Festplatte kaputt?
PogoPaul
Hallo Leute,
hab bei meiner zwei Monate alten HDD letztens beim Start von Linux die Info erhalten, das die Platte Fehler enthalte und ich doch bitte eine Sicherung der Daten vornehmen möge. An sich startet die Platte nochso wie sie soll, der Kurztest über "GSmartcontrol" liefert keine Fehler, beim Langzeittest bricht der Test nach 10 % ab. Hier das logfile:
Code:
smartctl 5.43 2012-06-30 r3573 [x86_64-linux-3.5.0-17-generic] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model:     Hitachi HTS547550A9E384
Serial Number:    J1100016C26G6C
LU WWN Device Id: 5 000cca 711c100fc
Firmware Version: JE3OA60A
User Capacity:    500,107,862,016 bytes [500 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 6
Local Time is:    Tue Jun  4 12:53:08 2013 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(   45) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 129) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   068   068   062    Pre-fail  Always       -       5570
  2 Throughput_Performance  0x0005   198   198   040    Pre-fail  Offline      -       138
  3 Spin_Up_Time            0x0007   253   253   033    Pre-fail  Always       -       1
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       640
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   115   115   040    Pre-fail  Offline      -       34
  9 Power_On_Hours          0x0012   098   098   000    Old_age   Always       -       902
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       498
191 G-Sense_Error_Rate      0x000a   095   095   000    Old_age   Always       -       655365
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       66
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       7617
194 Temperature_Celsius     0x0002   176   176   000    Old_age   Always       -       34 (Min/Max 16/46)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       53
197 Current_Pending_Sector  0x0022   088   088   000    Old_age   Always       -       488
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
223 Load_Retry_Count        0x000a   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed: read failure       90%       895         28625144
# 2  Extended offline    Completed: read failure       90%       893         28625144
# 3  Short offline       Completed without error       00%       892         -
# 4  Extended offline    Completed without error       00%        84         -
# 5  Short offline       Completed without error       00%        82         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Soll ich die Festplatte einschicken lassen und eine Garantieforderung rausschicken an den Verkäufer?
Und ist das normal, dass überall old-age und prefailure steht, obwohl ich die Platte gerade erst gekauft habe?
Danke im Voraus!
BEste Grüße,
PogoPaul
