[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine Identifikation der ICs mehr möglich.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Speed Bin & Die Revision
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWinfo (ab 7.26) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
in Windows booten ist nett, ob das aber Karhu oder Gsat stable ist ? @SH teste das mal erste Erkenntnisse wären interessant.
Ausserdem, welche Spannungen: IO, SA, VDimm.
Habe nur mal Super PI mit 32m laufen lassen bei 6200. Das war gut. Bin nicht so der Experte im RAM OC. Einfach das Samsung Preset genommen , welches schon auf dem Board verfügbar ist und dann nur die MHz hoch gesetzt :)
Ich mache heute Abend weiter
@SH
OC Profil hat er hinterlegt zum Download.
Mainboard ASRock z690 Aqua OC???
Das gibt nicht Mal beim Hersteller auf der Website
in ddr4 massivst ja. oder meinst du ausschließlich bezogen auf ddr5?
Okay ich werd in 2K zocken da macht es fast keinen Unterschied wie ich sehe. Bei Full HD siehts wohl anderst aus
Mainboard ASRock z690 Aqua OC??? Das gibt nicht Mal beim Hersteller auf der Website
Das sollten eigentlich alle kennen, die sich das Intel OC Event zum Plattform Launch angeschaut haben.
Intel-Core-i9-12900K-CPU-6.8-GHz-LN2-Overclock-_1-1110x1480.jpg Intel-Core-i9-12900K-CPU-6.8-GHz-LN2-Overclock-_3-1110x1480.jpg
Artikel über PNY 4800 mit Hynix Bestückung inkl. VDimm:Takt Skalierung, auch einige brauchbare Fotos von Hynix M-Die IC.
Preis liegt bei £449,99, also rund 500€ + 19% Einfuhrumsatzsteuer. o_O
Auch bei den Releases tut sich nix. Die Produkte werden eher weniger. Letzte Woche noch 20 DDR5 Artikel über alle Speichergrößen hinweg, jetzt 17.
Naja vielleicht auch gut so. Wenigstens nicht so wie bei den Grakas mit endlosen Paper Launches. :d
Wo siehst du da einen Preis ? find ich gut dann kaufen sich das so wenige das ich 2 bekomm :P ich hab ja eh mit 1200 geplannt
na so schlimm isses zum glück net. auf den UK preis musst noch die 20% VAT abziehen :LOL:. Wobei der 6400er bei mir mit 499£ sogar angezeigt wird. der 6200er ist bei 449£.
Du bekommst von Overclockers.co.uk keine VAT freie Lieferung, als Endkunde gleich zweimal nicht. < überholt
Da UK kein EU Mitglied mehr ist zahlst du hier die Einfuhrumsatzsteuer, und zwar auf den Artikelpreis+Versandkosten.
Wo wollt ihr da einen Preis angezeigt bekommen da steht doch überhaupt noch kein Preis dabei
Ist allerdings wirklich der Preis für die 6200er. Und noch der Preis für die 6400er
Noch mal £50 oben drauf.
Und da UK kein EU Mitglied mehr ist zahlst du hier die Einfuhrumsatzsteuer, und zwar auf den Artikelpreis+Versandkosten.
doch, sobald man angemeldet ist als EU Mitglied (hab mal testweise nen i5-12600k reingepackt, preis laut website 249£, im warenkorb dann -20% VAT nurnoch 207,49£):
wäre ja sonst auch zu dreist :LOL:
einfach auf die wishlist packen bei overclockers..
also bestellen kann man da definitiv sofern die mal verfügbar werden, aber wird halt so auf 550€-600€ für die high kits rauslaufen, da Versand auch bei 22£ liegt nach Deutschland
naja muss ja, zahlst ja sonst 2 mal
Also so wie ich es erwartet habe. Wenigstens sind die dann nicht so schnell ausverkauft :p
