[Sammelthread] Dell Studio XPS 1340 & Studio XPS 1640
Engadget
In all-too-familiar fashion, Dell's new Studio XPS laptops have snuck onto the company's store with nary a press release to keep them company. The 1340 is obviously the Studio XPS 13 we saw last month, while the 1640 is naturally the 16-inch version of the leather accented system. Both machines are (oddly) hitting at the same $1,199 pricepoint, with Core 2 Duo processors and the typical smorgasbord of options. The base model of the 1340 includes a P8400 processor, Vista Home Premium, a 13.3-inch WXGA LCD, 2 megapixel webcam, 4GB of DDR3 SDRAM, 320GB 7200rpm SATA drive, slot-loading DVD burner and NVIDIA GeForce 9400M G graphics, while the 1640 is similar, but with ATI Mobility RADEON M86XT graphics.
http://www.engadget.com/2009/01/07/dells-studio-xps-1340-and-studio-xps-1640-sneak-onto-the-scene/
via NotebookReview.com
http://forum.notebookreview.com/showthread.php?t=339394&page=65
Studio XPS 1340
http://configure.us.dell.com/dellst...&oc=DYDEGF3&s=dhs&dgc=EM&cid=39422&lid=997565
Deutsche Links:
http://www1.euro.dell.com/content/p...dio-xps-13?c=de&cs=dedhs1&l=de&ref=lthp&s=dhs
Notebookcheck Dell Studio XPS 13 Test
http://www.notebookcheck.com/Test-Dell-Studio-XPS-13-Notebook.14075.0.html
Notebookjournal Dell Studio XPS 13 Test
http://www.notebookjournal.de/tests/notebook-test-dell-studio-xps-13-791
Studio XPS 1640
http://configure.us.dell.com/dellst...&oc=DYDEFF3&s=dhs&dgc=EM&cid=39422&lid=997564
Deutsche Links:
http://www1.euro.dell.com/content/p...aptop-studio-xps-16?c=de&cs=dedhs1&l=de&s=dhs
Notebookreview Studio XPS 16 Test:
http://www.notebookreview.com/default.asp?newsID=4764
Notebookcheck Dell Studio XPS 16 Test
http://www.notebookcheck.com/Test-Dell-Studio-XPS-16-Notebook.14412.0.html
Notebookjournal Studio XPS 16 Test
http://www.notebookjournal.de/tests/test-dell-studio-xps-1640-790
Notebookjournal Studio XPS 16 Lesertest
http://www.notebookjournal.de/tests/test-dell-studio-xps-16-804
Benchmarkwerte des Studio XPS 16
http://www.forumdeluxx.de/forum/showpost.php?p=11340472&postcount=253
Heise: Multimedia-Notebook Dell Studio XPS 16 mit farbkräftigem Display
Test 20.08.2009 http://www.heise.de/mobil/artikel/Dell-Studio-XPS-16-mit-farbkraeftigem-Display-222545.html
Notebookjournal: Studio XPS 16 wird zum heißen Gamer
Test 28.08.2009 http://www.notebookjournal.de/tests/review-dell-studio-xps-16-ati-4670-976/
Notebookcheck: Dell Studio XPS 16 (ATI HD4670)
Test 05/10/09 http://www.notebookcheck.com/Test-Dell-Studio-XPS-16-ATI-HD4670-Notebook.21328.0.html
Heise (26.01.2010): Performanceprobleme bei einigen Dell-Notebooks mit Core i7
http://www.heise.de/newsticker/meld...inigen-Dell-Notebooks-mit-Core-i7-913571.html
PS: Wenn es interessante Testberichte / Usertests oder andere für die Allgemeinheit interessante Informationen gibt, kann ich diese gerne am dieser Stelle einfügen / verlinken.
(Benachrichtigung per PN / ICQ)
Last Update: 02.02.10
super und ich habe mir heute eins bestellt -.-" hab aber von anfang an 3 jahre service mitbestellt und das kostete mich 179€
Ein sehr netter und kompetenter Dell-Techniker war da und hat das Display getauscht. So weit so gut. Jetzt funktioniert die Displaybeleuchtung wie sie soll - leider spinnt nun das WLAN und teilweise auch die Menüleiste. Das WLAN steht neben dem Router und hat 18% empfang, während das andere 1340 100% erreicht. Also irgendwie habe ich mit diesem Modell einfach kein Glück. Ich werde jetzt mal Windows neu installieren und gucken, ob das was bringt :/
saint
Schau doch mal am WLAN-Modul, ob die Antennenkontakte verbunden sind. Wahrscheinlich hat der Techniker beim Wiederanschluss der Kabel geschlampt. Gleiches gilt für die Medialeiste, schau mal ob deren Kabel korrekt verbunden ist.
Müsste alles im Manual zum 1340 beschrieben sein.
Hat einer von Euch schon mal die DPC Latenzen des 1340/1640 getestet?
Am Besten natürlich jemand mit 'nem Pro-Audio USB-Interface und vorzugsweise mit aktivem LAN. :d
Falls nicht, ein entsprechendes Tool kann man unter http://www.thesycon.de/deu/latency_check.shtml finden.
Wäre nett, wenn mir mal jemand den Latenzwert nennen könnte bzw ob es im grünen Bereich bleibt oder Ausschläge gibt.
Also ich habe dem Techniker über die Schultern geguckt und er hatte alles nochmal überprüft. Geschlampt hat er nicht und sollte es dennoch passiert sein, mache ich ihm keinen Vorwurf. Nach seiner Auskunft ist das Gerät nicht gerade Wartungsfreundlich und die Kabelverlegung schien wirklich frickelig zu sein.
Was die Latenzen angeht: das ist ein allseitsbekanntes Problem mit dem Gerät - das hat starke latenzschwankungen mit genau diesem Tool. (mehr dazu bei notebookreview.com)
Auch interessant: die ungerade stehenden Geräte müssen sich teilweise dadurch reparieren lassen, dass die Schrauben in der Bodenplatte nochmal neu festgezogen werden (über Kreuz).
saint
na wie schauts aus...gibts inzwischen auch Leute die mit ihren Xps Studio 13 zufrieden sind?
ich bin zufrieden nach dem anfänglichen Problemen läuft jetzt alles so wie es soll!
Danke für die Info!
Wie schauts mit der Akkulaufzeit aus?
....hab inzwischen recht viele Varianten gelesen...von 1 std. bis 4 std. mit 6 zell.
Ich bin den 1340 glücklicherweise los. Nachdem das 2. Austauschgerät (also der 3. SXPS 1340) einmal durch den Techniker repariert wurde, trat ja ein erneuter Defekt auf. Als der Techniker dann nochmal kam und das Gerät nach dem erneuten Displaytausch garnicht mehr anging, sollte es laut Dell eingeschickt werden und ich mehrere Wochen auf die Reperatur warten. Genau um sowas zu vermeiden hatte ich bei Dell gekauft. Glücklicherweise konnte ich den Kaufvertrag wandeln, da es ja der 3. defekt an diesem Gerät war.
So schön ich das SXPS1340 finde, ich kann davon nur abraten. Was ich mit diesem Modell erlebt habe ist eine Frechheit. Und es handelte sich dabei nicht um ein einzelnes Montagsmodell sondern insg. 3 fehlerhafte Geräte. Ich habe stattdessen ein Sony VAIO VGN-SR41 gekauft und bin davon sehr begeistert.
Hallo
was ist von folgender Konfig. und Preis zu halten
Studio XPS 13
CPU: Intel® Core™ 2 Duo P8700 (2.53GHz,3MB L2 Cache, 1066MHz)
500 FP 7200u/min
4GB
Vista 64bit Home Premium mit Win7 Option
Bluetooth
3 Jahre Premium-Support-Service
Dell Wireless 1515 Mini-Karte, halbe Höhe (802.11n)
Red Leather back cover 13.3" WXGA (1280x800) White-LED Display
inkl. Versand
Das ganze für 1153€
welche CPU? inkl. Versand?
Ich hab meins für ~den selben Preis im März auch gekauft!
Aua, vergessen:-)
inkl. Versand
Wäre dieser eine Alternative zum SXPS13?
http://geizhals.at/deutschland/a445617.html
Einzig das Display müßte man sich vorher anschauen.
Gut ist das es kein Klavierlack hat.
Laut notebookjournal taugt das Display nix.
Mist, das NB hat sogar eine beleuchtete Tastatur.
---------- Beitrag hinzugefügt um 19:18 ---------- Vorheriger Beitrag war um 15:51 ----------
Welche HDD Größe ist im SXPS verbaut?
[/COLOR]Welche HDD Größe ist im SXPS verbaut?
Da kannste doch im Konfigurator verschiedene Größen auswählen und da steht auch der Preis daneben ?
Selber aufrüsten is auf jedenfall preiswerter als da jetzt gleich 500GB einbaun lassen.
Hab mich falsch ausgedrückt.
Ich meine die Zoll Größe.
Für mich nicht.
Hatte mal ein Cebop das gabs auch als MSI.
War schon ein ziemliche Ägerniss das Gerät.
Hab jetzt den ganzen Thread nochmals gelesen.
Wie ist den jetzt tatsächlich die Temperatur des SXPS13?
Kann man es auf dem Beinen ablegen? Oder wird es zu heiß?
Hi!
So jetzt hab ich auch meinen SXPS13 bekommen.
Ich weiss gar nicht was die Leute sich soo sehr darüber beschweren?!?! Verarbeitung ist 1A oder zumind gleich gut wie bei mein XPS1330.
Bei mir wird überhaupt nix zu heiß...
Nachdem mein XPS1330 extrem heiß wurde....kann ich es evt. nicht so gut beurteilen.
Der einzige Nachteil: Akku, 9Zellen - 4 Std
Hi!
Kannst du ein Review schreiben?
Bin eigentlich dabei mir auch ein SXPS13 zu bestellen.
Wie lange hast du gewartet?
Kannst du den genauen Lieferumfang bechreiben?
Hab mir jetzt ein SXPS13 bestellt
Studio XPS 13 : Intel Core 2 Duo P8700(2.53GHz,1066MHz,3MB)
Red Leather 13.3in WXGA (1280x800) White-LED Display
Camera : Integrated Camera with Facial Recognition Software
Memory : 4096MB (2x2048) 1067MHz DDR3 Dual Channel
Festplatte : 500GB Free Fall Sensor (7200 1/min)
Internal DVD+/-RW (DVD & CD read and write) Slot Load Drive including
Graphics : 256MB nVidia 9500m graphics card
Dell Wireless 1515 (802.11n) halbe Minikarte
Europe Dell Bluetooth 370 Card
German McAfee Security Centre 10.0 - 15 Month Subscription
3Yr Premium Warranty Support
Wenn es dann kommt schreibe ich ein Review.
Am 03.11. soll das NB laut UPS bei mir aufschlagen.
Leider hab ich das Gefühl ich bin hier der einzige mit einem SXPS13 :-(
---------- Beitrag hinzugefügt um 14:45 ---------- Vorheriger Beitrag war um 14:35 ----------
Zumindest unterhältst du den Thread alleine.. ;)
Die Verarbeitungsmängel sind angeblich derzeit recht ausgeprägt bei Dell, möglicherweise hat es sich schon rumgesprochen
Wenn der Nachfolger schwerer und wärmer is als der (indirekte) Vorgänger M1330 kaufts eben keiner der auf sowas wert legt.
Na,ja
sollten Verarbeitungsmängel vorhanden sei geht es sofort zurück
Ich würde es gar nicht erst annehmen.
Ein Dell ohne Mangel, ja ist denn schon Weihnachten ;)
Ähnliche Themen
