[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [11]
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
Ich mag das DFi wirklich:
FSb471 mit QuadCore und das bei VNB und VTT auf Minimum.
Bin wirklich gespannt was ich für FSB 500 brauche. Denke da sollten 24/7 taugliche Settings machbar sein.
Hoffentlich kann die CPU dann mithalten.
Edit:
Hab aber grad gesehen das mein PL noch auf 10 steht. Hab ich wohl früher mal so gehabt.
Schauen wieviel die Spannungen hoch müssen wenn ich das auf 8 senke.
Mußt mal CPU´z 2 mal öffnen dann kannst du auch den RAM anzeigen lassen. Für Dich nicht wichtig aber für uns :fresse:
Nächstes mal^^
Ram lief 1:1 also 942MHz. Der war mir aber erstmal egal da ich den FSB testen wollte.
Heute morgen hab ich kurz etwas an FSB 500 probiert, da müssen die Spannungen auf jedenfall deutlich nach oben.
Mit vnb 1,245 und Vtt 1,20 freezt er noch beim Windows booten.
Schauen was GTL und Vref dort bewirken können.
Als ich dann heut nochmal nach dem PL geguckt habe ist mir auch aufgefallen das ich im Fine Delay die Clock Settings alle auf Auto habe.
Dort werd ich ggf. mal Nominal probieren um es fix zu haben.
EDIT:
Ich hab mich jetzt doch erstmal dran gemacht die CPU auf 4Ghz aus zu loten.
Das lief leider erstmal überhaupt nicht, egal welche VCore, habe ich nach wenigen Sekunden Fehler bekommen.
Nun hab ich überlegt und eigentlich dürfte die VTT ja auch Einfluss auf die CPU Stabilität haben, selbst wenn der FSB mit weniger VTT stabil ist.
Oder täusche ich mich?
P.S. Echt schade das der Thread so tot ist. Damals als ich den E8400 getaktet hab waren hier ne Menge Gurus unterwegs^^
Wow, supie! die vtt und vnb ist ja mal hammer für fsb 471! Jetzt noch ramteiler 5:8 (?!) 333:800 mit pl8 und fast/fast und ram skews auf 3/3/1! Wird hauptsächlich mehr vnb brauchen!
Na ja wie auch immer viel erfolg, ich glaube das sind die niedrigsten spannungen für 471, welche ich auf nem dfi gesehen habe, und dabei war ich immer so stolz auf mein brett. Allerdings habe ich meinen ram in vollbestückung mit 1200mhz gefahren!
Hier noch ein wenig impressionen von meiner diva, hab sie selig:
[img=http://www.abload.de/thumb/capture_22042011_110716oqv.jpg]
[img=http://www.abload.de/thumb/capture_02052011_1751517lm.png]
[img=http://www.abload.de/thumb/capture_27062011_09174eu80.jpg]
just for fun max pl7 @ fsb 500:
Ja 471 ist echt super.
Meine Euphorie wurde nun bei FSB 500 leider etwas gedämpft.
Bin nun "schon" bei 1,2575vnb und 1,22vtt gewesen und dennoch wollte es nicht ordentlich booten. Trotz diverser GTL und VRef Settings.
Hab grad etwas die Lust verloren, weil es nicht so wollte wie ich.
Aber wenn ich mir deine Settings so ansehe, auf dem Board was ja auch immer sehr wenig Spannung gebraucht hat, war ich wohl auch einfach zu optimistisch^^
Zumal FSB 500 mit Dual auch bei minimal Spannungen lief^^
1,3 Vnb werden es jetzt mit dem Quad aber wohl werden.
Evtl muss ich am RAM mal rum spielen. Hab seit je her nur 3/3/1 gefahren weil das immer gut funktioniert hat.
Auf meinem UDR3 hatte ich die CPU auch auf 500 MHz FSB, Problem war aber das Board - das war mit 490 FSB echt an der Kotzgrenze, somit alles nicht mehr stabil. Aber wenn Du die NB auch unter H²O hast, dann spricht eigentlich nichts gegen 1,3 - 1,35 VNB oder täusch ich mich da?
Ja die CPU das wird auch noch was^^
Irgendwie bekomm ich die nicht mal mit 1,296V Stabil. Zumindest nachdem ich letztens das letzte BIOS Update gemacht habe.
Mal schauen wo dran es da liegt.
1,35VNB sind von den Temps sicher kein Problem. Nur fühlt es sich echt mies an dann plötzlich so viel mehr Spannung zu brauchen.
Mal schauen wie ich es dann am Ende laufen lassen. 500 ist einfach die schönere Zahl, und der RAM würde dann auch passender laufen.
für fsb 500 sind viele deteils sehr wichtig u.a. die cpu skews! Warte mal, hmmm..... genau: 700/100/100 warens bei mir für fsb 500! gtl`s passen bei den aller, allermeisten boards 67/67/63 mit vref 23. Das lief bei wirklich vielen!
700/100/100 fahre ich ebenfalls schon seit meinem e8400^^
Vref 23 hatte ich bei 471 drin und hat sich bei 500 bisher auch am besten geschlagen.
Bei den GTLs ists immer sehr unterschiedlich bei mit 67 läuft da z.b. fast nie.
Hast Du Vollbestückung?
Nein.
Nur 2x2GB Apogee GT 1066
Ich hab grad mal zum testen 1,35 vnb und 1,30 vtt gegeben. Aber dennoch freezt er sofort bei Prime.
Da glaub ich fast nicht das es an den Spannungen liegt. Sondern an irgendwas anderem...
Hallo möchte einen Bios Update vornehmen, habe den aktuellen runtergeladen und auf einen Stick gepackt nur dies wird vom Bios nicht erkannt.
Kann mir jemand sagen wie ich meinen Stick bootfähig mache?
MfG
Hi Leute, ich habe mal ne Frage.
Ich hab zwar das JR, aber das sollte ja egal sein.
Welche Prime Version nutzt ihr?
Ich habe mit meinem Q9550 nämlich die Erfahrung gemacht, dass die Version 25.11 einwandfrei in jedem Test durchläuft mit meinen Einstellungen und bei den Versionen 27.6 und 27.9 er sich sporadisch beim Small Run (24K) verrechnet (innherhalb von vllt 30 Sek.) und dann manchmal abschmiert.
Wie kann das sein? Ich habe damals den alle Test inkl Custom geschafft und jetzt gibts Fehler? :(
wo bekomme ich die letzten Treiber für das Board her?
Bei DFi scheint alles offline zu sein.
LAN und Audio hab ich mir direkt von Marvell bzw. Realtek geholt.
Aber wie siehts mit Chipsatz aus?
Danke.
Brauche ich auch noch einen extra Sata/RAID/AHCI Treiber von Intel?
Hallo :) ,
bin jetzt auch stolzer Besitzer dieses Boards und bräuchte ein wenig Hilfe beim ocen. Leider habe ich nicht soviel Zeit, mir alle 1034 Seiten hier dazu durchzulesen, obwohl ich schon einiges gegoogelt habe.
Problem:
E8400, der schafft 9 x 530MHz primestable bei zahmen Spannungen, und 6 x 610MHz sind bei entsprechenden Spannungen auch drin. Allerdings auf dem Asus Maximus II Formula.
Auf dem DFI laufen nichtmal 9 x 480 oder 6 x 500, trotz Erhöhung der Spannungen.
Was macht die Boot Up Clock? Was stelle ich da beim ocen ein?
Welches Bios ist empfehlenswert?
Gibt es Mod-Bios-Versionen, die die teilweise groben Abstufungen bei den Spannungen oder die sehr wenigen GTL´s feiner einstellbar machen?
Ich hab mir auch eins wieder im Marktplatz geschossen ^^ Freue mich schon richtig.
Doch nicht etwa das Plus mit der WaKü drauf :) ?
Na jedenfalls haben wir dann bald ein neues Gesprächsthema :d ...
Also Crucial Ballistix Tracer mit Micron D9GMH läuft auf dem Board. Hat auch mit Ach und Krach die 600MHz primestable gemacht bei 5-5-5-18 und 2,2V VDimm. Das Board untervoltet angeblich die VDimm um 0,1V, habe ich jedenfalls gelesen. Könnte stimmen, weil sonst (auf dem Asus z.B.) booten 600MHz RAM-Takt (natürlich mit Teiler gemacht :d ) schon mit 2,05V oder 2,1V.
Die VCore wird auch heftig untervoltet, jedenfalls behaupten das die Sensoren bei Aida64.
Bin gerade an 9 x 470MHz mit dem besten E8400, aber Prime Small stürzt immer nach 15 min ab. Dabei bin ich schon bei +150mV bei der VCore.
Naja wenn du keinen RAM hast, der mehr als DDR2-1000 bringt, mach dir erstmal keine Sorgen. Bis du 500MHz FSB stabil hast, hast du wahrscheinlich 200 Neustarts hinter dir :d . Also genug Zeit, richtig guten RAM zu besorgen :) . Soviele IC´s kommen ja für 600MHz FSB gar nicht infrage, denke ich: entweder Micron D9 oder Elpida ACBG (GSkill Trident und ich glaube auch OCZ LV Blade)...
Ach, mein lieblingsboard! gute jagd jungs!
Danke :d !
Heute liefen die 470 x 9 bei Prime endlich stabil, sowohl bei small als auch bei large. Bei 480 x 9 ist er aber sofort abgeschmiert. Hab jetzt nochmal die VTT um 2 Stufen hochgesetzt und die VRef von 28 auf 26, mal schauen ob jetzt die 480 stabil rennen.
Wenn ich mir den Spannungsbereich ansehe, würde ich mal auf Micron D9 tippen. Weil ich glaube nicht, daß du dir normale DDR2-800er kaufst, wenn du so ein Brett ocen möchtest, oder :d ?
Der Xeon ist nicht schlecht! Das erinnert mich übrigens mal wieder an unser Vorhaben: mit einem Quad 7 x 500 primestable :d .
Übrigens hab ich wahrscheinlich den VID-Bug. In Aida64 zeigt er 1,1V statt 1,225V VID an und ich hab mich schon gewundert, warum er die ganze Zeit um 0,25V untervoltet :) . Kein Wunder daß er bei 470MHz rumgurkt, wenn er da gerade erst bei seiner default Spannung ist :d .
Ich weiß nicht was für Chips der Ram "GX24GB6400C4UDC" von Geil hat, 18,90€ inkl. für 4GB mit guten Timings und 2V müssen gut gehen dachte ich, zur Not hole ich noch was irgendwo vor :d
Hat jemand sonst hier ne Ahnung?
Edit:
http://ramlist.i4memory.com/ddr2/
schaut nicht so gut aus ^^ Naja 533MHZ werden sie machen, aber zu wenig, Micron muss her :d
Andreas, ich teste grad den E8400 vor aufm P5E3 Premium hab jetzt FSB 500 schon stable, sollte noch einiges gehen.
1.CPU gefunden :)
Mal sehen ob gleich noch 600 gehen ^^
