CoreAVC v2.0: What's new in this release
CoreAVC H.264 Video Codec - Version 2.0.0.0 (2009121
- ADD: Initial support for Windows 7
- ADD: Support for Windows Media Center (in .MKV)
- ADD: Custom fourcc to match the Haali splitter
- ADD: Support for Non-Compliant Motion Vectors (MV)
- ADD: mmx optimizations
- ADD: mmx2 optimizations
- ADD: sse optimizations
- ADD: sse2 optimizations
- ADD: sse3 optimizations
- ADD: ssse3 optimizations (almost 70)
- ADD: sse4 optimizations
- ADD: faster handling of pure-DC chroma blocks
- ADD: new x86 cpu caps
- ADD: Multi-dupe weightp (+Future x264 changes)
- ADD: 64bit support
- FIX: Fix potential failure in CABAC MVD decoding.
- FIX: Proper alignment intrinsics for MSVC and GCC.
- FIX: AVC SEI+userdata fix
- FIX: Focus bug in Windows Media Center that disabled CUDA
- FIX: Better frame re-ordering on difficult streams
- CHG: Supports 16 CPU Cores (was 4 cores max)
- CHG: Support for QuadHD resolutions(4096×4096)
- CHG: New dc_add
- CHG: Faster CAVLC
- CHG: Faster CABAC
- CHG: Faster Deblocking (Massive deblocking overhaul)
- CHG: SSSE3: Faster Motion Compensation (20% faster on Core 2 Conroe and more for Penryn)
- CHG: New CoreNumber for 2.0
- CHG: Initial support for CoreAccount. Linking purchase+account
- CHG: Integrated the Haali splitter into the installer
- CHG: New installer supports both 32/64 bit Operating Systems
- CHG: Filter compiled against ICC (2% speed increase for modern Intel Processors)
- CHG: Updated IDCT to support ARM NEON Cortex A8 Support
- CHG: Updated Blitter YUV/RGB for ARM NEON Cortex A8 Support
- OEM: Initial ARM NEON Cortex A8 Support (iPhone, Touch, Linux, Windows Mobile)
- OEM: SDK NVIDIA CUDA 2.3 support
- OEM: Removed the windows direct3d requirement for CUDA (it can now be native)
- OEM: Updated GStreamer plug-in
Haali Media Splitter (20091112)
- ADD: Official 64bit support
- ADD: Official support for Windows 7
- ADD: Custom fourcc option for windows 7
- ADD: Silent install flags for each install option
- CHG: Disabled explorer thumbnail support (off by default)
Haali Media Splitter supports the following command line options:
/S - silent install without any UI
/MKVONLY - register only Matroska components
/AVI=[yes|no] - register AVI support
/MP4=[yes|no] - register MP4 support
/OGG=[yes|no] - register OGG/OGM support
/TS=[yes|no] - register MPEG TS support
/PS=[yes|no] - register MPEG PS support
/WMP=[yes|no] - register WMP to play in Windows 7
