar Grad gebracht. Das gleiche kann man nochmal machen, um den Abstand Lüfter Kühler zu verkürzen.
Dass es mit Towerkühlern schlechter wird, wurde auch in diesem Review zu dem Gigabyte gesagt.
Wenn ich auf 3.7 runtergehe wird es noch mal kühler, irgendwie klar. Wenn ich da mit der Spannung runtergehe wird es auch noch mal weniger oder?
Mir ist eine Idee gekommen. Wenn man einen Blick auf das Z270 von Asrock wirft, sieht man dass es einen deutlich dickeren VRM Kühler hat.
TweakTown.com Enlarged Image
hier im Detail: TweakTown.com Enlarged Image
Der Abstand der Löcher könnte durchaus der selbe sein. Vielleicht passt dieser Plug-and-play. (Heatpipe abknipsen)
Schon traurig, Intel bekommt einen ordentlichen Kühlkörper mit echter Wärmerleitpaste serviert und wir müssen uns mit Schaumstoff "zufrieden" geben...
Aber wieso sind die dann laut HWinfo kühler, wenn sie unter Last sind? Das ist doch mehr als seltsam. Und das alles abkühlt, aber die Temperatur des Sensors steigt.
- - - Updated - - -
Es gab übrigens einiges Feedback im Asrock Forum. Habe dich mal etwas unterstützt.
- - - Updated - - -
Habe noch mal ein moderateres übertakten ausprobiert.
Ram unverändert und CPU 3.6GHz mit 1.25V.
Motherboard: 108°C
CPU (Tctl/Tdie): 70.8°C
CPU: 61.5°C
Auxiliary: 57°C
AUXTIN1: 101°C
AUXTIN2: 99°C
CPU (PECI): 40°C
Das sind vlt. eh erst mal ausreichende Settings. In Spielen ist der vermutlich eh unterfordert für 75Hz. Ist die Spannung gut oder kann man da noch mal weiter runter?
Frag mich ob das Asrock Forum eigentlich jetzt nur Nutzer zu Nutzer ist, oder ob da auch mal die Entwickler rein sehen...
sonst ist das ganze ja ziemlich witzlos.
bitte gib uns Bescheid, wenn du eine Antwort auf deine Mail hast ;)
ich empfehle dir auch noch mal eine englische Mail an Asrock zu schicken. Die deutsche Adresse ist glaub ich mehr so eine Büroadresse. Das Entwicklerteam wird englischsprachig sein.
edit: das mit dem Z270 Kühler passt nicht, habe es mit einer Ausmess-Software gemessen.
AM4 : ca. 6cm
Z270: etwas über 7cm
Wenn ihr Kontakt in Deutschland zu ASRock haben wollt könnt ihr JZ kontaktieren: https://www.hardwareluxx.de/community/members/jz_-44313/
Ist bei uns im X370 Professional Gaming/Taichi Thread regelmäßig unterwegs und postet die neuesten Beta Biose, ich denke den Thread hier hat er einfach noch nicht gesehen ;)
Vermutlich hast du recht, wegen des Supports. Hoffe halt, die leiten es gleich weiter.
Das Forum ist immerhin von Asrock, oder? Vlt. kannst du ja auch den Support auf den Thread aufmerksam machen. Wenn ich ne Antwort habe, teile ich das gleich mit.
Wenn man ne CNC Fräse hätte könnte man das leicht selber machen. Ist ja im Prinzip nur ein Kupferblock mit zwei Bohrungen und einigen Kerben oben drauf. Aber muss halt präzise werden und als Laie mit einfachem Werkzeug eher schlecht machbar.
gute Idee! Könnten wir als Sammelbestellung im Forum realisieren.... nur brauchen wir jemanden mit CNC :d
Asrock schreibt folgendes zum Forum:
Wanna discuss or find out something for your ASRock products?
Come and get in ASRock worldwide forums to chat with ASRock global users!
Wer noch an der Uni ist, hat vlt. nen guten Draht zu der Werkstatt hat. Bei uns hätten die sowas vlt. mal eben gemacht, wenn man die kennt.
Es reicht doch einfach ein vierkant Profile aus Kupfer oder Alu. Aus Alu bekommt ihr das sogar aus jeden Baumarkt.
Für die Wissenschaft
So, habe jetzt den Kühler abgeschraubt!
Entwarnung für alle, das Ding kann man nachher problemlos wieder ran machen. Garantie? No problem.
nur passt auf diese schwarzen kleinen Scheiben auf die hinten sind.
Der Schaum ist sehr weich und etwas klebrig.
Jetzt lasse ich Prime95 laufen und gebe euch dann nochmal Werte mit dem Laser Thermometer.
Kann aber eigentlich jetzt schon sagen, diese 100 Grad+ aus HWiNFO kommen nicht hin. Auf den Wandlern ist weniger.
Krasser Scheiß, dass es dich jetzt gepackt hat. Bin schon ganz gespannt auf dein Urteil. Wie groß ist denn die Lücke zwischen Kühler und SpaWas? Wenn man einfach n Alu Blech nimmt, wie von Hardwarefreaky vorgeschlagen, könnte man ja ein WLP auf die Spawas legen und WLPzwischen Blech und Kühler. Kriegt man denn den Schaum ab und irgendwo für nen Garantiefall aufbewahrt?
