kayawish24
hello....
(my system specs are below in my signature)
Now i dont know that is my i7 950 D0 is bad batch or i am doing something wrong in overclocking.my Overclock is 10 hours prime95 stable @ 3.7GHz and the settings i used in bios are.
23x multiplier
BCLK 161
DRAMFrequency 1614 MHz
UCLK 3227 MHz
8-8-8-21
CPU VTT 1.22
QPI 1.4
Dram volts 1.54
rest of everything is on AUTO and HT is also OFF /Turbo is also OFF
on these settings my i7 950 @ 3.7GHz is stable more then 10 hours in prime95 blend test and NO errors but when i try to overclock my cpu to 4 GHz its even not stable @ 1.33v
the settings i used for OC it to 4 GHz is same as above except Dram is running @ 1750 MHz and even its not stable if i run the ram @ 1450 MHz.even increasing / decresing Multi & Bclk is not stable @ 4ghz on 1.33v.so why my i7 950 requires such a high increase in CPUVTT from 3.7GHz to 4GHz.
3.7GHz stable on 1.22v while for 4GHz it take more then 1.33v.why is this?
23x multiplier
BCLK 161
UCLK 3227 MHz
8-8-8-21
CPU VTT 1.22
QPI 1.4
Dram volts 1.54
