[Sammelthread] Gigabyte (GA-) G1.Sniper 3 / G1.Sniper M3 (Z77)
Willkommen im Sammelthread zu den
Gigabyte G1.Sniper 3
Layout:
Weitere Bilder:
Spezifikationen:
CPU
  • Support for Intel[SUP]®[/SUP] Core™ i7 processors/Intel[SUP]®[/SUP] Core™ i5 processors/ Intel[SUP]®[/SUP] Core™ i3 processors/Intel[SUP]®[/SUP] Pentium[SUP]®[/SUP] processors/Intel[SUP]®[/SUP] Celeron[SUP]®[/SUP] processors in the LGA1155 package
  • L3 cache varies with CPU
(Some Intel[SUP]®[/SUP] Core™ processors require a graphic card, please refer "CPU support List" for more information.)
Chipset
  • Intel[SUP]®[/SUP] Z77 Express Chipset
Memory
  • 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
  • * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
  • Dual channel memory architecture
  • Support for DDR3 2800(OC)/1600/1333/1066 MHz memory modules
  • Support for non-ECC memory modules
  • Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
  • 1 x D-Sub port
  • 1 x DVI-D port, supporting a maximum resolution of 1920x1200
  • * The DVI-D port does not support D-Sub connection by adapter.
  • 1 x HDMI port, supporting a maximum resolution of 1920x1200
  • 1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
  • Creative CA0132 chip
  • Support for Sound Blaster Recon3Di
  • High Definition Audio
  • 2/5.1-channel
  • Support for S/PDIF Out
LAN
  • 1 x Qualcomm Atheros Killer E2200 LAN chip (10/100/1000 Mbit) (LAN1)
  • 1 x Intel GbE LAN phy (10/100/1000 Mbit) (LAN2)
  • * Teaming is not supported.
Wireless Communication module
  • Wi-Fi 802.11 a/b/g/n, Supports 2.4/5 GHz Dual-Band
  • Bluetooth 4.0, 3.0+HS, 2.1+EDR
Expansion Slots
  • 2 x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2)
  • * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIEX16_1 and PCIEX16_2 slots.
  • 2 x PCI Express x16 slots, running at x8 (PCIEX8_1, PCIEX8_2)
  • * The PCIEX8_1 slot shares bandwidth with the PCIEX16_1 slot and the PCIEX8_2 slot with PCIEX16_2. The PCIEX16_1/PCIEX16_2 slot will operate at up to x8 mode when the PCIEX8_1/PCIEX8_2 is populated.
  • (The PCI Express x16 slots conform to PCI Express 3.0 standard.)
  • * PCIE Gen.3 is dependent on CPU and expansion card compatibility.
  • 2 x PCI Express x1 slots
  • (The PCI Express x1 slots conform to PCI Express 2.0 standard.)
  • 1 x PCI slot
Multi-Graphics Technology
  • Support for 4-Way/3-Way/2-Way AMD CrossFireX™/NVIDIA SLI technology™
Storage Interface
Chipset:
  • 2 x SATA 6Gb/s connectors (SATA3 0/1) supporting up to 2 SATA 6Gb/s devices
  • 4 x SATA 3Gb/s connectors (SATA2 2/3/4/5) supporting up to 4 SATA 3Gb/s devices
  • 1 x mSATA connector
  • * The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
  • Support for RAID 0, RAID 1, RAID 5, and RAID 10
  • * When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
2 x Marvell 88SE9172 chips:
  • 4 x SATA 6Gb/s connectors (GSATA3 6/7/8/9) supporting up to 4 SATA 6Gb/s devices
  • Support for RAID 0 and RAID 1
USB
Chipset:
  • Up to 2 USB 3.0/2.0 ports on the back panel
  • Up to 4 USB 2.0/1.1 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs:
  • Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
IEEE 1394
VIA VT6308 chip:
  • Up to 2 IEEE 1394a ports (available through the internal IEEE 1394a headers)
Internal I/O Connectors
  • 1 x 24-pin ATX main power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x PCIe power connector
  • 6 x SATA 6Gb/s connectors
  • 1 x CPU fan header
  • 4 x system fan headers
  • 1 x front panel header
  • 1 x front panel audio header
  • 2 x USB 2.0/1.1 headers
  • 2 x USB 3.0/2.0 headers
  • 2 x IEEE 1394a headers
  • 1 x Clear CMOS jumper
  • 1 x power button
  • 1 x Clear CMOS button
  • 1 x reset button
  • Voltage measurement points
  • 1 x BIOS switch
  • 1 x Trusted Platform Module (TPM) header
Back Panel Connectors
  • 1 x PS/2 keyboard/mouse port
  • 6 x USB 3.0/2.0 ports
  • 1 x D-Sub port
  • 1 x DVI-D port
  • 1 x HDMI port
  • 1 x DisplayPort
  • 2 x RJ-45 ports
  • 1 x optical S/PDIF Out connector
  • 5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Line In/Mic In, Line Out, Headphone)
I/O Controller
  • iTE I/O Controller Chip
H/W Monitoring
  • System voltage detection
  • CPU/System temperature detection
  • CPU/System fan speed detection
  • CPU overheating warning
  • CPU/System fan fail warning
  • CPU/System fan speed control
  • * Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
  • 2 x 64 Mbit flash
  • Use of licensed AMI EFI BIOS
  • Support for DualBIOS™
  • PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
  • Support for @BIOS
  • Support for Q-Flash
  • Support for Xpress Install
  • Support for Xpress Recovery2
  • Support for EasyTune
  • * Available functions in EasyTune may differ by motherboard model.
  • Support for eXtreme Hard Drive (X.H.D)
  • Support for Auto Green
  • Support for ON/OFF Charge
  • Support for Q-Share
  • Support for 3D Power
  • Support for EZ Setup
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller/ Downloads (Bios, Treiber etc.)
Gigabyte G1.Sniper M3
Layout:
Weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
  • 1 x D-Sub port
Audio
  • 2/5.1-channel
LAN
  • Intel GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
  • 1 x PCI Express x16 slot, running at x16 (PCIEX16)
  • * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  • 1 x PCI Express x16 slot, running at x8 (PCIEX8)
  • (The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
  • * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  • 1 x PCI Express x16 slot, running at x4 (PCIEX4)
  • 1 x PCI Express x1 slot
  • (PCIEX4/PCIEX1 slots conform to PCI Express 2.0 standard.)
  • Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
Storage Interface
Chipset:
  • 3 x SATA 3Gb/s connectors (SATA2 2~4) supporting up to 3 SATA 3Gb/s devices
  • 1 x eSATA 3Gb/s connector on the back panel supporting up to 1 SATA 3Gb/s device
USB
Chipset:
  • Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
  • Up to 10 USB 2.0/1.1 ports (4 ports on the back panel, 6 ports available through the internal USB headers)
  • 1 x 4-pin ATX 12V power connector
  • 3 x System fan headers
  • 1 x USB 3.0/2.0 header
  • 3 x USB 2.0/1.1 headers
  • 1 x D-Sub port
  • 1 x DVI-D port
  • 1 x HDMI port
  • 1 x DisplayPort
  • 2 x USB 3.0/2.0 ports
  • 4 x USB 2.0/1.1 ports
  • 1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
  • 2 x 64 Mbit flash
Unique Features
  • Support for @BIOS
Links:
- Preisvergleich
Kompatibilität Arbeitsspeicher:
Speicherliste:
kompatibel:
- 2*2GB
- 2*4GB
- 4*4GB
- 2*8GB
inkompatibel:
Speicherliste:
kompatibel:
- 2*2GB
G.SKill Ripjaws 4GB Kit DDR3 PC3-10666 CL7 (F3-10666CL7D-4GBRH)-
- 2*4GB
G.SKill Ripjaws 8GB Kit DDR3 PC3-10666 CL7 (F3-10666CL7D-8GBRH)
- 4*4GB
- 2*8GB
inkompatibel:
Kompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
Liste mit passenden Wasserkühler:
Reviews / Unboxing:
Werde deinen Thread gleich in den beiden Übersichten verlinken. Mal sehen wie viele Besitzer sich hier noch herum treiben :wink:
Danke Dir :wink:
Werden vermutlich nicht sehr viele sein, die Boards sind doch recht speziell.
aber warten wirs ab ;)
Übernehme ich so, wenn Du nichts dagegen hast?
Hau rein. Ich hatte sie ja einzeln schon in der Übersicht gepostet.
Ich bin wohl echt alleine mit einem der Bretter. :fresse:
Ich habe gerade folgendes Problem...
Versuche gerade Memtest von einem USB STick zu starten, was aber leider nicht wirklich funktioniert.
Die Oberfläche von Memtest erscheint immer nur für den Bruchteil einer Sekunde und danach bootet das System neu.
Der USB Stick startet allerdings an einem anderen System ohne Probleme, denke daher das es eine Bioseinstellung sein muss.
Evtl. hat ja jemand einen Tipp für mich, das der Stick auch mit dem Sniper startet.
nööö-biste nicht,hab auch eins seit erscheinen ;) und bin recht zufrieden.
super find ich den PCI->Slot und die 2 PCIex16 .
obwohl man munkelt das die performance durch den zusatzchip leidet und dann genausoschnell ist wie 1x16 und 1x8 im crossfire......
hat jemand schon das BETA Bios getestet??
Ansich bin ich mit dem µATX auch sehr zufrieden.
Wenn da nicht dies Probleme mit dem Sound wären. :wall:
soundprobleme?? welcher natur??
hi
kenn ich ;)- ich benutze die onboard nur fürs headset-da isses schon 2x vorgekommen mit den gleichen symptomen.
als hauptsound benutze ich PCI creative X-FI Fatal1ty-da is alles 100%
Ok, dann hoffe ich doch, das es dazu bald ein Treiber Update gibt.
Gibt ja bisher nur einen und alternativ direkt von Creative gibt es auch nichts.
konnte das auch nicht zuordnen-jetzt weiß ich ja das es der onboard-sound is.
wenigstens mal was ............
Was mir heute noch aufgefallen ist, das ich den Post Screen nicht komplett sehe.
Es erscheint lediglich das American Megatrends Logo, andere Infos werden mir nicht angezeigt.
Normal sieht es ja folgendermaßen oder ähnlich aus...
Ich kann wie gesagt nur das Logo sehen, aber den rest nicht.
hm-hast recht,muß mal selbst ins bios schaun wie man das einstellt oder obs ein bug is..
Laut Gigabyte Supporttelefon ist das normal.
Wegen meines Soundproblems konnte man mir aber auch da nicht weiterhelfen.
Board geht Montag in die RMA.
... dann berichte mal, wie sich die Austauschplatine verhaelt und ob die evtl. mit einer anderen Revisionsnummer daherkommt.
Mach ich, laut Support in 2-3 Wochen :wink:
hmm-RMA wg. dem sound-sollte ich mir vieleicht auch überlegen,aber 2-3wochen ohne board-booaaah :(
Ich habe zum Glück noch ein paar Boards hier, von daher wirds nicht so wild.
ist natürlich nicht schlecht son vorrat-aber das dann noch mit der Wakü-- wasne arbeit,voll der nachteil bei wasser.
ich denk ich wart mal ab was dein neues so macht ;)
:wink:
gibt's bei dem M3 Board eigentlich auch ein Multi-Bug ? Versuch grad jemand zu helfen der meint das egal welchen Multi er einstellt nicht übernommen wird nach CPU-Wechsel.
Kenn das vom M5G wo ich habe.
Auf die Gefahr hin, die Frage gruendlich misszuverstehen - Nein, nicht dass ich wuesste; mein i7 laeuft mit einem Multi von 45 tadellos.
Ja wird auch nicht an der CPU liegen, aber beim Asus Gene V und glaub auch paar anderen Boards gibt's manchmal nen Multi-Bug wobei er den eingestellen Multi nicht mehr übernimmt und es erst nach einem reset wieder funzt.
... den fuehrt das Motherboard bei mir nach Aenderungen am Multi oder Speichertakt ohnehin durch.
... ups. Nein, den brauchte ich noch nie. Ausser wenn ich´s mit dem OC zu bunt getrieben hatte ;) ...
