[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
ich würde gerne zu einem Testzweck ein modifiziertes D3h aus mein UD3h (beides z77x) aufspielen.. Will nur wissen ob die vom Bios her gleich sind?
Schöne Grüße
hmm, komme nicht so zurecht mit dem GA-Z77X-UD3H, USB 3.0 Probleme, wenn da ein USB Stick angeschlossen ist oder mein Tablet, dauert das hochfahren des Rechners immens lange oder er startet plötzlich aus dem Energiesparmodus von ganz alleine....USB-Treiber von Intel wie auch VIA sind die neuesten....
Ich hatte mit meinem alten Asrock Board P67 immer ein Lämpchen am Tower das blinkte wenn der Rechner im Energiesparmodus war...jetzt mit dem UD3H blinkt nichts mehr und so weiß man nie ob der Rechner ganz ausgeschaltet ist oder im Standby....
Beim Übertakten ist mir in letzter Zeit aufgefallen, dass das BIOS meines Z77X-UD3H öfter mal anfängt zu spinnen. Also entweder werden plötzlich die Einstellungen nicht mehr angenommen oder der Rechner fährt gar nicht mehr hoch. Setze ich dann das BIOS per CMOS Reset Schalter auf dem Mainboard zurück und boote neu kann ich wieder das BIOS aufrufen, aber es spricht nur noch englisch und auch wenn ich im Menü auf "Deutsch" stelle bleibt es englisch. Es ist dann praktisch in einem instabilen Zustand (oder halb zerschossen) und nur ein erneutes Flashen behebt das. Also habe ich das experimentieren vorerst sein gelassen, weil es nervt ständig neu flashen zu müssen.
Jetzt ist mir aber etwas merkwürdiges aufgefallen. Wenn ich mit AIDA64 die BIOS Infos aufrufe sieht es so aus:
Also irgendwie kaputt. Wenn ich ein BIOS frisch flashe stehen dort AMI BIOS und das Datum, alles korrekt. Doch sobald ich auch nur eine einzige Einstellung bei den Spannungen ändere oder das XMP Profil aktiviere sieht es wieder so aus wie auf dem Screenshot. Andere Einstellungen wie Secure Boot, ErP, Trusted Computing oder was auch immer verursachen das nicht. Nur wenn ich etwas an den Spannungen verändere (Reicht schon von "Auto" auf "Normal" zu ändern) zerschießt es da wieder diese Infos.
Passiert bei den ganzen letzten Beta BIOSen F20c, F20b und ich glaub bei den F19ern auch, habe aber nicht jede Version getestet. Davon abgesehen kann ich meinen i7 3770K stabil mit Spannungen auf "Normal" und 43er Multi betreiben. Aber ich darf dann keine Experimente mehr machen und möglichst nichts mehr im BIOS ändern, sonst kann es passieren, dass plötzlich nichts mehr geht. Sieht fast so aus, als würde sich das BIOS bei gewissen Einstellungen selbst zerstören oder hat mein Board eine Macke? :hmm:
Batterie mal für ne Stunde rausnehmen. Wirkt beim ud3h wunder ;)
Ich hab das Problem das mein 3770k im idle nicht mehr auf 1600 MHz runtertaktet. Stromspareinstellungen sind alle an. BIOS ist das f19e
BRAINs, mein Board verhält sich mit allen Versionen größer F18 genauso. F20c funktioniert aber einwandfrei.
Also das UD3H Bios F20mod 6 läuft super! :) keine Probleme bisher!
Vor ner gewissen Zeit auch meinen Freeze Verursacher gefunden, weder Ram noch Netzteil noch sonstwas...
es war die X-Fi Soundkarte. Einfach ne andere verbaut und nun läuft die Kiste!
Ja mit der X-Fi hatte ich auch schon viele Probleme ;)
Mit der D2X ist bis jetzt alles top.
Dito...meine oc settings werden auch nicht mehr übernommen. Er wechselt dann entweder von m bios zum anderen oder es kommt der screen wo ich die Standard settings laden kann oder ins bios wechseln will. Oder er will starten die Lüfter laufen kurz an und wieder aus usw.bis ich eben nochmal am case den restart button drücke oder am netzteil den Kippschalter mal aus und an mache. Aber wenn ich dann alles wieder eingestellt habe läuft er durch. Ist eben n Glücksspiel grade ob er gleich startet oder ich aushelfen muss mit genannten massnahmen. Hab ja noch Garantie aber bin 2t Käufer und weiss nicht wie Hardwareversand da reagiert trotz rechnung. Und wie lang das dann dauert. Es ist ja nicht kaputt in dem sinne...es hat nur n klatsch:-) und keine Böcke dass ichs umsonst ausbaue und einschicke.
Gesendet von meinem GT-N7100 mit der Hardwareluxx App
Danke für eure Rückmeldungen, ist also nicht nur bei mir so...
Hallo miteinander
Ich hoffe, ihr könnt mir bei meinem Problem helfen.
Ich bin seit heute stolzer Besitzer des GA-Z77X-UD3H Mainboards.
Meine restlichen Komponenten sind folgende:
- Seasonic G-550
- I5 2400
- 12GB RAM
- HD 7750
Habe den Computer heute zusammengebaut und Windows neu installiert. Nach der Installation der Treiber (via beigelieferter CD) wollte ich meinen DAC (USB Dr. DAC PRIME) testen. Da ich im Internet gelesen habe, dass die VIA USB Ports während der Windows Installation nicht funktionieren, habe ich meine Maus und Tastatur an die Intel Ports angeschlossen. Den DAC habe ich nach der Installtion an einen der VIA Ports angeschlossen.
Nach geraumer Zeit erschien beim Einschalten des DACs eine Windows Meldung, von wegen "das USB Gerät kann mehr Leistung liefern, wenn er am richtigen Port angeschlossen ist". Irgendwas in dieser Richtung. Ich bin richtig enttäuscht, habe ich extra wegen meinem DACs ein neues Mainboard gekauft.
Da die Treiber auf der CD veraltet sind habe ich den neusten VIA Treiber von der Gigabyte Homepage heruntergeladen. Nach der Installation funktionierte der DAC am VIA Port überhaupt nicht mehr (der DAC war zwar eingeschaltet, der Sound wurde trotzdem über die über 3.5mm angeschlossen Lautsprecher ausgegeben). Zu Testzwecken habe ich den DAC an einen der Intel Ports angeschlossen. Dort funktionierte er ohne Probleme. Das Switchen zwischen Lautsprecher und DAC funktionierte tadellos. Doch dann kam die Ernüchterung: Die Maus, die ich vom Intel weggenommen und an den VIA Port angeschlossen habe, funktionierte nicht mehr. Auch die anderen Geräte an den VIA Ports (Bluetooth Adapter, Wireless Maus) funktionierten nicht.
Könnt ihr mir vielleicht weiterhelfen? Bin zur Zeit ausser Haus. Werde morgen sicher noch das BIOS updaten und den neusten Intel USB Treiber installieren. Im Internet habe ich gelesen, dass das UD3H ein bisschen buggy ist was die USB-Anschlüsse anbelangt.
Hat jemand von euch ähnliche Erfahrungen gemacht?
Vielen Dank für eure Antworten!
Gruss
wasdenn
Es gibt im BIOS Einstellungen zu USB sowie unter Windows die Energiespareinstellungen. Prüfe das mal.
Hallo ivyboinc
Danke für deine Antwort! Ich habe die Einstellungen überprüft, leider weiss ich nicht, welche Einstellungen mein Problem lösen können. Es kann doch nicht sein, dass das Board solche Probleme mit den USB-Anschlüssen hat? Eigentlich brauche ich die USB3.0 Funktionalität nicht, da ich keine USB 3.0 Devices habe. Kann man diese Funktion vielleicht deaktivieren (dass die Ports nur als 2.0 funktionieren). Vielleicht löst dies mein Problem.
EDIT:
So, nun scheint es zu funktionieren. Ich habe einfach Windows noch einmal frisch installiert und dann direkt die Treiber von der Gigabyte Homepage genommen. Nun scheint alles zu funktionieren. :d Ich hoffe dass dies auch so bleibt, ansonsten läuft das Board ohne Probleme!
Gruss
Es gibt Geräte die an USB 3.0 einfach nicht richtig funktionieren. Bei mir war es mein Canon ip4950. Immer wieder kam es vor, dass er an USB 3.0 plötzlich keinen Mucks mehr machte. Erst dachte ich schon er sei kaputt, bis ich mal das Netzkabel ab- und wieder dransteckte. Da ging der Drucker wieder, aber am nächsten Tag nicht mehr, er war wieder eingefroren. Habe mir dann von GB ein Slotblech für die internen USB 2.0 Anschlüsse schicken lassen und den Drucker dort angeschlossen. Seitdem zickt er nicht mehr herum. Ebenfalls problematisch sind die Logitech Harmonys, welche an USB 3.0 überhaupt nicht erkannt werden. Am Board liegt das übrigens nicht, mein Bruder hat einen komplett anderen Rechner als ich und die gleichen Probleme.
Hallo BRAINs
Danke für deine Antwort! Danke für die Info, dachte, USB3.0 sei ohne Probleme abwärtskompatibel. Scheinbar ist dies nicht der Fall!
Zur Zeit funktioniert alles ohne Probleme. Falls es in Zukunft Probleme gibt werde ich ebenfalls eine Slotblende bei Gigabyte anfordern!
Gruss und schönen Tag noch!
... dachte, USB3.0 sei ohne Probleme abwärtskompatibel. Scheinbar ist dies nicht der Fall!
Du verwechselst da was:
  • Den USB 3.0 Standard.
  • Mit der Praxis bzw. Umsetzung durch die USB-Gerätehersteller.
Falls du aktuell keine Probleme hast mit Gigabyte, nach deiner Neuinstallation mit den von dir verwendeten Treibern, folgerst du: es funktioniert, Gigabyte hat "USB" richtig umgesetzt.
Falls du Probleme hast, folgerst du: Gigabyte ist schuld.
Es gibt eine Vielzahl von Geräten auf dem Markt, USB-Datensticks, Kabelverbindungen, Verlängerungen, Drucker, usw. Diese gibt es in verschiedenen Versionen, Herstellungszeiträumen, "Verbesserungen" hinsichtlich Kompatibilität, Anpassungen auf neue Betriebssystem etc.
Wer entscheidet, ob jede dieser Gerätschaften den USB Standard erfüllt ? Der Kunde, der eines dieser Geräte benutzt ? Ein PC ist komplex, vom BS über die Treiber, konkurrierende weil aktiv gesetzte USB-Geräte, gerade schlafen gegangene Geräte, im Zeitpunkt des Verbindens fehlende Ressourcen (CPU, laufende Datenübertragungen). Ein wildes Ein-, Aus- und Rumgestöpsele. :banana:
Nehmen wir die USB Controller. Wie bei WLAN, Bluetooth, SATA u.v.a.m. Ich behaupte: hätten wir einen Volkscontroller von einem einzigen Hersteller, es gäbe Null Probleme. Wie sieht die Realität aus ? Wildes Rumgeschimpfe, falls einmal was nicht nach Wunsch läuft, der Erkennungsprozess beim Zusammenstöpseln ist sensibel, weil es m.M. auf die Qualität der Signalübertragung ankommt.
Im Auto stecke ich das 12V Ladegerät ein, die Sicherung fliegt raus, boah ... der Autohersteller XYZ hat jetzt aber einen Mist durch die Qualitätskontrolle geprügelt. Was lernen wir aus der Sache ? :hmm: Was du (oben zitiert) forderst ist: Mercedes soll mir gefälligst eine neue Steckdose einbauen. Weil mein Ladegerät auf eBay für 0,99 Euro definitiv die Schuld nie haben kann. Oder das verlötete Kabel für 0,14 Euro garantiert funktioniert. Weil Gigabyte einfach Murks auf den Markt wirft, weil ich das so sehe.
(Gemeint als Beispiel, ja es gibt hochwertige Geräte die mit USB trotzdem Probleme machen.)
Es gibt Einzelerfahrungen, gesammelte Erfahrungen, gute wie schlechte Erfahrungen, die m.M. sehr abhängig sind von der Qualität aller beteiligten Komponenten. Ja, Gigabyte hat schon Murks abgeliefert, diesen evtl. über BIOS Updates weitgehend oder vollständig behoben. Wäre Gigabyte der Murksmarktführer, niemand würde das kaufen. In zahlreichen Arbeits- und Wohnzimmern laufen deren Mainboards, evtl. kaum voll ausgelastet mit der vollständigen Belegung sämtlicher Schnittstellen, die so ein Board zu liefern hat. Und mit jeder zusätzlichen Belegung einer freien Schnittstelle steigt ... der Murks ? ... nein die Komplexität, die ein Murkspotential offenbart.
Hallo ivyboinc
Vielen Dank für deine Antwort!
Dass ein PC System äusserst komplex ist, ist mir durchaus bekannt. Du interpretierst aber eindeutig zu viel in mein Geschriebenes hinein.
Wie du anhand von wenigen Abschnitten eine Aversion meinerseits gegenüber Gigabyte entdecken kannst bleibt mir rätselhaft. Ich habe mit keiner Silbe erwähnt, dass ich den Hersteller Gigabyte nicht mag. Würde ich ihn nicht mögen, würde in meinem Rechner ein Mainboard von ASRock, Asus, o.Ä. werkeln.
Aber man ist halt enttäuscht und zu einem gewissen Grade auch frustriert, wenn man nach stundenlangem Zusammenbau und anschliessender Windows Installation feststellen muss, dass die USB-Anschlüsse nicht funktionieren. Vor allem wenn man in der Vergangenheit nie mit so einem vermeintlich harmlosem Problem konfrontiert wurde. Da schiebt man die Schuld halt gerne an andere (ob gerechtfertigt oder nicht). Es werden ja nicht ohne Grund Standards definiert, an die es sich zu halten gilt.
Und sicherlich ist auch Gigabyte zu einem gewissen Grad schuld, haben sie sich doch für diesen Controller entschieden.
ich habe heute mal meine Treiber geupdatet. Danach ging gar nichts mehr (Bluescreen c4). Nach 2 Stunden rummachen hat sich der Via USB3 Treiber als Fehlerquelle herauskristallisiert. Habe dann den Treiber 1.9 von der CD genommen und nun läuft es wieder. Biosversion F18
EdIT:
Frage: Soll ich es so belassen oder gibt es eine Möglichkeit das ich den neuen Treiber installieren kann ? Hat wer ähnliches schon mal erlebt ?
Hier wurde eine Lösungsweg beschrieben: (Post18)
http://www.computerbase.de/forum/showthread.php?t=1109174&p=13620475#post13620475
Kann das funktionieren ?
sind probleme bekannt mit dem f15q bios? ich hatte das problem dass jegliche bios einstellung zwar sichtbar war im bios, allerdings nichts uebernommen wurde im endeffekt. ein cmos reset war jedes mal von noeten um ueberhaupt eine aenderung abzuspeichern. quasi, cmos reset > aendern > speichern > ok > nochmal etwas aendern? > cmos reset and repeat
bin nun aufs f14 zurueck, keine probs hier.
ich hab gestern mal einen usb3-stick angehängt, prompte hakte meine maus, die auch am hub hängt. usb ist jedenfalls keine domäne des ud3h
sind bei einem Cmos Reset die Profile die gespeichert wurden auch weg ?
Moin,
ich habe es gestern Abend nochmal probiert den VIA USB 3 Treiber zu aktualisieren. Nach 3 Stunden habe ich dann aufgegeben und bin wieder zurück auf den 1.9 Treiber. Ich glaube das Problem liegt an Treiberresten vom 1.9 Treiber die man wohl nur mit einer Neuinstallation runter bekommt ?! Problematisch war z.B. meine Logitech Webcm 525 die im USb Hub vom Dell U2312 (trotz neuester Treiber) beim Anstecken einen Bluescreen verursachte. Ich habe sogar alle deaktivieren Geräte aus dem Gerätemanager gelöscht.... hat nicht geholfen.
...kannst mir ruhig glauben, nach ClearCMOS kann man das im BIOS gespeicherte Profil wieder laden :-)
