[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
Und CPU VTT war übrigens auf 1.060 im Bios ... das hat AIDIA nur falsch ausgelesen.
Mit PLL Spielerei hatte ich bei Sandy auf GA Z68 keine guten Ergebnisse ... da lief es bei mir auf 1.8 am besten.
Na weist Du über 3,5 Stunden Custom FFT 960K stable ... das war bei mir immer auch BF3 stable.
Der Umstand das LinX stärker heizt ist mir bekannt ... ich werde allerdings auch keine 4.8 GHz laufen lassen 24/7 ... ich bescheide mich mit 4.4 oder 4.5. ;)
Geht nur darum auszuloten was unter Lukü möglich ist ... und wie VID sich auswirkt.
Gibt einem wieder Anreiz zu testen ob es etwas bringt, thx ^^
Ich überlege auch mal HT auszumachen um zu gucken, wie es dann ausschaut.
ich bekomm hier keine 4,5ghz mit 1,3v stable. allerdings zeigt cpuz auch etwas anderes als das bios an
der ralle fährt hier 1,18v.. Bild: x45_165wy9iko.png - abload.de
bin nun bei 1,4v!!!! wie schafft der des!? so ne üble cpu gibs doch gar nicht
Andere CPU, anderes Board? Bei Ivy würde ich empfehlen nicht über "~1,35 V" zu gehen.
Jede CPU ist anders und da du schon bei 1,4 V (ich nehme an unter Last bist) machst du irgendwas falsch oder aber deine CPU kanns einfach nicht.
Such lieber den Sweetspot deiner CPU, das macht mehr Sinn als mit Gewalt irgendwelche Taktraten zu erzwingen ^^
da muss was falsch laufen. beim 960er schmiert avast recht kurz nach dem start ab, der run rennt aber weiter
Ich denke bei dir stimmt was nicht ,aber du darfst dich von anderen CPUs und deren vcore blenden lassen ,die haben eine Extreme niedrige Stock vid ,ich habe eine Extrem hohe 1.18V
hab mal die settings angehängt. imho hakts irgendwo am speicher
HI, nimm mal vore response auf Auto und pwm phase control auf Auto, und stell mal die Vcore mal auf +0,010V und VTT auf 1,050V
Na da reagiert jede CPU anders darauf. Du solltest net zu viele Paramater gleichzeitig ändern sonst wird das nichts.
Ich kann Dir nur sagen dass meine CPU gut mit PLL 1.72, IMC 0.930 und VTT 1.060 geht.
Und bei 4.9 GHz ist auch irgendwie Schicht ... denn bei 5.0 GHz wird das Board etwas "schwierig"
(bekomme Bluescreen Fehler Codes die ich noch nie zuvor im Leben gesehen hab :fresse:)
4.9 GHz hingegen sind EZ PC erreichbar ... praktisch selbe Settings wie 4.8 nur eben etwas mehr VCore.
Und zuviel VTT tut nicht gut. Bei maximal 1.080 kann man es bleiben lassen. Unter PLL 1.70 kann man auch latten. Du könntest mal PLL 1.76, VTT 1.080 IMC 0.930 versuchen.
Und um den Speicher als Unbekannte aus der Gleichung zu entfernen DDR3-1333 CL9-9-9-31 Command Rate 2 TRFC 160. Einfach um auszuschließen, dass es am Ram liegt.
sind das alles bios-einstellungen oder in windows ausgelesen?
im 3d-gedöns hast du nur die ersten beiden parameter geändert, rest auf auto?
Richtig - werte so im Biios gesetzt.
Kann Dir mein 4.5 Ghz Profil mal auf Stick Speichern und via Email zu senden - müsste gehen.
Kannst Dir auf Stick speichern und im Bios laden. Dann passt Du nur noch die Vcore an und testest mal damit.
Ist das auch auf das d3h übertragbar oder eher nicht? Schon ganz nett das Feature von GB, bietet ganz neue Möglichkeiten damit und spar Arbeit. Kann man das eigentliich zb nach nem Bios Update und Reset problemlos wieder laden oder sollte man dann eher manuell neu einstellen?
Das D3H hat die Funktion nicht - kann keine UEFI Settings auf Stick Speichern/Laden. An falscher Stelle gespart - hatten wir schon mal. ;)
Aber mit Easy Tune kann man auch Settings in eine Datei Speichern und Laden ... auf diesem Wege müsste es auch gehen.
@anticucho Du solltest freilich darauf achten dass Du die selbe Bios Version hast also F8G flashen.
wie schaut deine 3d-power-seite aus? da stehen ja imho interessante einstellungen ala vcore llc und vtt llc
So, habe soeben mein Altes Asrock z68 nochmal aufgeschnallt mit der Ivy und was soll ich sagen es läuft besser wie das UD5, vorallem mit dem Speicher, habe mir Trident X gekauft, weil ich dachte ich hätte ein Speicherproblem, und auf dem UD5 laufen sie in ihren Specs, aber das auch nicht besonders gut, meine 2133 laufen da besser.
Und vorallem kann ich die Speicher mit 2600 auf dem Asrock laufen lassen was bei dem Ud5 nichtmal mit 12-13-13-36 lief bei 1,75V, so macht das Asrock bei 1,7V das mit 10-13-13-36.
Werde das UD5 verkaufen sobald das Extrem 9 oder das Asus Formula drausen sind, völlig verbugtes Board.
gruß
Das UD5H ist also ein verbugtes Board ? Kann man das so bestätigen oder stehen lassen ? Dann müßte ich ja meines retournieren ?
Speicher ist schon noch bisschen Baustelle auch beim UD3H ... vor allem ab 1866 aufwärts.
Bin mir auch sicher dass die CPU auf 5 GHz geht mit meinem Maximus V Gene.
Also wenn man Speicher auf 1866 laufen lassen will muss man wohl die subs bearbeiten.
Da sollte die heise Gigabyte Bios Entwickerlin wohl noch etwas Zeit mit verbringen. :fresse:
Ist meine Meinung! Vieleicht hab ich aber nur ein schrottboard bekommen, bin ziemlich gefrustet deshalb, mein Board hat definitiv ne menge Bugs, je nach Biosversion mal mehr mal weniger, wenn ich aber sehe wie das Asrock performt und das noch Z68 gegenüber dem UD5, geht das zurück. Alle die keine Probleme mit dem UD5 haben Glückwunsch, für mich ist es nichts mehr.
Raffaelo hast du gar keine Probleme mit dem Board? Machst du OC welcher Speicher? Kann ich fast nicht glauben, so verbugt wie meins is.
gruß
Ich kann nichts nachteiliges in Sachen RAM sagen beim ud3h ,laufen wohl ein Tick schlechter das war's
2000cl9 vdimm 1.5V
2133cl9 vdimm 1.57V
2200cl10 vdimm 1.63V
Was mir aber aufgefallen ist ,das 2200cl10 nur so schnell ist wie 2000cl9 ,trotz identische subtimmings
Hi, hab das Board noch nicht in Betrieb genommen, liegt hier aber einsatzbereit. Ivy 3570K kommt heute oder morgen, dann gehts los. RAM hab ich hier das 8 GB Kit von Corsair Vengeance LP, wird ja hier auf Seite 1 als kompatibel angegeben.
Mal schauen, was geht.
Kannst Du Dein Board denn reklamieren, wenn Du es nicht stabil in Betrieb nehmen kannst ?
Jo man tut aber gut daran die Subs manuell zu setzen oder XMP Profil zu laden und dann manuell anzupassen.
Selbst wenn XMP geladen wird kommt bei kleinerem Teiler dann teilweise Bullshit raus. Allerdings eher zu hohe Latenzen eingestellt als zu niedrige.
Du könntest wirklich mal Deine Ram Settings posten mit dem Gigabyte TweakLauncher ausgelesen. Damit werden auch einige Subs angezeigt.
@soul4ever
Dann haben die das nachgereicht in neuerem Bios ... wie ich das D3H noch hatte gabs das nicht.
Da gab es nur 4 Profile die man auch nicht benennen konnte.
Das Board nicht, aber das BIOS ist noch mehr oder weniger ne Katastrophe :/ Seit F5 kam da nichts mehr richtiges... nur noch neue Bugs dazu und nur kleine Fixes.
Ich verliere auch langsam die Geduld muss ich sagen, zumindest läuft mein Ram auf 2133Mhz und mit normalen Timings - aber auch nur mit 1,525V statt 1,5V (Asrock Z68 Extreme7 Gen3).
Das traurige ist aber ja, dass es bei den ASRock Z77 Boards auch kein Stück anders aussieht momentan.... und beim Extreme7 konnten sie nichtmal nen eSATA Bug fixen nach 3-4 Monaten...
Lan Anschluss ist nach 1 Monat auch kaputt gegangen, schick das jetzt die Tage zu JZ_, dann mal sehen wie das neue läuft und was ich machen werde :(
