sid schrieb:echt ?
hab vor paar tagen die B revision bei nem freund verbaut ...
da war das nich der fall![]()
firingsquad schrieb:operation, Leadtek�s cooler runs about 5 decibels quieter than NVIDIA�s reference dual-slot cooler design, but unfortunately this comes at a cost: temperature. We noted temperatures 9 degrees higher on the WinFast A400 Ultra TDH card than a reference GeForce 6800 Ultra running at the same 425MHz clock speed. (45 degrees idle for the reference card, versus 54 degrees Celsius for Leadtek, 58 degrees under load for NVIDIA, 67 degrees running the same load with the Leadtek card). Perhaps if Leadtek cranked up the RPMs so that their noise level matched that of the NVIDIA reference card the temperatures would be a little closer.
xbitlabs schrieb:Against the manufacturer’s claims, the new system couldn’t boast an absolute noiselessness. You could always hear the sound of the fan with a mixture of hiss from the air passing through the fine lattice. Fortunately, the noise level was low enough, even with the system case open. Due to some mysterious reason, Leadtek didn’t endow its new product with an ability to control the fan speed depending on the load on the graphics processor. The fan is always rotating at a constant speed. Well, we can hardly call it a drawback since a constant quiet sound is less irritating than the constant transition from silence to roar of NVIDIA’s reference cooling system. Overall, 3 Air-Surround Cooling System boasts an excellent efficiency, but it is only average in terms of noise. It has a long way to go to become a truly silent system.
