[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
So bin nun mal aufs F12g (mod von JZ) umgestiegen.
Habe die Vengeance LPs jetzt mal manuell eingestellt auf 9-9-9-24 1T und nachdem flashen vollständigen CMOS Clear gemacht per Batterie.
Mal gucken wie lange es nun dauert bis zum ersten Frootloop ^^
Servus. Habe ein Z77X-UD3H (grad noch mit F7 BIOS, werde noch das F11 draufspielen) hier und habe eine Frage zur Lüftersteuerung:
Habe z.Z. 3 Lüfter am Board angeschlossen, CPU_FAN, SYS_FAN1 und SYS_FAN3. Alle 3 Lüfter sind KEINE PWM-Lüfter, sprich sie haben einen ganz normalen 3poligen Stecker.
Im BIOS habe ich die Lüftersteuerung auf Silent gesetzt.
CPU_FAN und SYS_FAN1 werden runtergeregelt und fahren auf ca. 500rpm runter. SYS_FAN3 dreht jedoch ständig mit voller Drehzehl, egal welche Einstellung ich in der Lüftersteuerung setze.
Wie kriege ich den Lüfter an SYS_FAN3 geregelt? Laut Handbuch können SYS_FAN1-3 geregelt werden. Jemand eine Idee?
Danke Euch im Voraus und sorry, falls die Antwort auf meine Frage bereits iwo in den 90 Threadseiten drin steckt.
Es gehen nur 2 zu regeln.
Der SYS_FAN1 und CPU_FAN, mehr nicht ;)
Kannste per Speedfan machen.
Hm. Wieso steht dann im Handbuch, dass SYS_FAN1-3 geregelt werden können? Die Einstellung im BIOS bezieht sich ja auch explizit auf SYS_FAN1-3 und soll ja auch auf alle 3 greifen? Die Option heißt ja "1st/2nd/3rd System Fan Speed Control".
Hast du doch selbst schon gesehen das es nicht geht :d
Habe das selbe Board und es gehen nur die 2 mehr nicht.
Ich besitze keine, aber es wird sich vermutlich nichts ändern.
Jeder steuerbare FAN braucht nen extra Chip, 2 steuerbare sind schon echt viel für den Preis.
Also ich muss dich da vermutlich auch enttäuschen!
Aber du kannst, wenn es nur CaseFANS sind, die per Y-Kabel zusammenpacken und an SYS_FAN1 hängen.
Der hat genug Power für 2-4 denke ich mal ;)
Hallo zusammen, bitte in Kompabilitätsliste eintragen:
Thermalright True Spirit (verdeckt nicht den 1.Slot)
2x 4GB G.Skill Sniper 2133 CL11
auf Gigabyte Z77-UD5H
MfG
i7 3770k
G.Skill TridentX DIMM Kit 8GB PC3-19200U CL10-12-12-31 (DDR3-2400) (F3-2400C10D-8GTX)
AMD HD 6970
GA-Z77X-UD5H-WB WiFi Bios z.Z. F9e
Samsung SSD 830 Series 128GB
Intel X25-M G2 Postville 120GB, 2.5", SATA II
Asrock Sata 6 Card
Pioneer BDR-207D
NT: Corsair Professional Series HX850 850W ATX 2.3 (CMPSU-850HX)
ich habe ein ganz großes Problem mit der G15. Ich komme einfach nach laden der Optim. Defaults nicht mehr ins Bios, erst ein Bios Reset hilft. Aus und An hilft auch nicht auch Strom trennen hilft nicht es muss der Bios Reset ausgeführt werden.
Das Ganze ist mit F6 - F9e so. Ich habe die Tastatur am anderen Rechner @ Signatur gehabt funzt ohne Probleme.
GSATA 8 und der E-sata
kann es sein das man nur eines nutzen kann gleichzeitig? Denn wenn ich e-sata nutze wird das BD-LW am Sata 8 nicht mehr angezeigt.
und dann gibt noch bei jedem Start eine USB Fehlermeldung: Dieses Gerät könnte eine höhere Datenrate erzielen
cu Bohne02
Jo, ich musste das auch nach dem Kauf des D3H feststellen und muss sagen, dass ich mich schon ordentlich verarscht fühle. In 2012 mit 4 PWM-Anschlüssen werben aber nur 2 davon auch tatsächlich regeln lassen ist schon armselig.
Ansonsten bin ich eigentlich recht zufrieden mit dem Board (nachdem ich auf F9(10) geupdated habe und erst dann auch meine USB-Tastatur im BIOS ging).
Habe allerdings jetzt schon ein paar mal gehabt, dass meine Tastatur und Maus zeitweise aufgehört haben zu reagieren (Beleuchtung und Display der Tastatur gingen immer wieder ein und aus). Bin also noch etwas skeptisch.
ah ist wohl falsch von mir rübergekommen...
neu ist das XMP-Problem, stell mal alle Timings auf Auto, XMP aktiviert: Timings völlig falsch vom Bios gesetzt
das mit dem Ruhezustand ist getrennt davon zu sehen, da kann man NACH dem Aufwecken aus dem Ruhezustand und darauf folgendem Neustart zwar Timings im UEFI ändern und speichern., diese werden dann aber nicht gesetzt vom Board.
...ist echt komisch, bei mir ist alles normal mit XMP und S3 funkz auch :-/
Hab mir das Z77X-UD3H gestern bestellt.
Kann ich meine 4x4GB TeamGroup Elite 1333MHz weiter verwenden?
Dark Rock Pro 2 Kühler passt drauf, oder?
Hallo.
ich nutze das 16 GB Kit (4x4GB) Corsair Vengeance LP auf einem UD3H. Habe einfach die Timings manuell eingestellt und die Spannung auf 1,50V fixiert. Läuft einwandfrei. Bei einem Freund habe ich vor kurzem den Macho mit diesen Rams verbaut. Ist zwar ziemlich eng die Geschichte (ca 2mm zwischen Lüfter und Ram), aber passen tut es. Mit höheren Bausteinen könnte es Probleme geben. Du solltest wenn dann welche nehmen, die nach oben nicht breiter werden. Dann sollte es passen.
Besten Dank! Meine Frage bezog sich zwar auf das 2x8GB Kit, aber trotzdem danke! Ich hab dann jetzt einfach mal 16GB bestellt und hoffe auf eine baldige Gutschrift durch Mindfactory.
hab den Fehler gefunden (Bios F9e), sobald ich den CPI/PCIe Base Clock auf 100 fixiere, sind die Timings falsch (XMP-Profil, alles auf Auto):
bei Base Clock auf Auto ist alles OK:
das war bei der UEFI F8 noch nicht so...
Da fragt man sich doch manchmal echt, was die Jungs in TW da veranstalten :( Klar, UEFI schreiben ist sicher sehr komplex und der Code usw. auch nicht einfach zu lesen und schreiben, aber habe schon oft erlebt, dass Sachen die in alten Versionen perfekt liefen dann auf einmal nicht mehr gehen.
Da muss man doch einfach sicher stellen, dass Neuerungen in den richtigen Code geschrieben werden, und nicht in einen ältern/fehlerhaften? ^^
So ist das für die User echt ne Menge Arbeit immer alles testen zu müssen und erzeugt einfach nen Gefühl von Unsicherheit (selbst ich als "Bastler" hab schon kaum mehr Lust, jede neue Version mitzunehmen, da man sich nie sicher sein kann, dass auch die alten Sachen noch bzw. wieder laufen) :(
Ohne Jörgs Hilfe und Reports wären die Jungs glaub ich wirklich komplett verloren.
Endkontrolle beim Kunden halt. Nervt aber, wenn man teuer Geld für ein Produkt bezahlt.
Aber Jörgs umfassende Hilfe sind schon fast ein Argument pro GB !
Besten Dank nochmals an JZ_ an dieser Stelle.
...mensch, da kann ich stunden prüfen und finde nichts :-(
danke für die info... werde es sofort prüfen und dann weiterleiten :-)
...sodele, habe es geprüft und @Trust13 hat recht... leite es sofort weiter :-)
---------- Post added at 10:20 ---------- Previous post was at 09:47 ----------
hatte damals auch schon das gefühl, das meine instabilitäten irgendwie am base clock lagen
...hast du auch ein UD5H board ? ...der bug betrifft nur das UD5H mit letzten bios :-/
der Fehler war ja auch schon in F9d, das überall so gelobt wurde. War ich scheinbar der einzige, der den Base Clock manuel eingetragen hat (reine Gewohnheit) :/
@JZ
es wäre auch schön wenn auch gleich Logitech Tastaturen wieder gingen.
Gigabyte Z77X-UD5H WB
nein, ein ud3h. aber wie gesagt, ich hatte in irgendeiner bios-version das gefühl, dass instabilitäten mit dem base-clock zusammenhingen.
btw schrieb schon oben, dass beim 12g der multi auf 38 begrenzt war (auch nach einm load optimized), ältere bios-settings konnten nicht importiert werden
Hab hier UD3H, 3770K und 4x4GB 1333MHZ RAM (vom alten MB) liegen und werde das heute Abend einbauen.
Muß ich bei den BIOS-Settings irgendwas beachten, da der RAM "nur" 1333MHz hat?
... 4x4GB 1333MHZ RAM (vom alten MB) ...
Muß ich bei den BIOS-Settings irgendwas beachten, ...
Ich würde bei vier Modulen zunächst nur zwei einbauen, BIOS-Erkennung der SPD bzw. XMP-Profile prüfen, ggf. anpassen und danach die zwei weiteren Module installieren. Für die Installation des BS würde ich persönlich sogar auf Nummer sicher gehen und die Timing-Werte entschärfen, auch wenn die Module im alten Board früher schneller + stabil gelaufen sind. Ist alles fertig installiert, kann man m.M. sich an das Feintuning wagen, vorher bringt kaum messbare Prozentwerte sowieso nichts.
Hallo Leute,
Logitech Tastaturen wer von Euch hat eine an einem Z77 Board? ( Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI )
Ich kann ja hier nicht der Einzige sein der Probleme hat damit.
i7 3770k
AMD HD 6970
Asrock Sata 6 Card
Pioneer BDR-207D
ich habe ein ganz großes Problem mit der G15. Ich komme einfach nach laden der Optim. Defaults nicht mehr ins Bios, erst en Bios Reset hilft. Aus und An hilft auch nicht auch Strom trennen hilft nicht es muss der Bios Reset ausgeführt werden.
mit Google gab es auch jede Menge Treffer im Web.
cu Bohne02
