G.Skill 2GBHZ-OC-Ergebnisse ***Sammelthread***
Snoopy69
Urgestein
In diesem Sammelthread sollten nur G.Skill PC2-6400U CL4-4-4-12 F2-6400PHU2-2GBHZ behandelt werden.
Bitte nur in dieser Form angeben - zb...
0606 l 565MHz l 2,4V l 4-4-4-4 l ASUS P5W-DH l 701 l Luft l //mAr
So, auf geht´s - ich will was sehen... :)
Serial l Takt l Volt l Timings l Board l BIOS l Kühlung l User
0606 l 615MHz l 2,53v l 4-4-4-8 l Asus P5B Deluxe l 507 | Luft l Chrisch
0632 l 601MHz l 2.5V l 5-5-5-12 l ASUS M2N32-SLI Deluxe Wifi l 0406 l Luft l twoPhases
0606 l 570MHz l 2,2V l 4-4-4-12 l Intel Bad Axe 304 l 1304 l Luft l Sven Bode
0605 l 550MHz l 2,4V l 4-4-4-12 l ASUS P5W-DH l 701 l Luft l freestylercs
0643 l 550MHz l 2,31 l 5-5-5-15 l Epox MF4-J l 6823 l Luft l IVI
0605 l 547MHz l 2,3V l 4-4-4-4 l ASUS P5W-DH l 701 l Luft l jowi69
0628 l 542MHz l 2,2v l 5-5-5-15 l MSI K9A Platinum Xpress 3200 l 1.2B1 | Luft l Feichti
0632 l 530MHz l 2,4V l 4-4-4-12 l Intel Bad Axe 304 l 1334 l Luft l joe_cool
0628 l 525MHz l 2,4V l 4-4-4-12 l ASUS P5W-DH l 0903 l Luft l Gollum
0631 l 525MHz l 2,4V l 4-4-3-4 l ASUS P5W-DH l 1402 l LUFT l o.gh0st
0605 l 510MHz l 2,2V l 4-4-4-4-2 l ASUS P5WDH l 901 l Wasser l Hugo
0628 l 500MHz l 2,1V l 4-4-4-8 l ASUS P5W-DH l 701 l Luft l Dr. Wakeman
0606 l 500MHz l 2,1V l 4-4-4-9 l ASUS P5WD2-P l 606 l Luft l Dir Diggler
0631 l 500MHz l 2,2V l 4-4-4-12 l Intel Bad Axe rev 305 l 1334 l Luft l Nox997
0624 l 500MHz l 2,2V l 4-4-4-12 l ASUS P5W-DH l 701 l Luft l h-h-e
0628 l 500MHz l 2,25V l 4-4-4-4 l ASUS P5W-DH l 701 l Luft l Snoopy69
0606 l 467MHz l 2,1V l 4-4-4-12 l ASUS M2N SLI Deluxe nForce 570 l Luft l Riverna
0628 l 467MHz l 2,05V l 4-4-4-8 l ASUS M2N SLI Deluxe nForce 570 l Luft l Riverna
0633 l 463MHz l 2,3V l 4-4-4-12 l ASUS P5W-DH l 1405 l Luft l 3dfx
0626 l 416MHz l 2,1V l 4-4-4-12 l ASUS P5W-DH l 1407 l Luft l SKiLL3D
0626 l 415MHz l 2,1V l 4-4-4-12 l ASUS P5W-DH l 1101 l Luft l Kame
0628 l 400MHz l 2,4V l 3-3-3-8 l ASUS P5W-DH l 701 l Luft l h-h-e
0629 l 386MHz l 2,1V l 4-4-4-12 l ASUS P5W-DH l 1407 l Luft l Majin
0605 l 380MHz l 2,2V l 3-3-3-12 l ASUS P5W-DH l 604 l Luft l t-bone
-Seriennummer - kp 0606er jedenfalls
-max. Ramtakt - 565MHz
-Timings - 4-4-4-4 HP3 on
-VDimm - 2,4V
-MB - ASUS P5W-DH
-Bios-Version - 701
-Kühlung - System Wassergekühlt und Rams mit 80er Lüfter mit 2000RPM
-CPU Conroe X6800 Stepping4
würde sagen das ist wirklich das Maximum, mehr geht auf keinen Fall, jedenfalls net mit den Timings... Durchsatz war bei knapp 11k in Everest (Read)
Danke an Herrn Franke von www.mips-computer.de mit dem ich das getestet hab ;)
Sowie an www.sirius-computer.de die mir den Speicher gespendet haben ;)
-Seriennummer - 0605...
-max. Ramtakt - 380MHz
-Timings - 3-3-3-12
-VDimm - 2,2V
-MB - ASUS P5W-DH
-Bios-Version - 604
-Kühlung - Luft/80mm Lüfter auf Ram blasend
-CPU - Celeron D 336
Sicher nicht das maximum. Warte noch auf den Conroe
h-h-e schrieb:
@Snoopy69: Screens evtl. einfügen :confused: Ich teste mal am WE ...
@//mar: alter Absahner :fresse:
Könnte man machen - bläst aber den Thread auch irgendwie auf.
Ausserdem sind Screens nicht unbedingt ein Beweis der Ergebnisse.
Ich vertraue auf die Ehrlichkeit der einzelnen User. Wer faked, verar...t nicht nur andere - auch sich selbst ;)
Wenn ihr aber Screens posten wollt - ok...
Joh - ok...
Hab übrigens noch viele Stunden Ram-Benches vor mir...
Wieder BTT? ;)
hi,
hier mal mein ram,hab noch nicht voll ausgelotet wollte erstmal die 1000mhz stable.
Seriennummer - 0606
-Ramtakt - 500MHz primestable/ max immo ca. 530MHz benchstable
-Timings - 4-4-4-9
-VDimm - 2,1V
-MB - ASUS P5WD2-P
-Bios-Version - 606
-Kühlung - speicherkühlung 120er lüfter
Hi
hier mal mein maximum mit 1,9V@4-4-4-4
Seriennummer - 0605
-Ramtakt - 456MHz primestable
-Timings - 4-4-4-4
-VDimm - 1,9V
-MB - ASUS P5WDh
-Bios-Version - 0701
-Kühlung - Speicherkühlung: Lüfter
Im moment laufen gerade 546MHz@2,3V@4-4-4-4
jowi
Edit:
und hier noch die versprochenen 547MHz:
jowi
hmhm irgendwie krieg ich den ram nicht höher ;) beim a64 wars einfacher.
will die jetztige cpu nicht weiter quälen ;)
hab auch nen richtig miesen durchsatz laut everest...
Ich hatten einen 120er Lüfter @ 5V davor und habe keine fühlbare Erwärmung bemerkt, und das bei 2,3V VDimm.
jowi
meine werden recht heiß obwohl ich nen Lüfter davor hab, kann aber auch an der Zimmertemp (30 Grad) oder anderen liegen
Im Tiel steht ja 2GBHZ ich hab auch 2 GBHZ hier ;) aber die 1000er werde die woche mal das absolute Max ausloten
Hi
-Seriennummer - kp 0605er
-max. Ramtakt - 445MHz
-Timings - 4-3-4-4-2 HP3 on
-VDimm - 1,8V
-MB - ASUS P5W-DH
-Bios-Version - 701
-Kühlung - System Wassergekühlt (CPU,NB,SB,RAM,SpaWa)
-CPU P4 820D 2,8@3,74GHz
Gruß Hugo
0605 l 547MHz l 2,3V l 4-4-4-4 l ASUS P5WDH l 701 l Luft l jowi69
Pic ist ja im oberen Post, mit 5-5-5-15 und 2,4V sind zwar noch 552MHz stabil, das scheint dann aber doch das Maximum zu sein.
jowi
Alles Prime- und Memtest-stabil. Ein Kit das 3-3-3-8 bei 400MHZ läuft ist doch gar nicht so einfach zu finden :fresse: ; genau wie max. 2,2V bei 500MHZ für 4-4-4-12.
meine 1000er machen 3-3-3-8 400 bei 2,1 Volt ... gehen aber nach oben nicht so gut, wie einige 800er hier
Ich sehe du hast grad TeamGroups auf Lager. Kannst du die mal mit den 2GHZ vergleichen?
Er meint wahrscheinlich, wie weit die mit dem Takt kommen.
@HHE
Schickst Du die getesteten auch an Deine Kunden oder bekommen die neue Ware?
Die Pretested muss er ja wohl vorher getestet haben. Sonst kann er doch nicth fuer die Taktfrequenzen garantieren.
Das ist das Problem, weshalb ich nachgefragt habe.
Und wo genau ist da dein Problem? Ist doch kein Problem wenn er die tested, und dann an die Kunden verkaufen. Wie soll er denn sonst fuer die Taktfrequenzen garantieren?
