[Sammelthread] ASUS M5A99FX Pro R2.0 (AMD 990FX / SB950)
ASUS M5A99FX Pro R2.0 (AMD 990FX / SB950)​
Sockel AM3+ Mainboard​
Inhalt
  • Spezifikationen
  • BIOS
  • Overclocking / Undervolting
  • Problemlösungen
  • Links
Spezifikationen
Chipsatz
  • AMD 990FX / SB950
  • Realtek® ALC892
  • Realtek® 8111F
Speicherslots
  • 4 x DDR3 2133 (O.C.) (2400MHz Inofficial) /1866/1666/1333/1066MHz
  • max. 32 GB
Steckplätze
  • 2 x PCIe 2.0 x16 (Dual x16)
  • 2 x PCIe 2.0 x16 (x4 Mode, black)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Interne Anschlüsse
  • 1 x USB 3.0 Connector (unterstützt zusätzlich 2 USB 3.0 Ports (19-Pin)
  • 3 x USB 2.0 Connectors (unterstützt zusätzlich 6 USB 2.0 Ports)
  • 1 x TPM Connector
  • 1 x COM Port Connector
  • 7 x SATA 6Gb/s Connectors
  • 1 x CPU Fan Connector (4-Pin)
  • 1 x CPU OPT Fan Connector (4-Pin)
  • 3 x Chassis Fan Connectors (4-Pin)
  • 1 x S/PDIF out Header
  • 1 x 24-Pin EATX Power Connector
  • 1 x 8-Pin ATX 12V Power Connector
  • 1 x Front Panel Audio Connector (AAFP)
  • 1 x System Panel (Q-Connector)
  • 1 x DirectKey Button
  • 1 x DRCT Header
  • 1 x MemOK! Button
  • 1 x Clear CMOS Jumper
  • 1 x USB BIOS Flashback Button
Externe Anschlüsse
  • 1 x PS/2 Keyboard
  • 1 x PS/2 Mouse
  • 1 x eSATA
  • 1 x LAN (RJ45)
  • 2 x USB 3.0
  • 8 x USB 2.0 (ein Port umschaltbar für USB BIOS Flashback)
  • 1 x Optical S/PDIF out
  • 1 x Audio 7.1
Besonderheiten/Sonstiges
  • ASUS Digital Power Design:
    - Industry leading Digital 6 + 2 Phase CPU Power Design
    - Industry leading Digital 2 Phase DRAM Power Design
    - CPU Power Utility
    - DRAM Power Utility
  • ASUS Exclusive Features:
    - Remote GO!
    - USB BIOS Flashback
    - MemOK!
    - AI Suite II
    - Ai Charger+
    - Front Panel USB 3.0 Support
    - ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
    - Network iControl
    - USB 3.0 Boost
  • ASUS Quiet Thermal Solution:
    - Stylish Fanless Design Heat-pipe solution
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - DirectKey
    - Percision Tweaker 2
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 2
    - Multi-language BIOS
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Slot
    - ASUS Q-DIMM
    - ASUS Q-Connector
Lieferumfang
  • Asus M5A99FX Mainboard
  • Treiber CD
  • User Manuel
  • ATX (I/O) Blende
  • 4 x SATA 6Gb/s Kabel
  • 1 x SLI Bridge
  • 1 x Q-Connector (2 in 1)
|B|I|O|S|
22.05.2012 - 0311 (First Release)
29.05.2012 - 0403
  • Improve system stability
  • Improve memory compatibility
27.06.2012 - 0507
  • Enhance compatibility with some USB devices
27.07.2012 - 0601
  • Fixed Nvidia GTX 680 hang when runing with UEFI driver
07.08.2012 - 0707
  • Improve compatibility with Windows 8 OS
20.08.2012 - 0803
25.09.2012 - 0906
22.10.2012 - 1006 [REMOVED]
  • Support new CPUs. AMD FX-43xx / FX-63xx / FX-83xx (Vishera)
02.11.2012 - 1101
  • Support new CPUs
13.11.2012 - 1201
07.12.2012 - 1302
31.01.2013 - 1503
  • Fixed F8 function is abnormal under fastboot
15.04.2013 - 1708
  • Fix HDD(1TB up) read error under win XP of IDE mode.
01.08.2013 - 1903
  • Fixed Power On By RTC function failed.
11.10.2013 - 2005 (neustes)
  • Improve system stability.
Overclocking / Undervolting (Air-Cooling)
CPU
RAM
Overclocking / Undervolting (Water-Cooling)
:grrr: Problemlösungen :grrr:
<<< Links >>>
..OC/UV Ergebisse sind gerne gesehen und werden umgehend eingetragen
Gebe den Thread gerne ab, da ich meine Hardware veräußere ;)
Es gibt seit gestern schon wieder ein neues BIOS.
2012.09.25 - BIOS 0906
Bisher scheint das Board hier wohl keiner zu besitzen?
Schade eigentlich, ich bin mit dem Board sehr zufrieden, auch wenn ich es nur zum Testen nutze.
mir fehlt derzeit noch die Grafikkarte, hab nur ne grottige HD5450 drin^^
Was für ne CPU haste drauf?
AMD FX-8150, das System befindet sich noch im Aufbau, derzeit zuviele Baustellen daheim ^^
Ich jetzt erst das du die Bilder aus meinem Review hast :xmas:
Das habe ich jetzt auch gesehen.
Mein letztes System hatte ich vor 2,5-3 jahren (PII X3 720, 4GB und ne HD5850), mal schauen wie das neue läuft :)
Dann hast du doch eigentlich erst mal ne gescheite Graka.
Das System ist nicht mehr existent, musste damals wegen einem neuen Mischpult weichen^^ ..aber solangsam bekomm ich schon lust mal wieder bissl zu zocken :d
Kannst du was zum Stromverbrauch sagen?
Macht sich eigentlich die Digitale Spannungsversorgung irgendwie positiv bemerkbar? Also im vergleich zur analogen bei Rev.1.
Keine Ahnung wen du jetzt ansprechen wolltest, ich kann zum Verbrauch nichts sagen aber es dürfte nicht mehr verbrauchen als andere vergleichbare AMD Boards.
Die Spannungsversorgung ist meiner Meinung sehr gut. Was du mit nem Vergleich meinst, weiß ich jetzt nicht da es bisher ja noch kein Pro gab oder meinst du im Vergleich zum Evo?
Hab die gemeint welche das Board schon haben. Gefragt hab ich deshalb weil bei einem Schnelltest mein Evo R2.0 30W mehr verbraucht hat als das normale Board. Bios Version war da allerdings noch eine ältere.
Ich bin im Besitz von dem Board aber ich wüsste jetzt nicht mit welchem man das vergleichen sollte.
Weiß du grad was es im Idle verbraucht (1xSSD oder HDD, einfache Graka, Onboard alles aus) ?
Ne überhaupt nicht, hatte in Verbindung mit dem Brett nie nen Leistungsprüfer dran. Hatte sich bisher nie ergeben.
Ich habe die Spezifikationen der beiden Implementierungen nicht vorliegen, aber grundsätzlich würde ich ein digitales VRM einem analogen immer vorziehen.
Passend zum Thema, sehr schön geschrieben:
Analog VS Digital PWMs
Klar ist digital vorzuziehen, ich meinte nur ob jemand die, z.B. Spannungsstabilität mal verglichen hat.
Die Abhandlung von Sin kannte ich schon, aber trotzdem Danke.
Nun kommt wieder meine frage, mit was vergleichen?
Dank digitaler Spannungsversorgung sind zumindest die Schwankungen von VCore ect. sehr gering :)
Sobald es Lohn gibt und ich die restlichen Teile habe, werde ich ein umfangreiches Review machen, wie im GA-790FX-UD5P Thread ;)
LG lain
Vergleich zwischen Rev.1 (Analoge Spannungsversorgung) und Rev.2 (Digitale Spannungsversorgung).
Ob die Digitale Versorgung messbare Vorteile bringt.
Es gibt keine Rev. 1 bei diesem Board. Das R2.0 ist eigentlich nur dafür gedacht, das es Win 8 Ready ist.
Habs auf die Startseite gepackt ;)
Hoffe ich komm die nächsten Tage mal dazu ein paar ausführliche Tests zumachen..
LG lain
M5A99FX PRO R2.0 BIOS 1101 released
1.Improve system stability.
2.Support new CPUs
LG lain
Danke für die Info. Das 1006 BIOS wurde wieder entfernt auf der Homepage.
