Catalyst 5.5 Released [Sammelthread]
Soeben released, folgende Sachen wurden gefixt
# 3DMark05: Running the application under Windows XP for extended periods of time no longer results in the operating system failing to respond when using an ATI Radeon™ X700 PRO
# Ashli Viewer sample Wood: Display corruption is no longer noticed when Anisotropic Filtering set to 4x or above
# Ashli Viewer v1.6.0: Running the application under Windows 2000 and launching a sample item found in the Programs & Shaders no longer results in corruption being displayed in the sample item
# City of Heros: Playing the game under Windows XP with an ATI Radeon™ Xpress 200 series installed no longer results in the characters in the game appearing corrupted
# Freedom force VS The 3rd Reich: Playing the game under Windows XP with an ATI Radeon™ 8500 installed no longer results in the super hero character attributes appearing blank
# Imperial Glory Demo: Playing the game under Windows XP with an ATI Radeon™ X800 installed no longer results in the game failing to respond
# Star Wars Knights of the Old Republic 2: Setting the graphic option in the Catalyst™ Control Center to Optimal Quality, followed by launching the game and setting the resolution option to 1600x1200, no longer results in a performance drop being noticed
# Star Wars Knights of the old republic: Loading the Dantooine level of the game under Windows XP no longer results in slow game performance
# Setting the desktop display to 800x600 or 1600x1200 16/32bpp no longer results in the incorrect display resolution information being provided when checking the video control panel in the Catalyst™ Control Center
# Setting the display device to 1080i no longer results in the text on the custom format being illegible
# Setting a customized resolution for 720p now works properly when maintaining the aspect ratio
# Moving the TV to desktop2 and selecting swap device or double up no longer results in the CRT being in panning mode and display corruption being seen on the TV
# Having a TV connected as the only display device and clicking the OK button in the ATI displays tab found in the Advanced section of the Display Properties results in a flash of the TV image being noticed
# Connecting and enabling an HDTV and entering the properties page for the HDTV no longer results in the D3/D4 options being available in the D-Connector Control Panel
# The occasional Windows error messages no longer occurs when booting into extended desktop under Windows XP when using an ATI Radeon™ X300 or X600
# Corruption is no longer seen when connecting a secondary display device and moving the primary display device to the left of the secondary device, followed by disconnecting the primary display device and then reconnecting it
# Previewing or launching the aquarium screen saver under Windows XP Media Center Edition no longer results in the operating system failing to respond
# RF online game compatibility issue with all ATI Radeon™ series
# Launching the Catalyst™ Control Center help files from the Start->All Programs->Catalyst™ Control Center now results in the localized version of the help file being displayed
# Catalyst™ Control Center: Running the French custom install no longer results in a NewFeature1 component being listed
# The link found in the second and third help page for the Change Desktop Settings found in the Japanese version of the Catalyst™ Control Center no longer cross-references to an incorrect help page
# A black screen is no longer displayed when launching AMCap and attempting to view video from the tuner when using either the svideo or composite inputs
# Display corruption is no longer noticed on the TV when setting the TV format to PAL-B and attempting to adjust the flicker removal in the TV Advanced option
# Having a TV and CRT connected and clicking on Preview Automatic adjustment in the Optimize Media Center no longer results in both display devices displaying a black screen
Catalyst 5.5 Downloadübersicht
Release Notes
ich lade ihm mir mal und teste ihn gleich. mal gucken was 3dmark03 05 und aquamark sagen. :d
Edit: hier die ergebnisse.
12576 mit 5.4 3dmark03
73.160 mit 5,4 aquamark03
12627 mit 5.5 3dmark03
73127 mit 5.5 aquamark03
so toll is es nich.
Suche Erfahrungen bzw. Testvergleiche Cat. 4.12 und Cat 5.5 (gerne auch im web - hatte über google leider nichts gefunden).
Nutze ersteren (noch) mit einer 9700 pro.
Lohnt ein Umstieg auf den neuen unter Bildqualität- bzw. Performancegesichtspunkten?
so toll is es nich.
Geht doch, sind ja auch keine Quantensprünge zu erwarten, vorallem sollte man dann auch noch mit Games testen.
Ich guck immer bei dark-tweaking.com, da gibts immer sofort nen Test, wenn ein neuer Treiber rauskommt. Der 5.5 scheint sehr gut zu sein und performt endlich mal wieder überall wirklich überzeugend.
mfg :)
bei mir kommt die fehlermeldung "anwendung konnte nicht richtig initialisiert werden"...
(wenn ich den alten treiber runtergeworfen und den 5.5er draufgemacht hab)
was nu? :(
LG
