[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
da bin ich leider sehr pingelig
will ja auch kein vw emblem aufm Mercedes
Ich hoffe JZ meldet sich wieder die Tage - er ist in Sachen Gigabyte einfach die beste Informationsquelle - und hat die User hier im Forum schon oft unentgeltlich unterstützt.
Ich hoffe dass er sich durch Unterstellungen von 1-2 Flachzangen nicht vertreiben lässt. :(
@ IronAge.
Das klingt nicht gut. Wollte das Board ja auch.
vllt schwenke ich dann doch zu nem [FONT=Verdana, Arial, Helvetica]asus [/FONT]P8Z77-V LX um.
hmm
Naja mit dem nächsten Bios update kann es sich schon wieder ändern. Beim Z68X-UD3H hat es auch einiger Bios Updates bedurft bis es perfekt war.
UEFI ist einfach neu bei Gigabyte - darf man nicht vergessen - bei Asus hatte es halt schon die Vorgänger Generation.
Was definitiv sehr geil ist ist die Boot Geschwindigkeit mit meiner Crucial m4. :drool: Das MV Gene startet nicht so schnell.
Ich würde Dir aber eher zum UD3H raten ... das ist seit dem es erhältlich ist auch schon im Preis gefallen und hat auch eine 8 Polige ATX12V Buchse.
Hmm überlege halt hin und her. Weil rein von den Anschlüssen würde mir halt einfach das ds3h für 91€ bei amazon reichen. Gucke ich nach dem ud3h (hatte vor Jahren für den E6400 ein Board der Klasse), leg ich ma mind. 40€ drauf. Das muss halt irgendwie in Relation zueinander stehen.
Möchte halt gerne Gigabyte oder Asus. GB, weil ich bereits 2 Boards von denen hatte und sehr zufrieden war. Wobei die Geschichte mit "im Bios zurechtfinden" ja eh nicht mehr gilt wenn das Board jetzt UEFI hat? Und Asus denke ich irgendwie das es gut mit der 7970 zusammen läuft, aber das sind beides eigentlich Sachen die absolut zu vernachlässigen sind ;).
Ich hab noch knapp 2 Wochen Zeit schätz ich. Wenn ich nicht das ud3h nehme, müsste das Asus doch etwa auf dem Niveau des d3h, nur ausgereifter?
Bei den günstigeren Asus Boards hast Du schlechtere Spawa - im Preisbereich von 90-140€ würde ich ein Gigabyte nehmen - darüber vermutlich eher ein Asus.
Ich habe auch erst mal im Manual nachsehen müssen um C3/C6 etc. disable zu finden - das UEFI ist aber schon schick geworden.
Wobei mich leicht nervt dass ich z.b. den Profilen keine Namen mehr geben kann.
Und mir fehlt Ez Tune und Touch Bios vom Z68 her - der Knallinger dem eingefallen ist das durch Power 3D zu ersetzten sollte seinen Hut nehmen. :motz:
Danke für die Info. Dann wird es vllt doch ein ud3h. Auch weil Amazon das auch günstig anbietet (wollen die mehr machen bei PC Hardware? Erstaunlich viele Z77 bei Amazon gelistet...).
Allerdings, die Spawaqualität und Kühlung etc. kann man das anhand irgendwelcher Werte ablesen oder ist das eher Einschätzung/Abschätzung/Erfahrungswert?
Frage deshalb, um selbst zu recherchieren zu können und nicht immer nachfragen zu müssen ;)
Anhand der Bauteile die auf dem Board zu sehen sind kann man sich schon ein ungefähres Urteil bilden.
Ich packe jetzt mal einen 2500K drauf und teste was das D3H an Strom verbraucht.
Vielleicht teste ich auch mal mit iGPU ob es dann auch noch den Blackscreen bug hat. Ich vermute da einen Zusammenhang mit der Erkennung der Auflösung der dGPU.
Edit #1: Mit Bios 7d gibt es den Blackscreen im UEFI nach Neustart zumindest @default nicht mehr - dafür kann ich meine Maus nur an einer Achse vertikal im UEFI bewegen - genau so unbrauchbar. :fresse:
Edit #2:
Eben wieder einen Blackscreen im Bios gehabt - der Bug tritt auf sobald die Auflösung nach Neustart falsch erkannt wird - ich habe einen CRT am VGA Anschluß der dGPU.
Mit Qpad 5K und Mionix Naos Maus im UEFI Zeiger-Bewegung nur entlang der Y-Achse möglich - mit einer älteren Saitek Maus gibt es diesen Bug nicht.
was ist den mit deinem p8z77-v deluxe ?
nicht mehr zufrieden ?
hast du mal die anderen usb3 ports durchprobiert wegen der probleme mit der externen hdd
Ich schwanke zwischen dem Gigabyte Z77-UD3H und dem Asrock Z77 Extreme 4. Was mich beim UD3H stört ist das bei den oberen Spannungswandlern kein Kühlkörper drauf ist. Den hätten die doch auch noch draufmachen können, oder ?
Da kann ich Dich beruhigen - die werden nicht wirklich brontal warm - habe das D3H hier.
(das aber wegen einiger bugs wieder den return to sender macht.)
Verbrauch ist ganz ok beim GA-Z77X-D3H. (Netzteil Seasonic X-400FL - Grafikkarte AMD HD6450)
i5 2500K @default idle ~44W
i5 2500K @3.4 GHz load (prime95 Custom FFT 960K) ~110W
i5 2500K @4.0 Ghz load (prime95 Custom FFT 960K) ~117W (Vcore 1.140)
i5 2500K @4.2 GHz load (prime95 Custom FFT 960K) ~127W (Vcore 1.200)
i5 2500K @4.5 GHz load (prime95 Custom FFT 960K) ~153W (Vcore 1.296)
i7 2600K @4.5 GHz load (prime95 Custom FFT 960K) ~166W (VCore 1.296)
i5 2500K @4.6 GHz load (prime95 Custom FFT 960K) ~162W (Vcore 1.332)
i7 2600K @4.6 GHz load (prime95 Custom FFT 960K) ~183W (Vcore 1.344)
i5 2500K @4.8 GHz load (prime95 Custom FFT 960K) ~193W (VCore 1.416)
i7 2600K @4.8 GHz load (prime95 Custom FFT 960K) ~215W (Vcore 1.428)
i5 2500K @5.0 GHz load (prime95 Custom FFT 960K) ~220W (Vcore 1.476)
(Die Messungenauigkeit liegt bei 1%)
Was meinst du nun ist zu empfehlen? d3h oder ud3h? Unter der Vorgabe bis maximal 4,4 OCen zu wollen.
Ok danke, wenn sich da sonst nichts mehr tut oder ergibt, werde ich Ende der Woche das bestellen.
Vermutlich ist das mit dem nicht mehr vorhanden VDroop ab Multi 44 auch eher ein Feature - Loadline habe ich auf Auto - könnte also sein dass es Absicht ist.
PWM Phase Control habe ich für den Test mit 4.6 GHz auf High Performance für 4.8 GHZ auf Extreme Performance gestellt.
Die Mosfets werden selbst bei 4.8 GHz unter Volllast mit PWM Phase Control auf extreme Performance nicht besonders warm. Spulen hingegen erwärmen sich stärker.
Edit:
Nachdem es etwas läuft haben sich die Mosfets doch etwas aufgeheizt. Nicht dass man sich verbrennen würde - länger als 10-15 Sekunden ist Finger darauf aber nicht angenehm.
(Hab leider keinen Temperatur Sensor - daher diese etwas subjektive Einschätzung)
Auch wenn es für Alltagsbetrieb eher kein Problem darstellt würde ich für 4.8 GHz+ einen Lüfter auf die Spawa richten.
Mit Prime95 Custom FFT 960K vergleichbare Last hat man selbst bei anspruchsvollen Spielen nicht.
Das Board ist SUPER EASY @ 4.8 GHz Prime95 Custom FFT 960K stable ... das gefällt mir. :bigok:
Ich habe weder PLL, noch IMC (=VCCSA), noch VTT (=VCCIO), noch VDIMM berührt - einzig PWM Phase Control erhöht und manual VCore.
Und es läuft und läuft und läuft ... angesichts des guten Übertaktungsverhaltens ohne großes Gepfriemel bin ich jetzt doch ein wenig begeistert. :banana:
Hier mal ein Screenshot - den i7 2600K habe ich ohne HT quasi als i5 2500K laufen lassen.
Das Z77X-D3H wird ab 5GHz etwas zickig. Aber bis 4.8 GHz läuft es wirklich zauberhaft - hätte ich nicht erwartet.
Ob das eventuell am 4-Poligen ATX12V liegt werde ich die Tage durch Test des GA-Z77X-UD3H rausfinden - das hat 8-Pol ATX12V.
Wer 5GHz+ will aber vermutlich eher zu einem Z77X-UD5H greifen. ;)
Ja, ist bei meinem UD5 und meinem 2500k auch ähnlich. 4,8 macht die CPU noch im Bereich um die 1,3V... 5 Ghz laufen nichtmal mit 1,44V... Immer 101er gemixt mit 124 BSODs, vorallem aber 101. Nebenspannungen haben auch nicht wirklich geholfen, Ram auf 1333Mhz setzen aber auch nicht.
BSOD habe ich NULL ... steigt meist nur ein Core aus dann bei 5GHz wenn Prime95 mal etwas länger läuft.
Was das board auch nicht mag - egal bei welchem Takt - ist wenn man mit PWM Freqenz @ Fast oder C3/C6 disable spielt.
Für den 5GHz test habe ich zumindest mal EIST/C1E auf disable.
Aber bis 4.8 GHz ist es göttlich einfach - dafür muss man echt nicht mehr ausgeben - positiv überrascht. :d
Ob Kernausstieg oder BSOD hängt eigt. immer von der CPU ab.
Ob das UD5 schuld ist oder der 2500k lässt sich bei 5Ghz nicht 100% sagen, aber denke fast eher die CPU. Aber schon komisch, dass er auf bis zu 0,12V mehr nicht anschlägt bei den letzten 200 Mhz, so ne schlecht skalierende CPU hatte ich noch nie :/ Entweder gleich gar kein Boot ins Windows, oder die 5 Ghz liefen dann mit entsprechend mehr Spannung. Aber hatte erst 3 von 40 CPUs bei denen die 5Ghz stable liefen, also auch nicht so die TOP zuverlässigen Erfahrungswerte.
OK es mag sich etwas anders äußeren ... aber durch Bios Updates könnte hier noch was gehen beim UD5H insbesondere.
PWM Frequenz erhöhe ich auch auf dem Maximus V Gene wenn ich auf >= 5.GHz gehe - hast Du das beim UD5H mal getestet ?!
Beim UD3H wird damit das Board selbst @ 3,4GHz bockig - kein Post/Einstieg ins Bios mehr möglich - muss System am Netzteil ausschalten.
@ralle: danke schonmal für deinen test mitm 2600k.. sieht ja richtig gut aus. besonders weils "nur" das d3h ist ?!? somit sollte das ud5h die 5ghz locker knacken nehm ich mal an :d
Sooo, hab' mein UD5H jetzt auch mal eingebaut. Läuft noch mit dem guten alten 2600k.
Erster Eindruck auf die Schnelle:
- Boot geht extrem schnell, deutlich schneller als auf dem P67-UD5
- UEFI: Ist halt mein erstes, deshalb für mich noch gewöhnungbedürftig, im Endeffekt aber nix anderes als ein gepimptes BIOS
- meine Corsair Vengeance laufen nicht mehr mit 1866, zumindest nicht mehr mit den gleichen Timings, auf 1600 bis jetzt aber tadellos
- VCore musste ich eine Stufe höher ansetzen als beim P67
Was hat es mit der PWM Phase Control eigentlich auf sich? Brauche ich die bei meinem Pille-Palle-Kindergarten-4,5GHZ-OC überhaupt oder wird das erst jenseits der 5GHZ interessant?
Und zugegebenermaßen bin ich im Moment mit Einstellungen wie DDR- und VTT-Loadline-Calibration überfordert. Hatte ich an der Stelle noch nie :d
Wird also wohl noch einiges an Einarbeitungszeit brauchen, die Einstellmöglichkeiten sind aber auf jeden Fall deutlich größer als noch beim P67...
Danke für die ersten Infos von Deinem UD5H. Eventuell kann ralle Dir helfen, aber der testet wohl heute abend, oder morgen, die Ivys auf dem UD5H. Mal sehen, was so geht.
Das UD5H mit dem Ivy 3570K ( bestellt bei cu ) und Corsair Ven. LP ist z. Zt. auch mein fav. System.
