[Sammelthread] ASUS M5A99FX Pro R2.0 (AMD 990FX / SB950)
ASUS M5A99FX Pro R2.0 (AMD 990FX / SB950)​
Sockel AM3+ Mainboard​
Inhalt
  • Spezifikationen
  • BIOS
  • Overclocking / Undervolting
  • Problemlösungen
  • Links
Spezifikationen
Chipsatz
  • AMD 990FX / SB950
  • Realtek® ALC892
  • Realtek® 8111F
Speicherslots
  • 4 x DDR3 2133 (O.C.) (2400MHz Inofficial) /1866/1666/1333/1066MHz
  • max. 32 GB
Steckplätze
  • 2 x PCIe 2.0 x16 (Dual x16)
  • 2 x PCIe 2.0 x16 (x4 Mode, black)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Interne Anschlüsse
  • 1 x USB 3.0 Connector (unterstützt zusätzlich 2 USB 3.0 Ports (19-Pin)
  • 3 x USB 2.0 Connectors (unterstützt zusätzlich 6 USB 2.0 Ports)
  • 1 x TPM Connector
  • 1 x COM Port Connector
  • 7 x SATA 6Gb/s Connectors
  • 1 x CPU Fan Connector (4-Pin)
  • 1 x CPU OPT Fan Connector (4-Pin)
  • 3 x Chassis Fan Connectors (4-Pin)
  • 1 x S/PDIF out Header
  • 1 x 24-Pin EATX Power Connector
  • 1 x 8-Pin ATX 12V Power Connector
  • 1 x Front Panel Audio Connector (AAFP)
  • 1 x System Panel (Q-Connector)
  • 1 x DirectKey Button
  • 1 x DRCT Header
  • 1 x MemOK! Button
  • 1 x Clear CMOS Jumper
  • 1 x USB BIOS Flashback Button
Externe Anschlüsse
  • 1 x PS/2 Keyboard
  • 1 x PS/2 Mouse
  • 1 x eSATA
  • 1 x LAN (RJ45)
  • 2 x USB 3.0
  • 8 x USB 2.0 (ein Port umschaltbar für USB BIOS Flashback)
  • 1 x Optical S/PDIF out
  • 1 x Audio 7.1
Besonderheiten/Sonstiges
  • ASUS Digital Power Design:
    - Industry leading Digital 6 + 2 Phase CPU Power Design
    - Industry leading Digital 2 Phase DRAM Power Design
    - CPU Power Utility
    - DRAM Power Utility
  • ASUS Exclusive Features:
    - Remote GO!
    - USB BIOS Flashback
    - MemOK!
    - AI Suite II
    - Ai Charger+
    - Front Panel USB 3.0 Support
    - ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
    - Network iControl
    - USB 3.0 Boost
  • ASUS Quiet Thermal Solution:
    - Stylish Fanless Design Heat-pipe solution
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - DirectKey
    - Percision Tweaker 2
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 2
    - Multi-language BIOS
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Slot
    - ASUS Q-DIMM
    - ASUS Q-Connector
Lieferumfang
  • Asus M5A99FX Mainboard
  • Treiber CD
  • User Manuel
  • ATX (I/O) Blende
  • 4 x SATA 6Gb/s Kabel
  • 1 x SLI Bridge
  • 1 x Q-Connector (2 in 1)
|B|I|O|S|
22.05.2012 - 0311 (First Release)
29.05.2012 - 0403
  • Improve system stability
  • Improve memory compatibility
27.06.2012 - 0507
  • Enhance compatibility with some USB devices
27.07.2012 - 0601
  • Fixed Nvidia GTX 680 hang when runing with UEFI driver
07.08.2012 - 0707
  • Improve compatibility with Windows 8 OS
20.08.2012 - 0803
25.09.2012 - 0906
22.10.2012 - 1006 [REMOVED]
  • Support new CPUs. AMD FX-43xx / FX-63xx / FX-83xx (Vishera)
02.11.2012 - 1101
  • Support new CPUs
13.11.2012 - 1201
07.12.2012 - 1302
31.01.2013 - 1503
  • Fixed F8 function is abnormal under fastboot
15.04.2013 - 1708
  • Fix HDD(1TB up) read error under win XP of IDE mode.
01.08.2013 - 1903
  • Fixed Power On By RTC function failed.
11.10.2013 - 2005 (neustes)
  • Improve system stability.
Overclocking / Undervolting (Air-Cooling)
CPU
RAM
Overclocking / Undervolting (Water-Cooling)
:grrr: Problemlösungen :grrr:
<<< Links >>>
..OC/UV Ergebisse sind gerne gesehen und werden umgehend eingetragen
Gebe den Thread gerne ab, da ich meine Hardware veräußere ;)
Also ich kann von keiner GPT-Partitionierten Platte booten. Das funktioniert bei mir nicht und ich besitze auch dieses MB. Und habe dies schon mehrmals versucht. Man formatiert ja eigentlich Festplatten als GPT, wenn sie über 2TB besitzen. Darunter ist dies unnötig.
Es könnte funktionieren, wenn mit dem Installationsmedium der AHCI/Raid Treiber während der Installation hochgeladen wird
im UEFI-Modus wird mit GPT-Partioniert. Dieses Board unterstützt dieses ja. Es wird auch für Fastboot unter Win8 benötigt.
Mein Desktop (siehe Signatur) bootet ja auch
Bei mir hat das iwi nicht funktioniert. Meine Platten sind alle MBR-Formatiert. Meine Samsung SSD z.Bsp. wurde nach GPT formatierung von Windows nicht mehr als Bootlaufwerk akzeptiert, und da konnte ich machen was ich wollte, es ging einfach nicht
ich probiere das grad mal aus... UEFI deaktiviert und Legacy-boot aktiv
vorher unter GParted die Platte gekillt und MSDOS partitionstabelle drauf gemacht
---------- Post added at 15:06 ---------- Previous post was at 14:56 ----------
windows gibt zwar nicht mehr die Fehlermeldung von sich, aber zu Formatieren schafft es auch nicht mehr. [Fehler:0xabe3bac0]
das nennt sich also Windows 8 Ready
---------- Post added at 18:44 ---------- Previous post was at 15:06 ----------
hat keiner weiter mehr eine Idee? Das Board findet nicht immer eine Festplatte. Hab verschiedene Platten ausprobiert... keine will
---------- Post added at 20:22 ---------- Previous post was at 18:44 ----------
hab gerade mal das Sata-kabel ausgetauscht... und nun geht es.. kann nun Problemlos im GPT-Modus installieren
Ich glaube ich habe auch so ein Kabelproblem.
Wenn mein Rechner mal ein paar Tage aus ist findet er Sata 0,2, 4 und das RAID auf dem PCIe bus.
Sata 1, 3, und 5 hingegen nicht. Natürlich ist 1 das Bootlaufwerk......
musst wirklich die kompletten Kabel tauschen... bei mir hat es was gebracht. immer schön die dicken schwarzen aus der Schachtel nehmen... waren aber nur 4 Stück dazu
Danke für den Tipp.
Gibt es eine Marke die man getrost kaufen kann wenn man verschiedene Längen und gewinkelt will?
suche mal nach SATA3 Datenkabel mit doppeltem SAS Kabel
da wirst du findig
diese Strippen sehen genauso aus, wie die von Asus dazugelegten
geht mir genauso...
ansonsten ist es eine kleine stabile Platine... würde ich sofort wieder einsetzen
Hallo an alle hier, :wink:
habe da mal ne Frage, ob ihr auch die Windowsbootverzögerung (Windows 7 64Bit) merkt, wenn AHCI aktiviert ist?
Bei mir macht die Windowsbootverzögerung bei „Windows wird gestartet“ so ca. 7 bis 8 Sek unterschied zwischen AHCI und IDE aus. Die 8 Sekunden sind bei einer HDD nicht so schlimm aber bei einer SSD macht sich das schon bemerkbar, ob man Windows mit ca. 22 oder 14 Sekunden startet.
Hab Ihr da einen Lösungsvorschlag wegen der Bootverzögerung beim Windowsstart (nicht Bios Start) Habe immer die aktuellsten AMD AHCI Treiber drauf.
Gruß TG0815
Ach so mein System ist (schon teilweise etwas älter):
ASUS M5A99FX PRO 2.0, AMD FX8350 4,2GHz Turbo deaktiviert, 16 GByte Geil 1866er DDR3, Scythe Zipang 2 mit Xigmatek XAF-F1456 Blueline LED, SSD Samsung 840 EVO 120GByte + Seagate ST2000DM001 2TByte + Samsung DVD Brenner SH-224BB Creative X-Fi Extreme Music, Logitech G19 + G500, ASUS GTX670-DC2OG-2GD5, Monitor LG 24EB23, Logitech 2300, Aerocool Extrem Engine 3T
Verlinkt in der Übersicht und verschoben ins Sammelthread Unterforum :wink:
(ist mir bisher irgendwie durch die Lappen gegangen der Thread)
schaut mal... Asus hat mal wieder ein Bios-Update gebracht:
M5A99FX PRO R2.0 BIOS 2301
Update 2014.03.27
