[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine Identifikation der ICs mehr möglich.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Speed Bin & Die Revision
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWinfo (ab 7.26) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
@IronAge
Dieses Kingston-Kit. Hätte natürlich (wie wahrscheinlich jeder) lieber die G-Skill Trident. Aber als Übergangslösung genügt mir das dann erstmal, falls die eintreffen.
Habe die Gleichen bei Alternate in der Warteschlange. Mal sehen, was sich nächste Woche tut, hätte nur gern am WE gebastelt :(.
@IronAge
Werde dir denke ich mal gleich ziehen, danke fürs testen 👍
Wobei ich gerade die Benachrichtigung von Alternate für das am 30.10. bestelle Hero board bekommen habe, dass auf 01.12. angekündigt wurde und sich nun auf unbestimmte Zeit verschiebt :grrr:
Mal schauen was zuerst kommt, neue Ladung Ram oder das eigentlich bei Bestellung vorrätige und nun nicht mehr vorhandene board...
Ohje 🙈 Ich hab meins bei Cyberport bestellt, war erst "grün", jetzt in Bearbeitung / nicht vorrätig. Kann damit leben, wenn es bis Dezember dauern sollte - solange es überhaupt kommt. Warte ja sowieso noch auf den neuen Wasserblock von EKWB für die CPU, der wird ja auch frühestens Ende November eintrudeln.
Vorfreude ist die schönste Freude. Gerade in der Weihnachtszeit 😏 Das Glas immer halb voll sehen!
hahhhh! ... was für eine Ironie :ROFLMAO:
Alternate hat mein zweites Dominator-Kit eben losgeschickt :poop:
Hier ist doch kein Marktplatz...
Handelsanfragen entfernt.
Gibt es bei irgendwem Vorort noch DDR5 ram? Gefüllt ist ja alles weg aktuell , gerne mal melden wenn wer was hat, besorgen kann. danke
wollte den auch mit dem 12900k auf dem Apex kombinieren.
@IronAge
:hust:
einfache Übertaktungstabelle DDR5 (erste Version)
http://bit.ly/3bITglw
Hinweis zur Tabelle:
tCL kann auf jeden eingestellt werden, sogar aus dem Intervall 22-66,
tWR ist ein Vielfaches von 6 aus dem Intervall 48-96,
tRTP zur Auswahl 12,14,15,17,18,20,21,23,24,
CCDL-Auswahl aus dem Intervall 8-16,
CCDLWR ist immer 2-mal größer als CCDL, Intervall 16-32.
Hoffe das mit dem RAM wird nicht so ausarten wie bei den Grafikkarten. Wollte nächste Woche Mobo+DDR5+12700K bestellen.
Mal gespannt ob das klappt. Werde nix holen, wenn nicht alles drei sofort verfügbar ist.
Hoffe Crucial kommt mal aus dem Knick, wollte eigentlich BallistiX.
Habe heute auch meine CPU bei Alternate abgeholt und das Apex liegt schon hier aber der RAM fehlt und ich denke nicht, dass er in den nächsten Wochen verfügbar sein wird. Wenn man sich die Listen der Distributoren anschaut, ist dort gähnende Leere :(, ohne jegliche Angaben zu Lieferterminen!
Ich hab auch alles ausser Ram........
12900k, Z690 Hero und Alphacool Eisblock Pro RGB Digital.
Am Montag kommt noch ein Z690 Strix DDR4 von Computer Universe, was ich nicht mehr stornieren konnte.
Heute kam mein Z690 Aorus Pro und der 12700k von MF. Ram habe ich aktuell bei Proshop und NBB bestellt, mal schauen was zuerst ankommt (falls überhaupt :rolleyes2:).
Welches sind eigentlich die aktuell favorisierten Module bei denen man zuschlagen sollte? Dominator?
Sehe den Sinn der Dominator momentan nicht. 100€ Aufpreis nur für RGB? Sind ja auch "nur" 5200er. Wie gesagt, wenn dann nur die Trident Z5 (auf die wartet ja jeder..), ansonsten reicht auch ein normales 5200er Kit für 100 Euro weniger meiner Meinung nach.
Wenn es bei den Dominators nur um RGB geht, dann lohnt sich das natürlich nicht (zumindest nicht bei mir, lege da keinen Wert drauf). Ich hab aktuell auch das Kingston Fury 5200 bzw. 4800er bestellt (was anderes ist eh nirgendwo verfügbar). Sollte für den Anfang reichen und man kann ja nächstes Jahr ggf. nochmals tauschen wenn die schnellen Module da sind. Ist für die Trident schon ein Preis bekannt? Die werden doch bestimmt nicht gerade Schnapper sein.
Ok, wenn ich das so lese, bestell ich den RAM zuerst und wenn der HIER ist den Rest. :cool:
Die Trident Z5 RGB 5600er CL36 sind schon bei Alternate für 360 Euro gelistet, allerdings nicht verfügbar.
Gelistet sind sie dort seit knapp einer Woche schon, da die ganzen franz. Händler eine Lieferzeit von >2Wochen und Proshop bei der Vorbestellung Ende November angegeben hat würde ich mal mit dem Zeitrahmen rechnen. Ob man dann allerdings von 5200er auf 5600er gehen möchte ist eine andere Frage. Samsung ICs hin oder her
Hab mal meine Corsair Dominator First Edition (Micron) ein bissl getestet. Frequenzmäßig ist bei 5400 leider schon Ende bei meinem Kit. Also hab ich die "low latency" Route eingeschlagen:
Wird Zeit dass Samsung DDR5 verfügbar wird, mit den Micron geht echt nicht viel ;-)
Da kann man sich den Aufwand bei den Microns eigentlich auch sparen
Hatte der 8auer in seinem Test-Video auch erwähnt, dass sein Domi-Kit bei 5400 CL36 am Ende ist.
Die Gains sind schon ganz ordentlich gegenüber standard XMP, bis besseres verfügbar ist, ist es das schon Wert denke ich.
Aber an ein gutes DDR4 Kit mit optimierten Subtimings kommt man mit den Micron Modulen auf jeden Fall nicht ran:
mein 2x16 DDR4 Micron kit macht ja schon 5066 lul
das is schon echt schwach
dann muss ich solange ausharren. bleibt cpu und board erstmal in der verpackung
