[Sammelthread] ASUS Prime X370-Pro (AM4)
Prime X370-Pro
(AMD X370)
Inhaltsverzeichnis:
Technische Daten:
CPUAMD AM4 Socket AMD Ryzen™ 2nd Generation/Ryzen™ with Radeon™ Vega Graphics
Ryzen™ 1st Generation/7th Generation A-series/Athlon X4 Processors
Supports AM4 Socket 12/14 nm CPU
Supports CPU up to 8 cores
ChipsetX370
ArbeitsspeicherAMD Ryzen™ 2nd Generation/ Ryzen™ with Radeon™ Vega Graphics/ Ryzen™ 1st Generation Processors
4 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz
AMD 7th Generation A-Series/Athlon X4 Processors
4 x DIMM, Max. 64GB, DDR4 2400/2133 MHz
Dual Channel Memory Architecture
GrafikIntegrated Graphics in the AMD Ryzen™ with Radeon™ Vega Graphics/ 7th Generation A-Series APU
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 1.4b with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Erweiterungs-
schächte
AMD Ryzen™ Processors
2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
AMD 7th Generation A-series/Athlon™ Processors
1 x PCIe 3.0/2.0 x16 (x8 mode)
AMD X370 chipset
1 x PCIe 2.0 x16 (max at x4 mode) *3
3 x PCIe 2.0 x1
SpeichersystemAMD Ryzen™ Processors :
1 x M.2 Socket 3, with M key, type 2242/2260/2280/22110 storage devices support (SATA & PCIE 3.0 x 4 mode)
AMD 7th Generation A-series/Athlon™ Processors :
1 x M.2 Socket 3, with M key, type 2242/2260/2280/22110 storage devices support (SATA & PCIE 3.0 x 2 mode)
AMD X370 chipset :
8 x SATA 6Gb/s-Schnittstellen, grau,
Unterstützen RAID 0, 1, 10
LANIntel® I211-AT, 1 x Gigabit LAN Controller(s)
ASUS Turbo LAN Utility
ASUS LAN Guard
AudioRealtek® S1220A 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
USB
Schnittstellen
AMD Ryzen™/7th Generation A-series/Athlon™ Processors :
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau, Type-A)
AMD X370 chipset :
1 x USB 3.1 Gen 2 front panel connector Schnittstellen
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern, Type-A + USB Type-CTM)
4 x USB 2.0 Schnittstellen (4 intern)
ASMedia® USB 3.1 Gen 2 controller :
2 x USB 3.1 Schnittstellen (2 an der Gehäuserückseite, teal blue, Type-A)
Besondere
Features
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
ASUS 5X Protection III :
- ASUS SafeSlot Core: Fortified PCIe Slot prevents damage
- ASUS LANGuard: Protects against LAN surges, lightning strikes and static-electricity discharges!
- ASUS Overvoltage Protection: World-class circuit-protecting power design
- ASUS Stainless-Steel Back I/O: 3X corrosion-resistance for greater durability!
- ASUS DIGI+ VRM: 10 Phase digital power design
- ASUS Enhanced DRAM Overcurrent Protection - Short circuit damage prevention
- ASUS ESD Guards - Enhanced ESD protection
ASUS TPU :
- Auto Tuning
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Aura RGB Strip Headers
- Aura Lighting Effects Synchronization with compatible ASUS ROG devices
ASUS Exclusive Features :
- AI Suite 3
- Ai Charger
- Turbo LAN
- PC Cleaner
ASUS Quiet Thermal Solution :
- Stylish Fanless-Design Kühlkörperlösung& MOS-Kühlkörper
- ASUS Fan Xpert 4
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
- ASUS UEFI BIOS EZ Mode
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Turbo App
Anschlüsse
(Rückseite)
1 x PS/2 Tastatur/Maus Combo-Schnittstelle
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) Schnittstelle
1 x S/PDIF-Ausgang (optisch)
5 x Audio-Anschlüsse
2 x USB 3.1 Gen 2 (teal blue)Type-A
1 x USB 3.1 Gen 1 USB Type-CTM
5 x USB 3.1 Gen 1
Anschlüsse
(Intern)
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
1 x Prozessorlüfteranschluss (1 x 4 -pin)
2 x Gehäuselüfteranschlüsse (2 x 4 -pin)
1 x Aura RGB Strip Header
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x M.2 Socket 3 with M Key, type 2242/2260/2280/22110 storage devices support (SATA mode & PCIE mode)
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x CPU OPT Fan connector(s) (1 x 4 -pin)
1 x AIO_PUMP connector (1 x 4 -pin)
1 x W_PUMP+ connector (1 x 4 -pin)
1 x Clear BIOS-Taste
1 x System panel(s) (Q-Connector) (Chassis intrusion header is inbuilt)
1 x 14-1 pin TPM connector
1 x COM port header
ZubehörUser's manual
ASUS Q-Shield
4 x SATA 6Gb/s-Kabel
1 x M.2 Screw Package
1 x Supporting DVD
1 x SLI HB BRIDGE(2-WAY-M)
1 x Q-connector(s) (1 in 1)
  • Weitere und detailliertere Informationen gibt es auf der Herstellerseite.
Bilder:
Nach oben
weitere Bilder:
Uefi Bilder:
Nach oben
Bilder aus Bios 0504/0803
AI Tweaker
weitere Bilder:
Main / Exit
Advanced
Monitor
Boot
Tools
Software:
Nach oben
Nützliche Links
Nach oben
Reviews:
Nach oben
X370-Pro vs X470-Pro
Nach oben
  • Lohnt es sich auf das X470-Pro zu wechseln?
    Es wird sich nur lohnen, wenn man aus seinem RAM das letzte bisschen Leistung heraus holen will.
    Ansonsten gibt es keine großen Veränderungen im Vergleich zum X370-Pro.
    + Hohe RAM Takraten bis DDR4-3600 möglich (Nur in Slot A2,B2)
    + Geringerer Verbrauch (~ 5W weniger)
    + Zweiter M.2 Slot
    + Dritter Chassis Fan Anschluss
    + Erneut gutes VRM Design
    + Chipsatz Temperatur blieb immer unter 50°C (kann aber von Board zu Board schwanken)
    = Gleiche BIOS Einstellungen
    = Gleiche Bootzeit
    - Keine hohen RAM Taktraten bei Vollbestückung möglich (max ~ DDR4-2933)
    - Nur 6 SATA Ports
    - Aktueller Preis von ~160 Euro
    - BIOS Bugs vorhanden
    - I/O Deckel lässt sich nur entfernen, wenn man auch den VRM Kühler demontiert
  • Tests / Vergleiche
    Alle Tests sind Schnelltests mit teils Standardeinstellungen
    RAM Overclocking Vergleich:
    X370-Pro Bios 4008 | X470-Pro Bios 4008
    RAMTest ~1000%
    Max 1.35v Dram Voltage
    R5 1600X​
    R5 2400G​
    R7 2700X​
    Samsung B-Die
    X370-Pro
    X470-Pro
    DDR4-3133
    DDR4-3400​
    DDR4-3266
    DDR4-3400​
    DDR4-3266
    DDR4-3400​
    Hynix MFR
    X370-Pro
    X470-Pro
    DDR4-3066
    DDR4-3266​
    DDR4-3133
    DDR4-3333​
    DDR4-3133
    DDR4-3333​
    Höhere RAM Spannung mit optimierten Timings:
    DDR4-3533​
    CPU Overclocking Vergleich:
    Prime95 1h min Voltage @ 4.00GHz | Cinebench bei gleichen Settings
    Beide Boards nehmen sich nicht viel. Je nach CPU und Temperaturen schwanken die erreichten Ergebnisse leicht.
    2700X​
    Prime95​
    Cinebench​
    X370-Pro
    X470-Pro
    4.20GHz | 1933 Punkte
    4.20GHz | 1921 Punkte
  • X470-Pro genauer angeschaut
    Board
    Klicken für größere Ansicht
    VRM, AURA und Chipsatz
    VRM
    Kühler sind etwas länger, dafür aber niedriger geworden. Unter Last (4.00GHz, 2700X) sind sie nur Handwarm geworden.
    Br0da schrieb:
    Mit dem Prime-Pro bekommt man abermals ein sehr starkes VRM in Relation zum Preis.
    Es sind in der Tat nur die NexFETs den powIRstages gewichen.
    Ich würde mal behaupten dass jedenfalls mit Hinblick auf die VRM Hardware nur derjenige dem Aufpreis zum Hero zahlen muss, der Extrem OC betreiben will.
    Aura
    Das Board besitzt 6 LEDs. Vier davon unter dem Chipsatz Kühler, zwei unter dem I/O Shield
    Chipsatz
    Das Pad ist im Vergleich zum X370 etwas größer, bedeckt aber immer noch nicht die komplette Fläche.
    Die Temperatur blieb trotz warmen Raumtemperaturen (~25°C) immer unter 50°C.
Uefi / Downloads:
Nach oben
Offizielle Bios Dateien
- Please flash only with EZ Flash 3 Utility (Windows is not safe)
- Load and save default Settings before flashing
- Downgrade to an older AGESA Version is not possible with EZ Flash 3 Utility
Bios 6026
Update AMD AM4 AGESA V2 PI 1.2.0.6b
Improve system performance and stability
Add Renoir Support
Add Vermeer Support
Removed Bristol Ridge Support
Bios 5606
Support Windows 11 by default
Bios 5603
Improve system stability
Bios 5601
Update AGESA to ComboAM4 1.0.0.6
Improve DRAM stability
Improve system compatibility
Fixed AI suite 3 issue
Fixed HDMI and DP sound issue
Bios 5220
Update AGESA to ComboAM4 1.0.0.3ABBA
Bios 5216
1.Improve system performance.
2.Update AGESA to ComboAM4 1.0.0.3ABB
a.Fixes a compatibility issue with Destiny 2
b.Fixes an issue with certain Linux distros
c.Removes Gen 4 support when using Ryzen 3000 CPUs
3.Improves EZFlash performance to reduce boot time.
Bios 5204
Update AGESA to ComboAM4 1.0.0.3AB to improve compatibility.
Recommend updating the BIOS via EZ Flash
Bios 5008
Update AGESA to ComboAM4 1.0.0.2 to improve compatibility.
Recommend updating the BIOS via EZ Flash.
Bios 4801
Update AGESA to ComboAM4 0.0.7.2A for next-gen processors and to improve CPU compatibility
Bios 4602
Update AGESA to Combo-AM4 0.0.7.2 for the upcoming processors.
Added PBO Option in Ai Tweaker
Upate AMD chipset driver to 18.50.16 or later before updating BIOS if you use a Raven Ridge APU.
Alte Profile nicht laden. Diese sind inkompatibel und können zu einem Soft Brick führen!
Zurück flashen auf AGESA 1.0.0.6 über EZ Flash 3 ist nicht möglich.
Bios 4406
Update AGESA to Combo-AM4 0.0.7.0 for the upcoming processors and improve some CPU compatibility
Bios 4207
Update AGESA to PinnaclePI 1.0.0.6
Improve compatibility and performance with for Athlon™ with Radeon™ Vega Graphics Processors
Bios 4024
Bios 4012
Bios 4011
Update AGESA to PinnaclePI 1.0.0.2 + SMU 43.18
Bios 4008
Bios 3907 BETA
Bios 3805
Bios 3803
Update AGESA to PinnaclePI 1.0.0.0a
Bios 3404
Bios 3203
Nicht auf das "neuste" 3203 Bios vom 25.01.18 updaten!
Bios ist vom 09.11.17 und war damals mit einigen Komponenten inkompatibel.
Bios 3402
Bios 3401
Update AGESA to 1071 (Support for Raven Ridge APUs)
Ein zurück flashen auf eine ältere Version ist danach nicht mehr möglich
Bios 3203
Bios wurde von Asus zurück gezogen.
Bios 1201
Bios 1001
No changelog available
Bios 0902
Update AGESA to 1.0.0.6b
(Fixed PState Bug and PState Brick)
Bios 0812
Improve System stability (Removed CBS items)
Bios 0810
Enhance Memory Compatibility for Ryzen CPU
Improve LAN stability before entering to OS
Custom PState OC kann einen Bios Brick verursachen >>LINK<<
Bios 0807
Add CBS items
Bios 0805
Update AGESA to 1.0.0.6a
Bios 0803 [BETA]
Bios 0801 [BETA]
Bios 0614 [BETA]
Bios 0612
Bios 0604
Update AGESA to 1.0.0.4a
Hinweis: Nicht flashen wenn ihr Kingston HyperX Ram verbaut habt
Bios 0515
Improve system stability.
Enhance memory compatibility
Improve CPU temperature monitor function
Bios 0511
Make CPU temperature more precise
Bios 0504
Bios 0502
Downgrade mit offiziellem Bios
Bitte nur anwenden, wenn es mit dem internen EZ Flash 3 Utility nicht geht.
Anwendung auf eigene Gefahr
Anleitung und Bild:
- Originale Bios Datei herunterladen
- Umbenennen in zb. 1201.cap
- Bootbaren FAT32 USB Stick erstellen
- Bios Datei und Afudos auf den Stick kopieren
- Bios auf Werkseinstellungen zurück setzen
- Vom USB Stick booten
- Mit folgendem Befehl flashen. Ohne >><< Zeichen
- Falsche Eingabe der Befehle führt zum Brick!
>> afudos NameDerDatei.cap /x /p /b /n /k <<
afudos+NameDerDatei.cap+/x+/p+/b+/n+/k
+ steht für ein Leerzeichen
- Update kann mehrere Minuten dauern
- USB Stick entfernen und mit Strg+Alt+Entf neu starten
- Default Settings laden, neustarten und nochmal ein CMOS Reset durchführen. (Zur Fehlerreduzierung)
Bedeutung:
/x = Do not check ROM ID
/p = Program Boot Block
/b = Program Main BIOS
/n = Program NVRAM
/k = Program all non - critical blocks and ROM Holes.
  • RyZenPstateCalc by noko: Excel | XML
    (Zum ermitteln der Hex-Werte für PState OC)
BIOS Modding / LuxxMod:
Nach oben
  • Bios selber modden / nach seinen Wünschen anpassen
    Da jeder etwas andere Wünsche hat, wie das perfekte Bios aussieht, poste ich hier nun eine Anleitung zum selber machen.
    Beachte:
    Jegliche Änderung geschieht auf eigene Gefahr.
    Ich bin nicht verantwortlich für Schäden während oder nach dem flashen.
    Ihr könnt durch flasche Einstellungen (falsches Modding oder falsche Einstellungen in den freigeschaltenen Optionen) das Board bricken.
    Diese Anleitung gilt nur für das Prime X370-Pro, sollte vom Prinzip her aber mit allen AMI Bios Versionen (AM4 Boards) funktionieren.
    Anleitung BIOS Modding:
    Nicht mehr aktuell!
    ©Reous/HWLuxx
    If you copy this guide, dont forget to mention this thread.
    English
    made by L.
    Russian
    made by 1usmus
    French
    mady by L.
    1: Benötigte Programme:
    2: Einstellungen mit AMIBCP freischalten:
    • Fertige von deinem Bios eine Kopie an.
    • Öffne AMIBCP und lade darin die Kopie deiner Bios Datei.
    • Unter "Setup Configuration" seht ihr die gleiche Struktur wie in eurem Bios.
    • Nun könnt ihr bestimmen ob ihr Einstellungen freischalten oder Einstellungen ausblenden wollt.
    • Um eine Einstellung auszublenden markiert ihr die entsprechende Zeile, macht bei der Spalte "Show" einen Doppelklick und ändert ihn auf "No"
    • Um eine Einstellung freizuschalten markiert ihr die entsprechende Zeile, macht bei der Spalte "Access/Use" einen Doppelklick und ändert ihn auf "USER" oder "Superuser" (beide Optionen haben die gleiche Wirkung)
    • AMD CBS Menü kann mit AMIBCP nicht freigeschalten werden. Siehe dazu Punkt 3+4.
    • Das Bios speichern, nachdem alle Änderungen durchgeführt wurden. Das speichern kann je nach System etwas dauern.
    • Durch Modifikationen am Bios geht die digitale Signatur verloren. Die Meldung mit OK bestätigen.
    3: AMD CBS aus Bios extrahieren:
    • Öffne UEFITool und lade die zuvor abgespeicherte Bios Datei.
    • Öffne das Untermenü von AMI Aptio capsule.
    • Mache einen Rechsklick auf "UEFI image", wähle "Extract as is..." und speichere das Image ab.
    • Das abgespeicherte Image muss nun 2 KB (16.384 KB) kleiner sein als das original Image.
    • Öffne das extrahierte Image erneut im UEFITool.
    • Bis Bios 1201:
    • Öffne die Suche (Strg+F), gib bei "GUID" folgendes ein "F639D37E" und bestätige mit OK.
    • In der unteren Spalte "Messages" nun einen Doppelklick auf "GUID pattern "F639D37F-.....- ..." machen.
    • Ab Bios 3401:
    • Öffne die Suche (Strg+F), gib bei "GUID" folgendes ein "A5E369C8" und bestätige mit OK.
    • In der unteren Spalte "Messages" nun einen Doppelklick auf "GUID pattern "A5E369C8-.....- ..." machen.
    • Öffne das Untermenü vom Image "F639D37E..." (bzw "A5E369C8")
    • Mache einen Rechsklick auf die "PE32 image section" und speichere die Datei mit "Extract as is..." ab.
    • Die abgespeicherte Datei sollte nun so aussehen (Name "cbs" habe ich selbst gewählt).
    • Öffne nun den Universal IRF Extractor und lade die cbs.sct. Durch drücken auf Extract wird eine Text Datei (cbs IFR.txt) erstellt.
    4: AMD CBS bearbeiten:
    • Öffne die zuvor extrahierte Textdatei. Darin wird die CBS Datei leserlich dargestellt.
      Man sieht darin alle vorhandenen Einstellungen inklusive dem Hexcode.
      Bei unseren Board sind nur 4 Optionen freigeschalten. Core Performance Boost, Memory interleaving, IOMMU und Global C-state Control (grün markiert)
      Rot markiert sind Optionen, welche aktuell ausgeblendet sind.
      Die Liste geht nach unten noch viel weiter.
    • Einzelne Einstellungen "Setting" sind folgendermaßen unterteilt:
      Bezeichnung im Bios (grün), Einstellmöglicheiten (blau) und der dazugehörige Hexcode.
      Diese lassen sich beliebig mit dem Hex Editor hin und her verschieben.
      Man muss also nicht die kompletten Untermenüs freischalten, sondern kann zb das Setting "BankGroupSwap" aus dem Untermenü "UMC Common Options" einfach auf der Startseite einfügen.
      Ebenso kann man vorhandene Settings in den Untermenüs verschwinden lassen.
      Wichtig dafür ist nur, mit dem HxD Editor, den passenden Hexcode an der richtigen Stelle einzufügen.
    • Ist dies einem zu aufwendig, der kann auch einfach nur die Untermenüs freischalten.
      Dazu einfach mit dem HxD Editor den Hexcode "46 02" (True) in "47 02" (False) umändern.
    • Hat man alle Änderungen durchgeführt und abgespeichert, empfiehlt es sich noch einmal eine Textdatei mit dem Universal IFR Extractor anzulegen.
      Hat diese Textdatei die gleiche Größe (+/- 1 KB) wie die erste Textdatei, dann hat man alles richtig gemacht.
      Hat die zweite Textdatei nur eine Größe von einem KB (1 KB), dann hat man einen Fehler gemacht und man muss noch einmal von vorne beginnen.
    5: AMD CBS ins Bios einfügen:
    • Öffne wieder das UEFITool und lade dein Bios.
    • Suche den "GUID" "F639D37E-..." (bzw "A5E369C8-...")
    • Mache einen Rechsklick auf die "PE32 image section" und wähle "Replace as is..." aus.
      Lade und öffne deine gemoddete CBS Datei. Es sollte danach wie folgt aussehen.
    • Bios abspeichern, indem ihr auf "File => Save Bios file..." klickt.
      Ihr könnt nun auch einen vereinfachten Namen vergeben wie zb.: "0805Mod.rom"
      Wichtig: Die Datei darf weiterhin nur 16.384 KB groß sein.
    • Fertig ist das gemoddete Bios.
    6: Bios flashen:
    • Da die digitale Signatur nicht mehr vorhanden ist, ist es nicht mehr möglich das Bios über die interne EZ Flash Funktion zu flashen.
      Wir müssen auf das AMI eigene Flashtool "AFUDOS" ausweichen.
    • Erstelle einen DOS Startup Disk
      Stecke einen USB Stick ein, installiere "HP USB Boot Utility" und öffne danach das Programm "HP USB Disk Starage Format Tool".
      Setze einen Haken bei "Create a DOS startup disk" und suche nach dem im Download enthaltenen "usbdos" Ordner.
      Mit "Start" startet ihr den Formatierungsprozess.
      (Alternatives Programm: Rufus)
    • Kopiere nun das Programm "AFUDOS" sowie das gemoddete Bios auf deinem USB Stick.
    • Starte den PC neu, lade und speichere im Bios die Standardeinstellungen.
    • Boote vom USB Stick aus.
    • Gib folgenden Befehl ein: "afudos xxxx.rom /GAN" (xxxx ersetzen durch den Namen, den ihr vorher vergeben habt).
    • Der Lese-, Löschen-, Schreib- und Verifizierungsprozess startet nun automatisch.
    • Entferne den USB Stick und starte den PC mit "Strg + Alt + Entf" neu.
    • Ich hoffe ihr hattet Erfolg :)
    Gebricktes Board / Bios wiederherstellen:
    ©Reous/HWLuxx
    Sollte der seltene Fall eintreten und ihr das Board brickt, gibt es keine kostenlose Möglichkeit mehr zur Rettung.
    Durch ein modifiziertes Bios habt ihr auch keine Garantieansprüche mehr. Ob ihr es dennoch probiert ist euch überlassen.
    Wer auf lange Sicht, sowie zukünftige Boards modifizieren will, der sollte sich auch entsprechende Hardware besorgen.
    Die Rede ist von einem USB Flash Programmer.
    Ich beschränke diese Anleitung auf den "Revelprog IS" Programmierer. Dieser ist einer von den teuren aber ist Hardware- und Softwaretechnisch ausgereift.
    Auf dem Asus Prime X370-Pro ist ein Winbond 25Q128FW Bios Chip verbaut.
    Man hat zwei Möglichkeiten diesen neu zu flashen.
    [*]Letzteres ist die einfachere und schnellere Methode. Kabel lassen sich unkomplizierter einstecken als eine Klammer auf einem kleinen Chip anzubringen.
    1: Was wird benötigt:
    2: Verkabelung
    • JSPI1 mit USB Programmer verbinden.
      Auf richtige Verkabelung achten. Pin1 zu Pin1, Pin2 zu Pin2, ... .
    • Nachdem man alles komplett angeschlossen hat, kann man zur Fixierung Tesa Klebeband außen herum wickeln.
      Somit behält man auch nach entfernen der Kabel die richtige Pin Belegung bei.
    3: BIOS flashen:
    • Software "REVELPROG-IS_v1-6" öffnen
    • Richtigen BIOS Chip auswählen
    • USB Kabel verbinden.
    • Als Funktionstest einmal den BIOS Chip lesen.
    • Originale BIOS Datei laden.
    • Durch klicken auf "Write buffer to memory" wird der Chip automatisch gelöscht, beschrieben und verifiziert.
    • USB Kabel entfernen.
    • Verbindungskabel zum USB Programmer entfernen.
    • Mainboard wurde erfolgreich wiederbelebt.
MODS - Anwendung auf eigene Gefahr.
BiosMod 5606X
BCLK Spread Spectrum freigeschaltet.
Erweiterte DC Lüftersteuerung für AIO_PUMP und W_PUMP
- Min Lüftergeschwindigkeit kann auf 0% reduziert werden (vorher 60%)
- Mittel Lüftergeschwindigkeit kann auf 0% reduziert werden (vorher 60%)
- Option Allow Fan Stop hinzugefügt
AMD CBS freigeschaltet
ASPM Support hinzugefügt
Weitere Optionen hinzugfügt
Anleitung zum flashen ist im Download enthalten.
Ältere Versionen
BiosMod 5603X
- Max Temperatur von 75°C auf 85°C erhöht.
AMD CBS freigeschalten
Mod Profile 5220
Verwendbar mit dem originalen 5220 Bios (Nur verwendbar mit einer Zen2 CPU).
- BCLK Spread Spectrum Disabled
Mod Profile 5204
Verwendbar mit dem originalen 5204 Bios (Nur getestet mit einer Zen2 CPU).
- BGS Enabled / BGS_ALT Disabled (BGSen.CMO)
- BCLK Spread Spectrum Disabled (SS disabled.CMO)
- BCLK Spread Spectrum Disabled / BGS Enabled / BGS_ALT Disabled (SSdis BGSen.CMO)
BiosMod 5220X
BCLK Spread Spectrum freigeschalten.
Funktioniert nur mit einer Zen2 CPU!
AMD CBS freigeschalten (Advanced)
Mod Profile 4602
Verwendbar mit dem originalen 4602 Bios.
Für bessere Performence mit Dual Rank RAM oder Vollbestückung 4x Single Rank RAM (Nur bei Verwendung von Auto Subtimings).
- BGS Enabled + BGS_Alt Disabled (BGS EnDis.CMO)
BiosMod 5204X
Funktioniert eventuell nur mit einer Zen2 CPU!
Weitere Änderungen:
Bios startet standardmäßig im "Advanced Mode"
BCLK Spread Spectrum hinzugefügt (Ai Tweaker)
VDDP Voltage hinzugefügt (Ai Tweaker)
C6 Mode hinzugefügt (CPU Configuration)
Asmedia USB 3.1 Battery Charging Support hinzugefügt (Onboard Devices Configuration)
- Geänderte Hauptansicht
- Zen Common Options
- DF Common Options
- UMC Common Options
- NBIO Common Options
Erweiterte Booteinstellungen freigeschalten (Boot)
BiosMod 4602X
Weitere Änderungen:
- DF Common Options
Mod Profile 4207
Verwendbar mit dem originalen 4207 Bios.
- Precision Boost Overdrive Enabled (PBOEnabled.CMO)
- Bus Speed Spread Spectrum Disabled + Precision Boost Overdrive Enabled (BusSS+PBO.CMO)
- Bus Speed Spread Spectrum Disabled (BusSpread.CMO)
BiosMod 4207X
Option für Bus Speed Spread Spectrum hinzugefügt
- Inklusive Precision Boost Overdrive für Ryzen+
Weitere Änderungen:
My Favorites entfernt
- DF Common Options
- FCH Common Options
BiosMod 4008X v2
Weitere Änderungen:
- DF Common Options
BiosMod 3907B BETA
Option für HPET hinzugefügt
HPET bitte auf Auto oder Enabled lassen - Stabilitätsprobleme
- Mittel Lüftergeschwindigkeit kann auf 20% reduziert werden (vorher 60%)
Weitere Änderungen:
- DF Common Options
BiosMod 3803M
Weitere Änderungen:
Zum testen:
XFR 2.0 Configuration
Mem P-State
- DF Common Options
BiosMod 1201M BETA
Erweiterte Lüftersteuerung für AIO_PUMP und W_PUMP
- Min/Mittel Lüftergeschwindigkeit kann für DC Lüfter auf 20% reduziert werden (vorher 60%)
Alle Änderungen von den vorherigen Mods
BiosMod 1001M BETA
Bus speed ist jetzt bei ungefähr 100MHz
Alle Änderungen vom Bios 0902-1
BiosMod 0902-1
- DF Common Options
Overclocking
Nach oben
(1) Nicht höher als 1.425v (Allcore) einstellen (laut Robert Hallock, AMD). Eine höhere Spannung kann die Lebensdauer verkürzen.
Empfehlung: Sweet Spot ausloten und nicht darüber hinaus gehen.​
(2) Spannung unter anderem für den Speichercontroller. Je höher der Ramtakt desto höhere Spannung wird benötigt.
Empfehlung: Je niedriger desto besser, maximal 1.10v[SUP]*1[/SUP].
Eine zu hohe SOC Spannung kann zu Leistungsverlust im L3 Cache führen (Read, Write, Copy).
(3) Spannung für den Arbeitsspeicher. Laut Robert Hallock ist es möglich diese bis auf 1.50v zu erhöhen.
Empfehlung: Für 24/7 bis zu 1.35v.​
(4) Hilfe um den Arbeitsspeicher stabil zu bekommen. Nicht höher als 96 Ohm gehen.
Empfehlung: Siehe Spoiler.
Dies sind nur Richtwerte.
Samsung B (SR)2x8GB53.3 Ohm
Samsung B (SR)4x8GB53.3 Ohm
Samsung B (DR)2x16GB80/96 Ohm
Samsung B (DR)4x16GB43.6 Ohm
Hynix A (DR)2x8GB53.3 Ohm
Hynix A (DR)4x8GB40 Ohm
(5) Leichte Erhöhung der Spannung hilft bei hohen RAM Taktraten.
(6) VTTDDR Spannung immer auf 50% der Ram Spannung einstellen. Bei RAM: 1.350v => VTTDDR: 0.675v.
(Wird ab Bios 0803 automatisch eingestellt)
  • Welche CPU Spannung ist die richtige?
    Nach bisherigen Erfahrungen hat sich die SVI2 (CPU VDD) Spannung in HWInfo (Aida64 und HWMonitor) als am zuverlässigsten herausgestellt.
    CPUz schwankt von Board zu Board sehr stark und ist daher als Richtwert nicht geeignet.
    Weitere Infos siehe: HWInfo Entwickler Martin | Welche Spannungsangabe stimmt? - Planet3dnow
    ==> Der User barnacle2k hat mit einem Oszilloskop nachgemessen und nur Schwankungen im normalen Bereich festellen können ~3mV (0.003v).
    Jedoch gewisse Schwankungen sind unvermeidlich bei großen CMOS Schaltungen, die Änderungsrate im Stromverbrauch kann absolut gigantische Ausmaße annehmen. Wir reden hier immerhin von ~6 Milliarden Transistoren die Schalten.
    Update:
    Messungen mit Fest eingestellter Spannung (Achtung NOCH feinere Skalierung):
    IDLE
    LOAD:
  • Load Line Calibration
    Zur besseren Spannungsstabilisierung kann man LLC verwenden.
    Bei einer zu hoch gewählten LLC können Spannungsspitzen entstehen, welche die CPU beschädigen.
    Hinweis: Bios Versionen bis einschließlich 0604 haben noch einen LLC Bug. Die CPU wird dann ab Level 2+ einfach abgeschalten.
    (Freeze in Windows, Blackscreen in Windows, Kein Boot möglich bei Neustart oder nach betätigen des Reset Tasters)
    Gefixt ab Bios 0612. Ein downgrade auf ältere Versionen ist vermutlich deshalb auch nicht mehr möglich.
    Tritt weiterhin ein Blackscreen auf hat dies andere Ursachen.
    CPU Load Line Calibration (0810):
    SOC Load Line Calibration (0810):
    Messpunkte für Digitalmultimeter:
    Anwendung auf eigene Gefahr. Falsche Handhabung kann die Hardware zerstören.
  • BCLK Takt
    Der BCLK Takt zeigt in Ausleseprogrammen nur ~99.80MHz an oder springt hin und her.
    Hierbei handelt sich um einen Auslesefehler. Der Takt kann nicht durch einen hardwaretechnisch verbauten Sensor ausgelesen, sondern nur errechnet werden.
    Quelle: Asus / HWInfo
  • Arbeitsspeicher übertakten
    Bei hohen Taktraten kommt Ryzen am besten mit Samsung 8Gbit B-Die bestücktem Ram aus.
    (Siehe: Die ultimate HARDWARELUXX Samsung 8Gbit B-Die Liste)
    Hier noch eine sehr gute Anleitung, geschrieben von @Stunrise:
    Anleitung zum analytischen Übertakten des Arbeitsspeichers
    Programme um den Ram zu überprüfen, erstellt durch @emisarry42:
    [Übersicht] Speichertestprogramme 2018
    Anbei eine Liste zur Orientierung:
    HerstellerRankMaximaler TaktBeispiele
    SamsungSingle
    Dual
    3200 - 3466
    2933 - 3066
    F4-3200C14D-16GTZ
    F4-3200C14D-32GTZ
    HynixSingle
    Dual
    2933 - 3066
    2800 - 2933
    CMK16GX4M2B3200C16
    MicronSingle
    Dual
    2933 - 3066
    2800 - 3066
    BLE2C8G4D30AEEA
    Folgende Punkte sollten zum übertakten gegeben sein:
    - Mindestens Bios 0805 installiert.
    - Bei zwei Modulen immer Slot A2, B2 benutzen (Grau).
    - Bei Ramtakt größer 2666 nur gerade CL Timings eingeben.
    Weiterer Hinweis/Anleitung zum übertakten:
    Mein Asus PRIME X370-PRO verhält sich "interessant". Man darf auf keinen Fall zu viele Settings auf einmal ändern beim RAM, dann geht nix mehr. Wenn man naber immer nur ein Setting ändert, speichert, neustartet, dann geht da tatsächlich was. Habe gerade testweise Kingston HyperX 3200 MHz drinnen, der jetzt schonmal 2666 MHz schafft. Erst die Latenzen recht konservativ gewählt, gespeichert, neugestartet, dann die Spannung auf 1,295V festgesetzt, gespeichert, neugestartet und dann die Frequenz auf 2666 MHz gesetzt und er startet einwandfrei.
    Wenn ich alles auf einmal setze, dann geht nix. Mal weiter testen
    Und weiter geht's 2933 MHZ ! Bei 3200 bootet er nicht. Mal sehen ob ich das noch irgendwie hinbekomme.
    Quelle
    RAM lässt sich nicht höher als 2133 takten
    Lässt sich der Ram nicht höher als 2133 takten, so ist in den meisten Fällen ein defekter Ram Riegel die Ursache.
    Folgende Punkte kann man probieren:
    - Auch wenn die Ram Riegel eingerastet sind, lassen sie sich immer noch ein Stück weiter rein drücken.
    - Ram Riegel quer tauschen
    - Slot auf Verschmutzung überprüfen und gegebenfalls reinigen.
    - Ram Riegel im gleichen Slot, einzeln testen. Startet der Rechner mit einem Riegel nicht, ist dieser defekt.
    SOC Voltage
    Die SOC Voltage wird ab einem Takt von DDR4-2800 automatisch auf 1.10v angehoben, davor jeweils in 0.05v Schritten erhöht. Diese Spannung sollte ausreichen um Taktraten von bis zu 3333+ zu erreichen.
    Bei einigen Users hat sich eine zu hohe SOC Spannung (1.10v) aber auch als Ursache für Instabilitäten herausgestellt. Am besten ist es, die passende Spannung selbst heraus zu finden. Sprich von unten nach oben tasten, bis das System stabil ist.
    CLDO_VDDP Voltage
    In manchen Konfigurationen treten sogenannte Memory Holes auf. Das macht sich dann dadurch bemerkbar, dass das Mainboard z. B. mit 2933 und 3200 bootet, mit 3066 aber nicht. Memory Holes entstehen im Zusammenwirken von CPU und RAM und sind sehr individuell. Kontern kann man ein MH durch Verändern der CLDO_VDDP. (Quelle und Text von @curious)
    (Aktuell nur verfügbar in Bios 0807, 0810, 3803+ und BiosMods)
    Der Spannungsbereich, in dem man sich bewegen sollte, reicht von 700-1000mV. Da sich die Effekte dieser Spannung in einer Art Wellenform auswirken, ist ein Wert, der für eine Taktstufe passend ist, für die nächste vielleicht schon wieder ungeeignet. Außerdem gilt hier nicht "höher = besser". 940mV kann den gleichen positiven Effekt haben, wie 980mV, während z. B. 960mV nicht funktioniert.
    Mit Verschieben der CLDO_VDDP kann man aber auch die Stabilität günstig, manchmal entscheidend beeinflussen. Da die 3333 MT/s aktuell die höchste erreichbare Taktstufe für Dual Rank B-die darstellen, ist sie nicht als "Loch" zwischen ansteigenden Taktstufen erkennbar. Wenn also die 3333 partout nicht booten wollen oder regelmäßig Fehler in Stresstests auftreten, kann man nach einem mV-Bereich suchen, der das behebt. Das ist aber ein äußerst zeitaufwendiges Vergnügen, da man sehr methodisch vorgehen muss und aufgrund der feinen Granulierung viele Stabilitätstests benötigt, um die Resultate unterscheiden zu können (Link1, Link2)
    Ai Tweaker -> DRAM Timing Control -> CLDO_VDDP
    Um den unter CLDO_VDDP eingegebenen Wert speichern zu können, ist ein Cold Reset vonnöten. Das geht folgendermaßen:
    Im BIOS die Einstellungen speichern und neu starten (F10). Sobald der Bildschirm schwarz wird, die Reset Taste drücken und dann booten lassen. Der Reset muss erfolgen, nachdem die Einstellungen gespeichert wurden und bevor das Mainboard den Bootprozess beginnt
    BankGroupSwap
    Ab Bios 3803 ist diese Option Standardmäßig deaktiviert. Eine Änderung ist auch mit Mods nicht möglich.
    Dies ist eine mit AGESA 1006 neu eingeführte Option, um noch etwas mehr Leistung aus dem Ram heraus zu holen (Nur verfügbar mit Bios 0807, 0810 und BiosMods). Durch deaktivieren dieser Option, nur bei Single Rank Rams, erhält man zum Beispiel in Spielen mehr FPS.
    Bei Dual Rank sollte diese Option eingeschaltet bleiben.
    pcgameshardware schrieb:
    Für Besitzer von Single-Rank-RAM ist die Option "BankGroupSwap" einen Blick wert. Die Voreinstellung lautet "Auto", durch das Setzen auf "Disabled" verändern sich die Leistungswerte: Während Aida64 eher eine Verschlechterung signalisiert, sprechen praxisnahe Benchmarks gut auf die durchgeführte Änderung an: Das Komprimieren und Verschlüsseln unseres rund 3 GB großen Archivs nimmt 12 Sekunden weniger Zeit in Anspruch, was einer Verkürzung um 5 Prozent entspricht. Auch der Hexer Geralt läuft etwas flotter durch die Lande: Die Framerate in The Witcher 3 erhöht sich von 110,0 auf 113,6 Fps - ein Plus von immerhin 3 Prozent. Wie gewohnt verpufft der RAM-Effekt im GPU-Limit. Alle Ergebnisse in der Übersicht:
    test
    Quelle
    Timings von "The Stilt"
    Timings für DDR4-3200+, Samsung und Hynix (Getestet auf einem CH6. Werte nur zur Orientierung).
    Den größten, messbaren Leistungssprung erreicht man damit, indem man die Werte "TrdrdScl_SM" und "TwrwrScl_SM" auf minimal 2 reduziert.
    Getestet by The Stilt:
    Samsung 8Gbit B-Die (Single Rank):
    3200 Safe 1.35v
    3200 Fast 1.35v
    3333 Safe 1.35v
    3333 Fast 1.35v
    Hynix 8Gbit AFR/MFR (Single Rank):
    AFR 3200 Safe 1.340v
    AFR 3200 Extreme 1.405v
    MFR 3200 Safe 1.365v
    MFR 3200 Fast 1.390v
    Nützliche Programme
    Ryzen Timing Checker
    Anzeige der wichtigsten Timings und Einstellungen
    --Download v1.04--
    Made by The Stilt
    Ryzen DRAM Calculator
    Hilfe um passende Timings, Spannungen, RTT, procODT und CAS_BUS Einstellungen zu finden.
    --Download--
    SPD Checker / Writer
    Programm un das SPD Profil vom Ram zu überprüfen, zu speichern oder zu flashen.
    --Download v02--
    Made by @elmor
    spd_check.exe zum überprüfen bzw speichern
    spd_write.exe zum flashen
    Stabilitätstest
    Prime95
    HCI Memtest
    RAM Test - Karhu Software
    TPU MemTest64
    Google Stresstest
Q&A
Nach oben
  • Blackscreen / Bluescreen im Idle oder bei geringer Last
    Spontan auftretende Blackscreens im Idle oder bei geringer Last können durch Monitoring Tools oder OC Tools verursacht werden.
    Bekannte Beispiele sind zb.: HWInfo, Asus Ai Suite oder auch der MSI Afterburner.
    Im Zweifelsfall einfach alle Monitoring/OC Tools deaktivieren oder deinstallieren
  • CPU taktet nur auf 1.55GHz bzw auf 2.20GHz
    Hierbei handelt es sich um einen PState Bug. Dieser betrifft alle AM4 Mainboards und tritt nun in manchen Fällen auf. Behoben ab Bios 0902 bis 1201. Bei neueren Version kann der Bug wieder auftreten.
    Man kann es umgehen, indem man die CPU Spannung nur über den Offset einstellt ,OC Tools (zb ZenStates) verwendet oder über Custom PStates (Bios 0807/0810) einstellt.
  • Aura Beleuchtung funktioniert nicht mehr
    Das Board verfügt über 8 RGB LEDs. Diese können softwarebedingt ausfallen.
    Inzwischen gibt es ein inoffizielles Programm (made by elmor), mit desen Hilfe man die LEDs wieder zum Leben erwecken kann.
    Download: AuraFix X370-Pro 1.0
    Download: AuraFix X370-Pro 2.0
    Das Programm wurde für das CH6 entwickelt, funktioniert aber nach minimaler Änderung auch mit dem Prime X370 Pro.
  • CPU P-States ändern [BETA]
    Windows: Mit dem Programm ZenStates ist es möglich unter Windows Takt und Spannung für P0, P1 und P2 zu ändern.
    Hinweise und Download im Spoiler:
    Offizieller ASUS ZenStates Thread
    ZenStates wurde ursprünglich für das Crosshair 6 Hero entwickelt, funktioniert aber auch mit dem Prime X370-Pro.
    Es ist notwendig im Bios den CPU Multi und CPU Spannung auf Auto zu stellen!
    Wenn eine Agesa Version älter als 1004 verwendet wird (älter als Bios 0604) ist es notwendig HPET zu aktivieren.
    Windows 10: Energieplan auf Ausgewogen/Ausbalanciert stellen. Performance kann sich dadurch verschlechtern!
    Windows 7: Net Framework 4 oder höher wird benötigt.
    Bei Fehlermeldungen bei der Installation oder dem verwenden von ZenStates folgendes probieren: Rechtsklick auf jede einzelne .exe Datei - Eigenschaften - Allgemein - Bei Sicherheit auf Zulassen klicken - Übernehmen.
    Einstellungsbereich:
    Spannung P0-P2: 0.30625v - 1.550v
    Multi P0/P1: 5.5x - 50x | P2: 3.66x - 33.33x
    Download:
    ZenStates 0.2 BETA
    ZenStates 0.2.2 BETA
    ZenStates 0.3.6691
    ZenStates 0.4.6698
    ZenStates 0.5.6706
    ZenStates 0.6.6719
    ZenStates 0.7.6747
    elmor schrieb:
    - Created a new method for storing settings, hopefully works better. Also has the advantage of being human readable XML (should be located under C:\ProgramData\ASUS ZenStates).
    - Removed Performance Enhancer and replaced it with PPT/TDC/EDC control. They're inactive right now since I'm not able to reset back to default values at the moment.
    - Again attempts to install/start the service at launch so you don't have to manage it yourself
    - Added more details to the Event Log messages from AsusZsSrv for easier debugging
    - Any settings are now only applied when the tray icon is initialized
    - Added a "-min" switch for the software which is used for auto-starting. This means that by default when launching the application manually, the main window will be visible.
    - The "Save" button now only appears when settings are not saved
    Das Setzen von "Apply at system start" aktiviert auch automatisch die Option "Try icon at system start"
    BIOS: Ab Bios 3803 funktioniert das automatischer Heruntertakten auch im übertakteten Zustand.
  • Single Rank / Dual Rank + Verbaute Speicher ICs herausfinden
    Öffne in CPUz den Reiter SPD.
    Mit dem Programm Thaiphoon Burner ist es auch noch möglich zu sehen welche ICs verbaut sind.
  • Chipsatz Kühler
    Auf dem Chipsatz Kühler befindet sich eine dünne Folie.
    Zur besseren Kühlung ist es zu empfehlen diese zu entfernen.
    Der original Wärmeleitpad (15x15x1.5) des Kühlers deckt nur ca 2/3 der Fläche ab.
    Ein Austausch des Pads (20x20x1.5) hat in meinem Fall 4°C kühlere Temperaturen ergeben.
    54°C => 50°C - Minus Pad 8 (Reous)
    72°C => 59°C - Alphacool ThermalPad (caidoo)
    66°C => 36°C - HEATKILLER SB Rev3.0 Ni (SVI90: 1, 2)
    65°C => 50°C - Kupferplatte Mod (Pikin)
    "Ich habe mir dann Kupferplatte mit den maßen 20x20x1,5mm bestellt und mit Wärmeleitpaste (auf den Chipsatz, sowie auf den Kühler) montiert und die Temps sind auch sehr gut. Zusätzlich auf der Rückseite des Kühlkörpers noch ein dickes Wärmeleitpad montiert. Die Plattengröße muss aus dem Pad natürlich herausgeschnitten werden, damit der Anpressdruck nicht zu hoch ist und der Kühlkörper gerade aufliegt.
    Die Platten kosten im 10er Pack ~1,80 Euro. LINK
    Lediglich die Anbringung des Kühlkörpers auf dem Board ist etwas schwieriger, da schließlich Kupfer nicht so gut haftet wie ein Pad"
  • Lüftersteuerung im Bios:
    Die CPU sowie Pumpen Lüfter werden jeweils über eine Einstellung im Bios gesteuert.
    Hinweis: Nach Durchführung des Q-Fan-Tunings gelten die neuen ermittelten Minimalwerte (%) vom Board.
  • USB ist im ausgeschaltenen Zustand weiterhin aktiv
    Bei Windows ist Standardmäßig der "Schnellstart" aktiviert. Ist dieser aktiviert, bleiben auch die USB Ports aktiv, obwohl der PC herunter gefahren wurde. Ihr deaktiviert in folgendermaßen:
    Energieoptionen öffnen
    "Auswählen, was beim Drücken des Netschalters geschehen soll" drücken
    "Einige Einstellungen sind momentan nicht verfügbar" drücken
    Haken bei "Schnellstart aktivieren" entfernen
    Änderungen speichern
  • Ryzen und X370 Anbindung (USB, PCIe, SATA, ...)
    Text:
    • Ryzen Prozessor:
      - 4x RAM
      - 4x USB 3.0 (I/O Panel)
      - M.2 Sockel PCIE x4 (x2 variert je nach Prozessor)
      - PCIEX16_1 Slot:
      PCIE x16 (bei einer verbauten Grafikkarte)
      PCIE x8 (bei zwei verbauten Grafikkarten)​
      - PCIEX16_2 Slot:
      PCIE x8 (auch bei Single Betrieb)​
    • AMD X370:
      - 8x SATA 3
      - 2x USB 3.0 (Board)
      - 4x USB 2.0 (Board)
      - 1x USB 3.1 (Board/Frontpanel)
      - 1x USB 3.0 (I/O Panel)
      - 1x USB 3.0 Typ C (I/O Panel)
      - 3x PCIE x1 Slots
      - PCIEX16_3
      PCIE X4 (Teilt sich die Bandbreite mit PCIEX1_1 und PCIEX1_3)​
    Bild:
    Linien wurden zusammen geführt um es übersichtlicher zu halten.
  • Temperatursensoren
    Das Mainboard verfügt über 7+1 Temperatursensoren. Nähere Informationen siehe Spoiler.
    Mainboard:
    Der Sensor befindet sich in der unteren rechten Ecke:
    Chipsatz:
    CPU Sockel:
    Der Sensor sitzt direkt im Sockel
    2x VRM CPU / 2x VRM SOC:
    Das Board besitzt zwar VRM Sensoren, die angezeigten Werte sind allerdings fraglich.
    HWInfo erkennt alle vier Sensoren, die Temperatur ist bei allen aber identisch.
    Einfluss darauf nehmen kann man auch nur, wenn man von hinten einen Lüfter im Bereich der CPU VRMs montiert.
    T-Sensor (extern):
    Kontakte um einen Temperatursensor anzuschließen
  • Kein POST Bild bei Anschluss über Displayport
    Im Uefi die Option Boot => CSM auf disabled stellen.
    Durch deaktivieren dieser Option kann es zu Boot Problemen mit der Systemfestplatte kommen.
  • Uefi Update fehlgeschlagen
    Das Board besitzt ASUS CrashFree BIOS 3.
    Lade eine passende Uefi Version (Bios 0801 oder höher) herunter, benenne die Datei in "X370PRO.CAP" um und füge sie auf einem USB Stick ein.
    Rechner einschalten, USB Stick einstecken, USB Stick wird durchsucht und öffnet automatisch den ASUS EZ Flash 3 Updater.
    Hinweis: CrashFree BIOS 3 funktioniert nur, wenn folgender Screen erscheint:
Archiv:
  • Backplate entfernen
    Die Backplate ist seit AM4 auf dem Board festgeklebt und lässt sich nicht sofort entfernen.
    Im Spoiler ist eine Anleitung wie es am besten gehen sollte. Anwendung auf eigene Gefahr.
    Bei neueren Modellen (Mai/Juni) ist die Backplate nicht mehr verklebt, sondern ganz normal verschraubt.
    In manchen Fällen hilft es die Backplate vorher mit einem Fön zu erwärmem.
    Auf die Verschraubungen abwechselnd von oben Druck ausüben (4x).
    Gleichzeitig die Backplate von unten weg ziehen.
    Klebereste am Board oder der Backplate lassen sich problemlos mit dem Finger entfernen.
    Endergebnis
  • Cold Boot Bug
    PC startet nicht mehr nachdem er stromlos war. Eine wirkliche Lösung gibt es hierfür noch nicht. ==> Auf Bios 0803+ updaten.
    Man kann es aber folgendermaßen umgehen:
    Man Muss den Ram so einstellen das er auch mit 1.20v startet.
    Zb: DDR4-3200 CL14-14-14 1.35v läuft nur solange wie der PC am Strom angeschlossen ist.
    Umgehen indem man entweder den Takt reduziert oder die Timings erhöht.
    - DDR4-2933 CL14-14-14
    - DDR4-3200 CL16-16-16
  • Kein Boot
    Nach Änderungen im Uefi startet der Rechner nicht mehr.
    Führe ein Uefi Reset durch. Beachte der Rechner benötigt danach bis zu 1:30min um neu zu starten.
    Er durchläuft mehrere Reboots bis er die passenden Settings ermittelt hat.
  • Stromverbrauch:
    Minimale Konfiguration: HD4550, SSD, Maus und Tastatur
    - 41 Watt (Idle, Keine Last)
    - 95 Watt (Ryzen 1700 3.0GHz @ 0.900v, Prime95)
    - 133 Watt (Ryzen 1700 3.6GHz @ 1.145v, Prime95)
RAM Kompatibilität:
Nach oben
G . S k i l l​
SerieGrößeGeschwindigkeitMöglicher TaktUserBiosBezeichnung
Fortis16GBDDR4-2400 CL15-15-15DDR4-2666 CL16canada3404F4-2400C15D-16GFT
RipJaws V rot16GBDDR4-2800 CL15-15-15DDR4-2800 CL16kitano0805F4-2800C16D-16GRR
RipJaws 4 rot16GBDDR4-2800 CL16-16-16DDR4-2800t1kezZ0805F4-2800C15D-16GVR
RipJaws V rot32GBDDR4-3000 CL14-14-14DDR4-3066Cool McCool0805F4-3000C14Q-32GVR
RipJaws V rot16GBDDR4-3000 CL15-15-15DDR4-2933 CL16partygott2720803F4-3000C15D-16GVR
Trident Z silber/rot16GBDDR4-3000 CL15-16-16DDR4-2933 CL20MorLipf3203F4-3000C15D-16GTZB
RipJaws 4 blau16GBDDR4-3000 CL15-16-16DDR4-3066 CL16nur20033803F4-3000C15D-16GRBB
RipJaws V rot16GBDDR4-3200 CL14-14-14DDR4-3066AW3120803F4-3200C14D-16GVR
Flare X schwarz16GBDDR4-3200 CL14-14-14DDR4-2933
DDR4-3200 CL16
DDR4-3200
DDR4-3200
DDR4-3200
grysson
Speedwood
NoiseKiLLeR
berndhkb
Inka2k
0604
0803
0805
0805
3203
F4-3200C14D-16GFX
Trident Z silber/rot16GBDDR4-3200 CL14-14-14DDR4-3200
DDR4-3333
DDR4-3333
DDR4-3466
gR3iF
Chrissssssssss
Bomm3l
dargo
0805
0801
0805
0805
F4-3200C14D-16GTZ
G.Skill Trident Z RGB16GBDDR4-3200 CL14-14-14DDR4-3200
DDR4-3200
Bronkov1c
Diablokiller999
0810
4207
F4-3200C14D-16GTZR
Trident Z silber/rot32GBDDR4-3200 CL14-14-14DDR4-2933
DDR4-2933
DDR4-3066
DDR4-3066
caidoo
rekrats
azuki
CyR4DiS
0805
0801
0810
0810
F4-3200C14D-32GTZ
G.Skill Trident Z RGB32GBDDR4-3200 CL14-14-14DDR4-2933GorObrok0805F4-3200C14D-32GTZR
RipJaws V schwarz16GBDDR4-3200 CL15-15-15DDR4-3200pawelo0805F4-3200C15D-16GVK
Trident Z silber/weiß16GBDDR4-3200 CL15-15-15DDR4-3333 CL16Meriana0801F4-3200C15D-16GTZSW
Trident Z silber/rot32GBDDR4-3200 CL15-15-15DDR4-3200Kyrion0801F4-3200C15Q-32GTZ
Trident Z silber/rot32GBDDR4-3200 CL15-15-15DDR4-3066 CL14Reous0807-2F4-3200C15D-32GTZ
RipJaws V schwarz16GBDDR4-3200 CL16-16-16DDR4-2933LtFord0801F4-3200C16D-16GVK
Trident Z silber/rot32GBDDR4-3200 CL16-16-16DDR4-3066codeworkx0801F4-3200C16D-32GTZA
RipJaws V schwarz16GBDDR4-3200 CL16-18-18DDR4-2933
DDR4-3066
DDR4-2933
DDR4-3066
DDR4-2933
DDR4-3000
IceK
psych
schnipp959
barnabeus
Xontor
icekeuter
0803
1201
0801
0801
0511
4008
F4-3200C16D-16GVKB​
RipJaws V schwarz16GBDDR4-3200 CL16-18-18DDR4-3066Titan900803F4-3200C16D-16GVGB
Trident Z RGB16GBDDR4-3200 CL16-18-18DDR4-3066Lord_Melchior0801
F4-3200C16D-16GTZR​
Trident Z silber/rot16GBDDR4-3200 CL16-18-18DDR4-2933PuMa01530801
F4-3200C16D-16GTZB​
Trident Z silber/rot32GBDDR4-3200 CL16-18-18DDR4-3133Edion4012
F4-3200C16D-16GTZB​
RipJaws V schwarz32GBDDR4-3200 CL16-18-18DDR4-2800Silberfan0805
F4-3200C16D-32GVK​
Trident Z silber/rot32GBDDR4-3333 CL16-16-16DDR4-3066p1n00801
F4-3333C16D-32GTZKW​
RipJaws V schwarz16GBDDR4-3400 CL16-18-18DDR4-2933karenin0805-1
F4-3400C16D-16GVK​
Trident Z RGB32GBDDR4-3466 CL16-18-18DDR4-3066frkazid4207
F4-3466C16D-32GTZR​
Trident Z silber/rot16GBDDR4-3600 CL15-15-15DDR4-3200ZinG0801
F4-3600C15D-16GTZ​
Trident Z silber/weiß16GBDDR4-3600 CL16-16-16DDR4-3200Why_me0504
F4-3600C16D-16GTZSW​
Trident Z RGB16GBDDR4-3600 CL16-16-16DDR4-3200Harrybert0805
F4-3600C16D-16GTZR​
Trident Z silber/rot16GBDDR4-3600 CL16-16-16DDR4-3200
DDR4-3333
H96er
Moving
0801
0801
F4-3600C16D-16GTZ​
Trident Z silber/rot16GBDDR4-4133 CL19-21-21DDR4-3200audioslave0805
F4-4133C19D-16GTZA​
C o r s a i r​
Vengeance LPX schwarz16GBDDR4-2400 CL14-16-16DDR4-2666 CL16sun-man0801
CMK16GX4M2A2400C14​
Vengeance LPX schwarz16GBDDR4-3000 CL15-17-17DDR4-2933 CL16
DDR4-3066 CL16 (v5.30)
DDR4-2933 CL16
DDR4-2933 CL16
diwi08
gtlambert (1)
Nanaran
Beskarion
augustus
0515
0805-1
0801
0902
0805
CMK16GX4M2B3000C15​
Vengeance LPX rot16GBDDR4-3000 CL15-17-17DDR4-2933 CL16 (v5.30)nVoodoo0805
CMK16GX4M2B3000C15R​
Vengeance LPX schwarz32GBDDR4-3000 CL15-17-17DDR4-2666 CL16
DDR4-2933 CL16
DDR4-2800 CL18
NoXPhasma
diwi08
KaSpel
0515
0515
0801
CMK32GX4M2B3000C15​
Vengeance LED weiß32GBDDR4-3000 CL15-17-17DDR4-2800illumi2410801
CMK32GX4M2B3000C15​
Vengeance LED rot32GBDDR4-3000 CL15-17-17DDR4-2666koschi0801
CMU32GX4M2C3000C15R​
Vengeance LPX schwarz32GBDDR4-3000 CL15-17-17DDR4-2933 CL16 (v4.24)Bobbyca0805-1
CMK16GX4M2B3000C15​
Vengeance LED weiß64GBDDR4-3000 CL15-17-17DDR4-2800 CL16Baerliner0807
CMU64GX4M4C3000C15​
Vengeance LPX schwarz16GBDDR4-3000 CL16-20-20DDR4-3000 CL16 (v3.31)monkkey4602
CMK16GX4M2D3000C16​
Vengeance LPX schwarz16GBDDR4-3200 CL16-18-18DDR4-2933 CL14 (v4.24)
DDR4-3000 (v.5.39)
DDR4-3066 (v5.39)
DDR4-3066
DDR4-3066 CL14 (v5.39)
DDR4-3066 (v.5.39)
DDR4-3333 (v6.39)
Mr.X
pjgowtham
Fathoum
KenshiHH
frkazid
ts2011
fauli007
0805
4207
0810
0801
0902
3803
0803
CMK16GX4M2B3200C16​
Vengeance LPX schwarz16GBDDR4-3600 CL18-19-19DDR4-3333
DDR4-3333
Degan
Harrybert
0801
0805
CMK16GX4M2B3600C18​
K i n g s t o n​
ValueRAM8GBDDR4-2400 CL17-17-17DDR4-2400barnacle2k0504
KVR24E17S8/8​
HyperX Savage Rev.216GBDDR4-2666 CL13-15-15DDR4-2400Raul2320504
HX426C13SB2K2/16​
HyperX Savage32GBDDR4-2666 CL15-15-15DDR4-2666Docbyte0511
HX426C15SBK2/32​
HyperX Fury schwarz16GBDDR4-2666 CL15-17-17DDR4-2933BK-Morpheus0810
HX426C15FBK2/16​
HyperX Predator32GBDDR4-3000 CL15-16-16DDR4-2933TheSebi410515
HX430C15PBK4/32​
C r u c i a l​
Ballistix Sport LT grau16GBDDR4-2400 CL16-16-16DDR4-3133 CL20replikant0815 (1)3803
BLS2C8G4D240FSB​
Ballistix Sport LT rot16GBDDR4-2400 CL16-16-16DDR4-2400foxtrot0504
BLS16G4D240FSE​
Ballistix Sport LT weiß16GBDDR4-2400 CL16-16-16DDR4-2933 CL18timmaeh (1)3803
BLS2C8G4D240FSC​
Ballistix Sport LT rot32GBDDR4-2400 CL16-16-16DDR4-2400hacki0502
BLS2C16G4D240FSE​
Ballistix Elite16GBDDR4-2666 CL16-17-17DDR4-2666 CL17afro0801
BLE2C8G4D26AFEA​
Ballistix Sport LT rot16GBDDR4-2666 CL16-18-18DDR4-3000Reous3803
BLS2C8G4D26BFSE​
Ballistix Tactical16GBDDR4-3000 CL16DDR4-2933moki1550801
BLT2C8G4D30AETA​
Ballistix Sport LT grau16GBDDR4-2666 CL16-18-18DDR4-3066Hopie4406
BLS2K8G4D26BFSBK​
S a m s u n g​
---32GBDDR4-2133 CL15-15-15DDR4-3066 CL16Fusseltuch (1)0801
M378A2K43BB1-CPB​
P a t r i o t​
Viper 416GBDDR4-3733 CL17-19-19DDR4-3066 CL14VincAlastor0805
PV416G373C7K​
Ergänzungen:
*1Offizielle Angaben zur maximalen SOC Voltage gibt es momentan noch nicht.
Eine Anfrage an AMD ergab folgende Info. Da diese Werte allerdings ziemlich hoch erscheinen empfehle ich diese mit Vorsicht zu genießen.
AMD Support schrieb:
Thank you for the email.
I understand you have a query about the highest SOC voltage of Ryzen CPU.
The max voltage for this CPU is upto 1.4V.
So, you can set 1.2V but more than 1.4V may cause some damage for the CPU.
Thank you for contacting AMD.
In order to update this service request, please respond, leaving the service request reference intact.
Best regards,
AMD Global Customer Care
work in progress
Danke an alle für die tolle Mitarbeit
--Ansicht optimiert auf Mozilla Firefox--
Ich hatte bisher immer die neueste Version aufgespielt. Bei der 3203 würde ich aber warten, da es mir gestern erst mein Board verspult hat. Ich bin auch nicht der Einzige bei das passiert ist. In Zukunft werde ich auch nicht mehr das neueste Bios setzen sondern etwas warten. ;)
Normalerweise gerade bei Ryzen (neue Platform) immer aktuell halten. Allerdings scheint es wirklich mit dem neuen BIOS Probleme zu geben. Sogar Reous rät von ab.
Danke euch, dann werde ich noch auf die nächste Version warten. Wird ja denke ich relativ zügig kommen wenn es mit der aktuellen Probleme gibt oder nicht? :)
Hmm, also ich kann mit 3203 zuverlässig 3200+ booten (vorher war das Glückssache, 1 in 3). Das Fehlerbild in HCI gibt mir allerdings nicht wirklich Aufschlüsse. Kein Thread der Regelmäßig abkackt oder so, alle Fehler gut verteilt. Also wohl ein Timing Problem (oder Spannung, aber mehr als 1,45 gebe ich nicht), nur blöd das ich die sekundären gar nicht angefasst habe.. Also entweder ist ein Auto-Timing schon zu eng (Evtl tRDRDscl und tWRWRscl? Hab mal gehört das Ryzen die nicht mehr zu eng mag) oder ich hab halt einfach Pech. 2933 mit Timings die mir 72ns latenz geben ist jetzt auch nicht schlecht, wundere mich halt, da das Kit quasi die qualitativ hochwertigsten D-Dies waren damals. 3200 sollte mit denen doch möglich sein -.-
Edit: Angeblich ist mit 3203 der OPCache per Default deaktiviert (dh wenn er auf Auto steht)? Kann das wer bestätigen mit Mod-Bios?
OPCache is mehr oder weniger dafür da Instruktionen die schoneinmal decodiert waren zu speichern, um sie bei Bedarf wieder abzurufen. Spart Zeit, Energie etc.
Laut OC.net Forum reden wir von 5-7%, und der Grund fürs default Disable scheint der Segfault Bug zu sein.
Gibt es eine Methode sicher zu testen, ob der OPCache aktiv ist? Das wäre ein Unding, wenn der standardmäßig deaktiviert worden wäre, ohne eine Möglichkeit anzubieten, den wieder zu aktivieren.
Zumal das Deaktivieren, das Auftreten des Segfault-Bugs nur seltener macht, aber dies nicht vollständig verhindert.
Schwer zu sagen wo man ansetzen soll. Gesetzt in A2 / B2? DOCP Profil ausgewählt und dann manuell den Takt auf 2666 Mhz setzen und die Spannung kontrollieren. RAM sollte auf 1.35 V sein / SOC Spannung auf ~ 1.05 festsetzen.
DOCP Profil hatte ich nicht ausgewählt. SOC Spannung musste ich noch leicht anpassen. Mit 3066MHz hat er sogar gebootet, aber dann nach 1min kam ein Freeze. Mit 2800MHz läuft Prime jetzt seit 10 Minuten.
Danke für die Tipps!
Ich weiß leider keine. Hab auf gut Glück mal unter HWInfo und Aida bei den Instruction Features nachgesehen, aber da gibts nix dazu. Frage ist halt auch inwiefern das eigentlich stimmt mit dem Leistungsverlust.
Weil würde das stimmen müsste ja jeder konsekutiver Cinebench Lauf besser sein als der vorige, oder zumindest alle nachfolgenden müssten besser sein als der erste, was bei mir nicht grundsätzlich stimmt. Es sei denn man redet von 5-7% nur bei kompilieren, das war nicht so ganz klar.
@Intercore
Es liegt an der installierten Aura Software - ist Bios-unabhängig. Hatte das gleiche Problem.
Es gibt irgendwo eine schecht sichtbare Einstellung für den "AUS-Zustand", was da passieren soll. Wenn also Aura in der Software ausschaltest, aktiviert sich die Einstellung fürs "weiterblinken" automatisch. Man muss es dann nur noch ändern.
...bin grad in der Arbeit und kann die Problematik nur ausm Gedächtnis beschreiben
Gesendet von meinem A0001 mit Tapatalk
Tatsächlich. Hab ich vor einem halben Jahr ja schonmal machen müssen ... hab mich nicht mehr dran erinnern können :d
Das geht natürlich genauso in die andere Richtung. Bei einem reinem Gaming Rechner mag das egal sein, solange es halt läuft.
Ich bin übrigens wieder zurück zu meinen optimierten Subtimings. Das Fast-Preset vom Ryzen-Calculator führte recht schnell zur Instabilität. Forza Motorsport 7 ist mir bei Tests im CPU-Limit zwei Mal abgestürzt. Ich landete irgendwann einfach auf dem Desktop. Ich benutze aber auch tiefere Spannungen als vorgegeben bzw. vorgeschlagen.
Hallo. Ich hab eine Frage bezüglich Aura. habe meinen PC neu aufgesetzt und wollte Aura installieren. Es kam allerdings ein Fehler und danach wollte das Programm nicht öffnen. Nun habe ich das Problem, dass ich es noch nicht mal deinstallieren kann: Ich bekomme den Fehler, dass die Support-Datei für die Installation nicht installiert werden konnte. Neue Installation funktioniert aus gleichen Grund auch nicht. Licht bleibt so stecken, wie ich es vor dem Neuafsetzen des PCs hatte.....
Hi. Problem mittlerweile gelöst? Hatte die selbe Fehlermeldung als ich versucht hab eine neuere Version von Aura zu installieren. Deinstallieren scheint eh nicht möglich zu sein. Hatte ich auch versucht, danach funktionierte Aura nichtmehr, lief aber trotzdem im Hintergrund, Ordner ließ sich manuell nicht löschen obwohl alle Prozesse geschlossen waren. Hab dann alle Einträge in der Registrierung mit "Aura" manuell gelöscht, ccleaner laufen lassen und dann konnte ich zumindestens neu installieren sodass es wieder funktioniert.
@dargo: Ich finde den Calculator jetzt nicht so prall, die Werte sind einfach weit weg von der Realität, auch wenn er gut gemeint ist. Bei mir z.B. ist für 3333-CL14 nur möglich, wenn ich ProcODT auf 53 oder 48 Ohm stelle und die Spannung gleichzeitig auf 1,375v stelle, ohne jegliche weitere Anpassung bei RTT und CAD. Ich habe viel zu viel Zeit damit verschwendet, mit diesen RTT und CAD Werten rumzuspielen und hab dabei gar nicht gemerkt, dass es nicht besser, sondern nur viel schlechter wird. Das gleiche ist mit der Spannung, mehr ist bei mir ab 1,375v definitiv viel schlechter für die Stabilität. Auch die Latenzen sind einfach nicht richtig, einige "Safe" Werte sind nicht stabil, während andere "Fast" Werte sogar noch schärfer bei mir stabil laufen.
Wenn man das maximale ausloten will, hilft nur analytisches Vorgehen, verdammt viel Zeit (4-8 Wochen) und geduldeter Schmerz bei der Stromrechnung.
1: CPU-Core und CPU vCore auf Auto setzen, OC ist hier nur eine Unsicherheit und erhöht den Stromverbrauch
2: Als erstes würde ich den maximal stabilen Takt mit ganz laschen Timings 18-18-18-18-40-60 ausloten. Stabil ist, was eine Nacht HCI Memtest mit 16 Threads ohne Fehler übersteht. Variablen hier sind ProcODT (48, 53 oder 60), sowie vDIMM (1,35v - 1,45v) und vSOC (1,05v - 1,15v)
3: Den IMC muss man nochmal seperat mit Prime95 Blend testen, hier am besten 80% vom Speicher zuweisen und wieder ne Nacht laufen lassen. Wenn es Fehler gibt, muss die SoC Spannung rauf, bei mir sind 1,15v LLC3 nötig für wirklich stabile 3333Mhz, während HCI Memtest auch mit 1,125v LLC3 zufrieden ist.
4: Mit dem maximalen Takt würde ich dann die ersten 4 Timings in Kombination in zweier Schritten ausloten. Ich würde mit den Stilt Werten anfangen und versuchen die stabil zu bekommen, ansonsten halt in 2er Schritten raufgehen. Variablen hier sind Spannung und die Haupttimings
5: Die ganzen Subtimings müssen eigentlich mehr oder weniger individuell ausgelotet werden. Ich habe immer am Abend vor dem Schlafen gehen einen einzelnen Subtiming Wert erhöht, HCI Memtest gestartet und geschaut, ob am nächsten Morgen alles OK war. Angefangen habe ich immer mit "Traum Werten", also Stilt 3200Mhz UHQ für meinen 3333Mhz HQ Speicher. Am Anfang ist also jeder Wert mehr oder weniger "durchgefallen", damit konnte ich mich aber an die Maximalwerte langsam rantasten.
Für alle Timings, Stabilitäts- und Validierungstests sowie Ausloten der niedrigst möglichen Spannung habe ich wirklich etwa 8 Wochen den PC jede Nacht und fast jeden Tag während der Arbeit laufen lassen. Hört sich jetzt verrückt an, aber die Stromrechnung ist mir nicht so wichtig (~800 Stunden zu je ~100 Watt, also 80KWh, kostet ca. 20-25€) und während dessen habe ich den PC ja eh nicht gebraucht. Dafür habe ich jetzt rock stabil Settings, die jedem Benchmark und jedem Stabilitätstest standhalten und bei diesem Setup bleibe ich jetzt wieder 3 Jahre und freue mich bei jedem Game über die hervorragende Leistung, weit überhalb jedem Test mit Ryzen, bei voller Stabilität ohne Abstürze oder Performanceprobleme wegen Instabilitäten.
Warum schreib ich das alles? Weil ich zeigen will, dass man, wenn man maximale Ryzen RAM Performance stabil haben will, nicht einfach einen Calculator runterladen, die Werte Copy&Paste ins BIOS reinprügeln kann und dann auch noch erwarte, dass das alles so stabil läuft. Das wird es nie im Leben, keines eurer Settings ist auch nur ansatzweise stabil, nie würde euer PC bei den ganzen Einstellungen eine Nacht HCI ohne Fehler überstehen. Fakt ist, euer Arbeitsspeicher arbeitet falsch, er verursacht Übertragungsfehler, wenn ich 01101 reinschreibe, kann es sein, dass 11101 gespeichert wird und/oder ich beim Auslesen falsche Werte zurück bekomme. In manchen Anwendungen tritt das seltener auf und ist vielleicht allgemein weniger Problematisch, weil die Anwendung sagt "das kann nicht sein, bitte neu Berechnen" (= Performanceverlust), bei anderen Anwendungen tritt es vielleicht häufiger auf und ganz andere verursachen sofort einen BSOD. Fakt ist, kommt auch nur ein einziger Fehler in HCI Memtest und sei es erst nach 8 Stunden, läuft der RAM nicht stabil. Du bist wenigstens so ehrlich und sagst ganz klar "wenn die Games nicht gleich beim Laden abstürzen, ist alles bestens", ergo stehst du ganz klar zu deinem instabilen Arbeitsspeicher, der halt wenigstens selten genug offensichtliche Probleme verursacht, dass es für dich in Ordnung ist. Andere Internethulks lassen das gänzlich weg und vermitteln den Eindruck "Easy, Stilt Timings DDR4-3333Mhz bekomm ich locker hin". Das Problem bei so einer riesen Anzahl an unbekannten ist: Wenn es nicht stabil ist, wie willst du den Fehler identifizieren? Du hast ja überhaupt keinen Ansatzpunkt, was überhaupt stabil ist, wenn man einfach 30 Werte einträgt, ohne zu wissen, ob die überhaupt passen. Man muss selbstständig analytisch "Snapshots" machen, von denen ich sicher bin, dass diese Settings passen. Wenn ich eine Einstellung habe, die nachweisbar stabil war und ich ändere einen einzelnen Timing Wert und jetzt ist es nicht mehr stabil, weiß ich die Ursache. Wenn ich 30 Werte von einem Calculator in das BIOS prügel und ich hab Abstürze, habe ich Pech gehabt und kann auf gut Glück drauf rumstochern und nach einigen Tagen über den schlimmen Ryzen, das blöde Board oder den schlechten Speicher schimpfen. Es gibt schon einen Grund, warum im ganzen Netz fast niemand Bilder von HCI Durchläufen parat hat, weil die meisten nach 100% Aufhören aus Angst vor Fehlern und der Gewissheit, dass das instabil ist und ein paar Monate später nach ein paar Abstürzen wird über Ryzen geschimpft.
Genau deshalb bin ich überhaupt kein Freund von diesem Calculator, so gut er auch gemeint sein mag. Er vermittelt ein völlig falsches Bild und hilft in keiner Art und Weise weiter. Hätte ich einfach die 3333 Safe Timings abgetippt, wäre der Speicher nicht stabil und weit entfernt von wirklich scharfen Ergebnissen, manche Werte sind mehr als doppelt so hoch, wie notwendig. Aber der Wert tRDWR mit 7 läuft bei mir nicht stabil, ich brauche hier 8 und demnach würde ich trotz "semioptimaler" Performance einen instabilen RAM haben, ebenso wären bei mir sämtliche RTT, CAD und Voltage Settings falsch. Die DRAM Spannung ist zu hoch, die SoC Spannung zu niedrig.
Durch analytisches Vorgehen kann man ein gutes und stabiles Setting finden, mit diesem Calculator wird das nie im Leben der Fall sein, vollkommen unmöglich.
Danke ! genau richtig
Naja zumindest haben nabs die den Calculator nutzen wenigstens folgerichtige Werte (Hab schon genug gesehen, tRRDs/tWTRs größer oder gleich groß als tRRDl/tWTRl, obwohls ja schon im Namen ist usw...). Wenns nicht läuft kommen auch die von sich selbst auf die Idee etwas zu entschärfen.
Ob mit oder ohne Calc, der Anfang besteht immer darin nachzuforschen was man überhaupt mit welchen Werten verstellt. Hätte hier auch schon vielen Instabilitäten erspart, ganz ohne das Programm (ich sag nur tRFC, ein Timing das enger gesetzt nix an Leistung bringt, aber sehr wohl an Instabilität. Und wenn man es enger setzt, hängt extrem viel von den anderen Row Timings ab.)
Und wenn einem dann klar ist das der Calc schlicht und einfach nur das macht, was ich sonst mit Stift und Papier mache (nämlich auf Basis der absoluten Zeit ausrechnen was ungefähr der gleiche Wert bei verschiedenen Frequenzen wäre, und dann eben allgemeingültige regeln zur berechnung anwendet), brauchst du hier nicht ein an sich praktisches Programm verteufeln, das zwar immer noch Macken hat, aber gerade für CAD/RTT ist es praktisch für Leute die auch wissen was sie machen, denn was der Calc für die ausgibt ist nichts anderes als das gesammellte Wissen das die wir in mühseliger Kleinarbeit im Konsens zur Anfangszeit des Ryzens rausgefunden haben (was auch nicht heißt das die für alle Konfigs super laufen..).
Wenn ich da an die Anfangszeit zurück denke wo ich wochenlang nur für diese Einstellungen Zeit verbraucht habe, hätte ich für solche Anhaltspunkte sogar gern noch bezahlt.
Sieh das Ding quasi als Enzyklopädie, allgemeingültiges Wissen, aber im Kontext kann es sein das es deutlich abgewandelt wird.
Ihr habt beide recht, sowohl Stunrise als auch karenin. Das Tool von 1usmus ist für Unbedarfte sehr nützlich was ProcODT, RTT und DriveStrength Werte anbelangt und was die Timings angeht auch für Dual Rank Module mit Samsung ICs. Die Timings, die es für Single Rank ausspuckt, sind aber eher zweifelhaft. Ist auch kein Wunder, da 1usmus seine Erfahrungen und Erkenntnisse in erster Linie mit Dual Rank gesammelt hat.
Gerade bei den Spannungen kann man sich nicht wirklich auf das Tool verlassen. Da unterscheiden sich baugleiche Riegel mit den gleichen ICs oft gewaltig.
Ich hab allerdings auch noch nicht die neue Version v6 ausprobiert. 1usmus hat da einige Verbesserungen eingebaut.
Ich teste mit Games.
Das ist gelinde gesagt unprofessionell. Du solltest weder mit Deinen Einstellungen hausieren gehen, noch Andere anstiften oder ködern, solange Du nicht bewiesen hast, dass sie tatsächlich 100% stabil sind. Intensive Stresstests sind unabdingbar. Stunrise und smuper haben völlig recht. Wie schnell man sich täuschen kann, siehst Du z.B. hier.
Deine Spiele Benchmarks sind aber wirklich schön. Allerdings spielt keiner in 720p. Vlt. kannst Du die ja nochmal für 1080p wiederholen - wenn Du viel Zeit und Langeweile hast.
Hat noch jemand einen Tipp wie ich meine 2x16GB 2133 Samsungs zu 3200Mhz überreden könnte?
Bis zum Aida Stresstest komme ich, dann wird aber nach ca. 1 min ein Fehler erkannt.
Bios ist das 0902.
Habe die ausgegeben Werte von Ryzen DRAM Calculator versucht, sprich die procODT, RTT, CAD_BUS Werte angepasst, leider ohne Erfolg.
Spannungen DRAM 1,4v SOC 1,05v
Wenn Du tatsächlich die originalen Samsung Riegel hast, solltest Du Dir keine Hoffnungen machen. Ich hatte vor ein paar Wochen ein Single Rank Kit hier (2x M378A1K43BB1-CPB). Die haben zwar mit 3600 MT/s gebootet, aber stabil hab ich sie gerade mal auf 3066 CL16 gebracht. Die Riegel haben sich extrem störrisch verhalten und mochten weder manuelle Timings noch hohe Spannungen. Ich kann mir das Verhalten nur mit minderwertigen Platinen/elektronischen Bauteilen erklären, die für hohe Taktraten/Spannungen nicht ausgelegt sind. Dass Deine Dual Rank auf 3066 CL14 laufen, halte ich schon für ein Wunder, mit dem Du Dich glücklich schätzen solltest. Du solltest allerdings intensive Stresstests mit diesen settings durchführen (z.B. HCI MemTest >1000%). AIDA ist da nicht so gut geeignet.
Ich starte trotzdem noch einen Versuch. Die nächsten Tage trudeln hier 2x16GB C-die ein. Das sind - wie B-die - 8Gbit Chips, die Samsung erst Mitte dieses Jahres eingeführt hat und bisher scheinbar exklusiv auf den eigenen Modulen einsetzt. Mal schauen, was mit denen geht. Vlt. kann ich ja positive Erfahrungen aus meinen Tests an Dich weitergeben.
Mit der 1.01 Version vom RTC sollte BGS Alt auch angezeigt werden. In meinem Profil war er auf Auto. Ob das An oder Aus entspricht kann ich nicht sagen. Das angepasst Profil kann noch etwas dauern, da ich erst paar andere Tests machen will.
Default (Auto) ist BGS=enabled und BGS/A=disabled
Soweit ich weiß kann bei BGS/BGSA nur jeweils eine Option auf Enabled bzw Disabled stehen oder irre ich mich da?
Es können nicht beide auf Enabled stehen. Alles andere geht.
Hier die relevanten Beiträge von The Stilt zu BGS:
The Stilt zu BGS * Teil I
The Stilt zu BGS * Teil II
Gerade Spannung ist doch eh klar, wobei auch da gut ist, dass man einen Ausgangswert hat, muss natürlich nix heißen, aber erspart mir das testen von 1,25 aufwärts zb. Denn weniger als das tool angibt ist es normalerweise nie, und was mich betrifft trifft es das tool ganz genau. Soc läuft allerdings mit weniger. Wobei die vSOC eh teils total Schwachsinnig reagiert. Über 1,03125 habe ich USB-WLAN stick aussetzer, unter 0,975 auch.. Mit Auto = 1,1 und ohne ein bisschen Ahnung von der Sache würden mir wohl längst die Sicherungen durchgebraten sein weil nix funktioniert^^
Meine Erfahrungen sind gerade andersherum. Ich brauch auf verschiedenen Modulen meist weit weniger Spannung als vom Calculator empfohlen (z.B. 1.375v statt 1.415v).
Probleme mit vSOC und dem USB Controller hatte ich noch keine (Crosshair VI und ein halbes Dutzend permanente USB Peripheriegeräte + zahllose USB Sticks). Ich beginne meine RAM OCs normalerweise mit 1.1v und gehe dann runter auf 1.025-1.05v, nachdem ich einen stabiles OC gefunden habe.
@karenin: Falsch, bei mir ist es 1,375v und darüber ist es instabil, der Calculator sagt 1,385v - 1,4x
Beim SoC habe ich wie gesagt bei mir "mehr ist besser" und unterhalb von 1,10v geht gar nix, selbst der Boot macht hin und wieder Probleme damit.
Wie du siehst haben selbst erfahrene OCer jeweils andere Erfahrungen gemacht. Beim vMem brauchst du mehr, Curios und ich weniger. Bei vSOC braucht ihr wenig und ich viel. Viel hilft auch nicht immer viel, weshalb man auch nicht sagen kann, fangt alle zim Start mal hoch an. Man muss analytisch jeweils seine Settings ermitteln, kein Preset oder Calculator wird das bei Ryzen jemals zufriedenstellend erraten.
Danke für den Text! So sehe ich das auch. Ich bin leider noch am Anfang meiner Tests.
Zu 2. : Hast du einmal die vSoc und ProcODT mit den laschen Timings ausgelotet und dann so belassen? Falls nicht hast du beides wieder ändern müssen bei Optimierung der Timings bzw. Subtimings oder nur die vDimm?
Zu 5.: Hattest du einen Anhaltspunkt bzw. Anleitung für Subtimings, in welchen Wertebereich man den jeweiligen Subtiming Wert testen sollte?
Dein Text könnte super als Basis für eine Anleitung dienen.
Super Beitrag, denke das hilft vielen, auch mir, bei der Methodik und Einschätzung anderer Erfahrungswerte und die des Calc. Ich werde auf jeden Fall jetzt nochmal von vorne beginnen, zumal ich für 3200 sowieso ein stabiles Setting gefunden habe. Danke nochmals!
Noch eine Frage zu 2: Hast Du dann alle anderen Werte auf Auto?
Bei mir war ProcODT und vSoC nötig, um den Speichertakt 3333Mhz selbst zu stabilisieren, für die Timings waren beide Werte irrelevant. Daher würde ich anfangen mit dem Ausloten des maximalen Takts, aber mit sehr laschen Timings (18-18-18-18-40-60 Rest Auto). Wenn man das stabil hat, ist man zu 50% fertig, weil dann hat man eine stabile Basis, die nachweisbar läuft und auf Basis dieses Snapshots kann man immer weiter ermitteln, was an Timings geht und was nicht. Die Timings selbst haben dann eigentlich nur noch den Parameter der RAM-Spannung, hier kann man mit mehr oder weniger Spannung spielen. SoC und ProcODT würde ich nicht mehr anfassen, weil das dann validierte Werte sind, die zuvor ermittelt wurden und garantiert laufen. Anhaltspunkt sind immer die Stilt Timings, ansonsten hier nochmal ein Auszug nach meinem letzten Lauf.
Achja: Für das Ausloten des Speichertakts würde ich immer direkt auf 1,35v Speicherspannung gehen, das wäre mein Einstieg. Also mit 1,20v braucht man mMn gar nicht Zeit verschwenden. Zwischen 1,35 - 1,40v haben die meisten gute Ergebnisse gefunden
Vielen Dank, das hilft ungemein weiter, werde mich heute Abend direkt ran setzen und stabile 3333Mhz ausloten.
Zwei Fragen sind mir noch gekommen:
Hat dein Overclocking auf 3.7 Ghz Einfluss auf die relevanten Spannungen genommen?
Da du mit 3333Mhz ausgelotet hast, gehe ich von aus, dass du mit 3466 keine Chance hattest oder?
Mein OC hatte auf den Speicher keine Auswirkungen, aber ich habe den Speicher trotzdem ohne CPU-OC evaluiert, für alle Fälle (und besserer Verbrauch). 3466Mhz ging bei mir nicht, auch nach stundenlangem Probieren habe ich max 500% HCI geschafft. 3333Mhz war max. Benchmark ready wäre 3466 gewesen, aber nicht ernsthaft stabil.
Ich habe dann noch bei CPU-OC (ohne Mem OC) das maximale ausgelotet (3700Mhz@1,275v LLC3) und dann beides kombiniert und nochmals eine Nacht einmal HCI und einmal P95 getestet. Jetzt ist das Gesamt-OC validiert und "versiegelt" und da fasse ich nichts mehr an. Auch das BIOS lasse ich jetzt so, wie es ist. Cold Boot Bugs habe ich mit 53Ohm fast gar keine mehr und ich hab keine Lust auf neue Probleme. Das System läuft 1A und bleibt jetzt so
Edit: Ich hatte gar nicht mit positiver Resonanz gerechnet, sondern eher mit Hate von den ganzen Internethulks, die sich angegriffen fühlen. Ich poste heute Abend mal eine präzisere Anleitung mit einer vollen Auflistung aller meiner Settings. Aber wie gesagt, wer schnelle Ergebnisse für seine Signatur will, wird Enttäuscht sein
PS: Alle meine Werte beziehen sich ausschließlich auf 2x8GB Single Rank Speicher mit Samsung B-Die Chips. Mit DR, 2x16GB, Hynix, Crucial und co sind völlig andere Werte nötig!
Kurze Frage zum Bios. Ich habe hier im MP das Board mit einem Ryzen5 1600 gekauft. Welches Bios drauf ist weiß ich allerdings noch nicht da das System noch nicht aufgebaut ist.
Würdet ihr generell empfehlen das Bios immer aktuell zu halten oder sagt ihr das die aktuelle Bios sollte man lieber bleiben lassen? :d
Das System wird erst übernächste Woche aufgebaut.
Hab mir letzte Woche einen neuen PC aufgebaut und wollte einfach nicht starten. Da die Probleme der RAM bekannt ist habe ich hier nach meine RAM gesucht und gefunden das diese erst ab Bios 805 laufen.
Ja mit welchem Bios wurde mein neues X370 jetzt ausgeliefert? Auf dem Board steht es drauf und bei mir war es leider 612.
Musste dann mit anderen RAM starten, Bios Update drauf und neue RAM wieder rein. Dann lief alles sauber.
Wie kommst du überhaupt auf diese Idee?
Also ich habe noch niemandem die Waffe an die Brust gehalten du sollst jetzt meine Subtimings verwenden! :d Ob das professionell ist oder nicht ist mir komplett wumpe. Solange meine Games und Anwendungen einwandfrei laufen werden die Subtimings so verwendet und fertig. Sollte ich irgendwann mal auf eine Applikation treffen die dadurch instabil ist wird entweder was entschärft oder die Spannung von 1,37V bei DDR4-3333 leicht erhöht und weiter geschaut.
Wo wir schon bei Thema sind... früher (vielleicht sogar noch heute) schwörte man auf Prime95 bei der Stabilität. Heute lache ich nur drüber. Ich kann mit Prime95 Spannungen fehlerfrei fahren die in bestimmten Games instabil sind. Prime95 für eine grobe Richtung gerne, mehr aber auch nicht.
Für die RAM-Kompatibilitätsliste:
D.O.C.P.
BIOS: 3203
RAM: 16GB G.Skill RipJaws V schwarz DDR4-3200 DIMM CL16 Dual Kit (Dual Rank)
Bezeichnung: F4-3200C16D-16GVKB
Möglicher Takt: DDR4-2933
3066 läuft nach wie vor nicht stabil und 3200 startet überhaupt nicht.
Das führt zu keinen neuen Erkenntnissen, bedeutet nur Mehrarbeit. Mit steigendem GPU-Limit relativiert sich der Vorteil von schärferen Timings/Subtimings, höherer Bandbreite und/oder schnelleren CPU. Eins sollte man nur nicht vergessen, höhere Auflösung bedeutet nicht automatisch kein CPU-Limit. Meine Spielauflösung beträgt 1440p und selbst in dieser Auflösung mit AA/AF liegen die Frames in der getesteten Szene von F1 2015 beispielsweise nur 1% tiefer als der höchste Wert. Ist halt Worst Case was CPU-Limit angeht.
Das ist schon klar.
Ich hätte Deine Benchmarks gerne als Keule genutzt. Es gibt wahnsinnig viele Ignoranten, die der felsenfesten Überzeugung sind, dass RAM Speed unter Ryzen nichts bringt und die Dir dann uralte Reviews von genauso ahnungslosen Testern vorlegen. Wenn man anderer Meinung ist, verlangen sie sofort Spiele Benchmarks, die ich nicht liefern kann. Da kämen mir Deine Tests gerade recht. Nur wird dann gleich wieder das Argument "in 720p spielt doch keiner" ausgepackt.
Du solltest Dir mal die Granden im Kaufberatungsthread bei Computerbase anhören. Da ist immer noch Hynix 2933 C16 der letzte Schrei.
Du siehst, ich hab weder aus Vernunft noch Neugier nach 1080p gefragt. Es war der reine Eigennutz, der mich getrieben hat.
Ich sage nur, dass es gut ist Ausgangspunkte zu haben. Spannung ist ja irgendwo auch das kleinste Problem, bei 1,35 das die meisten DOCP von Haus aus benutzen, fangen die meisten eh an.
Das Ryzen allgemein relativ seltsam reagiert (eher eine Balance bei Spannungen/Termination etc sucht - Kenne genug die bei wenig SOC mehr vRAM brauchen und umgekehrt), liest man denke ich recht schnell sobald man sich informiert. Wie gesagt, das Tool ist nicht dafür da dir Arbeit abzunehmen (und das sagt 1usmus im übrigen ganz klar), sondern gibt dir einerseits errechnete Richtwerte (anhand deines Rams. Wenn ich 3400 CL16 Ram habe, und 2933 CL14 laufen lasse, habe ich effektiv gar nicht Übertaktet..) und andererseits Äquivalente zu TheStilts Timings runtergebrochen auf die anderen Straps.
Es geht ja auch niemand her und trägt die Timings von Stilt ein und beschwert sich dann bei dem wenns nicht wuppt. Oder will eine RMA von AMD weil er irgendwo gelesen hat das ein 1700er 3,8 mit 1,0v mitmacht und es seiner nicht schafft.
Die Ryzen sind jedenfalls absolut in der Position die so ein Tool -- aka gesammeltes Wissen aus den Foren im Laufe der Zeit, die CAD Werte (btw, die 24-24-24-24 die er als ersten Vorschlag bringt, sind die Auto werte..) die er anzeigt sind teilweise sogar aus meinen Tests und deren Posts im OC.net Forum über tausende Seiten verteilt -- nötig machen.
Anfangs keinerlei Erfahrungswerte, denn das Zusammenspiel war eine einzige Unbekannte. Wenn ich zurückdenke und mit 3/4 der Einstellungen nicht mal wusste was sie bedeuten geschweige denn irgendwo nachlesen konnte.. Ich hab jetzt noch die Datasheets für D-, E- und B-Die als Tab offen sowie eine Wissenschaftliche Arbeit über die Termination sowie skizzen welches Timing den Befehlskanal und welche den Datakanal betreffen^^
EDIT: @Reous, der Hinweis für 3203 im Startpost: Bei mir konnte ich die Original (=wie entpackt) Datei gar nicht laden UEFI intern, habe es umbenannt (schlicht 3203.cap) und plötzlich lief alles wie immer. Bei Agesa Updates sollte es eigentlich gängig und Allgemeinwissen sein, einen Reset VOR dem flash durchzuführen, da man nie weiß ob CPU intern was dazu kommt oder abgeschaltet wird (SMT, OPCache etc, sowas kann bricken wenn man es in der Konfig nicht auf defaults hat.) und man auch weiß das nicht nur das Bios sondern auch EC und sonstwas noch geflasht wird (-> Normal der Grund das kein Zurückflashen möglich ist)
Ich hätte ja gar nicht so eine Abneigung gegen den Calculator, wenn die Werte nicht so hammer hart daneben wären für den von mir getesteten B-Die. Alle Terminations (außer ProcODT, der ist ja bekanntermaßen 48-60), alle Spannungen, es war komplett alles Falsch und von der Realität unglaublich weit weg. Mir ging es übrigens genau gleich, ich bin froh, dass ich vorher irgendwo das Wort B-Die aufgeschnappt habe, und speziell danach gesucht habe beim Kauf. Aber das war alles viel rumgestochere ohne jegliche Ahnung am Anfang, da gab es auch noch fast keine Infos, außer den Stilt-Bildern...
Auch stimme ich ohne Vorbehalte zu: Der IMC von Ryzen ist mit Abstand der zickigste (oder schlechteste?), der mir je untergekommen ist. Obendrein habe ich noch nie einen CPU gesehen, der so starke Abhängigkeit vom Arbeitsspeicher hat und bei dem man rein mit der Optimierung von Subtimings (!) dermaßen große Gewinne erzielen kann. Kennst du einen anderen CPU, bei dem man ausschließlich mit Subtimings 10-15% reale Spieleleistung rausholen kann und das nicht nur in Extremfällen, sondern wirklich spürbar in fast jedem Game (sofern CPU-Limit)? Optimiert man bei Ryzen alle Timings und geht von 2666-CL14-Auto auf 3200-CL14-Stilt gewinnt man im Schnitt gut und gerne 20% an FPS, die im Spiel wirklich ankommen. Wie viel Core-Takt benötigt man, damit 20% mehr Leistung real in Games ankommen, +40%? Wäre der IMC von Ryzen robuster und die Subtimings von Haus aus etwas schärfer, wäre die mangelnde Spielperformance nie ein Thema gewesen. Die Kombination ist halt blöd, super zickiger Speichercontroller und extrem starke Abhängigkeit von Bandbreite und Timings.
Anbei noch die versprochene Anleitung zum analytischen Übertakten des Arbeitsspeichers, wenn man bei Stabilität und Performance keine faulen Kompromisse eingehen will.
1: CPU-Core auf Standard
Es ist wichtig, unnötige Fehlerquellen auszuschließen. Deshalb sollte der Prozessor selbst hier mit Standard-Spannung und Standard-Takt laufen, keine unnötigen Spielereien!
2: Schaltet sämtliche Energiesparoptionen sowohl in Windows, als auch im BIOS aus.
- Deaktiviert den EPU Power Saving Mode (AI Tweaker)
- VDDCR SOC Load Line Calibration: Level 3 (Digi+VRM)
- VDDCR SOC Current Capability: 130% (Digi+VRM)
- VDDCR SOC Power Phase Control: Extreme (Digi+VRM)
- Energiesparprofil: Höchstleistung (Windows Systemsteuerung)
- Power Down Enable: Disabled (DRAM Timing Control)
-> Die LLC Stufe 3 liefert die Spannung am konstantesten und hat die geringstmögliche Differenzen zwischen Idle- und Loadspannung, sodass wir hier Fehlerursachen ausschließen. Die anderen Optionen dienen dazu, dass kein Throttling einsetzt (Capability) und dass alle Phasen auch dauerhaft verwendet werden, ansonsten wird zwecks Energiesparen immer nur so wenig wie möglich Phasen verwendet. Wofür ein Board mit vielen Phasen kaufen, wenn man alle abgeschaltet lässt?
3: Ausloten des maximal stabilen Speichertakts
- Beginnt zunächst mit folgenden Spannungen: 1,35v (vMemory) | 1,1v (vSoC) | ProcODT 53Ohm
- VTTDDR muss immer genau die Hälfte von vMemory sein, bei 1,35v vMem also 0,675v und bei 1,4v vMEM 0,7v VTTDDR
- Setzt alle Timings auf Auto, außer die Haupttimings auf 18-18-18-18-40-60. Lässt den Gear Down Mode aktiv und den ganzen Rest auf Auto. Finger weg von irgendwelchem Tuning der Timings, die bleiben lasch und das ist auch gut so!
- Ihr braucht für die Tests unbedingt HCI Memtest, ich empfehle die Pro Version für 5€, ich hab dafür auch einen Launcher geschrieben, der die Fenster alle automatisch öffnet und anordnet. Video + Anleitung. Lasst euch Zeit, wenn ein HCI Lauf mehr als 100% gut läuft, bricht ihn nicht ab und schreibt OK. Stabil ist erst, was eine Nacht HCI Memtest ohne Fehler übersteht!
- Solltet ihr so merkwürdige Probleme haben, dass HCI immer erst bei 1000% einen einzelnen Fehler wirft oder es die ganze Nacht gut war und du dann den Browser öffnest und zack hast du einen Fehler, dann müsst ihr mit der SoC Spannung rauf! Wenn ihr hier etwas mehr habt, ist das völlig egal, die Optimale Spannung wird erst am Schluss ausgelotet. Ihr müsst nur aufpassen, dass die Spannung selbst nicht Probleme verursacht, wenn ihr also 1,20v SoC einen Fehler bekommt und bei 1,15v nicht, dann nimmt natürlich das 1,15v.
- Manchmal ist das Board zickig bei Änderungen im BIOS und startet pauschal nicht, egal ob die eingestellten Werte stabil sind! Nicht sofort aufgeben, wenn ich nur eine Kleinigkeit ändere (z.B. vMemory von 1,375 auf 1,38v) und es plötzlich gar nicht mehr startet, dann probiert es einfach erneut. Diese Auffälligkeit ist hin und wieder nach einer Änderung einfach einmalig da.
- Beginnt mit 3200Mhz und versucht diese mit den folgenden drei Attributen zum laufen zu bekommen: vMemory, vSoC und ProcODT. Alle anderen Einstellungen auf Standard belassen. Ihr solltet euch in folgenden Rahmen bewegen: 1,35 - 1,45v (vMemory), 1,05 - 1,20v (vSoC) und 48Ohm, 53Ohm und 60Ohm bei ProcODT. Bei ProcODT ist die allgemeine Empfehlung für B-Die am ehesten 53Ohm, den würde ich erstmal so setzen und nur dann modifizieren, wenn ich den Takt nicht mit den Variablen vSoC und vMemory zum laufen bekomme. Versucht jetzt die 3200Mhz mit verschiedenen Kombinationen von vMEM 1,35v - 1,45v und vSoC 1,05v - 1,2v, am besten jeweils in 0,025v Schritten ausgelotet zu erreichen. Man entwickelt relativ schnell ein Gespür dafür, ob eine Einstellung jetzt schlechter oder besser ist. Wenn ich vorher mit 1,05v SoC nichtmal richtig booten kann und mit 1,15v das soweit schon wunderbar funktioniert, ich aber in HCI Fehler bekomme, ist das ja schon viel besser und der richtige Weg. Wenn ich mit 1,35v vMEM direkt nach 10% einen Fehler bekomme und 1,4v bis 100% ohne Fehler laufen, bin ich hier auf dem richtigen Weg. Auf diese Art und Weise muss man sich hier mühsam und quälend herantasten.
- Solltet ihr eine stabile 3200Mhz Einstellung finden, versucht euer Glück mit 3333Mhz und eventuell 3466Mhz, solange bis ihr genug habt oder nicht mehr weiterkommt, weil alle Kombinationen nicht stabil sind
- Wenn ihr fertig seid, testet sicherheitshalber nochmal mit Prime95 Blend mit 80% von eurem Speicher. Wenn ihr hier Probleme habt, müsst ihr vSoC erhöhen, weil HCI den Controller nicht stark belastet, dafür ist Prime95 ideal. Mit mehr vSoC solltet ihr hier schnell Erfolg haben.
-> Wichtig: Schreibt euch eure Ergebnisse auf, weil ihr nach 30 Versuchen nicht mehr wisst, was am Anfang rausgekommen ist und ihr somit einige Werte sonst doppelt prüfen würdet.
-> Dieser Punkt ist am wichtigsten und wenn man hier erfolgreich fündig wird, hat man mehr als 50% der Arbeit hinter sich. Die Timings sind nur noch Formsache, dieser Punkt hier ist das knackigste! Lasst euch Zeit und nicht zu schnell entmutigen, es ist durchaus normal, wenn man hier auch nach 3 Stunden noch kein brauchbares Ergebnis hat.
4: Maximale Haupt Timings ermitteln
Wenn ihr eine Einstellung gefunden habt, die HCI Memtest und Prime95 stabil durchläuft, dann sind dafür die Einstellungen vSoC und ProcODT validiert und versiegelt. Tastet euch jetzt an die maximalen Timings (Haupt) heran und geht hier in Gruppen vor: Die erste Gruppe sind die ersten vier Timings, die alle gleich und einen geraden Wert haben sollten, ungerade Werte starten oft nicht. Also versucht hier 14-14-14-14 oder 16-16-16-16. Wenn ihr hier Probleme habt, könnt ihr noch mit der vMemory Spannung rauf oder runter und prüfen, ob es damit besser wird. Wenn ihr hier irgendwann eure maximalen Haupttimings habt, würde ich sowohl Takt, als auch Haupttimings, vSoC, ProcODT und vMemory nicht mehr anfassen, diese sind vorher als stabil getestet worden und müssen so bleiben. Eure einzige Variable ist jetzt noch die einzelnen Subtimings
-> Wie auch bei dem Takt lasst euch nicht entmutigen, wenn das Board direkt in den Fail Safe Mode startet! Manchmal zickt das Board bei Änderungen einmal herum, obwohl die Werte stabil sind. Einfach dann nochmal setzen. Die Stabilität wird mit HCI getestet und nicht davon, ob der PC startet, weil das wie gesagt oft buggy ist, einfach nochmal probieren.
5: Maximale Subtimings ermitteln
Lotet jetzt jeden einzelnen Subtimingwert aus. Fangt mit tRAS an, stellt ihn auf den bestmöglichen Wert. Als bestmöglichen Wert würde ich immer die Stilt UHQ B-Die 3200Mhz Werte nehmen. Ändert immer nur einen Wert auf einmal. Durch das in Schritt 3 und 4 validierte Setting könnt ihr sicher sein, dass wenn ein Fehler auftaucht, dieser garantiert wegen dem geänderten Timing Wert kommt. Wenn ein Wert dann eine Nacht in HCI Memtest stabil war, könnt ihr diesen Timing Wert mit in die stabile Konfiguration mit aufnehmen. In ganz seltenen Fällen kann es vorkommen, dass ihr bei nachfolgenden Timings Probleme habt, egal wie ihr diese einstellt - dann liegt es daran, dass das vorherige Timing trotz einer Nacht HCI nicht 100% stabil war und die Fehler bei dem darauffolgenden Timing noch daher kommen, dann müsst ihr eventuell an den vorherigen Timing nochmal ran - kam bei mir aber nicht einmal vor. Wenn ein Timing mehr 3 mal in nachfolgenden Timings mitgetestet wurde, könnt ihr diesen Wert versiegeln, also in die 100% stabile Konfig mit aufnehmen. Nicht vergessen: Wenn ich jetzt DDR4-3200-14-14-14-14-30 als rock stable identifiziert habe, teste ich damit weiter, z.B. DDR4-3200-14-14-14-14-30-46 und gehe nicht wieder auf 18-18-18 oder so zurück. Wenn es nicht läuft wird der unsichere Wert erhöht, dann geht es weiter mit DDR4-3200-14-14-14-14-30-48, solange bis die gesamte Kette stabil ist. Danach geht es mit dem nächsten Wert weiter, also DDR4-3200-14-14-14-14-30-52-4-6 usw.
Die bestmöglichen Werte werden zu 75% nicht stabil sein, ihr werdet meistens sehr schnell Fehler in HCI Memtest bekommen. Geht dann stufenweise um 1 oder 2 rauf, solange bis es eine Nacht HCI Memtest stabil ist. Die Werte tRRDS und tRRDL würde ich gemeinsam verwenden und zwar immer so, dass tRRDL 1,5x von tRRDS ist (tRRDS 4 = tRRDL 6 | tRRDS 5 = tRRDL 7 oder 8 | tRRDS 6 = tRRDL 9). Ebenso würde ich tRDRDSCL und tWRWRSCL sowie tWRWRSD und tWRWRSD sowie tRDRDSD und tRDRDDD als Pärchen verwenden (gleiche Timings). Ebenso könnt ihr dann auch versuchen, ob die Konfiguration ohne GearDownMode stabil läuft.
Tipp: Die wichtigsten Subtimings unter Ryzen sind tRDRDSCL und tWRWRSCL, dort solltet ihr versuchen, diese auf 2 zu bekommen.
6: BankGroupSwap
Wenn ihr alle Timings und Taktraten validiert habt, könnt ihr noch den BankGroupSwap und BankGroupSwapAlt Modus deaktivieren und wieder eine Nacht testen. Wenn auch das passt, könnt ihr schrittweise die Spannung reduzieren, um hier das Mimimum auszuarbeiten, solang bis es instabil wird. Die Spannung auf das minimum zu drücken, würde ich erst am Schluss machen. Nicht vergessen: Wenn ihr vSoC reduziert, immer auch Prime95 Blend testen, nicht nur HCI Memtest!
7: CPU-OC und Memory-OC kombinieren
Jetzt könnt ihr noch euer CPU-OC gemeinsam mit dem Memory OC testen. Wenn es Probleme gibt, liegt es definitiv am CPU-OC, weil das Memory OC 100% sicher validiert wurde. Eventuell ist das gesamte OC Potential geringfügig durch MemoryOC reduziert, weil die Temperaturen durch höheren Speichertakt und höheren vSoC doch merklich ansteigen (bei mir etwa 10°C zu 0,9v 2133Mhz) und das sozusagen passiv das OC-Potential geringfügig reduziert. Die endgültig Finale Konfig dann nochmal 1 Nacht durch HCI und 1 Nacht durch P95 Blend laufen lassen und ihr habt es geschafft.
Bei meinen Werten mit 3,7Ghz nicht verwundern lassen: Ich hab hier einfach einen OC-Krüppel, der nicht mehr rockstable packt. Zwar sind sogar 3,9Ghz Cinebenchstable und auch Gamestable bei 1,425v - in Prime05 bekomme ich aber nach wenigen Minuten Fehler und ein instabiles System ist doch Bullshit, dann lieber auf 5,4% Takt verzichten, dafür 40% weniger Stromverbrauch/Hitze/Lautstärke und einen (rock) stabilen Betrieb. Das liegt aber nicht am RAM, auch mit Standard-RAM geht hier nicht mehr.
8: Spannungen minimieren (Optional)
Wenn ihr die gesamte Konfiguration stabil habt, könnt ihr versuchen, noch weniger Spannung zu geben. Wie immer nur einen Wert ändern und prüfen, ob es damit noch läuft. Meines Erachtens nach würde ich da nicht zu viel Zeit rein stecken, weil das was ihr euch an Leistungsaufnahme durch weniger vMemory oder vSoC spart, verbraucht ihr 100x in den Testläufen.
Wenn ihr alle 6 Schritte durchgehalten habt, seid ihr die top 0,1% im Internet, die wirklich einen schnellen und stabilen Speicher unter Ryzen haben. Die ganzen Papiertiger in Internetforen haben zu mehr als 99% alle teilweise höchst instable Konfigurationen, die irgendwann wegen Abstürzen oder Fehlern ohnehin auf Auto gesetzt wird, während in der Signatur natürlich noch die Fantasiewerte stehen. Noch ein Tipp: Wenn ihr euch diese mega Arbeit gemacht habt, fasst nichts mehr davon an! Bleibt bei eurer BIOS-Version und bei eurer Einstellung, ein BIOS-Update, was beispielsweise die Auto-Werte ändert, könnte euch alles ruinieren!
PS: Die Anleitung bezieht sich ausschließlich auf Samsung B-Die 2x8GB Single Rank Speicher! Für Micron, Hynix, DualRank, Vollbestückung, usw kenne ich mich nicht aus und die Werte können zum Teil enorm abweichen. Das analytische Vorgehen selbst ist natürlich immer gleich, nur muss man z.B. für DualRank ganz andere ProcODT Werte eintragen (60-96), eventuell mit den RTT und CAD Werten spielen uvm.
Nochmal eine Auflistung meiner Settings:
AI Tweaker
CPU-Core Ratio: 37
CPU-Voltage: 1,275v (manual)
SoC-Voltage: 1,15v (manual)
Memory Frequency: 3333Mhz
DRAM Voltage: 1,375v
VTTDDR Voltage: 0,68750v
AI Tweaker / Digi+VRM
CPU Load Line Calibration: Level 3
CPU Current Capability: 130%
VRM Spread Spectrum: Off
CPU Power Duty Control: Extreme
CPU Power Phase Control: Extreme
SoC Load Line Calibration: Level 3
SoC Current Capability: 130%
SoC Power Phase Control: Extreme
AI Tweaker / DRAM Timing Control
ProcODT: 53 Ohm (48 hat auch funktioniert)
Cmd2T: 1T
Gear Down Mode: Disabled
Alle Timings siehe Screenshot unten
Advanced / AMD CBS / DRAM Memory Mapping (nur im MOD BIOS verfügbar, THX an number9 und Reous)
BankGroupSwap: Disabled (egal für Stabilität, steigert aber Gaming Performance auf kosten von RAM Benchmark Leistung)
BankGroupSwapAlt: Disabled (egal für Stabilität, steigert Gaming Performance auf kosten von RAM Benchmark Leistung)
Alle nicht aufgeführten Einstellungen sind auf Auto!
Timings sind wie folgt
hab nur zum Test mal kurz mit deinen Werten angefangen und hab leider schnell Fehler bei hci erhalten (noch innerhalb der ersten 100). Hab dann den tRC Wert bisl runter gesetzt (immer 2er Schritte) weil ich mal gelesen hatte, dass der tRC Wert ungefähr tRP +tRAS sein soll und so Stabilität dazugewonnen. Gerade bin bei 46 glaub ich und bin zumindest jetzt schon über die 400 und er läuft noch. Das sagt natürlich noch nichts aus, wundert mich aber dennoch warum niedrigere Werte vermeintlich besser laufen. Wahrscheinlich iwas mit cycletime aber ich verstehe einfach nicht viel von RAM.
Könntest du evtl. mal einen AIDA Cache+Mem Benchmark machen damit ich Vergleichswerte habe? Kann leider erst am We richtig testen dh. mit schlaffen Timings Mhz ausloten, da ich ungern meinen PC laufen lassen, wenn ich zur Arbeit gehe.
€: Oh gerade gesehn, dass Du einen neuen Beitrag geschrieben hast. Den werd ich mir erstmal zu Gemüte führen! Danke nochmal für deine Mühe!
So habe ihn gelesen und muss sagen eine tolle Anleitung für alle, gerade für Leute, die nicht so viel Ahnung haben (also für mich!). Ich selbst bin bisher immer von Werten von Anderen losgegangen und hab bisl rumgespielt. die 3200 und 3333 hab ich tatsächlich bei 13h hci stabil bekommen, aber immer ohne genau zu wissen welche Subtimings etwas beeinflussen. Da ich aber sowieso gerne rumspiele, werde ich mal alles von Anfang an, wie von Dir beschrieben, probieren.
Noch ne ganz andere Frage, wenn ich einen AIDA Bench sehe, welche Werte beeinflussen die Latenz(also den ns Wert um die 70?) Der scheint mir ja einer der wichtigeren Werte zu sein, da ich in vielen Benchmarks (also Spiele etc.) gesehen habe, dass häufig bessere Timings höheren RAM Takt schlagen.
Die AIDA Latenz wird durch die Haupt Timings, sowie durch den Speichertakt beeinflusst. Bei mir sind es etwa 68-69ns, mit 3333-CL16 sind es ~71ns gewesen. Wenn du schon stabile 3333Mhz hast, bist du schon quasi 50% durch und das vor allem den wirklich ätzenden Teil schon hinter dir. Der Rest ist nur noch Formsache, weil bei den Timings man nicht so viele Variablen hat. Bei den Haupttimings sind es zwei (Haupt Timings und Spannung), bei den Subtimings gar nur eine (nur der jeweilige Subtiming). Das geht entspannt vor sich hin und braucht nur (Computer)Zeit, aber eigentlich kaum Aufmerksamkeit.
Ich würde mal gern noch Wissen, ob es wirklich Unterschiede darin gibt, ob man seinen RAM mit dem DOCP Profil Eintrag laufen läßt oder ohne (meint: Docp einstellen, danach die Frq/Timings usw abändern vgl zu ohne DOCP Profil einstellen aber immer noch die FRQ/Timings usw verändern).
Hab da auch jetzt immer noch seltsame Berichte gehört. Bei mir machts keinen Unterschied (mit 3203 aber noch nicht probiert).
