[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine Identifikation der ICs mehr möglich.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Speed Bin & Die Revision
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWinfo (ab 7.26) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
Bei mir steht „wird von der Logistik bearbeitet“. Einmal C40 und einmal C36. Na da bin ich mal gespannt.
PS. Paketmarke habe ich schon für das C36er Kit.
Falls das Jemandem taugt, aber kein Plan ob die liefern man kann 999x in den Warenkorb packen^^
Arbeitsspeicher Crucial CT32G48C40U5
DDR5-RAM, 4800 MHz, 288-pin, CL40, 32 GB 297.49 €
Taugen die was? also der RAM, oder besser finger weg?? ich brauche halt noch RAM für mein 12700k auf nem MSI Z690......... aber die Preise.....
Crucial ist die Micron Hausmarke. Also OC technisch nicht wirklich relevant. Für Standard Betrieb sollte es gehen.
joooo nice
einmal 5600 cl40 RGB
einmal 6000 CL 36
einmal 6000 CL40 RGB
alle drei bestellungen durchgegangen und verschickt :d:d verdammt da werde ich wohl bisschen was zurückschicken müssen. oder eben ebay
würdet ihr 6000 cl 36 oder 6000 cl 40 rgb behalten?
denkt ihr es gibt da einen spürbaren unterschied?
hääää du weist nicht welcher besser ist, brauchst eig nur ein kit und bestellst trotzdem gleich 3 kits?
schick das was du nicht willst zurück und entschuldige dich bei alternate du hamster^^
der c36 sollte besser sein. die frage ist eher ob du ihn zum laufen kriegst
klar ich hab 3 stück bestellt weil ich bisher immer pech hatte und die bestellung nie durchgekommen ist.
hab die ganz einfachen schwarzen 5600 C36 ohne BlingBling bestellt (1x...!)... jetzt brauch ich nur noch ein Board und eine CPU zum basteln
@even.de darfst mir eine klatschen :haha:
Z690 Apex (vermutlich bester RAM support)
ASUS ROG Strix Z690-I (beengt, RAM Support vermutlich besser als beim 4Slot "billig" Strix-G)
ASUS ROG Strix Z690-G (noch gar nix gelesen)
mein ITX Wakü System muss ich nicht auf biegen und brechen erhalten... wenn es auch herrlich klein ist...
joooo nice
einmal 6000 CL 36
Natürlich zurück schicken 🤡
Bevor du sie zu rück schickst biete sie doch auf dem HWL Marktplatz an :d
Gibts eigentlich schon DDR5 nicht nur mit on-die ECC sondern auch mit Host-ECC?
Habe noch nichts gefunden.
So meine beiden Alternate Trident Z5 6000er C36 u. C40 Kits sind da. Werd die beiden mal kurz antesten die Tage und dann zumindest eins in den HWLuxx Market stellen.
Also ich bekomme die G.Skill 6000 CL40 mit dem neuen BIOS 0015 auch nicht stabil, bzw glaube ich es liegt nicht am BIOS sondern am Speicher selbst, sobald dieser 65°C erreicht gibt es Fehler, aber lass ich ihn 5600 CL36 laufen passiert nichts, selbst bei 70°C. :kotz:
Also meine 6000er CL36 1,3V laufen ohne Probleme aufm Apex. MemtestPro wurde nur mal kurz bis ~60% laufen gelassen ohne Fehler. Mehr Zeit hatte ich noch nicht zum testen.
Sicherlich, nur halt nicht für Endkunden.
Mit irgendwas müssen Intel und die Superscaler ja den Sapphire Rapids testen ;)
Welches BIOS? XMP1 oder 2. Manuell etwas angepasst?
Das 0053 hab ich drauf. Hatte beide XMP‘s probiert und beide haben sich mit Fehlern geschmückt. Aber auch nur weil eine Einstellung im Bios auf 1,35V stand. Weiß jetzt genau nicht welche ausm Kopf. Fand den Wert meines Erachtens zu hoch. Bin kurz auf 1,25 runter und danach hatte ich keine Fehler mehr.
Memory Controller Voltage ist bei XMP1 bei 1,35V bei Auto Einstellung. Bei XMP2 ist die Voltage auf 1,1V gestellt. Der eine zu hoch der andere zu niedrig.
Bin wieder zurück vom 0015 Bios auf das 0010er BIOS, damit lief der Ram mit angepassten Subtimings stabiler. Komisch ist, dass der RAM mit Karhu RAM Test bis 7000% fehlerfrei läuft und ich auch beim zocken keine Probleme habe und dann plötzlich wenn ich das Spiel beende, das System rebootet und ich mit den exakt selben Einstellung beim Karhu RAM Test Fehler bekomme... könnte Temperaturbedingt sein, kann mir das nicht erklären.
So läuft vorerst einmal. Schau mir jetzt mal das C40er Kit an. Nur OC lässt zu wünschen übrig. 6400 will er irgendwie nicht richtig booten und das mit CL40.
Gkill F5-6000U3636E16GX2-TZ5RK
- 6600C40 Bootet, aber Windows crashed 🚫
- 6400C36 problemlos in Windows, aber TM5 failed 🚼
- 6000C32 TM5, Karhu, gsat stable ✅
- 6200xxx müsste ich noch testen
Ist das ein 0815 Kit oder was selektiertes?
Hab eben die G.Skill 5600C40 bekommen, leider keine 6000er. Sind die viel schlechter als die 6000er Kits, oder keine große Selektion?
Würde eher sagen 0815. Bekomm mein 6000er CL40 gegenüber dem CL36 überhaupt nicht stabil. Egal was für Spannungen ich eingestellt habe immer Fehler. Kann aber auch am Bios liegen.
Bei mir läuft das 0010 und 0015 nicht gut.
6000 1T und 6200 1T kriege ich nur mit 0053 stabil.
