[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Eie (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine Identifikation der ICs mehr möglich.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Speed Bin & Die Revision
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWinfo (ab 7.26) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
Was glaubt ihr, wird ab Donnerstag viel an Speicher zum Verkauf "freigeschaltet" oder folgt das im Laufe des Monats? Seltsam ist ja das es kaum RGB-Speicher (ja wem es gefällt :)) zu kaufen gibt.
Ich Bezweifel, dass da viel Freigeschaltet wird zum Stichtag. Was die Händler im Lager oder im Zulauf haben werden sie bereits Online gestellt haben. Nicht alle Händler nehmen Vorbestellungen an daher wird man ggf. zum Ende der Woche noch ein paar Posten sehen. Von G.Skill hat man aus der Trident Serie auch noch gar nichts gesehen. Glaube Caseking zB. hat ja noch so gut wie gar nichts gelistet (gehabt). Alles andere wird dann langsam reintröpfeln wie halt üblich bei HW im Jahre 2021.
Hört sich ja nicht so toll an was "Igor Clickbait" hier zu DDR5 sagt:
"DDR5 ist hingegen echter Murks, das muss noch reifen. Heute kam endlich mal ein gescheites DDR4-Brett. Aber bis zum Launch wird das nichts mehr. Ich bin auch bei den CPUs etwas unschlüssig, wie schnell die zweite Lieferung kommt, die Shops zucken mit den Schultern. RAM ist sogar in TW schon knapp."
Quelle
05-gskill-intel-xmp-3_0-list-screenshot.png 03-gskill-ddr5-7000-cl40-screenshot.png
Update:
Quelle
Ja und was meint er genau? Performance? Stabilität? Preis? Verbrauch?
Tja, wahrscheinlich eine Kombo aus allem was du aufzählst. Die Gear Modi werden wahrscheinlich eine große Rolle spielen, habe in nem China Forum gelesen ab 6000MHz braucht man schon Gear 3, keine Ahnung ob's stimmt. Andere, die schon testen schreiben, man muss Richtung 8000MHz gehen, damit DDR5 einigermaßen etwas bringt. In zwei Tagen wissen wir ja alle mehr, mich interessiert es eh kaum, ich bleibe vorerst bei DDR4. Hier soll Gear 1 laut China Foren auch bis 4000MHz gehen, wir werden sehen - das Preisleistungsverhältnis wird auf jeden Fall eher mangelhaft sein.
Auf den offiziellen Screenshots der letzten Press Releases war für DDR5-6600/6800/7000 stets Gear 2 aktiv.
^^Jau, kann ja sein, ich schrieb ja, keine Ahnung ob's stimmt, ich glaube Gear 3 gibt es auch gar nicht offiziell, Gear 2 und danach kommt direkt Gear 4 - wahrscheinlich ist ja auch nicht jeder IMC in den CPUs gleich, unterschiedliche Bretter usw., wird daher wohl ein großes Chaos sein zu Anfang. Ich mein schon in Gear 2 läuft der Speichercontroller der CPU mit nur noch halber Frequenz des Speichers, ich lasse mich mal überraschen erwarte aber ehrlich gesagt nichts Großes. Aber der Spieltrieb und das Neue machen es auch schon interessant genug für einige.
Edit:
Hier bei so einem Text kann man ja in etwa erahnen was kommt - 1,5V und so scherze.
hi zusammen,
Board und CPU habe ich schon. Muss mich jetzt zwischen diesen beiden Rams entscheiden (oder ihr habt einen Tipp für besseren sofort verfügbaren Ram)
Edir: also von den 16 GB wären es dann halt zwei (also 20€ Teurer)
hi zusammen,
Würde das günstigere nehmen und selber hoch takten. Auf 5200 sollte man schon kommen.
Die Produktseiten zumindest der Mainstream-Modelle sind nun online, bisher aber noch ohne QVL.
Ripjaws S5:
Triden Z5:
Trident Z5 RGB:
Ist doch super nice von Igor hier zu warnen. Diese krueppel ddr5 RAM mit 4800 5200 cl 38 (gnah nicht 18 natuerlich) oder noch schlimmer die jetzt im Umlauf sind werden wohl schlechter performen mit alder lake als mit nem ordentlichen ddr4 kit.
Die 5600 cl16 sind dann schon massiv besser und das wird auch erst der anfang sein.
Diese krueppel ddr5 RAM mit 4800 5200 cl 18 oder noch schlimmer...
Hast du mal versucht die Vorgangsdauer in ns von DDR5-5200 CL18 auszurechnen? Du wärst wahrscheinlich überrascht :fresse:
Hier auch nochmal crosspost vom Alder Lake Thread. Grade bei mir eingetroffen:
0f036626-2dc6-4490-aa8a-eb11ce1e4b76-jpeg.687430
Details:
CMT32GX5M2B5200C36FE
DDR5 5200 36-38-38-74 - 1,25V - VER 3.43.01
Naja halt ein bisschen mehr Marketing für ein paar € extra als Limited Edition. Die normalen Kits sind ja DDR5 5200 38-38-38-84 - 1,25V - 3.43.01 und schaffen die Werte vom Limited ja sehr wahrscheinlich auch. Der Unterschied ist ja wirklich marginal... Lässt sich halt gut verkaufen wenn was limitiert und nummeriert ist :d
Oh man...mit DDR 5 Speicher sieht es ja echt blöd aus aktuell. Hab mir nun zur Überbrückung 2x Crucial 8GB DDR5 Modul CT8G48C40U5 bei Computeruniverse
bestellt. Vorbestellt habe ich bei Alternate 32GB G.Skill RipJaws S5 5200 / CL 38...mitlerweile ist die Bestellung allerdings auf "aktuell nicht Lieferbar" gerutscht, glaube
nicht mehr daran den wie angekündigt am 16.11. geliefert zu bekommen.
Zum Glück wurde Board und CPU schon versendet - denke mal, dass ich die RipJaws erstmal stornieren werde un bis 2022 mit dem 4800er Ram aushalte. Denke
mal nächstes Jahr bekommt man für die 320€ wahrscheinlich auch 32GB 6000er oä. .
Kurze Frage bzgl. Ram allgemein der Timings.
Sehe und lese ja das bei DDR 5 die Timings aktuell nicht so pralle sein sollen.
Wird es denn DDR 5 mit den Timings wie bei DDR 4 geben? Oder wird das irgendwie kompensiert durch die hohe Taktraten?
Eventuell gibts da nen Video auch zu? Wäre interessant wenn mich da jemand etwas aufklären könnte.
Leute ich habe es geahnt aber jetzt ist es amtlich, die Welt wird immer verrückter!
Quelle:
Jo, falls Schutz-Marke werden die Anwälte beim Zoll anrufen... 😝
Würde den RAM aus dem MP gern kaufen aber bin da noch nicht freigeschaltet :(.
Für alle die sie noch nicht entdeckt haben, verlinke ich die Hardwareluxx Tests hier auch noch mal:
Je nach Spiel und Auflösung bringt der Einsatz von DDR5 aber auch in Spielen einen Vorteil – oder auch mal nicht. Man kann an dieser Stelle aber schon sagen, dass kein Spieler Angst vor dem Einsatz von DDR4 haben muss oder auf besonders schnellen Speicher warten sollte, um auf die gleiche Leistung wie mit DDR4 zu kommen.
Als RAM haben wir das Gigabyte-AORUS-DDR5-6200-Kit (GP-ARS32G62D5), bestehend aus 2x 16-GB-DIMMs, verwendet. Die Module haben gleich drei XMPs in der Revision 3.0 integriert, verwendet haben wir das erste Profil mit DDR5-6200 bei CL40-40-40-80 bei 1,35 V. Ohne Komplikationen konnte das Gigabyte Z690 AORUS Master dieses Profil umsetzen. Im manuellen Modus wollten wir dann noch weiter hinaus und gleichzeitig die Latenzen weiter reduzieren. Herausgekommen sind dann lediglich DDR5-6200 mit CL38-38-38-80.
[HWBOT] Neuer Memory Frequency WR: DDR5-8704
Laut Validierung mit G.SKILL "F5-6000U4040A16G".
