[Sammelthread] Asus P5B / P5B Deluxe /-WiFi–AP (Intel P965) [7]
Aktuell
Die komplette P5B-Reihe ist 45nm CPU ready : XS.org
1hoch
Inhalt
uber
Überblick
Sockel: LGA775
Unterstützte CPUs_
Intel® LGA775 Platform
Intel® Penryn Ready
Intel® Quad-core CPU Ready
Intel® Core™2 Extreme / Core™2 Duo Ready
Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
Unterstützte FSBs_ 1066/800/ 533 MHz
Chipsatz_ P965 Express
1 PCIe x16 PEG Link
Sehr gut übertaktbar, FSBs über 500MHz keine Seltenheit [P5B Deluxe]
[Ich brauch noch mehr Allgemeines]
p5b
P5B
  • Storage
    • 4x SATA 3Gb/s [ICH8]
    • 1x IDE über JMicron
    • 1x eSATA über JMicron
    • 1x SATA über JMicron
  • RTL8111B PCI-E Gb LAN
  • 8-channel HD Audio
  • AI NOS™ / AI Gear / AI Nap
^Inhalt
clbBios-Changelog fürs P5B
2104 - 2009/05/27
Support new CPUs. Please refer to our website: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
1604 - 2007/07/13
1. Enhance memory compatibility under FSB1333 mode
1501 - 2007/07/05
1. Add new CPU uCode to support new processor
1405 - 2007/06/13
1. Update CPU ucode to support new processor
2. Revise SLP 2.0 rule
3. Enable hotplug support under AHCI mode
4. Fix displayed CPU frequency incorrectly after downgrade CPU ratio
1202 2007/04/04
1. Fix system may sometimes hang after load default in setup then exiting right away while having Conroe CPU
installed.
2. Add new uCode to support new CPU.
1102 - 2007/01/31
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
1. Finetune Q-Fan control algorithm
2. Enable EIST under VISTA
3. Update CPU Ucode to support new CPU
4. Fix BBS device string not correct under AHCI mode
5. Support SLP2.0 string
6. Fix HCT unreported I/O and memory issuse
7. Support disable USB function item
8. Allow disable XD for conroe L
9. Add full reset after change DRAM mode to enhance memory compatibility
10. Support CONROE E0 CPU(FSB 1333)
11. Fix AC Power loss function not correct
12. Support x4 DIMM
0806 - 2006/11/
1. Enable support for WiFi-TV card
2. Enable PreslerXE 3.73 support
3. Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI
mode
4. Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
5. Enhance ATA ODD compatibility
6. Support Conroe-L CPU
7. Fix CPU VCORE too high after overclocking fail
0701 - 2006/10/5
2. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
3. Reduce system full reset of times
4. Patch some VGA card can't found when NB Vcore value has been set too high
5. Fix DDR frequency 889 unstable by SPD
6. Add new CPU Ucode to support Kentsfield B3 stepping CPU
7. Improve S3 resume time
8. Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
9. Fix chassis fan 2 speed not correct when fan speed too low.
^Inhalt
p5bp
P5B-Plus
  • Intel LGA775 Platform
  • Intel® Quad-core CPU Ready
  • Intel® Core™2 Extreme / Core™2 Duo Ready
  • Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
  • 1066/800/ 533 MHz
  • Dual-channel DDR2 800/667/533
  • 1x PCI Express x16
  • Storage
    • 6x SATA 3Gb/s [ICH8R]
  • PCI-E Gigabit LAN controller
  • AI NOS™ / AI Gear / AI Nap/ TPM Support
  • All High-quality Conductive Polymer Capacitors
^Inhalt
clpBios-Changelog fürs P5B Pus
0638 - 2008/10/29
Enhance the compatibility with certain memory.
0604 - 2007/06/13
1. Fixed PCProbe II fail to install problem
2. Add new uCode to support new processors
3. Enable SATA Hotplug support under AHCI mode
^Inhalt
p5bd
P5B Deluxe
  • Crossfire-Freigabe, 2te Karte über elektrischen PCIe-x4-Slot über die Southbridge angebunden [ca. 20% Leistungsverlust]
  • Storage
  • Dual Gigabit LAN controllers, Marvell® PCI-E and PCI Gigabit LAN controllers
  • 8 Phase Power Design
  • Fanless Design - Heat Pipe & Stack Cool 2
  • Array Mic / Noise Filter
    WiFi-AP: WiFi-AP Solo
^Inhalt
cldBios-Changelog fürs P5B Deluxe
Download --> http://amd.co.at/anti/asus/
1238 - 2009/02/11
Fix system hangs at POST while using certain 4GB memory and CPUs.
1215 - 2007/07/13
1212 - 2007/07/09
1. Add new CPU uCode to support new processors
3. Enable support for SATA hot plug function under AHCI mode
4. Fix after downgrade CPU ratio, the Conroe L frequency not correct under ASUSCPU
1101 - 2007/04/04
1 Add new uCode to support new CPU.
2 Fix system won''t complete POST with GV-MVP/RZ2(TV tuner) connected and power on before motherboard.
1004 - 2007.01.30
**This BIOS does not support roll back to older BIOS**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
0910 - 2006.01.16
1. Update Jmicron option ROM to 1.06.59
2. Fix AC Power loss function not correct
3. Support x4 DIMM
4. Moidfy Write to Precharge Delay default from 10 to 11
5. Enable support for EIST under VISTA
6. Finetune Q-Fan rule
7. Support SLP 2.0
8. Fix BBS device string not correct under AHCI mode
9. Enable Disable USB capability
10.Support ASUS WIFI-TV card
11.Revise CPU temperature calculation algorithm for PECI
0910 - 2006/12/27
no changelog avaible..
0908 - 2006/12
0903 - 2006/11/
0804 - 2006/10/25
1. Support conroe L processor
2. Update JMicron option rom 1.06.22
3. Modify CPU fan low limit speed from 800 RPM to 600 RPM
4. Implement ASUS CGI performance with ATI 1950 graphic cards
0801 - 2006/10/11
we havent changelog ...
0711 - 2006/10/04
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
0706 - 2006/09/20
1. Enhance CrossFire performance.
2. Enable NVIDIA 7950GX2 display under crashfree mode
3. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
4. Fix memory display message not correct under multi-language (dank an Norstern)
5. Add Kentsfield B3 uCode
0701 BETA - 2006/09/11
1. Fix chassis fan2 may not detect fan speed under ProbII if low spin fan is used.
0614 - 2006/09/06
1 Support DDR2 SO DIMM
2 Support DDR2 double side X16
3 Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
4 Fix Kentsfield B0 stepping CPU can't adjust ratio issue
5 Support Conroe / Kentsfield ratio overclocking higher than default (multi max 6- 11 (x-6800) -13
6 Fix CPU Fan Profile mode not correct after system shutdown
^Inhalt
ram
Kompatibler Speicher
kein Anspruch auf Vollständigkeit
sämtliche Micron D9: D9GMH und mit D9GKX
AENEON PC2-5300U-555-12 (DDR2-667) (AET760UD00-30DA98Z)
A-DATA Vitesta Extreme Edition DDR2-800+MHz PC2-6400 Dual Channel Kit CL4-4-4-15 2x1024MB
Corsair XMS2 PC2-5300U CL4-4-4-12 (DDR2-667) (TWIN2X1024-5400C4)
Corsair XMS2 PC2-6400U CL5-5-5-12 (DDR2-800) (TWIN2X1024-6400)
Corsair XMS2 PC2-6400U CL3-4-3-9 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400U CL4-4-4-12 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400PRO CL4-4-4-12 (DDR2-800) (TWIN CM2X1024-6400C4PRO)
Corsair XMS2 PC2-8500U CL5-5-5-15 (DDR2-1066) (TWIN2X2048-8500C5)
Corsair XMS2 Dominator Series PC2-8500U CL5-5-5-15-2T (DDR2-1066) (TWIN2X2048-8500C5D)
Corsair XMS2 Dominator Series PC2-8888U CL4-4-4-12-2T (DDR2-1111) (TWIN2X2048-8888C4DF)
Crucial Ballistix PC2-6400U CL4-4-4-12 (DDR2-800) (BL2KIT12864AA804)
Crucial Ballistix PC2-5300 3-3-3-12 D9GMH
Crucial Value CL5 D9GMH + D9GKX
GSkill GBHZ old D9GMH
G.Skill PC2-4200U CL4 (DDR2-533) (F2-4200PHU2-2GBNT)
G.Skill PC2-5300U CL5 (DDR2-667) (F2-5400PHU2-2GBNS)
G.Skill 2GB F2-6400PHU2-2GBNS ab 0614 Bios
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNR)
G.Skill PC2-8000U CL4-4-4-5 (DDR2-1000) (F2-8000PHU2-2GBHZ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-1GBNQ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNQ)
^Inhalt
G.e.i.L PC2-6400 CL4-4-4-12 (PC800) (GX21GB6400UDC)
Kingston DDR2-RAM 2x512MB 533MHz KVR533D2N4/512
Kingston DDR2-RAM 2x1024MB 533MHz KVR533D2N4K2/2G
Kingston HyperX DIMM 1 GB DDR2-750, KHX6000D2/1G ( max 850 mhz)
MDT PC2-6400U CL5 (DDR2-800) (M1GB-800K)
Mushkin EM2-5300 2048MB PC2-5300U CL5 (DDR2-667) (991382)
Mushkin EM2 PC6400 2048MB DualKit
Cellshock DDR2-800 CL4 (CS2221041)
OCZ OCZ2P10002G-K (OCZ Platinum Enhanced Latency XTC)
OCZ2N9001GEB
OCZ28001024EBDCPE- (OCZ Platinum DIMM Kit 1024MB PC2-6400U CL4-3-3-8)
OCZ2N11001G
Hynix HYMP564U64BP8-S5 (512MB 5-5-5)
Hynix HYMP512U64BP8-S5 (1GB 5-5-5)
Hynix HYMP564U64AP8-S6
Hynix HYMP512U64AP8-S6
Golden Emp. 8HTF6464AY-80EA3
Golden Emp. 16HTF12864AY-80EA3
Golden Emp. 8HTF6464AY-80ED4
Golden Emp. 16HTF12864AY-80ED4
Transcend TS64MLQ64V8J (Transcend DIMM 512MB PC2-6400U CL5)
TwinMos ??? M2Y51264TU88A2B-25
NANYA NT512T64U88B0BY-25
NANYA NT1GT64U8HB0BY-25C
^Inhalt
eigEigenarten
botBoot-Bug/An-Aus-Bug
Wie äußert sich dieser Bug?
Wird der PC nach dem Herunterfahren komplett vom Strom getrennt, zum Beispiel in dem man das NT danach abschaltet, wird das Board beim nächsten Systemstart zuerst einmal starten, dann wieder ausgehen um dann normal zu booten, was nicht gerade lebensdauerförderlich für die angeschlossenen Festplatten ist.
Kann man dieses Verhalten umgehen?
Den "Boot Bug" nach Netztrennung kann man auf verschiedene Weisen umgehen: Den Rechner herunterfahren und Netzschalter des NT auf AN lassen, sodaß das Board weiterhin mitStandBy-Strom versorgt wird, dann bootet der Rechner beim nächsten Start normal oder mittels Master / Slave Leiste. Der Verbrauch hierbei schwankt zwischen 2 und 20 Watt - je nach angehängten Verbrauchern. Achtung: auch die verwendete Leiste kann den Verbrauch beeinflussen. Mit einer alten Lidl-Leiste lag der Verbrauch bei 3 Watt und mit einer viel aktuelleren Aldi-Leiste zeigte der Verbrauchsmesser bei gleicher Konfig fast 18Watt. Sofern ich mich nicht verrechnet habe, hier ein Rechenbeispiel: 14 Std. täglich "Standby" (also PC heruntergefahren an der Leiste) mit 20Watt bei 0,18€ pro kw/h ergeben ~ 19€ für ein Jahr. Ist Umweltpolitisch nicht ganz korrekt, aber mir den 1,50€ im Monat wert ;)
Strap-Verhalten [Umschalten der internen Timings][/B]von Sven Bode
Hier gehts weiter>>
messMesspunkte
vCore
vFSB
^Inhalt
BiosBIOS
bif0Bios-Flashen *BETA*
Vor dem Flashen das System auf Standardtakt zurücksetzen.
Es gibt 3 verschiedene Methoden:
EZ-Flash
1. Neues Bios von Asus herunterladen und entpacken
2. Bios-Datei auf Diskette oder USB-Stick speichern
3. Neustarten
4. Entweder beim POST ALT+F2 drücken, oder EZ-Flash im Bios unter Tools/Werkzeuge auswählen
5. Laufwerk auswählen mit TAB, dann ENTER zum Flashen
6. Der Rechner startet nach Abschluss des Flashvorgangs neu​
Afudos
2. Am besten direkt in P5B.rom umbenennen
3. entsprechendes Afudos-Programm von Asus herunterladen
4. Bootbare Diskette erstellen
5. afudos.exe und P5B.rom auf die Diskette kopieren
6. Rechner mit der Diskette im Laufwerk neustarten
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom
9. ENTER Der Flashvorgang beginnt. Den weiteren Anweisungen folgen​
Unter Windows mit ASUSUpdate[Erhöhtes Risiko]
2. ASUSUpdate von Asus herunterladen
3. ASUSUpdate installieren
4. ASUSUpdate starten und dem folgenden Dialog folgen
5. Rechner neustarten​
Nun wieder alles so einstellen, wie gewohnt.
Das Flashen war erfolgreich und ihr habt euer BIOS auf die den Letzten Stand aktualisieren.
bif1Flashen älterer Versionen
1. Bios von Asus herunterladen
3. Afudos v2.07 von hier herunterladen
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom /n /pbnc
bif1Totes Bios wiederbeleben
Bei Ami-BIOS braucht man eine Diskette, bei dem das BIOS-Image als "amiboot.rom" im Rootverzeichnis liegt. Die legt man ein, schaltet den Rechner ein und hält eine magische Tastenkombination (üblicherweise Ctrl + Home, deutsch Strg + Pos1) gedrückt. Das System sollte dann beepen, auf die Disk zugreifen und das BIOS flashen (der Bildschirm bleibt dabei aber dunkel - Flash-Ende wird durch einen oder mehrere Beeps angezeigt).
Weitere Verarbeitung folgt, bei Fehlern PM an mich.
bif2PECI-Interface
***In Arbeit***​
bif3Static Read Control
***In Arbeit***​
trsTreiber/Software
Aktuelle Treiber gibt es auf
support.asus.com
  • chipAktuelle Chipsatztreiber bei Intel
    >>Link<<
  • soundSoundtreiber
  • ahciAHCI-Einbindung
    AHCI-Einbindung bei der Neu-Installation von Win XP (für alle, die das auch wissen wollten).
    Vorbereitung (Treiberdiskette erstellen)
    1. Datei iata62_cd.exe von der Intel-Webseite runterladen
    2. Datei in d:\temp\ kopieren (Beispiel)
    3. Start>Ausführen> "d:\temp\iata62_cd.exe -a -a"
    4. Den Lizenzvereinbarungen zustimmen.
    Anmerkung zu 3. und 4.: Keine Angst, es wird nichts installiert, auch wenns so aussieht.
    5. Die Dateien aus dem Verzeichnis c:\programme\intel\Intel Matrix Storage Manager\Driver (...\Driver64 bei der
    64bit edition) auf eine Diskette speichern (direkt nach a:\ )
    Win-XP-Installation
    1. Nach dem Neustart ins Bios gehen
    2. Main > IDE Configuration > SATA Configuration [Enhanced]
    3. Configure SATA as: [IDE/RAID/AHCI]
    4. AHCI auswählen
    5. Bootreihenfolge: CD oder DVD-Laufwerk muss an erster Stelle stehen
    6. F10 und Neustart (vorher noch Win XP Installations-CD einlegen )
    7. Irgendwann gleich zu Beginn wird man aufgefordert, F6 zu drücken -> F6 drücken
    Anmerkung zu 7.: Bei mir ist dann nicht gleich was passiert, hab F6 noch paarmal weitergedrückt, ist nix
    "Schlimmes" passiert
    8. Irgendwann stellt Windows fest, dass es gar keine Festplatte gibt, aber man kann, wenn man möchte, einen
    externen Treiber einbinden (JA!)
    9. Diskette rein, Windows-Installation lädt die nötigen Dateien ohne zu mucken von der Diskette
    10. Dann wird festgestellt, dass 3 Treiber zur Verfügung stehen (RAID, AHCI, SCSI) - AHCI wählen
    11. Danach alles wie gehabt - bis es dann heisst: Fertig!
    Dank an pheeacs für dieses Tutorial]
^Inhalt
nbsStrap-Verhalten[Umschalten der internen Timings]
Auslöser der ganzen Problematik - verbunden mit dem Performanceeinbruch ist
hier zu finden.
Für die Praxis relevant ist der Verlauf der grünen Linie welcher sich bzgl. der Performance wie folgt äußert.
Beispiele:
Boot bis 400 (laut Kurvenverlauf Strap 1333 genannt) - hier im Forum gerne 1067er genannt - ein SuperPi 32M
Durchlauf:
bis dorthin ist die Welt noch in Ordnung (bis FSB 400) aber dann mit FSB 401:
wie kann man diese Situation umgehen - diesen Performanceabfall, hervorgerufen durch Verlangsamung der internen
Chipsatztimings, wenn man im Bios FSB 401 einstellt und somit in der "langsameren" Strap (1600 lt. Diagramm oder
im Forum 1333) landet? [Anm.: Strapverhalten wg. FSB1333-CPUs neu prüfen]
Mittels eines Tools wie
Clockgen
wenn man vorher mit einem FSB von max 400 gestartet hat. Aber dabei gilt es zu bedenken:
1. Boot mit 333-400 - wenn Boot mit weniger werdet ihr Schwierigkeiten haben die 400 zu erreichen (langsamere
Straps)
2. Genug Boardspannung einstellen - ein guter Wert für FSB 400-420 bei der Arbeit mit Clockgen sind 1,45V - 1,55V
auch möglich, mehr bitte nur mit WaKü.
Kurze Erläuterung bei der Einstellung des Tools:
1. Herunterladen (Siehe Link) oder eben hier:
http://www.computerbase.de/downloads/software/systemueberwachung/clockgen/?url=11187
2. Tool Starten und auf "PLL Setup" klicken
3. Im Clock Genarator Setup den Taktgeber CY28551 auswählen
4. Ignore GSB/PCI anklicken
5. Apply Selection
6. Dann über PLL Control den Takt erhöhen
Selbstverständlich muss man dieses nicht nach jedem Start einstellen,
Unter "Options" Punkt "Apply Current Setting at Startup" einfach aktivieren ;)
Resultat ist dann folgendes:
keine Verlangsamung mehr :d...
...und funktioniert auch mit 4GB
Dank an Sven Bode
^Inhalt
oceOC-Einstellungen
  • Gute Erklärung zu den wichtigsten Einstellungen bei XS.org
    >>Link<<
  • Overclocking-Guide bei tthetechrepository
    >>Link<<
  • Zusammenspiel von FSB, CPU und RAM (Teiler) (dank an Shaguar)
    >>Link<<
oclOC-Liste
oclhwmHardware-Mods
Hier Pics zum VDroop Mod
Anklicken der Bilder führt zur großen Version]
noch ein Link dazu: http://www.xtremesystems.org/forums/showpost.php?p=2007217&postcount=30
Ein Bleistift ist ausreichend dafür ;)
[Modifikationen auf eigene Gefahr und unter Verlust der Garantie]
^Inhalt
raz
Passendes Zubehör
  • Speicherkühler
    • OCZ - XTC Memory Cooler
    • Corsair Airflow RAM-Kühler
Unterschiede P5B --- P5B deluxe (WiFi):
Die Unterschiede werden in dieser Liste von Asus sehr gut dargestellt:
http://event.asus.com/2006/mb/P5B/models.html
Darüber hinaus gibt es Unterschiede in den Bios-Einstellungen, die dazu führen, dass das P5B keine so guten OC
Eigenschaften wie das P5B Deluxe (WiFi) besitzt. (Dies wird hoffentlich durch ein Bios-Update gelöst)
vDimm 1,8-2,1 / vCore 1,2125 - 1,7 (P5B)
vDimm 1,8-2,45 / vCore 1,1 - 1,7 (P5B Deluxe)
Einmal kann man die Speicher-Riegel beim P5B Deluxe mit mehr Spannung versorgen, was dazu führt, dass man sie bei
höherer Taktung stabil laufen lassen kann.
Zum anderen kann die Spannung der CPU beim P5B deluxe deutlich niedriger gesetzt werden als beim P5B
(non-deluxe). Im Fall eines Allendale hat dies z.B. den Vorteil, dass man ihn mit dem Standard-Takt auf 1,1V
laufen lassen kann, während man beim non-deluxe erst bei 1,2125V anfangen kann und somit Potenzial verschenkt
(Strom / Temperatur).
amnAnmerkungen zum Thread
allAllgemeines
Eure Mitarbeit ist natürlich erwünscht!​
chaChangelog
26.03.10 V1.00: Die jeweils letzten BIOS-Versionen nachgetragen
28.07.07 V0.41: BIOS-Flash-Guide hinzugefügt
20.07.07 V0.35: Noch mehr Infos eingefügt
20.07.07 V0.30: Weitere Infos eingefügt
19.07.07 V0.11: Geordnet, Bios-Changelogs aktualisiert
19.07.07 V0.10: Erster Release: Vorläufige Gliederung eingefügt​
danDanksagungen
  • Seppelchen dafür, mich zu überreden, den Thread zu übernehmen und Infos
  • Sven Bode für das Versorgen mit Infos
  • pheeacs für das AHCI-Tutorial
  • Berlinrider
  • Antivirus für das Erstellen des ersten Sammelthreads
  • Und die vielen anderen, die hier aktiv sind
^Inhalt
ich bin gerade so happy :)
Ich habe just gerade ein absolut totgeflashtes Asus M3N-HT Deluxe/Mempipe über die SPI Schnittstelle und ein selbstgebasteltes LPT-auf-SPI Kabel wieder ans Leben bekommen. - Dank dem entscheidenden Tipp in diesem Forum 200 Ohm Widerstände in die 4x Signalleitungen zu packen.
Das hört man gerne! ;) Freut mich das du Erfolg hattest.
Moin!
Mal ne Frage, hat das P5B Deluxe Wake on Lan?!
Ich habe schon gegoogelt , aber nix gefunden was mir weiterhilft?!?
Ja, der über PCI-E angeschlossene Port kann WOL. Im BIOS muss dazu der Punkt "Wake on PCI-E" auf enabled gestellt werden. Der müsste unter Power Management oder so stehen.
Moin!
Ich werde da mal nachschauen, glaube aber das das dort nicht steht!
Ich werde mal einen Screenshot machen, evtl heißt es ja anders! Ich bin nicht so belesen auf dem Gebiet!
Danke!
Ist es das Weiße im zweiten Bild? Das habe ich mal aktiviert!
Jo passt. Muß aber meistens im Windows Gerätemanager im Netzwerkkartentreiber zusätzlich aktiviert werden.
Ich nutze openmediavault zur Wiedergabe meinerVideos. Da gibt erscheint eine Einstellung nicht!
Mein Bruder hatte das Problem auch auf seinem ASUS P5K-E.
Das einzige, das geholfen hat, war die NB VCore im BIOS auf 1.40V anzuheben.
Das ist beim P5K-E eine Stufe höher als die niedrigste Stufe (1.25V). Beim P5B-Deluxe gibt es anstelle von 1.40V nur 1.45V. Das ist auch der von Tech ARP vorgeschlagene Wert. Hast Du mal versucht, die NB Spannung auf 1.45V zu setzen?
Tech ARP Artikel: How To Fix The PCI Express x1 Bug
momentan down, deswegen hier die Google Cache Version
Noxolos
---------- Beitrag hinzugefügt um 16:37 ---------- Vorheriger Beitrag war um 15:18 ----------
Doofer Weise habe ich mich auf Grund von Systemproblemen und Hängern dazu hinreißen lassen, das EEPROM meines Marvell 88E8056 PCIe LAN Chips mit der Revision 1.4 aus dem Gigabyte Forum zu flashen. Meine Probleme waren danach nicht beseitigt, aber der Netzwerkchip funktionierte nach wie vor, weswegen ich es so gelassen hab. (Da ich Idiot kein Backup des ROMs gemacht hatte, konnte ich eh nicht zurück :grrr:). Jetzt habe ich festgestellt, das Wake-On-LAN nicht mehr klappte :-[. Nach vielen Tests mit verschiedenen Treibern blieb nur das ROM-Update als Ursache. Mein Bruder hat mir dann ein Backup von seinem ROM gemacht und das hab ich geflasht. Er hat das P5K-E, welches auch den Marvell Chip 88E8056 nutzt.Seitdem geht Wake-On-LAN wieder.
Da aber die Aufschrift auf dem Chip nicht 100% übereinstimmt, wollte ich hier darum bitten, dass ein P5B-Deluxe Besitzer mir ein Backup von seinem Chip zieht und zukommen lässt (Ist so klein, dass man das hier anhängen kann). Dann kann ich auf Nummer sicher gehen.
Wichtig wäre, dass die Board Revision übereinstimmt und der Chip möglichst identisch ist:
Ich habe das P5B-Deluxe Revision 1.03G
und so sieht mein LAN Chip aus
Der Chip befindet sich direkt über USB 9 & 10 und rechts vom unteren LAN Port an der ATX-Blende. Das ganze ist dicht unter dem Bogen der Heatpipe.
Dazu wird das Flash-Tool benötigt:
GIGABYTE Motherboard FAQ oder direkter Download
Zum Erstellen des Backups wird nur die Datei yukonvpd.exe aus dem Archiv benötigt (lasst das andere am besten wech, damit ihr nicht aus Versehen euren Chip flasht ;)). Die Datei packt ihr auf irgendein DOS Boot-Medium (keine Boot-CD sondern USB-Stick oder Diskette, weil es unter DOS beschreibbar sein muss) und bootet dann davon wobei durch Drücken von F5 die Bearbeitung der Startdateien umgangen werden muss (es soll also in reines DOS ohne Tastaturtreiber etc. gebootet werden).
Jetzt müssen folgende Befehle eingegeben werden:
(wichtig ist das große G und das große R, außerdem dran denken, dass bei englischem Tastatur Layout das "y" auf "z" liegt und "-" auf "ß")
yukonvpd -G
yukonvpd -R P5BDelux.raw
Danach sollten sich auf dem Boot-Medium zwei neue Dateien befinden:
MACADDR.txt <= TXT-Datei mit MAC-Adresse und SUBSYS-ID
P5BDelux.raw <= ROM Backup
Das war dann alles unter DOS.
Der Aufbau der Datei MACADDR.txt sieht so aus:
<MAC-Adresse>
<MAC-Adresse>
000000000000
1043
81f8
Die beiden letzten Zeilen enhalten die SUBSYS-ID und sind die eigentlich für mich wichtigen Zeilen. Es könnte auch sein, dass das mein Fehler war, weil ich das Update gemacht habe und dabei die SUBSYS-ID von Gigabyte eingestellt wurde:
SUBSYS-ID vom P5K-E meines Bruders (vor dem "&REV_12")
SUBSYS-ID von jemandem im Gigabyte Forum (vor und nach dem Update)
Die beiden Dateien dann bitte in ein ZIP-Archiv packen und hier an einen Beitrag anhängen. Wäre toll, wenn das einer von Euch für mich tun könnte.
Vielen Dank
Noxolos
Hallo Noxolos, hast Du die Datei faq_marvell_eeprom.zip von Gigabyte zufällig noch? Danke vorab.
Ja, die müsste ich noch haben. Ich versuche heute Abend dran zu denken und sehe mal nach.
