Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]foobar2000 v2.24.1 Final wurde veröffentlicht
Implemented Ogg chapter support. Converter can write multichapter Ogg files after disabling Ogg chaining support.
New major revision of bitcompare code, improved performance of 64-bit build.
Allow local M3U referencing remote M3U to be both read as playlists, prevent HLS reader being used on non-HLS content.
Updated File Operations recycle bin detection logic, mitigating lag/lockup occurring for some users.
Made network encryption error messages more useful.
Stop decoding ADTS AAC when running into APE tags, instead of reporting errors.
Report zero-length WAV files as broken.
Wine compatibility fixes.
2024-02-12:
Improved ReFacets performance.
Fixed erratic behavior if ID3v2 tag contains multiple date fields.
Suppressed advancing to the next playlist item if internet radio playback stops due to a network error.
File Operations: Added an option to overwrite existing files.
Suppressed repeating console messages about decoder shims used.
More thorough error reporting for blank WAV files.
Added video_codec info for Windows Media Video.
Added stream_count info for formats that support multiple streams.
2024-02-19:
Fixed regression preventing internet radio album covers from being shown.
Applied dark mode to component license popup.
Updated zlib to 1.3.1.
2024-02-28:
Playback CPU usage optimizations.
Small chunks returned by decoder are merged into one to reduce amount of wakeup cycles during playback.
Made possible to store peak information in Opus files.
2024-03-04:
Worked around audio glitches with very low output buffer size introduced in previous build.
Fixed glitchy seekbar movement in certain scenarios.
Prevented nonsensical video codec names from being reported for certain MP4 files.
Fixed regressions in ASX playlist loader.
Converter: More detailed error messages for specific file creation errors.
2024-03-08:
Mitigation for Converter failures when writing to Google Drive volume.
Opus decoder updated to 1.5.1
WavPack decoder updated to 5.7.0; made WavPack library version shown in components list.
Monkey's Audio decoder updated to 10.52
Cleaned up and bugfixed detection of MP4 video codec names.
Prevented nonsense sample rate & channel count from being shown on MP4 files with no audio track.
File Operations: Defer info reload to prevent bugged display of cuesheets after moving whole folder.
2024-03-14:
Playback CPU usage reduced.
Fixed exclusive output lagging in specific scenarios.
Add Location now strips extra non-text characters from the entered URL.
Made Ogg chapters beginning from CHAPTER001 recognized.
Allowed absolute paths in cue sheets.
Extended MP4 chapter manipulation commands to work with other formats that support chapterizer interface, such as Ogg or Musepack.
2024-03-18:
Fixed foobar2000 v2.0 regression causing folder watch events to be dropped without triggering full rescan if there's too many of them pending.
2024-03-21:
Made stream selector show long codec names.
Media Library: made track add & remove events triggered in groups, resulting in much faster autoplaylist updates.
2024-03-27:
Create "disable-foocrash" in install folder to kill crash reporting (dump files still get written).
Run with /nocrashinfo to suppress generation of crash reports.
File Operations: Suppressed useless secondary progress bar if renaming files.
2024-03-28:
Fixed 2024-03-21 regression causing unnecessary Media Library disk access.
2024-04-07:
Fixed very old and very rare Album List lock up bug.
Pause / resume playback on system sleep / resume.
Installer script update.
2024-04-10:
ReFacets playlist interaction bug fixes.
ReFacets added "Last Modified" stats column.
Removed system sleep / resume handlers, didn't properly suppress errors with internet radio.
Made disconnected internet radio streams resumed quietly, without showing error popups.
32-bit build: Removed tone generator assembly optimizations, tone:// should produce identical output in all versions now.
Updated to NSIS 3.10.
2024-04-13:
Fixed crash if freedb/gnudb server returns more tracks than asked for (regression since 2.0).
2024-04-15:
Fixed stuck drag&drop scrolling mode in various list controls after receiving external drag&drop.
Made list control obey system drag threshold values, making it easier to register clicks if mouse moves slightly between mouse down and mouse up events.
Opus decoder updated to 1.5.2.
2024-04-26:
Cleaned up interaction with what's left of freedb.
- Made more apparent which freedb-compatible service is in use.
- If there are multiple providers configured, you can specifically choose one from CD Ripper dialog.
- Discarded malformed server replies.
Fixed WASAPI Exclusive timing glitches with exotic settings.
Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
Fixed regression in File Operations recycle bin detection, causing unwanted delete prompts when recycling.
2024-04-27:
Fixed WASAPI exclusive regression from last build.
2024-05-01:
Removed gnudb from default online tagger settings, as gnudb now demands users to input their actual email addresses.
If you wish to use gnudb, you can configure it manually, but we strongly recommend against it.
Online tagger now defaults to freedb.dbpoweramp.com which works once again.
Changed storage of freedb server list settings, to a text file in profile folder.
Added toggle to disable tooltips in Album List.
2024-05-13:
Prevented all MP4 tag fields prefixed with replaygain_ from being treated as technical information, only actual ReplayGain fields are now such.
Workaround for ReplayGain scanner attempting to scan Audio CD in multiple threads.
Removed arbitrary denial of reading of cuesheets over FTP/HTTP/etc.
2024-05-17:
ReFacets & Album List: Improved processing of %<field>% expressions, artist and artist sort should be split together properly.
Added tweak options for ReplayGain thread counts.
Made Properties ReplayGain scan not try to scan Audio CD in multiple threads.
Removed arbitrary limit of items per "apply gain to file content" pass.
2024-05-23:
Reverted to VS2019 compiler, unintended AVX requirement has been removed.
Made fact chunk in PCM WAV files ignored.
Updated VS runtime DLLs to the latest version.
2024-05-31:
Improved compatibility with multi-value MP4/M4A tags.
Fixed 2024-05-17 regression causing bad substitution of | character in Album List / ReFacets.
Fixed JXL/AVIF/HEIC external album covers not being recognized, even if relevant system image codecs are present.
2024-06-17:
Fixed nonsensical messages in Converter log when copying non audio files over.
Updated MP4 tmpo tag manipulation, restored ability to write which was lost a few years ago.
2024-06-20:
Mitigated poor performance of "Visualize with VST" and equivalent features since CPU usage optimizations in previous beta builds.
2024-06-24:
No longer drops DLLs for other CPU architectures than the running one when installing components.
Internal changes to deal with wildcard characters in filenames on filesystems other than standard Windows one. Windows version should not be affected by this.
2024-06-30:
Added %channel_mask% title formatting field, on top of on $info(WAVEFORMATEXTENSIBLE_CHANNEL_MASK).
Utilized proper hashmap for metadb_display_field_provider lookup, should speed title formatting up somewhat on heavy configs.
2024-07-06:
Fixed title formatting regression from build 2024-06-30, causing some fields to disappear.
Amended AccurateRip log formatting, added track number info to lines where it was missing before.
Made https:// used for help.foobar2000.org links.
2024-07-07:
Amended title formatting regression fix.
2024-08-08:
Fixed different builds using different rounding for float >> integer audio conversion, mainly affecting 24-bit output (least significant bit differences only).
MP4/M4A/M4B: Prefer QT chapters over chpl if more than 255 chapters found.
MP4/M4A/M4B: Fixed very rare tag update failures if exceeding 4GB boundary. Note that previous versions would just leave the file untouched and report an error if running into this scenario, never corrupt files.
2024-08-14:
Complex mitigation for corrupted config.sqlite - fresh config.sqlite is created, all readable content is transferred over.
Made refuse to retag MP4/M4A/M4B files with QT chapters if chapter count exceeds 255, to prevent erratic behavior. Please remux such files to another container to allow tagging.
Made WMA tag writing behave less erratically if fed tags read by FFmpeg decoder wrapper.
Improved performance of float>>int24 audio conversion.
2024-08-22:
Further mitigation for issues caused by corrupted configuration files.
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
Fixed bugs with urlencoding in HTTP redirects.
2024-08-29:
Internal changes (C++ noexcept specifier) to improve usefulness of crash reports.
Refactored Matroska chapter handling. If a multichapter Matroska file is played as a whole (from remote URL etc), chapter names will be shown as dynamic track titles.
Fixed a bug causing dynamic track titles (internet radio etc) to be possibly discarded.
hätte mal ne Frage:
kann man in der Android Version vom aktuell abgespielten Lied in die dementsprechende Stelle in der Wiedergabeliste springen?
ich vermisse diese Funktion irgendwie...
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
2024-08-29:
2024-08-31:
Fixed selection tracking regression from 2024-08-29.
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
2024-08-29:
2024-08-31:
2024-09-02:
Mitigation for extreme column width causing CListControl (Playlist, Verifier, possibly others) to go off the rails.
Fixed false MD5 verification errors on exotic bit depth FLAC files.
2024-02-12:
2024-02-19:
2024-02-28:
2024-03-04:
2024-03-08:
2024-03-14:
2024-03-18:
2024-03-21:
2024-03-27:
2024-03-28:
2024-04-07:
2024-04-10:
2024-04-13:
2024-04-15:
2024-04-26:
2024-04-27:
2024-05-01:
2024-05-13:
2024-05-17:
2024-05-23:
2024-05-31:
2024-06-17:
2024-06-20:
2024-06-24:
2024-06-30:
2024-07-06:
2024-07-07:
2024-08-08:
2024-08-14:
2024-08-22:
2024-08-29:
2024-08-31:
2024-09-02:
2024-09-11:
Fixed opening of webm audio renamed to .opus being very slow to open.
Fixed more odd behaviors of tag editing on MP4/M4A with QT chapters.
foobar2000 1.6.2 Final für iOS wurde veröffentlicht.
Changelog v1.6.2:
Restored ability to manually input UPnP media server URLs.
When turning console logging on, current backlog is now saved.
If internet radio stream is stuck at 0:00, clicking same radio station again restarts it rather than doing nothing.
Fixed skinned playback view showing nonsensical remaining time for internet radio streams.
Made Media Servers page automatically search local network for SMB and FTP servers.
Updated invalid filename character criteria; uploading unsupported filenames via FTP should fail more gracefully; allowed question marks in file names.
Fixed Matroska embedded cover display.
Reverted 1.6 "share on server" naming of shares in Media Library, to show network protocol (SMB or FTP or other) used.
Moved console logs location, no longer creates "Console Logs" in music folder.
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
New version numbering scheme: 2.24 for planned stable release year of 2024. Stable release will follow soon.
Attempted workaround for rapidly restarting playback locking up D2D visualizations on some systems.
Internet Radio search & list: clicking a stream that is already playing no longer restarts playback.
Fixes for plain WAV files over 4GB in size. Note that WAV file format does not actually support content longer than 4GB.
Made current console backlog saved when toggling logging on.
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
Updated RAR extraction code to the latest official code release.
Fixed hardware-accelerated visualization crash on settings change.
2024-10-04:
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
Fixed specific cases of corrupted configuration data causing foobar2000 to crash.
Fixed inconsistent drag&drop behavior when dragging items between playlists.
2024-10-11:
2024-10-04:
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
Fixed Internet Radio search not working through a proxy server.
SQLite updated to 3.46.1.
Fixed Ogg VBR bitrate display regression.
2024-10-18:
2024-10-11:
2024-10-04:
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
Fixed a bug causing foo_upnp internet streams to be treated as radio and unintentionally looped.
2024-10-28:
2024-10-18:
2024-10-11:
2024-10-04:
2024-09-11:
2024-09-02:
2024-08-31:
2024-08-29:
2024-08-22:
2024-08-14:
2024-08-08:
2024-07-07:
2024-07-06:
2024-06-30:
2024-06-24:
2024-06-20:
2024-06-17:
2024-05-31:
2024-05-23:
2024-05-17:
2024-05-13:
2024-05-01:
2024-04-27:
2024-04-26:
2024-04-15:
2024-04-13:
2024-04-10:
2024-04-07:
2024-03-28:
2024-03-27:
2024-03-21:
2024-03-18:
2024-03-14:
2024-03-08:
2024-03-04:
2024-02-28:
2024-02-19:
2024-02-12:
2024-02-05:
foobar2000 v2.24 has been released, for Windows and Mac OS.
This release changes the version numbering scheme, minor number for the intended release year.
While Windows version is mostly a maintenance/bugfix update, Mac version implements lots of previously-missing functionality, such as user interface layout customization.
Windows: Download | Release Notes
Mac: Download | Release Notes
Internet radio bug fixes & reliability improvements.
Codec & audio format fixes, most notably:
- Implemented Ogg chapter support.
- MP4/M4A/M4B tagging & chapter manipulation fixes.
- WAV compatibility fixes; made zero-length WAV files reported as broken.
- Cuesheet compatibility improvements - allowed absolute path, allowed playback over network.
Usability improvements, most notably:
- Fixed inconsistent drag&drop behavior when dragging items between playlists.
- Made current console backlog saved when toggling logging on.
- Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
General improvements, most notably:
- New major revision of bitcompare code, improved performance of 64-bit build.
- Improved stability of hardware-accelerated visualizations.
- Improved recovery of corrupted configuration data.
Converter
- Mitigation for Converter failures when writing to a Google Drive volume.
- More detailed error messages for specific file creation errors.
- Can write multichapter Ogg files after disabling Ogg chaining support.
File Operations
- Suppressed useless secondary progress bar if renaming files.
- Defer info reload to prevent bugged display of cuesheets after moving whole folder.
- Added an option to overwrite existing files.
- Updated recycle bin detection logic, mitigating lag/lockup occurring for some users.
Third party code libraries updated.
Various other tweaks & fixes, see release notes for full list of changes.
foobar2000 for Mac 2.24 Final wurde veröffentlicht.
Changelog v2.24:
Lowest supported Mac OS version is now Mac OS 11 "Big Sur".
Entirely new Mac user interface, allowing various panels to be embededd in main foobar2000 window.
Lots of appearance & usability improvements, reworked various windows to look more consistently with modern Mac OS.
- Added update checks - checks for last public beta/stable build, same as Windows version.
- Added menu commands to configure Audio Units without going through Preferences.
- Utilized monospace digit font in for most of user interface.
- Implemented meta autocomplete in Properties dialog.
- Implemented Advanced Preferences search.
- Made possible to keep running after closing main window.
- Made File menu dynamic-generated properly, made various previously-hidden commands accessible, including "Reset Configuration", "Browse Configuration Folder", etc.
- Cleaned up title capitalization in menu commands.
- Implemented Cmd+F search in Playlist.
- Fixed whole lot of bugs related to wildcard characters (*, ?) in file names.
File Operations
