[Sammelthread] Asrock ALiveNF7G-HDready / ALiveNF7G-HD720p (nForce 630A MCP) [1]
ALiveNF7G-HDready:
1. Socket AM2 for AMD Athlon™ 64FX / 64X2 / X2 / 64 and Sempron processors
2. NVIDIA® GeForce 7050 / nForce 630A MCP Chipsets
* AMD LIVE!™ Ready
* Supports Dual Channel DDRII800/667/533 with 4 DIMM slots, maximum capacity up to 8GB
* ASRock AM2 Boost: ASRock Patented Technology to boost memory performance up to 12.5%
* Integrated NVIDIA® GeForce7 Series (NV44) DX9.0 VGA, Pixel Shader 3.0, Max. shared memory 256MB
* 1 x PCI Express x 16 slot
* Hybrid Booster - ASRock Safe Overclocking Technology
* Untied Overclocking : During Overclocking, FSB enjoys better margin due to fixed PCIE/ PCI Buses
* Dual VGA Output: Support DVI-D and D-Sub ports by independent display controllers
* Supports HDCP function with DVI-D port, to enjoy better quality with High Definition HDCP Encryption contents
* Supports 720p Blu-ray (BD) / HD-DVD playback
* NVIDIA® PureVideo™ Ready
* 4 x Serial ATAII 3.0 Gb/s, support RAID (RAID 0, RAID 1, RAID 0+1, RAID 5, JBOD), NCQ, AHCI and "Hot Plug" functions
* Supports Gigabit LAN 10/100/1000 Mb/s
* Supports 2 x IEEE 1394 headers (one port on back panel, one header on board)
* HDMI_SPDIF header, providing SPDIF audio output to HDMI VGA card, allows the system to connect HDMI Digital TV/projector/LCD devices.
* Chipset embedded HDMI Audio which supports HDMI signal through DVI-D port by using DVI to HDMI adapter (not bundled)
* 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
* Windows® Vista™ Premium 2007 Logo Ready
* ASRock DVI_1394 I/O: 1 x VGA/DVI-D Port, 1 x VGA/D-Sub Port, 1 x IEEE 1394 port
Das ALiveNF7G-HD720p hat im Gegensatz zum HDready keine Firewire Schnittstelle.
2. FAQ - Frequently Asked Questions
- lassen sich 3 Pin Lüfter steuern? Nein das geht nicht.
- ist ein weiterer als der CPU Lüfter steuerbar? Nein auch das nicht.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
HDready:
http://www.asrock.com/mb/download.asp?Model=ALiveNF7G-HDready&s=
720p:
http://www.asrock.com/mb/download.asp?Model=ALiveNF7G-HD720p&s=
Neueste Biosversionen mit Lüftersteuerung finde man unter:
http://www.pctreiber.net/filebase.php?lim=0&cat=142
USB Stick bootfähig machen
http://www.forumdeluxx.de/forum/showpost.php?p=7080307&postcount=442
3.2 Reviews
http://www.ocworkbench.com/2007/asrock/ALiveNF7G-HDREADY/g1.htm
http://www.hkepc.com/bbs/hwdb.php?tid=810664&tp=NVIDIA-MCP68&rid=810664 (mit Vergleich zum 690G)
http://www.virtual-hideout.net/reviews/ASRock_AliveNF7G-HDready/index.shtml
http://www.phoronix.com/scan.php?page=article&item=771&num=1
3.3 Interessantes:
- der sehr kleine GPU Kühler
- 4 Ram Bänke mit bis zu 8gb Speicher
- HDMI Anschlussmöglichkeit, wenn auch nur über den DVI Anschluss
- Single Chip Design
- Videobeschleunigung, die der ATI 690G Chip teilweise nicht bietet :banana:
- umfangreiche Bioseinstellungen. U.a. CPU Parameter, GPU Takt nicht einstellbar
- günstig im Vergleich zu anderen 7050er Boards.
- 4 Sata II Plätze
3.4. Overclocking
Im Review lief das Board stabil mit 280mhz. Für die erste Biosversion kann sich das doch sehen lassen.
4. Preise
HDready bei Geizhals.at
720P bei geizhals.at
5. Bekannte Probleme:
- Die Auflösung von 1600x1200 wird nicht korrekt dargestellt.
- Beim Biosupdate von Version 1.60 auf 2.00 kann es zur Zerstörung des Bios kommen. Daher sollte vorher auf der Umweg über das 1.90er oder ein anderes Bios gemacht werden!
6. Fixes:
- schlechte USB Performance:
http://www.forumdeluxx.de/forum/showpost.php?p=6701416&postcount=165
- Grafikproblem bei 1600x1200er:
http://www.forumdeluxx.de/forum/showpost.php?p=6705173&postcount=166
- Lüftersteuerung dreht zu hoch:
http://www.forumdeluxx.de/forum/showpost.php?p=7076113&postcount=434
Unter Windows bekomme ich jedes Mal die Fehlermeldung, dass entweder kein Netzwerkkabel, oder aber ein defektes Kabel angeschlossen ist und folglich keine Verbindung zu einem Netzwerk hergestellt werden kann.
Es gibt im WWW einige für Windows 7/8 gemoddete nForce-Treiber, mit denen würde ich es als Erstes versuchen. Die "offiziellen" Releases basieren alle auf den letzten Vista Treibern. Da Nvidia vor dem Erscheinen von Windows 7 aus dem Chipsatzgeschäft ausgestiegen ist, wird es da auch nicht Neues mehr geben.
Da habe ich auch schon einige probiert, leider ohne Erfolg.
Es ist ja überhaupt sehr merkwürdig, da bei allen anderen im Normalfall die Win7-Standardtreiber oder eben die WHQL nForce-Treiber einfach ihren Dienst verrichten und bei mir geht nicht ein einziger Treiber, egal wie alt oder woher...:hmm:
Leuchten/Blinken die LEDs am Netzwerkanschluß, wenn ein Kabel verbunden ist?
Gibt es im Gerätemanager Auffälligkeiten?
Es blinkt/leuchtet nichts, egal was für Kabel ich anschließe.
Im Gerätemanager wird der Netzwerkadapter als voll funktionstüchtig dargestellt. Einzig irgendein Coprozessor wird momentan als unbekannt aufgeführt.
Falls Du eine Linux-Live-CD zur Hand hast, boote mal testweise damit. Dort werden eigentlich so ziemlich alle Netzwerkkarten erkannt und eingebunden.
Auch da habe ich das gleiche Problem wie unter Windows: angeblich ist kein Netzwerk verfügbar/kein Kabel oder ein defektes Kabel angeschlossen!
Der funktioniert leider nicht, weil keine Treiber für den 630a enthalten sind:
"Supported:
nForce 7 series:
790i SLI, 790i Ultra SLI, 780i SLI
nForce 6 series:
680i SLI, 680i LT SLI, 680a SLI
nForce 5 series:
550, 570 Ultra AMD, 590 SLI AMD, 570 SLI AMD"
An dem Punkt würde ich die LAN-Buchse mal mit Windows XP auf Funktion testen... am Ende ist der Anschluss defekt und du machst dir ganz die Mühe mit Win7 ganz umsonst :(
Ich bin jetzt so weit, dass ich einfach den 10er investiere und dem PC eine Gbit-Lankarte spendiere! Bevor ich jetzt noch mal 3 Tage teste wie ein Doofer und mein Wunschsetup trotzdem nicht funktioniert.
Schließlich ist das Verhalten alles andere als normal, denn es haben ja genug Leute Win7 auf alten nforce-Brettern laufen, also sollte das ja prinzipiell kein Problem des OS oder der Treiber sein.
Nachtrag:
Ich konnte es nicht unversucht lassen und habe auf einer kleinen Platte XP installiert...auch dort wird der Adapter zwar scheinbar erkannt und ein Treiber installiert, aber er funktioniert trotzdem nicht! Ich habe es erneut mit diversen Kabeln und Treibern probiert, aber der Anschluss scheint einfach tot zu sein! Das hatte ich echt noch nie.
Naja, dann wird es halt einfach eine PCI-Karte und gut ist ;)
Wenn die LEDs dunkel bleiben, dann ist der Anschluß definitiv defekt.
Die Netzwerkfunktionen müssen ja bereits vor dem Start vorhanden sein, z.B. für Wake-on-LAN oder Booten übers Netzwerk.
ist der im BIOS evtl Deaktiviert
Er ist nicht im Bios deaktiviert...wenn es doch nur so einfach gewesen wäre :d
habe mein alive nf7g -hdready brett ausgegraben
und als 2te platte eine 4tb seagate drangehangen diese wird im bios nur mit 1,8tb angezeigt ,, kann ich diese dennoch problemlos als Datengrab platte nehmen ?
2.1z bios ist drauf
ah ok thx also bis 2tb normal
ach das brett hat ja ein pci x1 , nen Sata hostcontroller kost ja auch nur ein paar euro
Ich wollte heute meinen Rechner nach längerer Standzeit wieder in Betrieb nehmen.
Aber ausser dem Drehen des CPU Lüfters auf Hochdrehzahl passiert nichts.
Woran könnte es liegen, dass der Rechner sonst nichts macht.
Ich denke nicht, dass das ein spezielles Problem dieses Mainboards ist.
Es kommen also die üblichen Fehlerursachen in Frage.
Batterie wechseln, CMOS-Resetten, Grafikkarte ausbauen und mit interner Grafik starten bzw. mir extra Grafikkarte versuchen, Netzteil unter die Lupe nehmen, Kondensatoren auf dem Mainboard auf Aufgeblähtheit checken usw.
Ich hatte es dann erst einmal versucht, mit Komponenten abziehen.
Nachdem ich die Festplatte und den Brenner ab hatte, bin ich zumindest erst einmal zum Bios gekommen. Und mit Anstecken ging es dann sogar auch.
Wo der Fehler nun lag, gute Frage.
*ausbuddel*
Hat auf diesem Board zufällig Jemand Windows10 am Laufen?
Speziell habe ich Bedenken, dass die integrierte Grafik nicht mehr mit einem Treiber versorgt wird und mit dem Windows10-Treiber vermutlich Youtube u.ä. nicht mehr möglich ist.
