Image script fehler !
XSS
Semiprofi
Stuttgart
Hallo ,
Ich bastel grade an einem ubload script für bilder allerdings habe ich einen fehler drin den ich nicht finde
Code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
</head>
<body background="background.gif" bgcolor="#272f80">
echo "
<center>";
echo "<br>
if ($_GET['id'])
	$id = $_GET['id'];
else
	die ("no id selected");
echo "";
echo "";
echo "";
echo "<br>
echo "
<table bgcolor="white" border="0">
  <tbody>
    <tr>
      <td>";
echo "<a href="./index.php"><img src="./$path%22%20.%20$id%20.%20%22" border="0"></a>";
echo "</td>
    </tr>
    <tr>
      <td>
      <center><a href="./index.php">zurück</a></center>
      </td>
    </tr>
  </tbody>
</table>
?></center>
</body>
</html>
Code:
<html>
<head>
  <title>EasyImageHoster - www.xss.kilu.de/imag</title>
  <link rel="STYLESHEET" type="text/css" href="style.css">
</head>
$max_size)
	echo "<font arial="" helvetica="" sans-serif="" color="#003330" face="\"Geneva,">Datei zu groß !</font><br>
\n"; exit; }
if (($_FILES['userfile']['type']=="image/gif") ||
($_FILES['userfile']['type']=="image/pjpeg") ||
($_FILES['userfile']['type']=="image/jpeg") ||
($_FILES['userfile']['type']=="image/png")) {
// generate random signs
$zufall = rand(1,9);
$zufall2 = rand(1,26);
$buchstaben = array( "1" => "arx", "2" => "opt", "3" => "bwy",
"4" => "cqs", "5" => "viu", "6" => "rgh", "7" => "jdv", "8"
=> "klz", "9" => "bfi", );
$buchstaben2 = array( "1" => "a", "2" => "b", "3" => "c", "4"
=> "d", "5" => "e", "6" => "f", "7" => "g", "8" => "h",
"9" => "i", "10" => "j", "11" => "k", "12" => "l", "13"
=> "m", "14" => "n", "15" => "o", "16" => "p", "17" =>
"q", "18" => "r", "19" => "s", "20" => "t", "21" => "u",
"22" => "v", "23" => "w", "24" => "x", "25" => "y", "26"
=> "z", );
$unikat = $buchstaben[$zufall] . time() . $buchstaben2[$zufall2];
// upload progress
$file = $_FILES['userfile']['name'];
$new_bild = $unikat.substr($file, strrpos($file, "."));
$res = move_uploaded_file($_FILES['userfile']['tmp_name'], "./" . $path
. $new_bild);
if (!$res) { echo "<font arial="" helvetica="" sans-serif="" color="#003330" face="\"Geneva,">Fehler , probieren sie es erneut !</font><br>
\n"; exit;
else
<br>
 $old_y)
	$thumb_w=$new_w;
	$thumb_h=$old_y*($new_h/$old_x);
if ($old_x < $old_y)
	$thumb_w=$old_x*($new_w/$old_y);
	$thumb_h=$new_h;
if ($old_x == $old_y)
	$thumb_w=$new_w;
	$thumb_h=$new_h;
$dst_img=ImageCreateTrueColor($thumb_w,$thumb_h);
imagecopyresampled($dst_img,$src_img,0,0,0,0,$thumb_w,$thumb_h,$old_x,$old_y);
if (preg_match("/png/",$system[1]))
	imagepng($dst_img,$filename);
if (preg_match("/gif/",$system[1]))
	imagegif($dst_img,$filename);
else
	imagejpeg($dst_img,$filename);
imagedestroy($dst_img);
imagedestroy($src_img);
createthumb($path.$imgf,$tpath.$imgf,$tsize,$tsize);
<script type="text/javascript">
function highlight(field)
	field.focus();
	field.select();
</script>
<center>
<center>
</center>
You selected a wrong filetype!<br>
\n"; exit;
if ($tsize <= 380)
	echo "
  <form action="nowhere" method="post"></form>
  <tbody>
    <tr>
      <td>URL:</td>
      <td><input name="thetext" onclick="highlight(this);" size="60" value="<? echo 'http://' .$domain .'/' ?>viewer.php?id=<? echo $imgf; ?>" type="text"></td>
    </tr>
    <tr>
      <td>DIRECT URL:</td>
      <td><input name="thetext" onclick="highlight(this);" size="60" value="<? echo $urlf; ?>" type="text"></td>
    </tr>
    <tr>
      <td>HTML:</td>
      <td><input name="thetext" onclick="highlight(this);" size="60" value="<a href="<? echo " http="" .$domain="" .="" ?="" type="text">viewer.php?id="><img src="%3C?%20echo%20%27http://%27%20.$domain.%27/%27.$tpath.$imgf;%20?%3E" border="0">'></td>
    </tr>
    <tr>
      <td>BBCode:</td>
      <td><input name="thetext" onclick="highlight(this);" size="60" value="[URL=<? echo 'http://' .$domain .'/'; ?>viewer.php?id=<? echo $imgf; ?>][IMG]<? echo 'http://' .$domain.'/'.$tpath.$imgf; ?>[/IMG][/URL]" type="text"></td>
    </tr>
    <tr>
      <td>IMAGE:</td>
      <td><a href="viewer.php?id=%3C?%20echo%20$imgf;%20?%3E"><img src="%3C?%20echo%20$thbf%20?%3E"></a></td>
    </tr>
  </tbody>
</table>
	echo "";
	echo "";
	echo "
<table bgcolor="white" border="0" width="457">
  <tbody>
    <tr>
      <td>
      </td>
    </tr>
  </tbody>
</table>
	echo "<br>
<br>
	echo "";
?></center>
</body>
</html>
Das ganze in Action xss.kilu.de/imag
Sag mal was soll das sein? Ich sehe PHP Befehle aber keine PHP Tags. Der Browser und auch der Webserver hält das für eine reine HTML Seite. Die PHP Befehle werden also nicht ausgeführt sondern einfach nur angezeigt. Sieht dann natürlich etwas merkwürdig aus.
das tut weh :fresse: das schmerzt richtig beim lesen :d aber es sind ja nicht nur die fehlenden tags. sondern auch noch nicht eskapte " dabei... und davon eine menge
Ja also mein Problem ist der Upload der funktioniert nicht !
So wie dein Quelltext momentan geschrieben ist, würde mich alles andere auch stark wundern.
<html>
Es handelt sich also um eine reine HTML Seite. Ich kenne kein HTML Tag für einen Uploader. Dein Quelltext beinhaltet PHP Befehle die aber in einer reinen HTML Seite nicht ausgeführt werden. Also was ist nun dein Problem? Willst du einen HTML Seite ohne PHP Befehle haben oder doch eher einen PHP Seite, die HTML ausgibt? Ich tippe mal auf zweiteres. In dem Fall müsstest du erstmal das fehlende PHP Tag ergänzen und beim Rest wird sich dann der PHP Interpreter schon beschweren.
ah ok nur bevor ich das script gekauft habe war es english und es ging jetzt ist es deutsch und es geht nicht !
Bitte was? Du hast dafür auch noch Geld ausgegeben? Wieviel kostet sowas?
Ich hab dir doch schon geschrieben wo dein Problem liegt. Rede ich Chinesisch? Da fehlt auf jedenfall ein PHP Tag. Das gilt sowohl für die englische als auch für die deutsche Version. Hast du beim Übersetzen selber das PHP Tag gelöscht? Ich finds ja irgendwie lustig, dass du so toll auf dem "geht nicht" rumreitest. Aber gut ich mach da einfach mal mit. Der Quelltext geht nicht. Soviel steht fest :) Ohne PHP Tag wird das auch weiterhin nicht gehen. Ich hoffe aber mal wie du auf ein göttliches Wunder. Vieleicht gehts ja morgen einfach so :P
So und nun füge da mal das fehlende PHP Tag hinzu und versuchs nochmal. Wenns dann immernoch nicht geht, schaun wie woran es liegt.
Hab das mit NVU übersetzt (ist nicht mein erstes Projekt ) das Upload problem hab ich jetzt gelöst so jetzt habe ich noch ein problem und zwar wenn man auf regeln klickt das es nicht funktioniert !
Code:
<html>
<head>
  <title>EasyImageHoster - Host Your Images</title>
  <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
  <link rel="shortcut icon" href="favicon.ico">
  <link rel="stylesheet" href="style.css" type="text/css">
</head>
<center>
<br>
<table align="center" bgcolor="white" border="0" cellpadding="2" cellspacing="2" width="740">
  <tbody>
    <tr>
      <td>
      <a href="http://www.xss.kilu.de/imag"><img src="logo_up.png" alt=" " border="0" height="115" width="350"></a>
      <center>
      <br>
      <br>
      <p>
      <img src="ff.gif" alt=" " height="10" width="8">  <a class="menu" href="./">Home</a>
      <img src="ff.gif" alt=" " height="10" width="8">  <a class="menu" title="Click here to advertise with us" href="mailto:HBfreak93@googlemail.com">Werben Sie mit uns</a>
      <img src="ff.gif" alt=" " height="10" width="8"> <<a href="http://www.xss.kilu.de/imag/regeln.html">Regeln</a></p>">Regeln</a>
      </p>
      <br>
      <br>
      <br>
Wählen Sie eine Image-Datei zum Hochladen
      <br>
Max-Datei-Größe ist auf 5000KB<br>
      <br>
      <form method="post" enctype="multipart/form-data" action="basic.php">
        <input name="userfile" size="27" type="file">
        <br>
        <br>
        <br>
        <input value="Upload" name="upload" type="submit">
      </form>
      <center><br>
      <br>
      <br>
EasyImageHoster v.05<br>
(c) 2009 by <a href="mailto:HBfreak93@googlemail.com">Fabian Geissler</a>
      </center>
      </center>
      </td>
    </tr>
  </tbody>
</table>
</center>
</body>
</html>
Code:
// --------------------- (C) 2009 by xss --------------------- //
// ------- PLEASE DO NOT REMOVE MY (C) FROM THE SCRIPT -------- //
// ------------------------- THANX :) ------------------------- //
include "config.php";
if (!isset($_FILES['userfile'])) exit;
if (is_uploaded_file($_FILES['userfile']['tmp_name'])) {
if ($_FILES['userfile']['size']>$max_size)
	echo "<font color=\"#333333\" face=\"Geneva, Arial, Helvetica, sans-serif\">File is too big !</font><br>\n"; exit;
if (($_FILES['userfile']['type']=="image/gif") || ($_FILES['userfile']['type']=="image/pjpeg") || ($_FILES['userfile']['type']=="image/jpeg") || ($_FILES['userfile']['type']=="image/png"))
				"2" => "opt",
				"3" => "bwy",
				"4" => "cqs",
				"5" => "viu",
				"6" => "rgh",
				"7" => "jdv",
				"8" => "klz",
				"9" => "bfi", );
				"2" => "b",
				"3" => "c",
				"4" => "d",
				"5" => "e",
				"6" => "f",
				"7" => "g",
				"8" => "h",
				"9" => "i",
				"10" => "j",
				"11" => "k",
				"12" => "l",
				"13" => "m",
				"14" => "n",
				"15" => "o",
				"16" => "p",
				"17" => "q",
				"18" => "r",
				"19" => "s",
				"20" => "t",
				"21" => "u",
				"22" => "v",
				"23" => "w",
				"24" => "x",
				"25" => "y",
				"26" => "z", );
// upload progress
$res = move_uploaded_file($_FILES['userfile']['tmp_name'], "./" . $path . $new_bild);
if (!$res)
	echo "<font color=\"#333333\" face=\"Geneva, Arial, Helvetica, sans-serif\">Didn't work, please try again</font><br>\n"; exit;
else
<br>
//set url variables
$imgf = $new_bild;
$thbf = $tpath.$imgf;
$urlf = 'http://' .$domain .'/' .$path .$imgf;
chmod("./" . $path . $imgf,0400);
//create thumbnails
function createthumb($name,$filename,$new_w,$new_h)
$system=explode('.',$name);
if (preg_match('/jpg|jpeg|JPG/',$system[1]))
	$src_img=imagecreatefromjpeg($name);
if (preg_match('/png|PNG/',$system[1]))
	$src_img=imagecreatefrompng($name);
if (preg_match('/gif|GIF/',$system[1]))
	$src_img=imagecreatefromgif($name);
$old_x=imageSX($src_img);
$old_y=imageSY($src_img);
if ($old_x > $old_y)
	$thumb_w=$new_w;
	$thumb_h=$new_h;
	$thumb_w=$new_w;
	$thumb_h=$new_h;
else
<head>
	field.focus();
	field.select();
</script>
<title>EasyImageHoster - www.imagehoster.6x.to</title>
</head>
<body bgcolor="#272f80" background='background.gif'>
<center>
<table border='0' bgcolor='white'>
<FORM action="nowhere" method="post">
<center>
<tr><td>URL:</td><td><input type="text" name="thetext" onClick='highlight(this);' size="60" value="<? echo 'http://' .$domain .'/' ?>viewer.php?id=<? echo $imgf; ?>"></td></tr>
<tr><td>DIRECT URL:</td><td><input type="text" name="thetext" onClick='highlight(this);' size="60" value="<? echo $urlf; ?>"></td></tr>
<tr><td>HTML:</td><td><input type="text" name="thetext" onClick='highlight(this);' size="60" value='<a href="<? echo 'http://' .$domain .'/'; ?>viewer.php?id=<? echo $imgf; ?>"><img src="<? echo 'http://' .$domain.'/'.$tpath.$imgf; ?>" border="0"></a>'></td></tr>
<tr><td>BBCode:</td><td><input type="text" name="thetext" onClick='highlight(this);' size="60" value="[URL=<? echo 'http://' .$domain .'/'; ?>viewer.php?id=<? echo $imgf; ?>][IMG]<? echo 'http://' .$domain.'/'.$tpath.$imgf; ?>[/IMG][/URL]"></td></tr>
<tr><td>IMAGE:</td><td><a href='viewer.php?id=<? echo $imgf; ?>'><img src='<? echo $thbf ?>'></a></td></tr>
else
echo "<font color=\"#333333\" face=\"Geneva, Arial, Helvetica, sans-serif\">You selected a wrong filetype!</font><br>\n"; exit;
if ($tsize <= 380)
	echo "</table>";
	echo "<table border='0' bgcolor='white' width='457'>";
	echo "<tr><td><center><a href='./index.php'>back</a></td></tr>";
	echo "</table>";
	echo "<br><br>";
	echo "</body>";
So nun ist das PHP Tag auch vorhanden und somit wird alles dazwischen auch als PHP Seite und nicht als HTML Seite erkannt. Der Link "Regeln" funktioniert bei mir. Was genau ist da dein Problem bzw dein erwartetes verhalten? Vieleicht erübrigt sich das aber mit deinem nächsten Problem.
Tu mir mal einen gefallen und übersetze den Quelltext selber ins Deutsche. Das Programm macht es jedenfalls falsch oder aber der Quelltext war schon vorher falsch.
Was bitte ist <<a für ein Tag? Soll der Link wirklich ">Regeln heißen? Warum ist da ein </p> wo garkeins hingehört? Warum ist da ein schließendes </a> zuviel? Der Quelltext ist von Hinten bis Vorne unsauber. Klar das da nichts so funktioniert wie es soll.
Naja jetzt funktioniert mal alles , ich schreib des Zeug jetzt mal in ner Woche neu !
