[Sammelthread] Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac
  • Ersteller Gelöschtes Mitglied 189576
  • Erstellt am
Sammelthread Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac​
die beiden Mini-ITX AM4 von Asrock
Inhaltsverzeichnis:
  • Technische Daten
  • Preisvergleich
  • Fragen / Antworten
  • RAM Kompatibilität
  • Berichte & Reviews
  • aktuelle BIOS Versionen
Technische Daten
AB350 Gaming-ITX:
Code:
[table="width: 500"]
[tr]
	[td]Gaming Armor[/td]
	[td]Power
- Hi-Density Power Connector (8 pin)
Memory
- 15μ Gold Contact in DIMM Slots
VGA Card
- 15μ Gold Contact in VGA PCIe Slot (PCIE1)
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
- Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]Unique Feature[/td]
	[td]ASRock Super Alloy
- Premium Power Choke
- Dual-N MOSFET
- Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
- Matte Black PCB
- High Density Glass Fabric PCB
- 2oz Copper PCB
Intel® 802.11ac WiFi
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop[/td]
[/tr]
[tr]
	[td]CPU[/td]
	[td]- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
- Digi Power design
- 8 Power Phase design
- Supports 95W Water Cooling[/td]
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory B350[/td]
[/tr]
[tr]
	[td]Memory[/td]
	[td]- Dual Channel DDR4 Memory Technology
- 2 x DDR4 DIMM Slots
- AMD Ryzen series CPUs support DDR4 3466+(OC) / 3200(OC) / 2933(OC) / 2667 / 2400 / 2133 ECC & non-ECC, un-buffered memory*
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
- Max. capacity of system memory: 32GB**
- 15μ Gold Contact in DIMM Slots[/td]
[/tr]
[tr]
	[td]BIOS[/td]
	[td]- 128Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 5.1 compliance wake up events
- Supports jumperfree
- SMBIOS 2.3 support
- CPU, DRAM, PCH 1.05V, PROM 2.5V, Voltage Multi-adjustment[/td]
[/tr]
[tr]
	[td]Graphics[/td]
	[td]- Integrated AMD Radeon™ R-Series Graphics in A-series APU*
- DirectX 12, Pixel Shader 5.0
- Max. shared memory 2GB
- Supports 2 x HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Ports (Compliant HDMI monitor is required)
- Supports HDCP with HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with HDMI Ports[/td]
[/tr]
[tr]
	[td]Audio[/td]
	[td]- 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
- Premium Blu-ray Audio support
- Supports Surge Protection
- Nichicon Fine Gold Series Audio Caps
- 120dB SNR DAC with Differential Amplifier
- Pure Power-In
- Direct Drive Technology
- PCB Isolate Shielding
- Impedance Sensing on Line Out port
- Individual PCB Layers for R/L Audio Channel
- Gold Audio Jacks
- Supports Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]LAN[/td]
	[td]- Gigabit LAN 10/100/1000 Mb/s
- GigaLAN Intel® I211AT
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE[/td]
[/tr]
[tr]
	[td]Wireless LAN[/td]
	[td]- Intel® 802.11ac WiFi Module (Free Bundle)
- Supports IEEE 802.11a/b/g/n/ac
- Supports Dual-Band (2.4/5 GHz)
- Supports high speed wireless connections up to 433Mbps
- Supports Bluetooth 4.2 / 3.0 + High speed class II[/td]
[/tr]
[tr]
	[td]Slots[/td]
	[td]AMD Ryzen series CPUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x16 mode)*
AMD 7th A-Series APUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x8 mode)*
- 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
*Supports NVMe SSD as boot disks[/td]
[/tr]
[tr]
	[td]Storage[/td]
	[td]- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket, supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
[/tr]
[tr]
	[td]Connector[/td]
	[td]- 1 x LPC Header
- 1 x AMD Fan LED Header
- 1 x CPU Fan Connector (4-pin)*
- 1 x Chassis Fan Connector (4-pin)
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*
- 1 x 24 pin ATX Power Connector
- 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
- 1 x Front Panel Audio Connector
- 1 x AMD LED Fan USB Header
- 1 x USB 2.0 Header (Supports 2 USB 2.0 ports) (Supports ESD Protection)
- 1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection)
*The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
**The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
CHA_FAN1/W_PUMP can auto detect if 3-pin or 4-pin fan is in use.[/td]
[/tr]
[tr]
	[td]Rear Panel I/O[/td]
	[td]- 2 x Antenna Ports
- 1 x PS/2 Mouse/Keyboard Port
- 2 x HDMI Ports
- 1 x Optical SPDIF Out Port
- 2 x USB 2.0 Ports (Supports ESD Protection)*
- 1 x USB 3.0 Type-A Port (Supports ESD Protection)
- 1 x USB 3.0 Type-C Port (Supports ESD Protection)
- 2 x USB 3.0 Ports (Supports ESD Protection)
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)[/td]
[/tr]
[tr]
	[td]Software and UEFI[/td]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN*
UEFI
- ASRock Full HD UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock Easy RAID Installer[/td]
[/tr]
[tr]
	[td]Support CD[/td]
	[td]- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar[/td]
[/tr]
[tr]
	[td]Accessories[/td]
	[td]- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
- 2 x ASRock WiFi 2.4/5 GHz Antennas
- 1 x Screw for M.2 Socket[/td]
[/tr]
[tr]
	[td]Hardware Monitor[/td]
	[td]- Temperature Sensing: CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Tachometer: CPU, Chassis, Chassis Optional/Water Pump Fans
- Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Multi-Speed Control: CPU, Chassis, Chassis Optional/Water Pump Fans
- Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore[/td]
[/tr]
[tr]
	[td]Form Factor[/td]
	[td]- Mini-ITX Form Factor: 6.7-in x 6.7-in, 17.0 cm x 17.0 cm
- 2oz Copper PCB[/td]
[/tr]
[tr]
	[td]OS[/td]
	[td]- Microsoft® Windows® 10 64-bit
* For the updated Windows® 10 driver, please visit ASRock's website for details: http://www.asrock.com
[/td]
[/tr]
[tr]
	[td]Certifications[/td]
	[td]- FCC, CE
- ErP/EuP ready (ErP/EuP ready power supply is required)[/td]
[/tr]
[/table]
X370 Gaming-ITX
Code:
[tr]
	[td]Power
Memory
VGA Card
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
[/tr]
[tr]
- Dual-N MOSFET
- Matte Black PCB
- 2oz Copper PCB
ASRock Steel Slots
[/tr]
[tr]
	[td]CPU[/td]
- Digi Power design
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory X370[/td]
[/tr]
[tr]
	[td]Memory[/td]
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory**
[/tr]
[tr]
	[td]BIOS[/td]
[/tr]
[tr]
	[td]Graphics[/td]
[/tr]
[tr]
	[td]Audio[/td]
- Pure Power-In
- Gold Audio Jacks
[/tr]
[tr]
	[td]LAN[/td]
- Supports PXE[/td]
[/tr]
[tr]
- Supports high speed wireless connections up to 867Mbps
- 2 antennas to support 2 (Transmit) x 2 (Receive) diversity technology
[/tr]
[tr]
	[td]Slots[/td]
[/tr]
[tr]
	[td]Storage[/td]
[/tr]
[tr]
	[td]Connector[/td]
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)**
[/tr]
[tr]
- 2 x HDMI Ports
[/tr]
[tr]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock XFast LAN*
UEFI
[/tr]
[tr]
	[td]Support CD[/td]
[/tr]
[tr]
- 1 x ASRock WiFi 2.4/5 GHz Antenna
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
	[td]OS[/td]
[/td]
[/tr]
[tr]
	[td]- FCC, CE
[/tr]
[/table]
Preisvergleich
AB350 Gaming-ITX/ac: ASRock Fatal1ty AB350 Gaming-ITX/ac Preisvergleich geizhals.eu EU
X370 Gaming-ITX/ac: ASRock Fatal1ty X370 Gaming-ITX/ac Preisvergleich geizhals.eu EU
Fragen und Antworten:
  • Was ist der Unterschied zwischen dem AB350 und X370?
    Da ein ITX Board nicht die kompletten Vorteile von X370 nützen kann, unterscheiden sich die beiden nur gering. Das X370 hat schnelleres WLAN und erlaubt PCIe Bifurcation
    edit 17.8.2017: Die beiden haben nun doch andere VRM Komponenten, wie br0da herausgefunden hat:
    FDPC5030 = AB350; SM7341EH = X370
    ASRocks X370 und B350 mini-ITX unterscheidet doch mehr, als der Kühlkörper (anfangs): VRM on the new AM4 motherboards - Page 251
    Die FETs im Vergleich:
    RDS(on) max​
    Rise + Fall Time
    FDPC5030Q1:
    5.0 mOhm @ VGS = 10 V @ ID = 17A
    6.5 mOhm @ VGS = 4.5V @ ID = 14 A
    Q2:
    2.4 mOhm @ VGS = 10V @ ID = 25 A
    3.0 mOhm @ VGS = 4.5V @ ID = 22 A
    Q1: 20ns
    Q2: 20ns
    SM7341EHQ1:
    3.9mOhm @ VGS = 10V @ ID = 24A
    6.5mOhm @ VGS = 4.5V @ ID = 24A
    Q2:
    1.2mOhm @ VGS =10V @ ID = 24A
    2mOhm @ VGS =4.5V @ ID = 24A
    Q1: 18.6ns
    Q2: 39ns
  • Wie unterschieden sich die VRM Kühler?
    alt: https://abload.de/img/img_15572ssdc.jpg
    neu: https://abload.de/img/fullsizerenderfaujg.jpg
  • Ich habe noch den alten VRM-Kühler, was kann ich tun?
    Schreibt den Asrock Support an! Der Support will danach noch eine Rechnung und die Seriennummer vom Board.
    ASRock > Support Request Form
  • Welchen RAM habt ihr getestet?
    Dazu habe ich ein 16GB Trident Z 3200MHz CL14 Kit. F4-3200C14D-16GTZ
    Mit den XMP Profil konnte ich den Ram nicht starten. Wenn ich jedoch die Spannung auf 1.4V erhöhe, die command rate auf 1T setze, Geardown Mode und BankGroupSwap deaktiviere, dann läuft er und es gab nach 2 Stunden Memtest64 keine Fehler.
    Als RAM habe ich Kingston KVR21E15D8K2/16I
    Corsair CMK16GX4M2A2400C14 funktioniert ebenfalls einwandfrei, ist direkt mit 2400Mhz gestartet.
    Aber ne kleine Info, ich habe diesen RAM hier beim Kollegen auf einen AB350 am Laufen:
    GWW416GB3000C15DC
    Dieser hat Samsung D-Die und ist Dualranked. Er läuft auf 3000Mhz mit 15-17-17-35 bei 1,35v, das läuft tadellos. Haben gestern was probiert und sind am Ende bei 1,35v auf 3200mhz bei 17-19-19-38 gekommen. Dualranked sollte er so schnell sein wie 3400-3500er Singlerank.
RAM Kompatibilität
Asrock gibt folgenden Arbeitsspeicher auf der Homepage an (Update 7.10.2017; 27 neue Einträge):
Code:
DDR4	3000	4GB	ADATA	KM4B4GX2A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	2800	16GB	ADATA	AX4U2800316G16			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-SRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400316G16-BBF			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BBZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRD			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRZ			DS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SRZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRZ	ADATA		DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SBF			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BWZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRD			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRZ			DS		2pcs
DDR4	2133	8GB	ADATA	AD4E2133W8G15-BHYA (ECC)			SS		2pcs
DDR4	2400	8GB	Apacer	AU08GGB24CEYBGC			SS		2pcs
DDR4	2133	8GB	Apacer	78.C1GM3.AF10B	Hynix		DS		2pcs
DDR4	3000	8GB	Avexir	AVD4UZ130001608G-4BZ1RR			SS		2pcs	v
DDR4	2400	8GB	Avexir	AVD4UZ124001608G-1COR			SS		2pcs
DDR4	2400	4GB	Avexir	AVD4UZ124001604G-1COB			SS		2pcs
DDR4	3000	8GB	Corsair	CMD32GX4M4B3000C15 (Hynix-M)			SS		2pcs	v
DDR4	2800	8GB	Corsair	CMK32GX4M4A2800C16			DS		2pcs
DDR4	2800	8GB	Corsair	CMD32GX4M4A2800C16			DS		2pcs
DDR4	2800	4GB	Corsair	CMD16GX4M4A2800C16			SS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C15 ver4.23			DS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16 ver 5.30			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C15			SS		2pcs
DDR4	2666	4GB	Corsair	CMK16GX4M4A2666C16			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C16			SS		2pcs
DDR4	2400	8GB	Corsair	CMK32GX4M2A2400C14			SS		2pcs
DDR4	2133	4GB	Corsair	CMV4GX4M1A2133C15			SS		2pcs
DDR4	2666	8GB	Crucial	BLT8G4D26AFTA.16FAD			SS		2pcs
DDR4	2666	4GB	Crucial	BLE4G4D26AFEA.8FAD			SS		2pcs
DDR4	2400	8GB	Crucial	CT8G4WFD824A.18FB1 (ECC)			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFS8213.8FB1			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.16FA2			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.C16FAD11			SS		2pcs
DDR4	2133	4GB	Crucial	CT4G4DFS8213.8FA1			SS		2pcs
DDR4	2133	16GB	Crucial	CT16G4DFD8213.16FB1			SS		2pcs
DDR4	3066	8GB	G.Skill	F4-4133C19D-16GTZKWC			SS		2pcs	v
DDR4	3066	8GB	G.Skill	F4-4000C18D-16GTZR			SS		2pcs	v
DDR4	3000	4GB	G.Skill	F4-3000C15Q-16GRR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3200C16D-16GTZB			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-4266C19D-16GTZR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3466C16D-16GTZSK			SS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3333C16D-32GTZSK			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C14D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3866C18D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C15D-32GTZR			DS		2pcs	v
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFT			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GBTZR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFX			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFX			SS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFT			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFT			DS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFT			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFXR			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFXR			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFT			SS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFX			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFT			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFXR			DS		2pcs
DDR4	2400	4GB	Geil	GWB48GB2400C14DC			SS		2pcs
DDR4	2133	8GB	Geil	GP48GB2133C15SC			SS		2pcs
DDR4	2666	8GB	HyperX	HX426C15FB/8			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13SB2K4/32			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3/8	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3/16	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K4/64	Hynix M-die		DS		2pcs
DDR4	2400	8GB	HyperX	HX424C15FB2K4/32			SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3/8	Hynix M-die		SS		2pcs
DDR4	2400	4GB	HyperX	HX424C15FBK4/16			SS		2pcs
DDR4	2400	16GB	HyperX	HX424C15FBK4/64			DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3/16	Hynix M-die		DS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB2K4/32			SS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB/8			DS		2pcs
DDR4	2400	8GB	J&A	JAD4U24001608-8M			SS		2pcs
DDR4	2400	4GB	J&A	JAD4U24001608-4M			SS		2pcs
DDR4	2133	4GB	J&A	JAD4U21331508-4M			SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron D-die		SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron H-die		SS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron D-die		DS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron H-die		DS		2pcs
DDR4	2400	8GB	Kingston	KVR24N17S8/8			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FBK4/32			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FB2/8			SS		2pcs
DDR4	2400	4GB	Kingston	KVR24N17S8/4	Micron		SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15S8/8			SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15D8/8			DS		2pcs
DDR4	2133	4GB	Kingston	KVR21N15S8/4			SS		2pcs
DDR4	2133	16GB	Kingston	KVR21N15D8/16			DS		2pcs
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMZ			SS		2pcs	v
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMB			SS		2pcs	v
DDR4	3000	4GB	KLEVV	IM44GU48A30-GIIHMC			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX1A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4B4GX1A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX2A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	2666	8GB	KLEVV	KM4Z8GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	8GB	KLEVV	KM4Z8GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X1N-2666-15-15-15-35-0			DS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X2N-2666-15-15-15-35-0			DS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X2N-2400-15-15-15-35-0			DS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X1N-2400-15-15-15-35-0			DS		2pcs
DDR4	2133	8GB	KLEVV	IMA41GU6MFR8N-TF1			SS		2pcs
DDR4	3000	8GB	Neo Forza	NFMUD480E8-3000DH2A			SS		2pcs
DDR4	2800	4GB	Panram	PUD42800C164G4NJW			SS		2pcs
DDR4	2666	8GB	Panram	W4U2666PS-8G			SS		2pcs
DDR4	2666	16GB	Panram	W4U2666PS-16G			DS		2pcs
DDR4	2400	8GB	Panram	PUD42400C158G4NJW			DS		2pcs
DDR4	2400	8GB	Panram	W4U2400PS-8G			SS		2pcs
DDR4	2133	8GB	Panram	W4U2133PS-8G			SS		2pcs
DDR4	3333	8GB	Patriot	PV416G340C6K (11BF2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G340C6K (11E2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G360C7K (11E1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G360C7K (11BF1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G320C6K (11BF2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11EC2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11D1)	Samsung 11D1		SS		2pcs	v
DDR4	3000	4GB	Patriot	PV48G300C6K (14M1)			SS		2pcs	v
DDR4	2933	8GB	Patriot	PV416G300C6K (11BF2)			SS		2pcs	v
DDR4	2933	4GB	Patriot	PV48G300C6K (11EC2)			SS		2pcs	v
DDR4	2400	8GB	Patriot	PSD48G240081			SS		2pcs
DDR4	2400	8GB	Patriot	PVE416G240C5KRD (11BF2)			SS		2pcs
DDR4	2400	4GB	Patriot	PSD44G240081			SS		2pcs
DDR4	2400	4GB	Patriot	PVE48G240C5KRD (11EC2)			SS		2pcs
DDR4	2400	16GB	Patriot	PSD416G24002			DS		2pcs
DDR4	2133	8GB	Patriot	PSD48G21332			SS		2pcs
DDR4	2133	4GB	Patriot	PSD44G213381			SS		2pcs
DDR4	2400	4GB	Samsung	M378A5244CB0-CRC			SS		2pcs
DDR4	2133	8GB	Samsung	M378A5143DB0-CPB			SS		2pcs
DDR4	2133	8GB	Samsung	M391A1G43EB1-CPBQ (ECC)			SS		2pcs
DDR4	2133	4GB	Samsung	M378A5143EB1-CPB			SS		2pcs
DDR4	2133	4GB	Samsung	M378A1G43DB0-CPB			SS		2pcs
DDR4	2133	8GB	Silicon Power	SP008GBLFU213N01			SS		2pcs
DDR4	2666	8GB	Team	TFWD48G2666C15BBK			SS		2pcs
DDR4	2400	8GB	Team	TED48G2400C16BK			SS		2pcs
DDR4	2400	4GB	Team	TED44G2400C16BK			SS		2pcs
DDR4	2133	8GB	Transcend	TS1GLH64V1H			DS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3SP-24MSPGNGFY7B			SS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3CP-241MCALGFY7J1			SS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7B			DS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7J1			DS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42131024			SS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42133512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD421333512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD42133512			SS		2pcs
DDR4	2400	8GB	V-Color	TD8G16C17-UH			DS		2pcs
DDR4	2400	8GB	V-Color	TC48G24S817			SS		2pcs
DDR4	2133	8GB	V-Color	TC48G21S815-iMS			SS		2pcs
DDR4	2133	8GB	V-Color	TD8G8C15-093E			SS		2pcs
Berichte & Reviews
https://smallformfactor.net/reviews/motherboards/fatal1ty-asrocks-x370-ab350-gaming-itxac-motherboards-reviewed
deutsches Video-Review: ASRock Fatal1ty AB350 Gaming-ITX/ac - Quick Review - YouTube
16.03.2018 - Aktuell gibt es einen Bug mit den Raven Ridge CPUs die bei WLAN Nutzung zur Instabilität führen. Dazu solltet ihr mal einen Blick in die Beta BIOS werfen. (4.51A)
Links zu den neusten BIOS Versionen findet ihr hier:
AB350: ASRock > Fatal1ty AB350 Gaming-ITX/ac
X370: ASRock > Fatal1ty X370 Gaming-ITX/ac
Wer noch eine ältere Version nutzt und auf 4.0 oder höher möchte, bitte das Bridge BIOS nicht vergessen.
Eigentlich brauchst du nur die Treiber, die PROSet Software ist unnätig, da Windows selbst WiFi verwalten kann.
Danke für die Antworten. Bleibe dann wohl dabei nur den Wi-Fi und BT-Treiber zu installieren.
Ich bin bestimmt nicht der Einzige der mit dem diesem Board auf Zen 2 aufrüstet. Was habt Ihr denn vor auf Euren Boards zu verbauen? Ich schiele ja etwas auf den 3800x. Möchte gerne den maximalen Takt für 120Hz und dabei SMT deaktivieren.
Der 2700x hat ja die selbe TDP. Diese CPU war mir damals wegen den kleinen VRM-Kühlern vom Board aber etwas too much. Deswegen bin ich schon am grübeln, ob nicht doch ein neues ITX-Board mit besserer Kühlung und Spannungsversorgung für den 3800x her muss. Aber über 200€ für ein Board ist im Vergleich zu den 110€ vom Fatal1ty schon eine Hausnummer. Zumal die ITX-Boards den X570 eh nicht auslasten wegen den eingeschränkten Möglichkreiten.
Fatal1ty X470 Gaming-ITX/ac
Fatal1ty B450 Gaming-ITX/ac
1.Supports AMD next generation Ryzen™ processors
2.Update AMD AGESA Combo-AM4 1.0.0.1
* Please install "AMD all in 1 with VGA driver ver:18.50.16.01_WHQL" or a later version before updating to this BIOS.
* If you updated the BIOS before updating the AMD all in one driver, please refer to the Display recovery SOP to recover your system.
* User will not able to flash previous BIOS once upgrading to this BIOS version.
* If the current BIOS version is older than P1.70, please update BIOS to P1.70(PinnaclePI-AM4_1.0.0.6) before updating this version.
Nachdem mein Asus Billigboard (was anfangs nur als Übergangslösung gedacht war) jetzt seit dem neuesten BIOS update einen meiner RAM Riegel plötzlich nicht mehr erkennnt und von diesem nicht startet (man kommt nicht mal ins Bios, vorher gingen beide Problemlos, jetzt geht der eine weiterhin problemlos, doch der andere wird nurnoch als "undefined 8GB RAM" erkannt und schon im BIOS nicht zur RAM Größe mit gezählt) will ich mir jetzt das Fatality B450 ITX holen (was ja keinen eigenen Thread hat und recht ähnlich zu den 300ern ist.
Falls der RAM auf dem auch nicht geht muss ich den wohl zu G.Skill einschicken, ich hoffe mal es liegt am ASUS Billigbaord...
Da AMD ja aber gesagt hat dass die neuen CPUs auf B450 und X470 problemlos mit der gleichen Performance laufen ist das Mainboard glaube ich sowieso ne gute Idee (hätte man das vor nem Jahr gewusst hätte ich mir das gleich geholt...). PCIe 4.0 brauch ich nicht und dafür 300€ auszugeben halt ich nicht sinnvoll da ich bei dem 8 Kerner bleiben will und die riesigen aktiv gekühlten VRMs wahrscheinlich nicht brauche.
Was mich aber mal Interessieren würde, wäre wie ihr den VRM Spielraum bei den Asrock ITXern findet. Meint ihr da ist noch Reserve um den 8 Kern 3800X gut zu übertakten? Oder kommen die mit den 1800X/2700X schon an die Grenzen?
Gibt es (mit den neuen BIOS Updates) im BIOS die Möglichkeit ram auf 3733 zu stellen, was momentan ja nicht stabil ist, mit den Zen 2 CPUs aber dann laufen dürfte?
Hat das B450 iTX auch das problematische WLAN Modul?
Ja, dort ist auch der Intel AC3168 drin. Beim X470-ITX ist der Intel AC9260 drin.
Kann man aber einfach austauschen, das AC9260 kostet ca 12€. Oder gleich ein besseres WiFi 6 Intel AX200 nehmen, kostet ca 20€. Das ist auch bei den neuen X570 Boards verbaut.
Intel® Wi-Fi der Serie 6
So langsam könnte ASRock mal das Zen2-Bios für das B350 raushauen.
Das neue Wlan-Modul hat bei mir keine wirkliche Änderung gebracht. Wenn ich einen USB-Stick oder externe HDD an einen USB 3.0 Port neben den Wlan-Antennen stecke bricht das Wlan komplett zusammen. Natürlich nur so lange bis ich das Gerät wieder trenne, dann geht es sofort wieder. Nervt mich schon sehr, da das Board nicht gerade mit USB 3.0 Ports um sich wirft.
Hast du schon eine CPU, da du so eilig bist ?
Erste AB350 BIOS sind online ;)
@ JZ_,
möchte so früh wie möglich bescheid wissen, ob ein Bios für die neuen CPU's erscheint oder nicht, da ich mich sonst nach einem anderen Board umschauen müsste.
Ich bleibe erst mal geduldig :)
BIOS 5.70
* If the current BIOS version is older than P5.30, please update BIOS to P5.50(PinnaclePI-AM4_1.0.0.6) before updating this version.
Intel WiFi-und BT-Treiber v21.20
Downloads für Funknetzwerke
Sehr gut. Werde am Montag oder Dienstag berichten, wie die CPU auf dem neuen Board läuft. Vorher mach ich mit dem 2600x noch ein paar Messungen mit dem EnergyCheck 3000 was den Verbrauch unter verschiedenen Anwendung betrifft um später vergleichen zu können. Denke der 3800x ist die maximal zumutbare CPU für das Board. Aber vielleicht schaltet sich die Vernunft noch ein und drängt mich zum 3700x.
Der 3700x wird der absolute Sweetspot werden. Außer bei hohen Multicore Lasten wird die höhere TDP des 3800x wohl wenig bringen vermute ich mal. Ich klopf mir auch einen drauf.
Wäre super wenn Du einen Erfahrungsbericht hier posten könntest.
So, erster Eindruck mit dem 3700x ist ernüchternd.
Seit der neuen CPU startet der PC nicht mehr. Der PC geht zwar an, es laufen aber nur die Lüfter der Grafikkarte. Lüfter von CPU und Gehäuse stehen still. Nach etwa 30 Sekunden geht er dann aus und automatisch wieder an und das in einer Endlosschleife.
Mal schauen was da los ist. Biosupdate wurde vorher erfolgreich geflasht.
Edit: Habe das Problem eingrenzen können. Der Ram der vorher problemlos mit 3200 MHz lief funktioniert jetzt nicht mehr mit 3200 MHz. Nach einem Biosreset kam ich ins Windows wo mir gleich eine Meldung entgegen kam, dass kein Audiowiedergabegerät gefunden wurde. Dann PC neu gestartet, nur den Ram wieder auf 3200 gesetzt und schon wieder die Geschichte mit den Lüftern die sich nicht drehen und den automatischen Neustarts nach 30 Sekunden.
Der Ram lief vorher mit dem 2600x immer mit 3200 MHz. Warum das jetzt nicht mehr klappt ist mir ein Rätsel.
Kommt da noch ein Bios Update?
Ja. AGESA 1.0.0.3 fehlt ja noch/kommt sicher bald. Das mit der reduzierten RAM Geschwindigkeit wird bei anderen Boards auch beschrieben. In 300er Schritten von 2133 ausgehend mit den manuell eingetragenen stabilen 3200er Timings probiert?
Da werden mit Sicherheit noch weitere Updates kommen. ASRock hat da derzeit die AGESA 1.0.0.1, andere Hersteller sind dagegen schon bei 1.0.0.3AB. MSI scheint da die Vorreiterrolle zu spielen und ist am aktuellsten.
Vorrangig sind aber die X570 Boards, da kommen fast täglich neue Updates. ;)
[Übersicht] Ultimative AM4 UEFI/BIOS Übersicht (11.07.19)
Danke für Eure Hilfe. Ich habe mich mal schrittweise an die 3200 rangetastet. Jetzt läuft es mit 3200, danke Sputnik. Werde gleich mal ein paar Benches durchlaufen lassen. CPU-Z hat mir auch völlig überraschend 4.391.10 MHz angezeigt. Das Board scheint keine Probleme mit dem Turbo zu haben und kommt ziemlich nahe an die 4.4 GHz. Der PC hat sich bereits ein mal im Desktop aufgehangen. Gleich mal den neuen Chipset Treiber installieren.
@ Vinci, daumen drücken für ein baldiges Update :)
Ich bin froh, dass ASRock da noch die Unterstützung für die Bristol Ridges (A-series) hat. Habe da übergangweise einen A10-9700 drin. Warte noch ab, bis der 3400G einen akzeptablen Preis hat. ;)
Ansonsten habe ich noch 2 weitere Gigabyte ITX-Boards (AB350N und AORUS PRO B450-I) mit Ryzen 2400G. Die haben beide AGESA 1.0.0.2, allerdings ohne Bristol Ridge support.
Auf all zu schnelle Aktualisierung würde ich nicht hoffen, ASRock ist in der Hinsicht bei den alten Boards etwas zögerlich. Außer bei gröberen Bugs.
Das BIOS 5.70 mit AGESA 1.0.0.1 hat da über 2 Monate gedauert. :(
Nach ein paar Benchmarks gebe ich mal eine vorsichtige erste Einschätzung ab - Es läuft :)
Mein 3700x macht max. 3,8 GHz AllCore Turbo und 4.4 GHz auf einzelnen Cores. Alle Lüftereinstellungen im Bios sind gleich. WLP Innovation Cooling IC Diamond 24 Carat
2600x / 3700x
Verbrauch kompletter PC ohne Monitor nach 5 Min. Desktop Idle / Wlan aus
50W / 54,3W
CineBench R20
3016 Punkte / 4623 Punkte
170W / 119W - Kann mir das mit dem hohen Verbrauch vom 2600x nicht erklären
75 Grad max./ 72 Grad max.
3DMark CPU Test
6607 Punkte / 9605 Punkte
Bis das neue Bios erscheint wird erst mal von OC/UV-Versuchen abgesehen. Will auch nicht wieder extra die GPU ausbauen, um das Bios per Jumper zu resetten. Ist bei einem ITX Case schon etwas nervig, wenn der Jumper direkt unter der GPU sitzt und man so gar nicht ran kommt. Merke: Nächstes Board hat einen Resetbutton an der Blende.
Hab jetzt auch einen 3600 am laufen, RAM geht bei mir auch manuell nicht über 2133, aber sonst läuft es schon relativ rund. Die Lüfter drehen beim POST voll auf und das BIOS hat viel mehr Einstellungen als zuvor.
Bis du direkt auf 3200 oder wie hast du den RAM so zum laufen bekommen?
Ich nahm beide Speicher raus, setzte einen wieder ein und versuchte es zunächst mit 2666. Als das klappte, traute ich mich ich an das XMP Profil 3200 was zum Glück sofort funktionierte. Der 2. Speicher wurde darauf problemlos erkannt und lief brav im vorgegebenen Takt.
Der 3700x taktet bei mir im Cinebench AllCore bei 100% mit 3892 MHz. In Prime sind es bei 100% noch 3620 MHz. Beide jeweils laut Ryzen Master Tool im 88 Watt Limit. Unter Precision Boost waren schon selbstmörderische Werte voreingestellt :fresse:
Aber ganz nettes Programm. Mit dem 2600x nie in Betracht gezogen.
Bei Cinebench taktet mein 3600 mit ca. 4GHz all-core, in Prime95 fällt er nach ner Weile auf ca. 3,8GHz. Laut HWiNFO64 verbrät er hierbei max. 75W. Mit meinem NH-U9S wird er dabei max. 78C warm.
habe von einem B350ITX mit Ryzen 1700 auf ein B450ITX mit 3700X gewechselt.
Finde die ITX Boards ausreichend für mich und betreibe diese bei mir in einem ITX Case, welches aber gut gekühlt ist... idle um die 30-35 und prime bleibt unter 60.
So nach Umbau gestern Nacht... ;) fiel mir schon auf, dass beim normalen Programm/Browser öffnen, die Lüfter hochdrehen... und das Ryzen Master Tool zeigt mir auch einen sofortigen Anstieg der idle Temp auf über 60... was nicht mal prime schafft nach Minuten Laufzeit...
Kann das jemand bestätigen oder hat er sowas beobachtet? Hab nix übertaktet, Treiber alles aktuell, WIN10 auch natürlich neu... bin da ratlos oder fehlt es einfach noch am passenden (fertigen) Bios?
@earthcrisis,
nutzt du das Master Tool zum übertakten? Als ich das Programm gestern zum ersten mal installiert und dann Precision Boost gutgläubig aktiviert habe, sprang die Core-Temp in CineBench innerhalb von 5 Sekunden auf 92 Grad. Voreingestellt waren da glaube 235 Watt für die CPU. Standard sind es maximal 88 Watt. 105 brauche ich für 4 GHz AllCore in Cinebench. Für Prime sind es schon 115W. Scheint mir so, als ob über das Master Tool angegegen wird wie viel Saft die CPU ziehen darf und regelt den Takt dann eigenständig, je nach Situation.
Mir sagt der Ryzen Master nur, dass ich keine unterstützte CPU habe :ugly:
Ich hab PBO an drei Stellen im BIOS ausgestellt, unter Prime95 sehe ich maximal 78C. Nutzt ihr auch den neuen Ryzen Balanced Power Plan? Den braucht man anscheinend für CPPC2.
Neustes Windows Build und Chipsatztreiber dürfte auch Notwenig sein.
Wenn einem der Stromverbrauch egal ist kann man natürlich auch einfach auf Höchstleistung stellen^^
@Ripcord
Nein, alles Standard und nichts übertaktet. Wie gesagt CPU idle je nach Energiesparplan 31-35Grad und unter Last Prime nicht über 60...
Nur dann öffnet man Browser oder irgendwas und er schnellt sofort auf 65Grad hoch aus dem idle und Lüfter fangen an, also keine langsame Erwärmung, sondern sofort liegt die Temperatur an. Total komisch.
Starte ich aber prime und belaste CPU... erwärmt sie sich langsam von idle Temp zu 60. :(
