Externe SSDs: Welche Modelle eignen sich derzeit am besten für schnelle und mobile Speicherlösungen?
charlesdevis
Hello dear community!
I hope you are all well. I'm currently looking for an external SSD that's good for fast and portable storage solutions . Since technology is constantly evolving, I wanted to ask for your recommendations and experiences.
Which models can you recommend that meet these requirements? Are there any specific brands I should look out for? And have you had personal experiences with certain models that you can share?
I look forward to your advice and experiences! Thanks in advance.
FAQ Prefix entfernt. Was ist eine FAQ?
Das Thema passt außerdem besser in unser Server-Unterforum:
Wenn du hilfreiche Antworten willst, solltest du aber auch konkretere Angaben zu eurem Ist-Zustand, Zukunftsplänen und Bedürfnissen machen.
[closed]
